uus teema   See teema on lukus, sa ei saa siin muuta postitusi või vastata teemale! Raud »  Protsessorid »  overclock märgi kõik teemad loetuks
mistafox
sõnum 03.08.2004 14:56:30 overclock vasta tsitaadiga
--------[ AIDA32 (c) 1995-2004 Tamas Miklos ]---------------------------------------------------------------------------
Version AIDA32 v3.93
Author tamas.miklos@aida32.hu
Homepage http://www.aida32.hu
Report Type Report Wizard
Computer TUULIKKI
Generator Tuulikki Ojalo
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
Date 2004-08-03
Time 14:54
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
OS Service Pack None
Internet Explorer 6.0.2600.0000 (IE 6.0 - Windows XP)
Computer Name TUULIKKI
User Name Tuulikki Ojalo
Logon Domain TUULIKKI
Motherboard:
CPU Type AMD Athlon XP, 2000 MHz (7.5 x 267) 2400+
Motherboard Name Asus A7N8X v2.0 Deluxe (5 PCI, 1 AGP Pro, 3 DIMM, IEEE-1394)
Motherboard Chipset nVIDIA nForce2 Ultra 400
System Memory 512 MB (DDR SDRAM)
BIOS Type Award (05/14/03)
Communication Port Communications Port (COM1)
Communication Port Communications Port (COM2)
Communication Port ECP Printer Port (LPT1)
Display:
Video Adapter RADEON 9200 SE - Secondary (128 MB)
Video Adapter RADEON 9200 SE (128 MB)
3D Accelerator ATI Radeon 9200 SE (RV280)
Monitor Plug and Play Monitor [NoDB] (2323919)
Multimedia:
Audio Adapter nVIDIA MCP2 - Audio Codec Interface
Audio Adapter nVIDIA MCP2 - Audio Processing Unit (Dolby Digital)
Storage:
Floppy Drive Floppy disk drive
Disk Drive ST340014A (40 GB, 7200 RPM, Ultra-ATA/100)
Optical Drive Generic DVD-ROM SCSI CdRom Device
Optical Drive LITE-ON COMBO LTC-48161H (DVD:16x, CD:48x/24x/48x DVD-ROM/CD-RW)
Partitions:
C: (NTFS) 38154 MB (28367 MB free)
Input:
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse PS/2 Compatible Mouse
Network:
Primary IP Address 10.0.0.210
Primary MAC Address 00-26-54-11-0B-76
Network Adapter 3Com 3C920B-EMB Integrated Fast Ethernet Controller (10.0.0.210)
Network Adapter NVIDIA nForce Networking Controller
Modem Nokia 5100 IrDA
Peripherals:
USB Device IRXpress USB Infrared Device
USB Device Logitech QuickCam Express
--------[ Computer Name ]-----------------------------------------------------------------------------------------------
Computer Comment Logical
NetBIOS Name Logical TUULIKKI
DNS Host Name Logical tuulikki
DNS Domain Name Logical
Fully Qualified DNS Name Logical tuulikki
NetBIOS Name Physical TUULIKKI
DNS Host Name Physical tuulikki
DNS Domain Name Physical
Fully Qualified DNS Name Physical tuulikki
--------[ DMI ]---------------------------------------------------------------------------------------------------------
[ BIOS ]
BIOS Properties:
Vendor Phoenix Technologies, LTD
Version ASUS A7N8X2.0 Deluxe ACPI BIOS Rev 1005
Release Date 05/14/2003
Size 512 KB
Boot Devices Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD
Supported Standards DMI, APM, ACPI, PnP
Expansion Capabilities PCI, AGP, USB
[ System ]
System Properties:
Manufacturer ASUSTeK Computer INC.
