uus teema   vasta Raud »  Protsessorid »  Veel Intel EM64T tehnoloogia telgitagustest märgi kõik teemad loetuks
sõnum 26.07.2004 02:21:27 Veel Intel EM64T tehnoloogia telgitagustest vasta tsitaadiga
Leidsin ühe toreda 2003 a. Inteli presentatsiooni
Mõned lõigud presentatsioonist
64-Bit Extension Technology to IA-32 Architecture
Increase number of General Purpose (GP) registers from 8 to 16
R8-R15 (8-new 64-bit GP register)
All GP registers increase to 64-bits (from 32-bits)
RAX, RBX, RCX, RDX, RBP, RSI, RDI, RSP (64-bit versions of current GP registers)
8 additional SSE registers (128-bit)
XMM8-15
64-bit Instruction pointer
RIP
New/Modified System Registers
NEW: Extended Feature Enable Register (ctrl register for enable/disable extended features in CPU)
Modified: Control registers extended to 64-bits (CR0-CR7)
Modified: Descriptor Table registers extended to 64-bits (GDTR, IDTR, LDTR)
Modified: Debug registers extended to 64-bits (DR0-DR7)
Support for flat virtual address space up to 64-bits
4-level paging w/4KB pages; 3-level paging w/2MB pages
Software Developer Tip
3DNow! instructions are not supported by 64-bit extension technology capable processors (including prefetchw instruction)
Result of prefetchw instruction in code will vary by O/S (64-bit extension technology capable versions)
Microsoft: Expected behavior ranges from application shutdown (due to Undefined OpCode fault) to performance degradation
Linux: May cause Undefined OpCode fault
Other 3DNow! instructions will cause the process to terminate on both types of O/S’s
Intel recommends S/W developers not use the prefetchw instruction or intrinsics which generate the prefetchw instruction
Contact Microsoft for a list of intrinsics which generate prefetchw
If you use the prefetchw instruction, make sure CPU supports it
E.g. check for 3DNow! presence bit in the extended CPUID feature flags
Processor Physical Address Space Virtual Address Space
Nocona / Prescott 36-bits 48-bits
Potomac 40-bits 48-bits
Viimasest lähtub, et Potomac protsessoris on kõrvaldatud esimeses EM64T tehnoloogiaga versioonis 36-bit piirang.
Küll aga on huvitav 3DNow! instruktsioonide (mis teadupärast on AMD leiutis) võimalik fataalne mõju süsteemi stabiilsusele.
Intel-i rohi sellele probleemile on lihtsalt mitte kasutada 3DNow! prefetchw instruktsiooni icon_biggrin.gif
HV-s ID-kaardiga autentimine
sõnum 26.07.2004 02:23:24 vasta tsitaadiga
Lisaks Platform considerations
Software
Changes needed for any platform to support “IA-32e mode”
64-bit O/S
64-bit Drivers
64-bit capable BIOS
Some applications may need to be recompiled to run correctly under “Compatibility” mode (no different from our competition’s implementation)
Compatibility mode does not support Virtual-8086 Mode or Real Mode
Applications which depend on these modes likely will not work in compatibility mode
Certain O/S functions and/or API’s available in “Legacy 32-bit” mode, may not be supported in “Compatibility” mode
Intel not aware of such instances, but it is possible
SW developers need to work with O/S vendor to know for sure
ragface
ragface
sõnum 09.08.2004 16:33:16 vasta tsitaadiga
anandtech tesits uut 64-bit xeonit ja v6rdles teda athlon64 3500+ (?!) testi lugejad olid tulemustega väga rahul (samuti inteli toetajad - xeon64 oli parem icon_biggrin.gif ):
http://www.anandtech.com/linux/showdoc.aspx?i=2158
kommentaarid:
http://www.anandtech.com/talkarticle.aspx?i=2158&ATVAR_START=21&p=1
anandtech sai oma aasta normi eest s6imu:
wow, WTF were you guys thinking!?!
