praegune kellaaeg 24.10.2026 21:48:39
muku
11.07.2004 02:27:05
F-Secure Antivirus & ZoneAlarm |
damn, ZoneAlarmi uus versioon keeldub installeerumast F-Secure AntiVirusega samasse masinasse. ütleb, et tekkivate ühilduvusprobleemide tõttu asja ei installita
Ilmselt mõlemad firmad üritavad müüa oma terviklahendusi - ZoneAlarm oma Pro versiooni viirustõrjega ja F-Secure oma Internet Security't (AV'le külge poogitud tulemüür)....
Kui inimestel on ZoneAlarmPro'st, F-Secure Internet Security'st ja Norton Internet Security'st (võrdlevaid) kogemusi, siis võiks neid siin jagada ning soovitada, milline neist osta, milline jätta.
Head ja Vead, palun
Märt.
12.07.2004 00:29:39
Tulemüüridest soovitan soojalt hoopis Keriot- osta pole seda vaja...
| Kommentaarid: 29 loe/lisa |
23 |
d3t
13.07.2004 13:59:36
Hmm, kasutan zone alarm pro with web filtering ja norton anty virus 2004...
Testi tulemused:
Security Status: Safe!
You are protected against most common security threats.
Hacker Exposure Check
Description:
Tests your TCP ports for unauthorized Internet connections.
Analysis:
Your computer appears safe from most common intrusions. To learn more about the threats you are protected against, view a detailed analysis of your test results.
Windows Vulnerability Check
Description:
Tests whether basic information, including your PC's network identity, can be seen by hackers.
Analysis:
Your computer's identity is secure. However, this does not mean you are completely safe from all Internet security threats.
Trojan Horse Check
Description:
Attempts to test for access to your computer through methods commonly used by Trojan horses.
Analysis:
Your computer and data are not vulnerable to Trojan horse attacks. However, Trojan horse threats are constantly evolving, and unless you have a personal firewall and current virus protection, you're not completely safe. To learn more about threats you are protected against, view a detailed analysis of your test results.
Antivirus Product Check
Description:
Checks for a current version of a commonly-used virus protection product.
Analysis:
Your computer is running virus protection software and you are at low risk to virus attacks. However, viruses are constantly evolving and you need to keep your virus protection current to stay safe.
Virus Protection Update Check
Description:
If you have a virus protection product on your computer, this test checks the date of your most recent virus protection update. If the updates are more than two weeks old, they are not considered current.
Analysis:
Your virus protection has been updated recently and you are at low risk for virus attacks. However, viruses are constantly evolving, and unless you keep your defenses current, you're not completely safe.
Tulemüüri testi tulemused: Pole pahad või mis?
jah, mis siis ikka, NORTON ANTY VIRUS 2004 ja zone alarm with web filtering on parim, kuigi nortoni tulemüüril pole ka midagi viga aga ma eelistan siiski zone alarmi... odavam ja teeb sama töö ära!
_________________ IsAiUseful.com - tee oma esimesed sammud kohaliku AI suunas
| Kommentaarid: 85 loe/lisa |
72 |