Product A7N8X2.0
Version REV 2.xx
Serial Number xxxxxxxxxxx
Wake-Up Type Power Switch
[ Motherboard ]
Motherboard Properties:
Product A7N8X2.0
Version REV 2.xx
[ Chassis ]
Chassis Properties:
Manufacturer Chassis Manufactture
Version Chassis Version
Serial Number Chassis serial Number
Asset Tag Asset-1234567890
Chassis Type Desktop Case
[ Memory Controller ]
Memory Controller Properties:
Error Detection Method None
Supported Memory Speeds 70ns, 60ns, 50ns
Supported Memory Types DIMM, SDRAM
Supported Memory Voltages 3.3V
Maximum Memory Module Size 1024 MB
Memory Slots 3
[ Processors / AMD Athlon(tm) XP ]
Processor Properties:
Manufacturer AMD
Version AMD Athlon(tm) XP
External Clock 133 MHz
Maximum Clock 3000 MHz
Current Clock 2000 MHz
Type Central Processor
Voltage 1.6 V
Status Enabled
Upgrade ZIF
Socket Designation Socket A
[ Caches / L1 Cache ]
Cache Properties:
Type Internal
Status Enabled
Operational Mode Write-Back
Associativity 4-way Set-Associative
Maximum Size 128 KB
Installed Size 128 KB
Supported SRAM Type Synchronous, Pipeline Burst
Current SRAM Type Synchronous, Pipeline Burst
Socket Designation L1 Cache
[ Caches / L2 Cache ]
Cache Properties:
Type External
Status Enabled
Maximum Size 256 KB
Installed Size 256 KB
Socket Designation L2 Cache
[ Memory Modules / DDR1 ]
Memory Module Properties:
Socket Designation DDR1
Type DIMM
Installed Size Not Installed
Enabled Size Not Installed
[ Memory Modules / DDR2 ]
Socket Designation DDR2
Type DIMM
Installed Size 256 MB
Enabled Size 256 MB
[ Memory Modules / DDR3 ]
Socket Designation DDR3
Type DIMM
Enabled Size 256 MB
[ Memory Devices / DDR1 ]
Memory Device Properties:
Form Factor DIMM
Type DRAM
Type Detail Synchronous
Total Width 72-bit
Data Width 64-bit
Device Locator DDR1
Bank Locator Bank0/1
[ Memory Devices / DDR2 ]
Form Factor DIMM
Type DRAM
Size 256 MB
Total Width 72-bit
Data Width 64-bit
Device Locator DDR2
Bank Locator Bank2/3
[ Memory Devices / DDR3 ]
Form Factor DIMM
Type DRAM
Size 256 MB
Total Width 72-bit
Data Width 64-bit
Device Locator DDR3
Bank Locator Bank4/5
[ System Slots / PCI1 ]
System Slot Properties:
Slot Designation PCI1
Type PCI
Usage In Use
Data Bus Width 32-bit
Length Short
[ System Slots / PCI2 ]
Slot Designation PCI2
Type PCI
Usage Empty
Length Short
[ System Slots / PCI3 ]
Slot Designation PCI3
Type PCI
Usage Empty
Length Short
[ System Slots / PCI4 ]
Slot Designation PCI4
Type PCI
Usage Empty
Length Short
[ System Slots / PCI5 ]
Slot Designation PCI5
Type PCI
Usage Empty
Length Short
[ System Slots / AGP ]
Slot Designation AGP
Type AGP
Usage In Use
Length Short
[ Port Connectors / PRIMARY IDE/HDD ]
Port Connector Properties:
Port Type None
Internal Reference Designator PRIMARY IDE/HDD
Internal Connector Type On-Board IDE
External Connector Type None
[ Port Connectors / SECONDARY IDE/HDD ]
Port Type None
Internal Reference Designator SECONDARY IDE/HDD
[ Port Connectors / FLOPPY ]
Port Type None
Internal Reference Designator FLOPPY
Internal Connector Type On-Board Floppy
[ Port Connectors / Serial Port 1 ]
Port Type Serial Port 16550 Compatible
Internal Reference Designator Serial Port 1
Internal Connector Type None
External Reference Designator Serial Port 1
External Connector Type DB-9 pin male
[ Port Connectors / Serial Port 2 ]
Internal Reference Designator Serial Port 2
External Reference Designator Serial Port 2
[ Port Connectors / Parallel Port ]
Port Type Parallel Port ECP/EPP
Internal Reference Designator Parallel Port
External Reference Designator Parallel Port
External Connector Type DB-25 pin female
[ Port Connectors / PS/2 Keyboard ]
Port Type Keyboard Port
Internal Reference Designator PS/2 Keyboard
External Reference Designator PS/2 Keyboard
External Connector Type PS/2
[ Port Connectors / PS/2 Mouse ]
Port Type Mouse Port
Internal Reference Designator PS/2 Mouse
External Reference Designator PS/2 Mouse
[ Port Connectors / USB1 ]
Port Type USB
External Reference Designator USB1
External Connector Type USB
[ Port Connectors / USB2 ]
Port Type USB
External Reference Designator USB2
[ Port Connectors / USB3 ]
Port Type USB
External Reference Designator USB3
[ Port Connectors / USB4 ]
Port Type USB
External Reference Designator USB4
[ Port Connectors / USB5 ]
Port Type USB
External Reference Designator USB5
[ Port Connectors / USB6 ]
Port Type USB
External Reference Designator USB6
[ Port Connectors / ETHERNET ]
Port Type Network Port
External Reference Designator ETHERNET
