praegune kellaaeg 24.04.2026 16:21:22
Dumb(_;_)
09.08.2004 12:36:48
AOAfoorumis on üleval moditud bios Epoxile, kus pinget kuni 1,8 peale tõsta saab.
EPoX Tech sealsamas küll hoiatab liigse pinge 'lisaefektide' eest:
The options are there in BIOS as the BIOS has this option hidden, but the reason for that is that A64 as a 0.13 SOI part unless cooled by water, TEC or phase change will suffer a similar fate to a Northwood or Prescott at high voltage (as http://www.over****ers.co.uk's Gibbo invented the term Premature Northwood Death Syndrome). Hence the BIOS has the option left out although the dual buck phase arrangement has this offset as an option.
So yes - this is there and useable - but please do be careful as I know you love your CPU's and boards. If you are going to run this please ensure - 1. Good CPU cooling and 2. You put your powerpack's little blue heatsinks on your PWM or 8KDA3 series board rather than your VGA card. |
Esimesed kasutajate kommentaarid tunduvad olevat positiivsed...
| Kommentaarid: 60 loe/lisa |
55 |
