praegune kellaaeg 14.11.2026 07:15:52
eXiter
17.07.2004 12:13:44
Mingi SATA ketta Seting BIOSis |
Selline asi Abit nf7-s v2.0 plaadi BIOS-is
Integrated peripherals'all
EXT-P2P's Discard Time
ja valikutes on 1ms, 30us, 9,6us, 3,8us
See "us" peaks vist tähendama nanosekundit.
Mida selline setting annab juurde? Default on seal 30us.
MANUALIS POLE SELLEST JUTTUGI, KUSJUURES SELLEST ÜLEVAL JA ALL TOODUD READ ON ILUSTI ÄRA MÄRGITUD SEE ON VAHELE JÄÄNUD.
_________________ okse RÖÖTS |
Kalle
17.07.2004 16:08:39
"Set EXT-P2P's Discard Time to 30us to fix SiliconImage Sil3112 SATA Controller will crush SATA HDD."
...ja lisaks veel: see options on lisatud NF7-S BIOS'i alates nf719 updatega Bios Issue Date:2003/05/13:
Fixed SATA RAID-0 data corruption issue by adding a new option "EXT-P2P's Discard Time" in "integrated Peripherals". The default setting is "30 us" ; which is recommended by NVidia. In case the problem is still there, try "1 ms" please.
Manualis ei saagi sellest juttu olla, kuna see lisati hiljem kui manual trükitud - aga Google's on sellest juttu küll.
| Kommentaarid: 4 loe/lisa |
zbx
23.07.2004 22:43:37
mikrosekund on see, kuna "müü" (kr.k) täht ei ole just standard
| Kommentaarid: 367 loe/lisa |
300 |
Meha
03.08.2004 14:42:05
| Kas sa biosis kontrollisid kõik ilusti ära?
| Kommentaarid: 6 loe/lisa |