External Connector Type RJ-45
[ Port Connectors / Joystic Port ]
Port Type Joystick Port
External Reference Designator Joystic Port
External Connector Type DB-15 pin female
[ Port Connectors / MIDI Port ]
Port Type MIDI Port
External Reference Designator MIDI Port
[ Port Connectors / Onboard 1394 ]
Port Type FireWire (IEEE P1394)
External Reference Designator Onboard 1394
External Connector Type 1394
[ Port Connectors / Line In Jack Port ]
Port Type Audio Port
External Reference Designator Line In Jack Port
External Connector Type Mini-jack (headphones)
--------[ Sensor ]------------------------------------------------------------------------------------------------------
Sensor Properties:
Sensor Type Asus ASB100 Bach, Winbond W83L785TS-S
Sensor Access SMBus 2Dh, SMBus 2Eh
Temperatures:
Motherboard 34 °C (93 °F)
CPU 45 °C (113 °F)
CPU Diode 53 °C (127 °F)
Cooling Fans:
CPU 2596 RPM
Voltage Values:
CPU Core 1.68 V
CPU Aux 1.68 V
+3.3 V 3.30 V
+5 V 4.81 V
+12 V 12.61 V
-12 V -12.52 V
-5 V -4.74 V
Debug Info 68 68 CF B3 C6 C5 C5 2D 82 FF FF 7B (01)
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Alias Thorton
CPU Stepping A2
L1 Code Cache 64 KB
L1 Data Cache 64 KB
L2 Cache 256 KB (On-Die, Full-Speed)
CPU Physical Info:
Package Type 453 Pin PGA
Package Size 4.95 cm x 4.95 cm
Transistors 54.3 million
Process Technology 6Mi, 0.13 um, CMOS, Cu
Die Size 101 mm2
Core Voltage 1.60 / 1.65 V
I/O Voltage 1.6 V
Typical Power 47.4 - 53.7 W (depending on clock speed)
Maximum Power 60.3 - 68.3 W (depending on clock speed)
CPU Manufacturer:
Company Name Advanced Micro Devices, Inc.
Product Information http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118,00.html
CPU Utilization:
CPU #1 17 %
--------[ CPUID ]-------------------------------------------------------------------------------------------------------
CPUID Properties:
CPUID Manufacturer AuthenticAMD
CPUID CPU Name AMD Athlon(tm) XP 2400+
CPUID Revision 06A0h
Extended CPUID Revision 07A0h
Platform ID CBh (Socket A)
IA CPU Serial Number Unknown
Instruction Set:
AMD 3DNow! Supported
AMD 3DNow! Professional Supported
AMD Enhanced 3DNow! Supported
AMD Extended MMX Supported
AMD64 Not Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE 2 Not Supported
IA SSE 3 Not Supported
CLFLUSH Instruction Not Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Not Supported
Conditional Move Instruction Supported
FEMMS Instruction Not Supported
MONITOR / MWAIT Instruction Not Supported
CPUID Features:
36-bit Page Size Extension Supported
Advanced Cryptography Engine Not Supported
Alternate Instruction Set Not Supported
Automatic Clock Control Not Supported
CPL Qualified Debug Store Not Supported
Debug Trace Store Not Supported
Debugging Extension Supported
Enhanced SpeedStep Technology Not Supported
Fast Save & Restore Supported
Fast System Call Supported
Hyper-Threading Technology Not Supported
L1 Context ID Not Supported
Local APIC On Chip Supported
LongRun Not Supported
LongRun Table Interface Not Supported
Machine-Check Architecture Supported
Machine-Check Exception Supported
Memory Type Range Registers Supported
Model Specific Registers Supported
No-Execute Page Protection Not Supported
Page Attribute Table Supported
Page Global Extension Supported
Pending Break Event Not Supported
Physical Address Extension Supported
Processor Duty Cycle Control Not Supported
Processor Serial Number Not Supported
Random Number Generator Not Supported
Self-Snoop Not Supported
Thermal Monitor Not Supported
Thermal Monitor 2 Not Supported
Time Stamp Counter Supported
Virtual Mode Extension Supported
Enhanced Power Management:
Frequency ID Control Not Supported
Software Thermal Control Not Supported
Temperature Sensing Diode Supported
Thermal Monitoring Not Supported
Thermal Trip Not Supported
Voltage ID Control Not Supported
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard ID 05/14/2003-nVidia-nForce-A7N8X2.0C-00
Front Side Bus Properties:
Bus Type DEC Alpha EV6
Bus Width 64-bit
Real Clock 133 MHz (DDR)
Effective Clock 267 MHz
Bandwidth 2133 MB/s
Chipset Bus Properties:
Bus Type HyperTransport v1.0
Bus Width 8-bit
Motherboard Physical Info:
CPU Sockets/Slots 1
Expansion Slots 5 PCI, 1 AGP Pro
RAM Slots 3 DIMM
Integrated Devices IEEE-1394
Form Factor ATX
Motherboard Size 240 mm x 300 mm
Motherboard Chipset nForce2-U400
Extra Features Q-Fan, CPU Overheating Protection, Serial-ATA/150, RAID
Motherboard Manufacturer:
Company Name ASUSTeK Computer Inc.