ANANDTECH
in our next review, we'd like to show your how an AthlonFX53 compares to a 2.8Ghz Celeron
........."as you can see, the Celeron just cannot keep up with the AMD monster, looks like intel is really going to have to pick up the pace or AMD could rule the frickin' world with this new behemoth"
really though, a Xeon3.6 vs. a A643500, WTF, where is the Opt 150? how about showing apples to apples, this is like comparing apples to bannanas.
ja kõige rämdem solvang:
I would only expect this sort of incomplete and shoddy journalism from Tom's Hardware or the like.
L6ppu veel üks link:
seekord siis uus xeon vs opteron 250... v6ib juba lihtsalt sissejuhatuse p2rast lugeda icon_smile.gif
http://www.gamepc.com/labs/view_content.asp?id=noconaopteron&page=1&cookie%5Ftest=1
\R
Kommentaarid: 18 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 16
sõnum 10.08.2004 09:15:58 vasta tsitaadiga
täiesti mõttetu see anandtechi test thumbs_down.gif miks teha sellist testi, kui see ei näita tegelikult midagi... Xeon on ekstra tööjaamadele, serveritele loodud
päris head kommentaarid: My suggestion for a future test: Sempron 2000+ vs. Prescott 3.6. Title of review: "Both AMD and Intel have released 2 new processors recently. How do they perform against each other?". thumbs_up.gif
razor
sõnum 10.08.2004 13:07:30 vasta tsitaadiga
Since the excuse to not compare Athlon 64s to Intel Pentium based processors has always been "you can't compare apples to oranges," we found ourselves fairly entertained to come into the possession of a 3.6GHz EM64T Xeon processor. Intel's EM64T is Intel's true x86_64 initiative. This 3.6GHz Xeon processor is actually the exact same CPU in as the LGA775 Pentium 4F we will see in just a few weeks. We are offering a preview of an unreleased processor on 64-bit Linux systems. Now, we have Intel and AMD 64-bit x86 processors, 64-bit Linux operating systems and a few days to get some benchmarking done
seega ei olnudki nii offtopic compare
Kommentaarid: 132 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 120
DoS
DoS
sõnum 10.08.2004 13:21:43 vasta tsitaadiga
razor kirjutas:
mis offtopic?
huumorivennad küll seal anandtechis, ei tea palju intel neile maksis selle eest icon_lol.gif
Kommentaarid: 50 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 47
sõnum 10.08.2004 14:00:03 vasta tsitaadiga
DoS kirjutas:
razor kirjutas:
mis offtopic?
ragface
ragface
sõnum 10.08.2004 14:28:19 vasta tsitaadiga
kui xeon64 3.6 GHz on täpselt sama prose, mis LGA775 Pentium 4F, siis see test t6eopoolest oli m6ttekas... kuigi seal oli paar loogikaviga (msyql select - xeon64, 64-bit mysql vs a64, 32-bit mysql etc)
sellised tulemused peaks amd kasutajad ju berserki ajama icon_smile.gif ootame siis, kuni see uus prose ka tegelikult v2ljas on... probleem v6ib olla ka selles et 915, 925 kiibistikud on v2ga halva j6udlusega ning tegelikku perfomance kasvu ei tulegi ja kui tuleb, siis mis hinnaga...
p6him6tteliselt ei saa intel praegu amd-st mööda, sest nad tegid olulise vea projekteerimisel: l2ksid pipede ja mhzide kallale, selleasemel, et yldist arhitektuuri parandada... nad j6udsid mõlemal juhul viimase piiri l2hedale (praeguse tehnoloogia juures) ning variant oleks on-die memory controller, kuid selle patent on amd k2es (kui intel selle yle võtab, siis hakkab amd dikteerima arhitektuuri muudatusi). amd saab samas oma mhzide ja pipeda kallal rahulikult nokitseda... 90nm tehnoloogia peaks olema samuti see viimane piir, kust saaks odavalt ja stabiilselt elektronlylitusi teha. mitme tuuma puhul j6utakse samasse seisu l6puks... m2lu kontroller icon_smile.gif
return of risc icon_razz.gif ?
