uus teema   vasta Raud »  Kõvad kettad »  Lite-On'i kirjutajaga probleem märgi kõik teemad loetuks
mine lehele eelmine  1, 2
mezzanine
sõnum 24.08.2003 20:46:10 vasta tsitaadiga
Niih, sain Nero tegevusest paar logifaili ka, aga minu tagasihoidlik mõistus nendest küll välja ei loe kus kandis kala ujub...
17:43:06 #20 Phase 32 File dlgbrnst.cpp, Line 1571
Simulation started at 32x (4 800 KB/s)
17:43:06 #21 Text 0 File ThreadedTransferInterface.cpp, Line 1950
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
17:43:06 #22 Text 0 File Mmc.cpp, Line 17088
Set BUFE: supported -> ON , SMART-BURN : ON
17:43:22 #23 SCSI -1135 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x024A0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x04 0xD8 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
17:43:22 #24 MMC -1135 File Writer.cpp, Line 342
Write error
17:43:22 #25 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
17:43:23 #26 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
17:43:23 #27 CDR -201 File WriterStatus.cpp, Line 147
Invalid write state
17:43:23 #28 TRANSFER -18 File WriterStatus.cpp, Line 147
Could not perform EndTrack
17:43:30 #29 Phase 34 File dlgbrnst.cpp, Line 1571
Simulation failed at 32x (4 800 KB/s)
17:43:30 #30 Text 0 File Scsicmd.cpp, Line 402
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
freestyler
sõnum 27.08.2003 18:27:07 vasta tsitaadiga
link :: Aspicheck
Logist ei oska miskit arvata, aga ...
Mingi jama võib tekkida kui mitu erinevat kirjutamisprogrammi korraga installitud on.
Ja veel peaks kontrollima kas ASPI on korralikult installitud
VR53
VR53
sõnum 27.08.2003 18:38:22 vasta tsitaadiga
mezzanine kirjutas:
Ega's midagi - lasin igaks juhuks puhastusplaadiga üle
Seda poleks tohtinud kindlasti teha! Sellega keerad oma läätse persse!
Kas teistes arvutites käitub samamoodi?
Kas Nero 5-5.5 või 6? Endal solkis 6 ka ühe tooriku ära, tea ehk on selle viga...
DMA on ikka peal? Smart-burn? Vähetõenäoline, et need ise peaksid maha minema, aga tasuks kontrollida.
Kui on garantii - vii sinna, vastasel juhul võid ise piiritusega läätse puhastada proovida...
Kommentaarid: 843 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 636
Romb
Bännitud
Romb
sõnum 27.08.2003 19:45:35 vasta tsitaadiga
CMaster kirjutas:
mezzanine kirjutas:
Seda poleks tohtinud kindlasti teha! Sellega keerad oma läätse <b>piixu</b>!
Puhastusplaatide suhtes nõus. Viimasel ajal küll harva, aga paar aastat tagasi toodi päris palju peale neid remonti ja oli ka neid, kus laser vahetusse läks.
Piirituse suhtes olen kriitiline. Proovige peeglil peal üks koht piiritusega ära puhastada. Kui ära kuivab, jääb tuhmiks. Pärast tuleb kuivalt poleerida. Ohutum on kuiva vatiga tiku otsas(kui liksi pole sisse valanud, tolmu pühib ära). Kuigi soovitaks suruõhu ballooniga, no aga see liiga kallis.
Kuid päris ausalt öelda, kui ikka kogemusi ei ole, siis võid väga vabalt ka tuksi keerata. Annad spetsialistile teha, on tulemus garanteeritud ja ega ta nii palju ka maksa...