Product Information http://www.asus.com/products/mb/mbindex.htm
BIOS Download http://www.asus.com/support/download/download.aspx
--------[ Memory ]------------------------------------------------------------------------------------------------------
Physical Memory:
Total 511 MB
Used 229 MB
Free 281 MB
Utilization 45 %
Swap Space:
Total 1250 MB
Used 208 MB
Free 1041 MB
Utilization 17 %
Virtual Memory:
Total 1761 MB
Used 438 MB
Free 1323 MB
Utilization 25 %
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ 256 MB PC3200 DDR SDRAM ]
Serial Number None
Module Size 256 MB (1 rows, 4 banks)
Module Type Unbuffered
Memory Type DDR SDRAM
Memory Speed PC3200 (200 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Refresh Rate Reduced (7.8 us), Self-Refresh
Highest CAS Latency 2.5 (5.0 ns @ 200 MHz)
Memory Module Features:
Early RAS# Precharge Not Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Supported
Redundant Row Address Not Supported
Serial Number None
Module Width 64 bit
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
Chipset Properties:
CAS Latency 2.5T
RAS To CAS Delay 3T
RAS Precharge 3T
RAS Active Time 8T
Memory Slots:
DRAM Slot #1 256 MB (DDR SDRAM)
DRAM Slot #2 256 MB (DDR SDRAM)
AGP Properties:
AGP Version 3.00
AGP Status Enabled
AGP Aperture Size 256 MB
Supported AGP Speeds 1x, 2x, 4x, 8x
Current AGP Speed 8x
Fast-Write Supported, Disabled
Side Band Addressing Supported, Enabled
Chipset Manufacturer:
Company Name NVIDIA Corporation
Product Information http://www.nvidia.com/page/mobo.html
Driver Download http://www.nvidia.com/drivers
Problems & Suggestions:
Problem AGP aperture size is more than half of the system memory size. This may cause performance penalty.
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Award
Award BIOS Type Phoenix-Award BIOS v6.00PG
Award BIOS Message ASUS A7N8X2.0 Deluxe ACPI BIOS Rev 1005
System BIOS Date 05/14/03
Video BIOS Date 03/09/02
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
Suggestion Video BIOS is more than 2 years old. Update it if necessary.
--------[ Windows Video ]-----------------------------------------------------------------------------------------------
[ RADEON 9200 SE - Secondary ]
Video Adapter Properties:
Device Description RADEON 9200 SE - Secondary
Adapter String RADEON 9200 SE
BIOS String BK-ATI VER008.015.033.000
Chip Type RADEON 9200 SE AGP (0x5964)
DAC Type Internal DAC(400MHz)
Installed Drivers ati2dvag (6.14.10.6360 - ATI Catalyst 3.5)
Memory Size 128 MB
Video Adapter Manufacturer:
Company Name ATI Technologies Inc.