\R
sõnum 10.08.2004 14:31:04 vasta tsitaadiga
ragface kirjutas:
ei usuks kuigi mine sa tea... samas kunagi ei tea mida AMD tugev partner IBM välja mõtleb icon_smile.gif
Auron
Auron
sõnum 10.08.2004 14:38:02 vasta tsitaadiga
Päris naljakas vaadata kuidas inimesed kohe tatti hakkavad pritsima kui kuskil tulemused pole sellised nagu neile meeldiks icon_wink.gif
ZAndlamb
sõnum 10.08.2004 14:48:27 vasta tsitaadiga
Auron kirjutas:
Juba postist sain aru et oled inteli kasutaja...
razor
sõnum 10.08.2004 15:05:07 vasta tsitaadiga
mis neil tulemustel siis viga oli? osades appides oli ju amd üle...
Auron
Auron
sõnum 10.08.2004 15:08:27 vasta tsitaadiga
ZAndlamb kirjutas:
Auron kirjutas:
??? icon_lol.gif Kui vihjasid ,et ma inteli fänn olen,siis pean kurvastama sellega ,et mina ei suuda üldse sellist asja mõista nagu mingi arvutijupi fännamist icon_wink.gif Eelistan üldiselt seda mis on parem.Inteli sellesse uude üllitisse mis nagu parem oli mingites X testides mida tavakasutaja elusees niisama ei suuda kogeda või tähele panna mul suurt usku pole,kuigi üllatamis võimalus on alati olemas. Lihtsalt väga mannetu on selline asi kui firma teeb mingi toote ja siis osade persoonide suhtumises sellesse on kaks varianti,kui toode on halvem kui teine brand,siis parastatakse ja rõõmustatakse,kui on parem siis süüdistatakse automaatselt,et testi läbiviijad tegid sohki,olid kinnimakstud või test oli mõttetu.Ennast arvutialaselt kursis olevateks pidavad inimesed ei tohiks omale sellist kitsarinnalist ja ebaobjektiivset suhtumist lubada.Eriti veel sisi kui ise kõigest arvatakse ja ei olda seda toodet käes hoitud ,rääkimata testimisest.
razor
sõnum 10.08.2004 15:13:01 vasta tsitaadiga
täpselt. pealegi alguses mainiti ju eraldi, et too Xeon 3.6 peaks olema kohe kohe tulev LGA775 Pentium 4F. seega nutmiseks ei ole põhjust... ja lõpus mainiti ka, et varsti teevad Opt vs Xeon benchid...
sõnum 10.08.2004 16:03:07 vasta tsitaadiga
tegelikult märksa rohkem huvitaksin need mängude testid... hetkel nähtud testidest on tõesti vähe, et öelda, kumb parem...
ja kuna prosede disain on erinev, siis suht loomulik, et üks ühes parem ja teine teises... suhteliselt paratamatus, et see kes tahab mängudst kõike võtta soetab AMD, seni kuni pole väljas
MadMan
MadMan
sõnum 10.08.2004 16:11:04 vasta tsitaadiga
Selgelt on näha see, mis on kogu aeg sama olnud - Intel on tugevam MPEG ja videotöötluses, AMD üldiselt tugevam kõigis muudes rakendustes. Selline seis on kestnud juba AMD XP aegadest saadik ja varemgi. Aga Eestis müüakse gamer arvuteid Celeroni baasil...
Ikka Saab
~~NetMusique~~
Kommentaarid: 31 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 29
Arvo Cobrietti
Arvo Cobrietti
sõnum 10.08.2004 17:04:30 vasta tsitaadiga
mitte celeron ei ole nende puhul pudelikael vaid videokaardid mis seal sees (5200 ja 9200)
sõnum 10.08.2004 17:13:38 vasta tsitaadiga
Arvo Cobrietti kirjutas:
siiski ka celeron on pudelikaelaks icon_wink.gif ja neid FX5200 ja R9200 pannakse ka täiesti korralikesse arvutitesse ja rikutakse hea kooslus ära... nii et selles mõttes küll õüige, et videokad teinekord julmaks piduriks thumbs_down.gif
stepzter
stepzter
sõnum 10.08.2004 19:49:24 vasta tsitaadiga
Nendest Anandtechi Linuxi tulemustest ei tohiks mingeid järeldusi teha, kuna benchmarkid olid täiesti vigased. Asjad kompileeriti kokku ilma optimisatsioonideta ja kohati on A64 tulemused midagi hoopis muud, kui nad peaks olema (P4 tulemuste kohta ei saa midagi öelda, sest ei ole võrreldavaid andmeid, aga arvatavasti ei ole need ka õiged).
