praegune kellaaeg 24.11.2026 08:52:23
ihvike
31.07.2004 10:53:51
Faili saatmine MSN Messengeriga aeglane? |
| Põhjus - oled arvatavasti ruuteri taga. Lahendus - avada ruuteris TCP pordid 1863 ja 6891-6900.
| Kommentaarid: 12 loe/lisa |
12 |
31.07.2004 16:42:35
File transfer:
Both incoming and outgoing TCP connections use the range of ports from 6891 to 6900. This allows up to 10 simultaneous file transfers per sender. These ports must be open on any firewall between the peers. If you open only port 6891, users will only be able to do one file transfer at a time.
Audio & video conversation:
TCP 6901 ja UDP 6901
Application and Whiteboard Sharing:
TCP 1503
Remote Assistance:
TCP 3389
______________
allikas: Microsoft
ps: IMO, kui tegu UPnP ruuteriga, siis ei pea neid porte avama. oleneb ruuterist.
EDIT: kasulikku veel - http://support.microsoft.com/default.aspx?scid=kb;EN-US;q278887
_________________ "a rental car, three cheeseburgers and a head start."
viimati muutis SKG 31.07.2004 17:19:01, muudetud 2 korda |
313 |