Product Information http://www.ati.com/products/home-office.html
Driver Download http://www.ati.com/support/driver.html
[ RADEON 9200 SE ]
Memory Size 128 MB
--------[ PCI / AGP Video ]---------------------------------------------------------------------------------------------
ATI Radeon 9200 SE (RV280) Video Adapter
ATI Radeon 9200 SE (RV280) 3D Accelerator
LeadTek WinFast TV 2000 Multimedia Video
--------[ GPU ]---------------------------------------------------------------------------------------------------------
Graphics Processor Properties:
Video Adapter ATI Radeon 9200 SE (RV280)
GPU Code Name RV280
PCI Device 1002 / 5964
Transistors 36 million
Process Technology 0.15u
Bus Type AGP
Memory Size 128 MB
GPU Clock 200 MHz
RAMDAC Clock 400 MHz
Pixel Pipelines 4
TMU Per Pipeline 1
Vertex Shaders 1 (v1.1)
Pixel Shaders 1 (v1.4)
DirectX Hardware Support DirectX v8.1
Pixel Fillrate 800 MPixel/s
Texel Fillrate 800 MTexel/s
Memory Bus Properties:
Bus Type DDR
Bus Width 64-bit
Real Clock 164 MHz (DDR)
Effective Clock 328 MHz
Bandwidth 2624 MB/s
Graphics Processor Manufacturer:
ATI Registers:
ati-0F8 08000000
ati-140 00003200
ati-154 775774BF
ati-158 75320032
ati-CLKIND-0A 0059490C
ati-CLKIND-0B 48000E00
ati-CLKIND-0C 0400A430
ati-CLKIND-0D 00317FFA
ati-CLKIND-0E 0400FE00
ati-CLKIND-0F 00980098
ati-CLKIND-12 FF021212
--------[ Monitor ]-----------------------------------------------------------------------------------------------------
[ Plug and Play Monitor [NoDB] ]
Monitor Properties:
Monitor Name Plug and Play Monitor [NoDB]
Monitor ID IBM19FB
Model IBM 6651 P97
Manufacture Date Week 34 / 2002
Serial Number 2323919
Max. Visible Display Size 36 cm x 27 cm (17.7")
Picture Aspect Ratio 4:3
Horizontal Frequency 30 - 107 kHz
Vertical Frequency 48 - 170 Hz
Gamma 2.50
DPMS Mode Support Active-Off
--------[ Desktop ]-----------------------------------------------------------------------------------------------------
Desktop Properties:
Device Technology Raster Display
Resolution 1152 x 864
Color Depth 32-bit
Color Planes 1
Font Resolution 96 dpi
Pixel Width / Height 36 / 36
Pixel Diagonal 51
Vertical Refresh Rate 85 Hz
Desktop Wallpaper C:\Documents and Settings\Tuulikki Ojalo\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
Desktop Effects:
Combo-Box Animation Enabled
Drop Shadow Effect Enabled
Flat Menu Effect Enabled
Font Smoothing Enabled
Full Window Dragging Enabled
Gradient Window Title Bars Enabled
Hide Menu Access Keys Enabled
Hot Tracking Effect Enabled
Icon Title Wrapping Enabled
List-Box Smooth Scrolling Enabled
Menu Animation Enabled
Menu Fade Effect Enabled
Minimize/Restore Animation Enabled
Mouse Cursor Shadow Enabled
Selection Fade Effect Enabled
ShowSounds Accessibility Feature Disabled
ToolTip Animation Enabled
ToolTip Fade Effect Enabled
Windows Plus! Extension Disabled
--------[ Multi-Monitor ]-----------------------------------------------------------------------------------------------
\\.\DISPLAY1 Yes (0,0) (1152,864)
--------[ Fonts ]-------------------------------------------------------------------------------------------------------
Arial Black Swiss Regular Baltic 18 x 45 40 %
Arial Black Swiss Regular Central European 18 x 45 40 %
Arial Black Swiss Regular Cyrillic 18 x 45 40 %
Arial Black Swiss Regular Greek 18 x 45 40 %
Arial Black Swiss Regular Turkish 18 x 45 40 %
Arial Black Swiss Regular Western 18 x 45 40 %
Arial Swiss Regular Arabic 14 x 36 40 %
Arial Swiss Regular Baltic 14 x 36 40 %
Arial Swiss Regular Central European 14 x 36 40 %
Arial Swiss Regular Cyrillic 14 x 36 40 %
Arial Swiss Regular Greek 14 x 36 40 %
Arial Swiss Regular Hebrew 14 x 36 40 %
Arial Swiss Regular Turkish 14 x 36 40 %
