Evil14
25.08.2008 22:06:17
jap, täpselt sama jama mul.
| Kommentaarid: 224 loe/lisa |
195 |
libe
kvaliteetne mees
25.08.2008 22:48:47
irwe kohe annan video
kaadrisagedus videol oli 24-29FPS, kuid kui video salvestamise katki jätsin, siis kogu liikumine oli sama, ainult kiirem
õigemini 1680x1050@4xAA alla 60fps ei langenud ja mul oli vertical sync peal 60hz
video tuleb mingi 150MB ja mõne aja pärast
umbes 00:18 peaks asi kohal olema
http://www.hvpos.org/praht/nfs.mkv
Opening source files
G:\Videod\nfs 2008-08-25 23-12-05-51.avi
G:\Videod\nfs 2008-08-25 23-14-32-83.avi
General
Complete name : G:\Videod\nfs 2008-08-25 23-12-05-51.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 3.91 GiB
Duration : 4mn 54s
Overal bit rate : 114 Mbps
Video
Format : FRAPS
Codec ID : FPS1
Duration : 2mn 27s
Bit rate : 226 Mbps
Width : 1680 pixels
Height : 1050 pixels
Display aspect ratio : 1.600
Frame rate : 30.000 fps
Resolution : 24 bits
Bits/(Pixel*Frame) : 4.276
Stream size : 3.88 GiB
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Unsigned
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 4mn 54s
Bit rate mode : Constant
Bit rate : 1536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 27.0 MiB
Demux MKV, MP4, AVI, MOV and DIVX files
Preparer: Demux MKV, MP4, AVI, MOV and DIVX files
"E:\videod\StaxRip\Settings\Applications\VirtualDubMod\VirtualDubMod.exe" /s"G:\Videod\nfs 2008-08-25 23-12-05-51_Demux.vcf" /x
Filters
AVISource("G:\Videod\nfs 2008-08-25 23-12-05-51.avi","G:\Videod\nfs 2008-08-25 23-14-32-83.avi",audio=false)
Crop(0,6,-0,-4)
ConvertToYV12()
Audio Encoding
"E:\videod\StaxRip\Settings\Applications\BeSweet\BeSweet.exe" -core( -input "G:\Videod\nfs 2008-08-25 23-12-05-51.wav" -output "G:\Videod\nfs 2008-08-25 23-12-05-51_AudioOutput.mp3" ) -azid( -c normal -L -3db ) -ota( -d 0 -hybridgain ) -lame( -v --vbr-new -V 5 -b 32 )
Visit DSPguru's Homepage at :
http://DSPguru.doom9.net/
Audio Encoding Statistics
Start: 23:20:55
End: 23:21:00
Duration: 00:00:04
Speed: 1372 fps
Bitrate: 84,02 kbps
Video Bitrate: 5486 -> 5530
x264
"E:\videod\StaxRip\Settings\Applications\x264\x264.exe" --pass 1 --bitrate 5530 --stats "G:\Videod\nfs.stats" --bframes 16 --b-pyramid --direct auto --filter -2:-1 --merange 12 --threads auto --progress --no-psnr --no-ssim --subme 1 --partitions none --me dia --output NUL "G:\Videod\nfs.avs"
avis [info]: 1680x1040 @ 30.00 fps (6729 frames)
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 PHADD SSE4 Cache64
x264 [info]: slice I:32 Avg QP:23.34 size: 81243
x264 [info]: slice P:4407 Avg QP:27.66 size: 30097
x264 [info]: slice B:2290 Avg QP:25.44 size: 11182
x264 [info]: mb I I16..4: 56.5% 0.0% 43.5%
x264 [info]: mb P I16..4: 32.0% 0.0% 0.0% P16..4: 33.3% 0.0% 0.0% 0.0% 0.0% skip:34.6%
x264 [info]: mb B I16..4: 5.3% 0.0% 0.0% B16..8: 17.5% 0.0% 0.0% direct: 8.3% skip:68.9%
x264 [info]: final ratefactor: 26.72
x264 [info]: direct mvs spatial:99.0% temporal:1.0%
x264 [info]: kb/s:5736.8
encoded 6729 frames, 19.59 fps, 5737.01 kb/s
x264 Statistics
Start: 23:21:00
End: 23:26:44
Duration: 00:05:44
x264 Second Pass