HappyyChicken
sõnum 04.09.2003 15:13:17 vasta tsitaadiga
mul sama kirjutaja 3 erinevat värvi saab sellel cd kirjutajal olla roheline, punane ja orantsikas kollane roheline on siis kui ta loeb plaadilt midagi kui kirjutab siis on punane ja kui kolakas orants siis se tähendab seda et arvuti ei jõudnud kirjutajale järgi näitkeks kui väga palju mõtleb siis jääb ootama muidu vanemad cd kirjutajad rikuvad cd kohe ära kui arvuti mõtlema akkab ni et uuematel on kaitse peal se orantsikas kollane tuli ni et siis võib olla se kaitse rikkis kui sul siis p-e-r-s-e läheb
Mart
Mart
sõnum 07.09.2003 22:12:10 vasta tsitaadiga
HappyyChicken kirjutas:
hmm... rohelist pole ma küll veel kunagi näinud icon_confused.gif icon_rolleyes.gif
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 4
cbr
cbr
sõnum 08.09.2003 23:40:18 vasta tsitaadiga
Pane mingi kirjutatud plaat sisse ja hakka seda lugema. Küll näed!
Kommentaarid: 48 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 39
Mart
Mart
sõnum 09.09.2003 16:10:13 vasta tsitaadiga
Cobra[EST] kirjutas:
asoo... see kollane rohekas icon_smile.gif . Pole seda lihtsalt ennem märganud ... icon_rolleyes.gif icon_redface.gif
Mart
Mart
sõnum 04.05.2004 14:42:11 vasta tsitaadiga
Oijah. Jälle selle kirjutajaga jamad. Nimelt, kui audio plaati teen on kõik korras, aga kui mingit muud plaati teen, siis viskab ette, nii umbes 10% peal, Communication failure.
väike abi kuluks ära...
HacaX
HacaX
sõnum 04.05.2004 22:55:08 vasta tsitaadiga
Vaata juhtmestik üle. Endal oli kah vahepeal säärane asi (mul ei jõudnudki kuskile, vaid andis iga plaadi peale kohe kribamise algul selle errori). Sai siis *kõik* röstimisproged masinast maha lastud ning juhtmed üle vaadatud. Sealtpeale asi jookseb ning säärast prbleemi pole enam esinenud.
IMO & GPLed
Mart
Mart
sõnum 05.05.2004 13:17:56 vasta tsitaadiga
HacaX kirjutas:
fakit, mul nii 2 aastat tagasi ostetud arvuti, millel k-garantii. icon_mad.gif
vahepeal sain neilt kuidagi kleepsu, siis sai kõike näppida, kuid siis kärssas toiteplokk (väidetavalt ka emaplaat) ning oli vaja garantiisse viia ja nüüd jälle see kleeps peal, mida peal toiteploki ja emaplaadi mahapõlemist eemaldada ei tahaks. icon_rolleyes.gif
HacaX
HacaX
sõnum 05.05.2004 16:36:42 vasta tsitaadiga
Khmmm... kirjutamissoft - Nero, CDRWin, Alcohol 120%, teine CDRWin, DeepBurner... ja see pole vist isegi kõik mis tol hetkel raalis pesitses icon_smile.gif
IMO & GPLed
Mart
Mart
sõnum 15.05.2004 11:29:31 vasta tsitaadiga
Lasin kõik kirjutamisega seotud programmid maha ja siis peale ainult Nero (proovisin nii Nero 5 kui ka Nero 6). Kuid probleem oli ikka sama, viskas seda sama errorit.
Juhtmestikus ei saa vast viga olla, sest ta teeb audio plaate korralikult (kuigi on juhtunud, et mõnda audio plaati, mis on selle kirjutajaga kirjutatud, ei mängi mõni cd-mängija) ning hakkab data plaate algul kirjutama, kuni tuleb error (nii 11% peal tavaliselt) Muidu vaatasin ka juhtmestiku üle, kõik paistis korras olevat.
Garantii peaks ka läbi olema kirjutajal, kuna lepingus oli kirjas, et kirjutajal jms 1 aasta. Kuid sõbral oli ka K-arvutist ostetud arvuti ning sai peale kahte aastat ka veel CD-ROMi vahetatud. icon_rolleyes.gif Kahtlane värk seal K-arvutis üldse. icon_confused.gif
Oskab äkki keegi veel kuidagi aidata...