Arial Swiss Regular Western 14 x 36 40 %
Arial Swiss Regular Vietnamese 14 x 36 40 %
Comic Sans MS Script Regular Baltic 15 x 45 40 %
Comic Sans MS Script Regular Central European 15 x 45 40 %
Comic Sans MS Script Regular Cyrillic 15 x 45 40 %
Comic Sans MS Script Regular Greek 15 x 45 40 %
Comic Sans MS Script Regular Turkish 15 x 45 40 %
Comic Sans MS Script Regular Western 15 x 45 40 %
Courier New Modern Regular Arabic 19 x 36 40 %
Courier New Modern Regular Baltic 19 x 36 40 %
Courier New Modern Regular Central European 19 x 36 40 %
Courier New Modern Regular Cyrillic 19 x 36 40 %
Courier New Modern Regular Greek 19 x 36 40 %
Courier New Modern Regular Hebrew 19 x 36 40 %
Courier New Modern Regular Turkish 19 x 36 40 %
Courier New Modern Regular Western 19 x 36 40 %
Courier New Modern Regular Vietnamese 19 x 36 40 %
Courier Roman Baltic 8 x 13 40 %
Estrangelo Edessa Script Regular Other 13 x 32 40 %
Fixedsys Modern Baltic 8 x 15 40 %
Franklin Gothic Medium Swiss Regular Baltic 14 x 36 40 %
Franklin Gothic Medium Swiss Regular Central European 14 x 36 40 %
Franklin Gothic Medium Swiss Regular Cyrillic 14 x 36 40 %
Franklin Gothic Medium Swiss Regular Greek 14 x 36 40 %
Franklin Gothic Medium Swiss Regular Turkish 14 x 36 40 %
Franklin Gothic Medium Swiss Regular Western 14 x 36 40 %
Gautami Special Regular Other 13 x 56 40 %
Georgia Roman Regular Baltic 14 x 36 40 %
Georgia Roman Regular Central European 14 x 36 40 %
Georgia Roman Regular Cyrillic 14 x 36 40 %
Georgia Roman Regular Greek 14 x 36 40 %
Georgia Roman Regular Turkish 14 x 36 40 %
Georgia Roman Regular Western 14 x 36 40 %
Impact Swiss Regular Baltic 13 x 39 40 %
Impact Swiss Regular Central European 13 x 39 40 %
Impact Swiss Regular Cyrillic 13 x 39 40 %
Impact Swiss Regular Greek 13 x 39 40 %
Impact Swiss Regular Turkish 13 x 39 40 %
Impact Swiss Regular Western 13 x 39 40 %
Latha Special Regular Other 29 x 44 40 %
Lucida Console Modern Regular Central European 19 x 32 40 %
Lucida Console Modern Regular Cyrillic 19 x 32 40 %
Lucida Console Modern Regular Greek 19 x 32 40 %
Lucida Console Modern Regular Turkish 19 x 32 40 %
Lucida Console Modern Regular Western 19 x 32 40 %
Lucida Sans Unicode Swiss Regular Central European 16 x 49 40 %
Lucida Sans Unicode Swiss Regular Cyrillic 16 x 49 40 %
Lucida Sans Unicode Swiss Regular Greek 16 x 49 40 %
Lucida Sans Unicode Swiss Regular Hebrew 16 x 49 40 %
Lucida Sans Unicode Swiss Regular Turkish 16 x 49 40 %
Lucida Sans Unicode Swiss Regular Western 16 x 49 40 %
Mangal Special Regular Other 18 x 54 40 %
Marlett Special Regular Symbol 31 x 32 50 %
Microsoft Sans Serif Swiss Regular Arabic 14 x 36 40 %
Microsoft Sans Serif Swiss Regular Baltic 14 x 36 40 %
Microsoft Sans Serif Swiss Regular Central European 14 x 36 40 %
Microsoft Sans Serif Swiss Regular Cyrillic 14 x 36 40 %
Microsoft Sans Serif Swiss Regular Greek 14 x 36 40 %
Microsoft Sans Serif Swiss Regular Hebrew 14 x 36 40 %
Microsoft Sans Serif Swiss Regular Thai 14 x 36 40 %
Microsoft Sans Serif Swiss Regular Turkish 14 x 36 40 %
Microsoft Sans Serif Swiss Regular Western 14 x 36 40 %
Microsoft Sans Serif Swiss Regular Vietnamese 14 x 36 40 %
Modern Modern OEM/DOS 19 x 37 40 %
MS Sans Serif Swiss Baltic 6 x 13 40 %
MS Serif Roman Baltic 4 x 10 40 %
MV Boli Special Regular Other 16 x 52 40 %
Palatino Linotype Roman Regular Baltic 14 x 43 40 %
Palatino Linotype Roman Regular Central European 14 x 43 40 %
Palatino Linotype Roman Regular Cyrillic 14 x 43 40 %
Palatino Linotype Roman Regular Greek 14 x 43 40 %
Palatino Linotype Roman Regular Turkish 14 x 43 40 %
Palatino Linotype Roman Regular Western 14 x 43 40 %