Tundub, et artikli autor ei oma Linuxist eriti mingeid teadmisi, veel vähem täpsete ja relevantsete benchmarkide koostamisest.
Saab huviga oodata, kas tulevikus tuleb ehk midagi paremat.
MadMan
MadMan
sõnum 12.08.2004 13:35:33 vasta tsitaadiga
Kui AMD võib oma prosedele lisada SSE, SSE2 jne käsustiku, siis miks seda (3DNow!) ei või (ei taha?) teha Intel?
Kas on tõene väide, et kui Intel viib mälukontrolleri prose sisse, siis hakkab AMD dikteerima selle asja arengut?
Ikka Saab
~~NetMusique~~
stepzter
stepzter
sõnum 12.08.2004 14:59:26 vasta tsitaadiga
Intel lihtsalt ei taha seda teha. 3DNow ja SSE on põhimõtteliselt ühe ja sama eesmärgiga käsustikud natukene erinevate käsusemantikatega.
Ja Intel võib mälukontrolleri täiesti sõltumatult AMD'st prosa sisse viia.
lamp
lamp
sõnum 12.08.2004 16:21:45 vasta tsitaadiga
alates 2P systeemidest mõrvab opteron siiski xeoni ära.
smp rakendustes siis.
natuke kergendust toob asjale see dual fsb'ga twin castle tsipset.
aga yldiselt - midagi tõeliselt adekvaatset ei saa enne olema kuni pole win64 olemas
nendele prosedele.
eriti julm
Kommentaarid: 191 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 168
stepzter
stepzter
sõnum 13.08.2004 14:10:49 vasta tsitaadiga
Anandtech teostas testid uuesti, seekord tiba adekvaatsemate benchidega: http://www.anandtech.com/linux/showdoc.aspx?i=2163
DB ja assümmeetrilisekrüpto osas Opteron lausa mõrvab Xeoni. Mõlemad on serverite maailmas väga olulised ja prosamaiad rakendused.
2korda2
sõnum 13.08.2004 14:40:39 vasta tsitaadiga
lamp kirjutas:
Päris nii lihtne see ka pole.
Siin näiteks tehti päris hea test. Küll juba natuke vana - ma hindaks nüüdseks Xeoni edasminekut ( >10% MHz kasvu) isegi suuremaks, kui Opteroni oma (<10% MHz kasvu). Renderdamisel ( 3DS Max, Cinema 4dD) näiteks on DP Xeon isegi kiirem.
Tõsi Apache ja MySQL on küll Opteroni pärusmaa, siin pole mingit kahtlust.
Arvo Cobrietti
Arvo Cobrietti
sõnum 13.08.2004 15:06:06 vasta tsitaadiga
nendes progedes on ka P4 kiirem kui a64
ragface
ragface
sõnum 13.08.2004 15:18:16 vasta tsitaadiga
3DS Max, Cinema 4dD
serverid, mis selliseid asju teevad, jooksevad silicon graphics riistvaral.
db, veebiserver, skriptimiskeeled, kompileerimine, javarakendused : opteron 2x kiirem 200 taale v2iksema hinna eest... ega hp ja sun ilmaasjata oma tippmudelite platvormi v2lja ei vahetanud.
\R
stepzter
stepzter
sõnum 13.08.2004 16:16:13 vasta tsitaadiga
Renderfarmides kasutatakse päris palju Itanium2'te, aga P4 põhised odavamad purgid on ka üsna populaarsed, samuti ei ole AMD prosad ka täiesti tundmatud.
3D workstationites oli siiamaani ainukesed 64-bitised lahendused Opteron ja Itanium2, kusjuures esimene on oluliselt parema tarkvara toega ja odavam.
sõnum 13.08.2004 17:11:40 vasta tsitaadiga
mnjaa... filminduses võetakse AMD'd ka juba päris tõsiselt...