DigeBeni
DigeBeni
sõnum 17.05.2004 12:00:02 vasta tsitaadiga
... põmst' on pretensiooni esitamise aeg 2 aastat, võid ju õnne proovida ...
Mart
Mart
sõnum 17.05.2004 14:23:08 vasta tsitaadiga
aga kas muidu selline asi võib juhtuda, et viin garantiisse ning seal vaadatakse ning leitakse, et tõesti, on katki, kuid siis öeldakse, et kahjuks garantii läbi, maksa meile pappi "kulutatud aja" vms eest (nagu k-saluunil ikka kombeks)? icon_rolleyes.gif
DigeBeni
DigeBeni
sõnum 18.05.2004 09:13:48 vasta tsitaadiga
... nuh, siis võid küsida, et mille alusel nad raha nõuavad, kui EV seadusega on sätestatud seesugusele kaubale 2 aastat pretensiooni esitamise aega !?
... kui on huvi, siis siia teemasse:
https://foorum.hinnavaatlus.ee/viewtopic.php?t=48907
... on voyager_est kogunud tarbija õigustest väikse ülevaate ...
H_K
H_K
sõnum 18.05.2004 09:29:25 vasta tsitaadiga
kirjutaja LG 52x32x52x (softiks Nero 5), arvuti AMD, 512 RAM, Nforce2 baasil jne. norm arvuti. ca 4 kuud vana.
Iga 3 plaat jäi seisma järjest kirjutamisel ja arvuti jooksis kinni - aitas ainult nupust restart.
Järeldasin, et asi kuumeneb järjest kirjutamisel üle, nüüdsest 2 plaati järjest siis üks
suitsupaus ca 2 min. ja kirjutab kolmanda ilusti.
Kuidas kirjutada Neroga 800 MB plaadile, stabiilselt näitab, et 76 MB ainult vaba ruumi ja keeldub tegemast.
toorikuks TDK 800MB 40x, kleeps peal soovitab Nero't ja puha.
Kommentaarid: 53 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 51
DigeBeni
DigeBeni
sõnum 18.05.2004 09:32:35 vasta tsitaadiga
H_K, kasutame ikka otsingut kah:
https://foorum.hinnavaatlus.ee/viewtopic.php?t=31331
Alan B'Stard
Alan B'Stard
sõnum 18.05.2004 11:31:49 vasta tsitaadiga
DigeBeni kirjutas:
Seal on kirjas, et kui 6 kuud möödas, peab tootmisdefekti tõestama tarbija, ehk ekspertiis on ilmselt tarbija kulul ja tulemused pole ette teada...
Kommentaarid: 27 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 24
DigeBeni
DigeBeni
sõnum 18.05.2004 11:47:05 vasta tsitaadiga
Alan B'Stard kirjutas:
... eks seda annab väänata nii, kuidas mõistus peale hakkab, kuid kui ei hakka, siis tuleb tõepoolest rahakotti kergendada, mis muud ...
H_K
H_K
sõnum 17.06.2004 12:58:24 vasta tsitaadiga
praetor
praetor
sõnum 26.11.2007 18:29:28 vasta tsitaadiga
Vana teema, aga ei leidnud otsingust ka vastust omale. Suht OK masin (2200+prose 512ram) ja sai ostetud talle Samsungi dvd-kirjutaja ja verbatimi toorikud. Esimene plaat läks kohe pekki... Nero andis 51% peal errori "could not perform endtrack." Siis sai proovitud mingit Acme toorikut.. jälle sama jama. Käisin vahetasin Samsungi NEC kirjutaja vastu ringi... 1. plaadi kirjutas ilusti, aga siis edasi jällegi sama kamm. Olenemata toorikust ütleb kogu aeg 51% could not perform endtrack. Kirjutamise kiirust olen ka proovinud alla võtta... ei aita. Keegi oskab nõu anda icon_sad.gif ?
Kommentaarid: 220 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 195
uus teema   vasta Raud »  Kõvad kettad »  Lite-On'i kirjutajaga probleem mine lehele eelmine  1, 2