"E:\videod\StaxRip\Settings\Applications\x264\x264.exe" --pass 2 --bitrate 5530 --stats "G:\Videod\nfs.stats" --ref 3 --bframes 16 --b-pyramid --weightb --direct auto --filter -2:-1 --subme 6 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --trellis 1 --me umh --merange 12 --threads auto --progress --no-psnr --no-ssim --output "G:\Videod\nfs_EncoderOutput.264" "G:\Videod\nfs.avs"
x264 [info]: slice I:32 Avg QP:22.41 size: 85357
x264 [info]: slice P:4407 Avg QP:26.18 size: 30336
x264 [info]: slice B:2290 Avg QP:27.61 size: 8354
x264 [info]: mb I I16..4: 30.0% 49.1% 20.9%
x264 [info]: mb P I16..4: 13.0% 18.3% 2.3% P16..4: 28.4% 6.9% 2.9% 0.0% 0.0% skip:28.2%
x264 [info]: mb B I16..4: 4.5% 0.0% 0.0% B16..8: 18.0% 1.4% 1.1% direct: 2.0% skip:73.1%
x264 [info]: 8x8 transform intra:50.9% inter:63.1%
x264 [info]: direct mvs spatial:88.3% temporal:11.7%
x264 [info]: ref P 73.9% 14.8% 11.3%
x264 [info]: ref B 80.1% 19.9%
x264 [info]: kb/s:5548.0
encoded 6729 frames, 8.82 fps, 5548.22 kb/s
x264 Second Pass Statistics
Start: 23:26:44
End: 23:39:28
Duration: 00:12:44
Muxing
"C:\Program Files\MKVtoolnix\mkvmerge.exe" -o "G:\Videod\nfs.mkv" --noaudio --nosubs --default-duration 0:30.000fps "G:\Videod\nfs_EncoderOutput.264" --language 0:est --track-name "0:Estonian" "G:\Videod\nfs 2008-08-25 23-12-05-51_AudioOutput.mp3" --engage keep_bitstream_ar_info
mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:13
'G:\Videod\nfs_EncoderOutput.264': Using the AVC/h.264 ES demultiplexer.
'G:\Videod\nfs 2008-08-25 23-12-05-51_AudioOutput.mp3': Using the MP2/MP3 demultiplexer.
'G:\Videod\nfs_EncoderOutput.264' track 0: Using the MPEG-4 part 10 ES video output module.
'G:\Videod\nfs 2008-08-25 23-12-05-51_AudioOutput.mp3' track 0: Using the MPEG audio output module.
The file 'G:\Videod\nfs.mkv' has been opened for writing.
The cue entries (the index) are being written...
Muxing took 3 seconds.
Muxing Statistics
Start: 23:39:28
End: 23:39:32
Duration: 00:00:03
Speed: 1906 fps
Overall Statistics
Start: 23:20:55
End: 23:39:32
Duration: 00:18:36
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
hondaa
25.08.2008 22:52:39
| puik17 kirjutas: |
Üsna nüri kvaliteet, aga www.zone.ee/zz1 on olemas.
Esimene video peaks olema sujuv sõit ja teine, väljastvaates on siis nö värinaga,
lõpus on näha, et kui gaasi vabastan, siis läheb sujuvaks.
Ja kui see ongi gameplay efekt, no hea töö EA  |
vahelduseks võiks näiteks vähem pirtsutada ja EA rahule jätta, kui sa niikuinii tead, et tolle toodang sulle ei kõlba
| Kommentaarid: 24 loe/lisa |
24 |
puik17
25.08.2008 22:58:38
Sinu probleem ei tohiks see väga olla, et mulle selle firma juures midagi ei meeldi.
Üleüldse Pro Street on EA mängudest siiamaani minujaoks kõige sitem.
Ma ei ole väitnud, et kõik EA mängud halvasti tehtud on.
| Kommentaarid: 79 loe/lisa |
75 |
libe
kvaliteetne mees
25.08.2008 23:23:26
video kohal ja see sinu jant on gameplay feature
et paremini sõita, pead kaamerat vahetama või ümber harjuma, mitte inguma
softis
26.08.2008 07:54:49
puik17, wat?
Video põhjal see värin nüüd üldse nii hull polnud, kui sa kirjeldasid. Ma ootasin, et pilt ikka tuntavalt hüpleb ja tõmbleb...
Harju ära, see on gameplay efekt
| Kommentaarid: 21 loe/lisa |
21 |
puik17
26.08.2008 09:33:44
Videos ei ole vägahästi aru saada jah.
libe, videot ei saa vaadata, ilmselt pole sobivat pleierit või koodekit.
