praegune kellaaeg 14.11.2026 08:28:51
Lauri126
13.09.2004 23:08:01
kas need on head mälupulgad??? |
[ Apacer Tech. (256 MB PC3200 DDR SDRAM) ]
Memory Module Properties:
Module Name Apacer Tech.
Serial Number None
Module Size 256 MB (1 rows, 4 banks)
Module Type Unbuffered
Memory Type DDR SDRAM
Memory Speed PC3200 (200 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Highest CAS Latency 3.0 (5.0 ns @ 200 MHz)
2nd Highest CAS Latency 2.5 (6.0 ns @ 166 MHz)
ja vabandan, et nii loll olen, aga mis tähendab DDR SDRAM... Mu vanal arvutil olid lihtsalt SDRAMid, kas need on siis sama sitad või???
olc
130 |
