praegune kellaaeg 13.04.2026 05:02:41
wifebeater
02.03.2009 14:26:30
õige küll, XP mixing kernel (KMixer) võib tõesti midagi paha korda saata (krt teab, mida seal täpselt tehaxe), aga Vistas on see WaveRT-ga asendatud, mille saab ASIO v. ALSA taoliselt otseühenduses, ilma processimata tööle panna. USB või Firewire korral see värk loomulikult ei tööta, aga sisseehitatud või siini peal kaardiga funkab küll.
Sain naca targemax:
Contrary to popular belief, the kmixer of Windows 2000 and XP doesn't modify the sound and is thus bitperfect if these four conditions are met:
The PCM/wave volume slider of the mixer (sndvol32.exe) must be set at its maximum. Some start-up applications modify the volume slider (e.g. hardware monitoring tools from Asus).
The player must be compiled for the same architecture that the OS was compiled for - e.g. 32 bit player on a 32 bit OS, 64 bit player on a 64 bit OS. This is the case for the vast majority of installations because the 64 bit version of Windows XP isn't very commonly used.
Applications other than the player mustn't play sounds, otherwise the two output streams will be potentially sample rate converted and mixed.
Applications which are using the soundcard for recording have to use the same sample rate as concurrently running applications which are playing sounds - the soundcard has only one clock generator and hence this limitation arises.
Kui sa neid tingimusi järgid, peaks sul XP-ga ka täpselt see audiost välja tulema, mis failis kirjas on.
V126
02.03.2009 14:29:43
Winamp annab niisuguse teate Error while protsessing frame (FLAC__FILE_DECODER_SEEKABLE_DECODER_ERROR).
Muude failidega saab hakkama küll
wifebeater
V126
03.03.2009 14:29:57
| Failid täiesti korras.
ihvike
04.03.2009 11:30:56
| 24 bit failid? Winampis on defaultina 24 bit mängimise võimalus välja lülitatud. Preferences>Playback.
| Kommentaarid: 12 loe/lisa |
12 |
V126
04.03.2009 12:21:44
| Nii ta ongi ''Ripped in 24-bit/96 kHz | FLAC (seperate tracks)'' Vana Winamp 2,81 ei ole selleks ette nähtud ilmselt, suur tänu.
