Cul
25.02.2009 10:00:02
Üks kommentaar selle sama Slashdoti artikli alt. Minumeelest peab suht paika.
From what I've seen, there are very little changes in the audio layer from Vista to Windows 7. Now in Vista, all the audio DRM stuff relates to protected audio path and only matters if you are playing a DRM's file through a player that uses it. It has no effect, whatsoever, on media you produce. I say this as someone who has actually done plenty of audio production on a Vista system.
Now as for the audio thing it sounds like one or maybe both of two possibilities:
1) Crappy drivers. Windows 7 is still in the beta stage, and thus so are drivers for it. Some companies are rather fast with drivers for that and they are essentially release quality. Other companies suck at the drivers and thus have poor (or no) drivers out. Check a hardware board and you'll find all kinds of people saying "Where can I get Windows 7 drivers for my soundcard?"
2) Crappy hardware. Not all soundcards are created equal. You will find professional soundcards on the market that can handle 96 simultaneous inputs, 96 simultaneous outputs all at 24-bit 96kHz without dropping a sample. You'll also find cheap consumer cards that can't even do what they claim on the box. One thing that cheap cards have problems with more often than they should is operating full duplex, meaning outputting sound and inputting it at the same time. Some just plain can't do it, others can do it but have to cut the input or output sample rate, others are just flaky. Just because a soundcard has inputs, doesn't mean it deals with them well, since that is a feature many users don't make use of.
So I'd want to see this done in a properly controlled setup: It a quality, current, soundcard that is known to have good input and output quality, and known to have no issues doing both at the same time. Also ensure there are beta drives out from the company that don't state any major problems. Put it in a system and try it in Vista and make sure it works. Then Put Windows 7 on that same system, and try it again. If there's a problem, ok well then maybe there is something to this (though I'd still be interested in drivers). If not, and I suspect not, then this guy needs to STFU.
I get more than a little tired of morons who have a problem on their system and instantly run and blame the OS. No, it is often NOT the OS's fault. I get even more tried of all the FUD surrounding MS and DRM. I heard all this crap about Vista's audio DRM and how it was going to not let you control your own music. Well guess what? It is all 100% bullshit. You can record in Vista, you can mix and master in Vista, you can encode to non-DRM's format, including MS's own Windows Media format (which has no DRM by default, you have to set it up yourself). Vista doesn't at all mind or interfere.
This really strikes me as more of the same. I mean the guy is clearly a moron. He goes and downloads a crack for CS4, let's not play make believe like that's what he wasn't doing, and it doesn't work. So he blames Windows? What the hell? Then a random rant about audio. Ya, I'm thinking no.
I can't for sure say he's wrong, I've not yet test Windows 7 my self, but his story has all the markings of BS.
_________________ Kui ma eksin siis ärge kõvasti lööge.
Paar pilti
Natuke juttu |
| Kommentaarid: 4 loe/lisa |
soovija
25.02.2009 13:47:32
| Aamen selle peale. Põhimõtteliselt 90% juhtudest on tihendi viga või selle julla viga, mis on tooli ja monitori vahel. Kontrollige ennast ja vähem kisa. Asi töötab ilusti kui veidikene osata lugeda ja näha. Kes tahab vinguda, saab vinguda kõige kallal. Rahulikult lähenedes polegi asi nii hull.
85 |
RainbowD
01.03.2009 21:52:27
Minu meelest on kõik unustanud XP algus aja! Siis räägiti et Win. 98 on parim ja XP täiesti mõttetu, et arvutid ei jõua jooksutada mängud ja programmid tööle ei hakka ja siis veel meeletu draiverite probleem et miski õieti ei tööta!
Nüüd siis XP see parim ja Vista ja 7 ei kõlba kuhugi!
Jah uued OP süsteemid nõuavad paremat arvutit ja suuremat rahakotti kuid areng peab toimuma ja kohe perfektset asja loota ju ei saa!
Nii et uuendage oma riistvara ning ärge hoidke kokku siis ehk on teil ka paremaid sõnu rääkida näiteks Vista kohta!
Kui leiate tõrkeid oma OP süsteemis siis teavitage neist selle loojale siis osatakse nendega ka tegeleda!
Väikest mõtlemis ainet!!!
| Kommentaarid: 56 loe/lisa |
54 |
Degwees
03.03.2009 05:30:23
| Minu arust on iga Windowsi üle vingutud. Ma olen üpris kindel, et Windows 7 paneb pika puuga Vistale ja XP-le, rääkimata "heast 98st".
| Kommentaarid: 111 loe/lisa |
101 |
29.03.2009 16:05:14
| Degwees kirjutas: |
| Minu arust on iga Windowsi üle vingutud. Ma olen üpris kindel, et Windows 7 paneb pika puuga Vistale ja XP-le, rääkimata "heast 98st". |
Kõik sõltub rauast, kusjuures...
