| Kommentaarid: 92 loe/lisa |
AJ
| Kommentaarid: 37 loe/lisa |
36 |
SurfData
03.10.2009 20:59:21
tekkinud on ka 640gb STANDARDMÕÕTUDES läpaka ketta artikkel mida järgmine nädal isegi lattu oodatakse
Description WD SCORPIO BLUE 640GB 2.5" SATA 5400RPM
PAIGALDUSTÜÜP Sisemine
MAHT (GB) 640 GB
PÖÖRLEMISKIIRUS 5400 rpm
VAHEMÄLU 8 MB
OTSIMISKIIRUS (ms) 12ms
VÄLINE ANDMEEDASTUSKIIRUS 300 MB/s
SISEMINE ANDMEEDASTUSKIIRUS (MBITS/S) 85MB/s
FORM FACTOR (Hard discs) 2,5"
KÕRGUS 9.5 mm
KETASTE ARV 1
ÜHENDATAVUS Serial ATA II / 300
MÕÕTMED 0.95 x 6.98 x 10.02
KAAL (g) 117
Warranty 3 A
http://www.surfdata.ee/?a=85&ac=WD6400BEVT&ag=1
| Kommentaarid: 84 loe/lisa |
74 |
AJ
29.10.2009 23:44:49
Samsung EcoGreen F2 1.5TB Review
http://www.bit-tech.net/hardware/storage/2009/10/05/samsung-spinpoint-f3-1-5tb-review/1
E.
Samsung Spinpoint F3 1TB Review
http://www.bit-tech.net/hardware/storage/2009/10/06/samsung-spinpoint-f3-1tb-review/1
E.2
Hitachi Unleashes Two Blazing Fast Drives For The Enterprise
http://www.nordichardware.com/news,10052.html
| Hitachi Global Storage Technologies (Hitachi GST) today announced worldwide availability of two new 15,000 RPM Ultrastar hard drives for Tier 0/1, mission-critical, enterprise storage applications. The new drives include the Ultrastar C15K147, Hitachi’s first 15,000 RPM, 2.5-inch 6Gb/s Serial Attached SCSI (SAS) hard drive, and the new 600GB Ultrastar 15K600, the company’s fourth generation 3.5-inch drive with either 6Gb/s SAS or 4Gb/s Fibre Channel Arbitrated Loop (FCAL) interfaces. To help enterprises protect sensitive data and comply with privacy and data protection regulations, Hitachi now offers industry-compliant, self-encrypting, enterprise-class hard drives as an option across all of its 10,000 and 15,000 RPM Ultrastar drives. |
E.3
500GB Per Platter: Three Next-Gen 7,200 RPM Hard Drives
http://www.tomshardware.co.uk/2tb-hdd-7200,review-31718.html
36 |
Degwees
| Kommentaarid: 111 loe/lisa |
101 |
AJ
36 |
denis28
| Kommentaarid: 67 loe/lisa |
AJ
36 |
1dumbpcuser
12.12.2009 11:54:27
Intel Phasing Out SSDs with 50nm Flash
Tomshardware
97 |
AJ
36 |
SurfData
14.12.2009 21:49:35
ohooo...need on küll mõnusalt õhukesed
P.S Kas keegi oskab öelda kas samsungi 2TB ketas on 3 või 4 platteriga?
74 |
AJ
36 |
XYZ
16.12.2009 19:21:05
Oijee mis vana trikk välja kaevatud.... Tuleb meelde, et kunagi 8-tollistel flopydel sai ise sama trikki tehtud, neil oli mäletamisi sektori standardsuurus 128 baiti, kui käsitsi formaatimisparameetrid sai muudetud 1024 baidi peale + sektorite arv rajal korrigeeritud, siis kasvas flopy maht kah märgatavalt.... ja tollal oli see mõnus saavutus
| Kommentaarid: 81 loe/lisa |
12 :: |
56 |
16.12.2009 20:20:04
| XYZ kirjutas: |
Oijee mis vana trikk välja kaevatud.... Tuleb meelde, et kunagi 8-tollistel flopydel sai ise sama trikki tehtud, neil oli mäletamisi sektori standardsuurus 128 baiti, kui käsitsi formaatimisparameetrid sai muudetud 1024 baidi peale + sektorite arv rajal korrigeeritud, siis kasvas flopy maht kah märgatavalt.... ja tollal oli see mõnus saavutus  |
Kõik uus on unustatud vana...või kuidas see lause käiski?
XYZ
16.12.2009 20:41:10
| tomorrow kirjutas: |
| XYZ kirjutas: |
Kõik uus on unustatud vana...või kuidas see lause käiski?  |
vaevaltet mina ainus olen kes mäletab
8-toliised floppyd on muidugi uunikumid aga 720/1.44 flopydest 800/1.6 flopyde tegemine ja kasutamine võiks üsna paljudele tuttav temaatika olla....
12 :: |
56 |
Heineken
17.12.2009 15:56:35
Midagi huvitavat isegi .
| Kommentaarid: 24 loe/lisa |
23 |
Cancer
| Kommentaarid: 13 loe/lisa |
AJ
36 |
Heineken
23.12.2009 03:41:58
Kas see käib ainult WD ketaste kohta või saaks ka mingi suvaline ketas samasse formaati panna ?
Ruumilisa kuluks igalpool ära . Ja kui uue kasti ostuks läheb siis kavatsen Samsung F3 1TB masinasse osta ( lisaks välisele 1TB kettale ) .
23 |
23.12.2009 04:47:51
| Heineken kirjutas: |
Ruumilisa kuluks igalpool ära . Ja kui uue kasti ostuks läheb siis kavatsen Samsung F3 1TB masinasse osta ( lisaks välisele 1TB kettale ) . |
Kõik tootjad hakkavad seda kasutama.Kahjuks mitte täielikult ja kohe, sest see pole väga XP ühilduv ja nende XP kummardajate hala ei jõuaks ära kuulata kui kõik kettad seda meetodit kasutama hakkaks.
Miskipärast artiklist jäi mulje, et vanemate ketaste puhul seda ei toetata.Ju siis mingi muu asi ei võimalda
Vista ja Win7 toetavad seda
SurfData
06.01.2010 14:36:41
Siin jõulude paiku Malaisias kokku kruvitud ketastel on juba klepsud peal selle advanced formati kohta
74 |
AJ
06.01.2010 16:13:03
Seagate launches 640GB notebook drive
http://www.techspot.com/news/37503-seagate-launches-640gb-notebook-drive.html
Seagate pushed out a new device in the Momentus line today, introducing a 2.5" 640GB drive. Aimed at notebooks
that need mass amounts of storage, the 5400RPM drive uses a 2-platter design and sports 8MB of cache, making it at an impressive addition to their mobile storage lineup.
They aren't the first to have a 640GB notebook drive, with Western Digital beating them to the punch by several months. Both drives have comparable specifications, so there's nothing spectacular about Seagate's release. We can expect the Momentus 5400.7 to sell for around $120, comparable to the Western Digital Blue Scorpio.
These two vendors are now the only ones to offer 640GB 2.5" drives. Will others move in as well, or instead reach for the loftier goal of 1TB? As demand increases for higher-capacity SSDs, we must wonder if SSDs or traditional disks will be the R&D priority for this year. |
36 |