Palatino Linotype Roman Regular Vietnamese 14 x 43 40 %
Raavi Special Regular Other 18 x 53 40 %
Roman Roman OEM/DOS 22 x 37 40 %
Script Script OEM/DOS 16 x 36 40 %
Shruti Special Regular Other 19 x 54 40 %
Small Fonts Swiss Baltic 2 x 3 40 %
Sylfaen Roman Regular Baltic 13 x 42 40 %
Sylfaen Roman Regular Central European 13 x 42 40 %
Sylfaen Roman Regular Cyrillic 13 x 42 40 %
Sylfaen Roman Regular Greek 13 x 42 40 %
Sylfaen Roman Regular Turkish 13 x 42 40 %
Sylfaen Roman Regular Western 13 x 42 40 %
Symbol Roman Regular Symbol 19 x 39 40 %
System Swiss Baltic 7 x 16 70 %
Tahoma Swiss Bold Arabic 16 x 39 70 %
Tahoma Swiss Bold Baltic 16 x 39 70 %
Tahoma Swiss Bold Central European 16 x 39 70 %
Tahoma Swiss Bold Cyrillic 16 x 39 70 %
Tahoma Swiss Bold Greek 16 x 39 70 %
Tahoma Swiss Bold Hebrew 16 x 39 70 %
Tahoma Swiss Bold Thai 16 x 39 70 %
Tahoma Swiss Bold Turkish 16 x 39 70 %
Tahoma Swiss Bold Western 16 x 39 70 %
Tahoma Swiss Bold Vietnamese 16 x 39 70 %
Terminal Modern OEM/DOS 8 x 12 40 %
Times New Roman Roman Regular Arabic 13 x 35 40 %
Times New Roman Roman Regular Baltic 13 x 35 40 %
Times New Roman Roman Regular Central European 13 x 35 40 %
Times New Roman Roman Regular Cyrillic 13 x 35 40 %
Times New Roman Roman Regular Greek 13 x 35 40 %
Times New Roman Roman Regular Hebrew 13 x 35 40 %
Times New Roman Roman Regular Turkish 13 x 35 40 %
Times New Roman Roman Regular Western 13 x 35 40 %
Times New Roman Roman Regular Vietnamese 13 x 35 40 %
Trebuchet MS Swiss Regular Baltic 15 x 37 40 %
Trebuchet MS Swiss Regular Central European 15 x 37 40 %
Trebuchet MS Swiss Regular Cyrillic 15 x 37 40 %
Trebuchet MS Swiss Regular Greek 15 x 37 40 %
Trebuchet MS Swiss Regular Turkish 15 x 37 40 %
Trebuchet MS Swiss Regular Western 15 x 37 40 %
Tunga Special Regular Other 17 x 53 40 %
Webdings Roman Regular Symbol 31 x 32 40 %
Verdana Swiss Regular Baltic 16 x 39 40 %
Verdana Swiss Regular Central European 16 x 39 40 %
Verdana Swiss Regular Cyrillic 16 x 39 40 %
Verdana Swiss Regular Greek 16 x 39 40 %
Verdana Swiss Regular Turkish 16 x 39 40 %
Verdana Swiss Regular Western 16 x 39 40 %
Verdana Swiss Regular Vietnamese 16 x 39 40 %
Wingdings Special Regular Symbol 28 x 36 40 %
WST_Czec Decorative Symbol 10 x 12 70 %
WST_Engl Decorative Symbol 10 x 12 70 %
WST_Fren Decorative Symbol 10 x 12 70 %
WST_Germ Decorative Symbol 10 x 12 70 %
WST_Ital Decorative Symbol 10 x 12 70 %
WST_Span Decorative Symbol 10 x 12 70 %
WST_Swed Decorative Symbol 10 x 12 70 %
--------[ Windows Audio ]-----------------------------------------------------------------------------------------------
midi-in.0 0001 0067 MPU-401
midi-out.0 0001 0066 NVIDIA(R) DLS Synthesizer
midi-out.1 0001 0066 MPU-401
midi-out.2 0001 0066 Microsoft GS Wavetable SW Synth
mixer.0 0001 0068 NVIDIA(R) nForce(TM) Audio
wave-in.0 0001 0065 NVIDIA(R) nForce(TM) Audio
wave-out.0 0001 0064 NVIDIA(R) nForce(TM) Audio
--------[ PCI / PnP Audio ]---------------------------------------------------------------------------------------------
nVIDIA MCP2 - Audio Codec Interface PCI
nVIDIA MCP2 - Audio Processing Unit (Dolby Digital) PCI
--------[ ACM ]---------------------------------------------------------------------------------------------------------
[ AC-3 ACM Decompressor ]
ACM Driver Properties:
Driver Description AC-3 ACM Decompressor
Copyright Notice © 2003 by fccHandler
License Information GNU General Public License
Driver Features Dolby Digital AC-3 decoding for Windows ACM
Driver Version 0.07
[ DivX WMA Audio Compressor ]
Driver Description DivX WMA Audio Compressor
Copyright Notice Copyright (C) Kristal Studio Corporation, 1999 - 2000
Driver Features Compresses and decompresses audio data.