Minu raud üllatas mind meeldivalt üleminekul: XP Pro -> Vista Business x64 ca ~ +1,5 K võrra 3Dmark06 all
(Oli enda jaokski üllatus)
viimati muutis Etz 30.03.2009 14:48:38, muudetud 1 kord |
196 |
M00t
29.03.2009 17:50:35
| Etz, aga SP1'ga?
| Kommentaarid: 77 loe/lisa |
73 |
maxman007
29.03.2009 19:48:31
Kokkuvõtteks ikkagi on Windows 7 sitaks parem kui xp ja vista ja muu pläust
| Kommentaarid: 19 loe/lisa |
19 |
30.03.2009 14:49:05
| lu1de kirjutas: |
| Etz, aga SP1'ga? |
Ongi SP1 peal...
Põle endal teistsugust installikat...
196 |
heretic666
09.04.2009 23:36:59
Kas see kestis ka mitu-mitu aastat ?
| Kommentaarid: 73 loe/lisa |
RainbowD
09.04.2009 23:57:26
| no see kestis ikka päris pikka aega enne kui kõik korralikult toimima hakkas! Mõtle kas või seda kui kaua lubati sp2 välja lasta mis paljud probleemid lahendama pidi ja millal see lõpuks tuli!
54 |
10.04.2009 09:04:07
| RainbowD: Areng XP - XP SP1 - XP SP2 toimus umbes 3-e aasta jooksul. Mina ostsin endale XP SP2 Wondowsi aastal 2004 ja selleks ajaks oli SP2 variant juba tükk aega olemas olnud. Küll oli pikk vahe, enne kui SP3 ilmus.
211 |
10.04.2009 11:04:16
| tahanteada kirjutas: |
| RainbowD: Areng XP - XP SP1 - XP SP2 toimus umbes 3-e aasta jooksul. Mina ostsin endale XP SP2 Wondowsi aastal 2004 ja selleks ajaks oli SP2 variant juba tükk aega olemas olnud. Küll oli pikk vahe, enne kui SP3 ilmus. |
Ja ka siiamaani on olemas inimesi, kes on sügavalt veendunud et kasvõi SP2 on kurjast, rääkimata SP3'st
| Kommentaarid: 85 loe/lisa |
10.04.2009 11:11:27
| mikk36: OT: Niipalju on meeles, et XP ja XP SP1-ga olid tõesti mingeid probleeme. Ja seetõttu sel ajal ma ka meelega Win Me peal olin. Ja mul töötas ka Win Me ilma ühegi probleemita. Kui oli näha, et XP, koos SP2-ga töötab korralikult ja ilma probleemideta, siis saigi raha kulutatud ja XP Proff (Retail) ära ostetud. Ning minu XP SP2 versioon on mul siiani täiesti edukalt kasutuses ja töötab senini, kuni saab raha eest Win 7-t osta.
211 |
pots4t4j4
24.05.2009 13:40:35
Proovisin ka seda win7 käkki 2 päeva ja täitsa fail peaks ütlema
401 |
soovija
24.05.2009 13:42:11
| No pigem on sinus asi. Töötab teine väga kiiresti ja edukalt.
85 |
pots4t4j4
24.05.2009 13:43:21
| jep tõesti on see minu asi kui kõik asjad on nii ebardlikuks teha et kasutada ei kannata asi pole kiiruses või mitte jooksmises vaid ajuvabades lahendustes
401 |
RainbowD
24.05.2009 15:32:35
| Inimene on harjumuste ori!!!
54 |
24.05.2009 15:39:20
Kui muudatusi poleks, siis elaksime praegu DOS-i ja Win1.0 ajastul.