No seljuhul tuleb ära harjuda sellega
75 |
libe
kvaliteetne mees
26.08.2008 20:36:51
| puik17 kirjutas: |
No seljuhul tuleb ära harjuda sellega  |
www.videolan.org
RKsilver_old
02.10.2008 11:32:17
Tere, kas keegi oskab öelda miks see mäng mul töötada eriti ei soovi..
läppariks hp dv5235ea
vista ultimate 32bit
kõige uuemad driverid
2gb ram
1.6ghz core duo protsessor
120gb ketas
intel gma 950 integreeritud graafikakaart
et, iga mäng mida mängida olen proovinud, on töötanud, isegi colin macrae rally 2005..
aga selle mänguga see mure, et kui resolutsioon on 640xXXX siis ma saan mängida ca 10 sekundit kui ta viskab mind desktopile.
ning kirjutab et mingi APPcrash..
kui panen reso khe 800 või 1024 peale siis viskab kohe välja kui üritan mängima hakata ...
lasin peale kah 1.1 patchi aga ikka sama asi ..
nõuanded oleksid teretulnud..
isegi minu läpparist natuke lahjem läppar
nimelt peaaegu sama läppar aga gma 900 graafika kaardiga läppar saab seda mängu mängida : /
| Kommentaarid: 9 loe/lisa |
9 |
weasel
02.10.2008 11:33:54
Ma ostsin mängule (PS3 versioonile) need autode extender packid (2tk). Lasin peale, aga carlotti neid ei ilmu, küll aga on näiteks vastastel nüüd need autod käes.
_________________ PSN: weaselEST |
| Kommentaarid: 38 loe/lisa |
hondaa
02.10.2008 13:45:56
gallardo-l ja muudel sellisetel sõidavad vastased ka ilma ostmata
24 |
weasel
02.10.2008 13:58:26
| hondaa kirjutas: |
gallardo-l ja muudel sellisetel sõidavad vastased ka ilma ostmata  |
Pidasin silma Porsche GT3 RS-i, Carrera GT-d jne. Ja ega ma neid vastastele ei ostnud. Uuringi, et kas mäng peab 100% läbi olema, et ma neid carlotis näeksin.
RKsilver_old
04.10.2008 17:47:01
Nuh, targad, keegi ei oska aidata siis ?
9 |
t6nn_k
05.10.2008 16:17:02
| osta uus arvuti
| Kommentaarid: 16 loe/lisa |
RKsilver_old
05.10.2008 18:27:47
| t6nn_k kirjutas: |
| osta uus arvuti |
Minugi poolest,
kuhu ma selle kontonumbri sulle saadan ?
9 |
libe
kvaliteetne mees
05.10.2008 18:52:22
| RKsilver kirjutas: |
| t6nn_k kirjutas: |
| osta uus arvuti |
Minugi poolest,
kuhu ma selle kontonumbri sulle saadan ?  |
aga miks sa siis ostsid selle mängu, kui oli teada, et see ei vasta miinimumnõuetele
RKsilver_old
05.10.2008 20:53:52
[quote="libe"]
| t6nn_k kirjutas: |
| osta uus arvuti |
Minugi poolest,
aga miks sa siis ostsid selle mängu, kui oli teada, et see ei vasta miinimumnõuetele [/quote
can i run it selline lehekülg, näitab, et ma saan seda mängida..
nüüd kus siis panin propertise- compapility win xp sp2
saan mängida 1024 resol ca 30 minutit ja siis viskab välja...
9 |
weasel
06.10.2008 09:44:41
Midagi kuumeneb üle vast...
tont23
25.10.2008 23:22:14
kellelgi veel sellist jama on et Car Lotis jookseb mäng kokku? kui autosid vahtida...pärast seda chevroletti viskab igatahes errorit ...mängu 1.1 ver siis
| Kommentaarid: 127 loe/lisa |
111 |
hondaa
15.11.2008 13:33:09
autosid saab tuunida ainult careeris? küsin igaks juhuks üle, äkki jäänud mõni koht 2 silma vahele
e: keegi ei tea?
e: no aga soovitage siis vähemalt mõnda head drifti autot
24 |
Ernits
15.11.2008 13:59:28
| hondaa kirjutas: |
| e: no aga soovitage siis vähemalt mõnda head drifti autot |
RX-8
| Kommentaarid: 99 loe/lisa |
86 |
hondaa
15.11.2008 17:31:35
| Frankie666 kirjutas: |
| hondaa kirjutas: |
RX-8  |
proovin, ilge jama tokyo dockyaed-si drifti ära tegemisega, bemm ei saa 3000 punktigi kokku
aga ikkagi, kuskil mujal peale careeri ei saa tuunida, prooviks pigem lihtsalt enne ära, kas one hea, ei taha kohe raha kulutama hakata
24 |
simpanzzz
15.11.2008 21:25:26
| hondaa kirjutas: |
RX-8  |
Lotus Elise
Endale sobis
| Kommentaarid: 58 loe/lisa |
55 |
TruePlaya
15.11.2008 21:38:22
Nuh, targad, keegi ei oska aidata siis ?  |
Läppariga võid netis pornokatel käia, kuid mitte mänge mängida..
| Kommentaarid: 30 loe/lisa |
striker13
15.11.2008 21:54:20
rx-7 on driftis parem.
_________________ Sarcasm is just one of the many services I offer to people who ask stupid questions. |
| Kommentaarid: 95 loe/lisa |
90 |