Driver Version 4.02
[ DSP Group TrueSpeech(TM) Software CODEC ]
Driver Description DSP Group TrueSpeech(TM) Software CODEC
Copyright Notice Copyright (C) 1993-1996 DSP Group, Inc.
License Information TrueSpeech is a trademark of DSP Group, Inc., Santa Clara, California.
Driver Features Compresses and decompresses DSP Group TrueSpeech(TM) audio data.
Driver Version 1.00
[ Fraunhofer IIS MPEG Layer-3 Codec (advanced) ]
Driver Description Fraunhofer IIS MPEG Layer-3 Codec (advanced)
Copyright Notice Copyright © 1996-1999 Fraunhofer Institut Integrierte Schaltungen IIS
Driver Features bitrates up to 56kBit/s, mono and stereo codec (advanced)
Driver Version 1.09
[ Indeo® Audio Software ]
Driver Description Indeo® Audio Software
Copyright Notice Copyright © 1997 Intel Corp.; © 2000 Ligos Corp.
Driver Features Indeo® Audio Software
Driver Version 2.05
[ Ingenient Technologies, Inc. G.726 CODEC ]
Driver Description Ingenient Technologies, Inc. G.726 CODEC
Copyright Notice Copyright (C) Ingenient Technologies, Inc
Driver Features Decompresses ITI G.726 audio data.
Driver Version 4.00
[ Intel Music Coder ]
Driver Descrip
www.mööblihunt.ee
Kommentaarid: 12 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 11
aise
aise
sõnum 03.08.2004 14:58:16 vasta tsitaadiga
icon_lol.gif pole sõnu lihtsalt, loodame, et keegi tsiteerima ei hakka icon_razz1.gif
Kommentaarid: 189 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 172
wend
sõnum 03.08.2004 14:59:47 vasta tsitaadiga
küll on kerge olla ebanormaalne
Kommentaarid: 126 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 111
mistafox
sõnum 03.08.2004 15:00:35 vasta tsitaadiga
no parem kirjutan kõik muidu kellelgi jääb väheks ja hakkab eraldi eriasju kysima ma ei ole tarkur ei oska vastata igale kysimusele parem ylevaade vähemalt
www.mööblihunt.ee
wend
sõnum 03.08.2004 15:01:22 vasta tsitaadiga
Ok,ok. Ära solvu.
aise
aise
sõnum 03.08.2004 15:04:45 vasta tsitaadiga
mistafox
sõnum 03.08.2004 15:05:37 vasta tsitaadiga
irw mis teha ma olen noob irw kes yritab juba mitmendat päeva arvutitega mässata overclock ja casemod
www.mööblihunt.ee
pang
sõnum 03.08.2004 15:05:49 vasta tsitaadiga
icon_biggrin.gif kus see küsimus oli?
Et niisama tahtsid meile näidata?
Kommentaarid: 50 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 46
sergay
sõnum 03.08.2004 15:06:36 Re: overclock vasta tsitaadiga
Et nagu tahad klokkida vä?
viimati muutis sergay 03.08.2004 15:07:17, muudetud 1 kord
Kommentaarid: 15 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 8
mistafox
sõnum 03.08.2004 15:06:46 vasta tsitaadiga
ee kysimus seisneb selles et kuidas teha overclocki ja kui kiireks saab jne et nagu mis võimalused mul oleks icon_redface.gif icon_redface.gif
www.mööblihunt.ee
wend
sõnum 03.08.2004 15:06:55 vasta tsitaadiga
aise
aise
sõnum 03.08.2004 15:07:15 vasta tsitaadiga