Postitatud mobile device
211 |
plekkpurk
31.05.2009 15:15:36
| Minu arust on juba enne Vista tulekut pidevalt tiirlenud sellised "piraatide hirmujutud", üks jaburam kui teine, et küll pannakse uutesse emaplaatidesse kiibid, mis ei lase allalaetud filme vaadata, küll on os'is mingid jälitusprogred sees ja nii kui Britney lugusid tõmbad, on kapo ukse taga ja sada muud asja. Elu on näidanud, et enamik sellistest juttudest on alusetu ärplemine. Ja isegi kui antud seik tõele vastab siis pärast meediatähelepanu võetakse vast lõppversioonist need asjad välja. Ja üleüldse oleks ju MS'i poolt puhas debiilsus ise oma konkurentisvõimet nudida. Huvitav, kuidas nad kavatsevad siis profitasemel helitöötluses konkurentsi pakkuda Applele kel selles sfääris on niigi juba lõviosa turust? Absurd.
| Kommentaarid: 8 loe/lisa |
pkwild618
10.06.2009 01:00:59
To plekkpurk: õige jutt. Muide tarkvara sellise kiibi keelamiseks tuleks vist peale esimese emaplaadi tootmist välja Pealegi kui Windows kuskil seda ei maini, et ta tahab Windowsi kasutajat luurata (need license värgid linnuke i agree jms. pläma), siis oleks see kriminaalkorras karistatav tegu .
| Kommentaarid: 38 loe/lisa |
14 :: |
d3t
23.06.2009 13:10:29
Microsoft ignoreerib jätkuvalt betatestijaid!
Ma olen korduvalt juhtinud tähelepanu Windows 7 pesitsevale turvaaugule, mis on nüüdseks tänu Microsofti ignorantsusele koos lähtekoodiga välja lastud. Kõik vead mis on sellekohta Microsoft Connectis avatud on suletud kirjeldusega By design.
Loe edasi
_________________ IsAiUseful.com - tee oma esimesed sammud kohaliku AI suunas
72 |
24.06.2009 12:10:12
A"rge p6dege nende m6ne pisikese turvaaugu t6ttu, pidem hoide po"ialt, et lubatud Finaal tuleks sygisel va"lja.
Ning suur osa esmastest aukudest parandatakse nagunii yhtse paketina. Keegi ei raiska aega ega raha mingi yksiku koodiriba lappimiseks.
Ja samuti ka"tuvad ka k6ik konkurendid, olgu selleks Mac vms, et parandused ilmuvad paketina.
211 |
xtr
06.08.2009 00:08:21
| RainbowD kirjutas: |
| Minu meelest on kõik unustanud XP algus aja! Siis räägiti et Win. 98 on parim ja XP täiesti mõttetu/---/ |
Minumeelest räägiti siis, et Windows 2000 on parim Isegi sai 2k pealt XP-le minemisega kõvasti venitatud
_________________ M: Magic Mouse + Keyboard, MX Master 3S
M: 16GB DDR4, 1TB SSD |
| Kommentaarid: 331 loe/lisa |
273 |
Look Right
Anna vin
11.08.2009 21:40:43
Ja praegu oled veel xp peal? Või venitasid ja venitasid ja läksid Vistale üle?
Mul igatahes küll plaan 7 peale suhtkohe kohe peale väljatulekut üle minna. Viimasega nii harjunud, et xp'd ei taha enam näha ka
_________________ Ehitusprojektid ja konstruktiivsed lahendused HV kasutajatele soodsamalt
M: Zafira A/Astra G põhjakaitse - 30€ |
18 |
xtr
12.08.2009 13:18:04
Praegu olen mõne masinaga XP peal ja mõne masinaga 7 peal. Vista peale minekuga venitamise kohta ei saagi öelda venitamine, sest mul ei olnudki plaanis Vista peale minna
273 |
hanz
23.08.2009 20:57:39
| What was claimed? Well, some guy decided that he wanted to crack his (legally purchased, no doubt) copy of Photoshop on his Windows 7 install. Windows 7 then sprung into life to break his crack, defend Photoshop's virtue against his unwelcome advances, protect a load of random DLLs from deletion, and open up the firewall so that Adobe could see that he was up to no good. Yup yup. To add insult to injury, Windows 7 then crippled the dude's sound card. Or something. |
| xtr kirjutas: |
Minumeelest räägiti siis, et Windows 2000 on parim Isegi sai 2k pealt XP-le minemisega kõvasti venitatud  |
seda on iga uue Windowsi kohta räägitud, 3.1 vs 95 ei mäleta, aga kui 98 tuli välja, siis oli ka tohutult veendunud 95 kasutajaid. Ainus Windows, mis on siiani üldtunnustatult väga halb on Windows Me.
| taikonaut kirjutas: |
| Mul igatahes küll plaan 7 peale suhtkohe kohe peale väljatulekut üle minna. |
sama siin. seda muidugi põhiliselt seetõttu, et nagunii peaks lähiajal fresh installi tegema, kuna XP on jälle kole palju igasugust saasta kogunud ja aeglaseks jäänud, aga ka esimesed kokkupuute 7mega on olnud positiivsed
_________________ Lahedad mängud  |
| Kommentaarid: 7 loe/lisa |
