praegune kellaaeg 11.11.2026 19:38:47
Amfiibinimene
05.07.2004 08:41:10
NetDDE Agent |
| iga kord kui arvuti tööle panen hakkab tööle ja raisk kinni ei lase end panna mida teha
| Kommentaarid: 9 loe/lisa |
9 |
Max Powers
05.07.2004 09:11:05
http://www.microsoft.com/Downloads/details.aspx?displaylang=en&FamilyID=9F7C3381-78AF-4D86-9F3D-62C962A7A33E
Mõneti võiks ka see sind aidata.
Option 2: If you aren't using Network DDE, you can disable the
Network DDE DSDM service, which will prevent this attack from working. Go
to the "Services" administrative control panel application, and set the
"Network DDE DSDM" service to "disabled". A word of caution: Microsoft
Office uses Network DDE to communicate over the network. Disabling this
service may interfere with Microsoft Office operations. Proceed with
caution, and test this configuration in your environment first before
deploying, as with any non-vendor supplied fix. Any other DDE enabled
applications, such as Microsoft Hearts, Clipbook, etc., will not function
properly with this service disabled.
182 |
Amfiibinimene
05.07.2004 09:14:47
| op systeemiks xp
9 |
Max Powers
05.07.2004 09:23:40
| Amfiibinimene kirjutas: |
| op systeemiks xp |
No aga service all asub ta ikkagi ja sealt saab disable valida.
182 |
Amfiibinimene
05.07.2004 09:51:38
| see sai tehtud nüüd vaatan et norton ei anna endale autoprotecti enam peale panna
9 |
