praegune kellaaeg 13.09.2026 15:17:23
1dumbpcuser
12.05.2025 06:05:54
Tech Experts Say The Elder Scrolls IV: Oblivion Remastered's Camera Breaks the Longer You Play and Eventually Crashes When Loading a Save, Call for Emergency Patch
link
Digital Foundry has run an extensive analysis on Oblivion Remastered on all console platforms and found the game to have significant problems across the board. DF’s Thomas Morgan said of Virtuos’ Unreal Engine 5 overhaul:
No platform is spared of issues: whether it's PS5, PS5 Pro, or either Xbox Series machine, all struggle with traversal hitches while roaming the open world. Secondly, there's major sub-60fps frame-rates, where I've also discovered that performance slowly degrades with more playing time - quite possibly down to a memory leak. And finally, software freezes are the icing on the cake, with all PlayStation and Xbox platforms crashing to the system menu on loading a save one too many times.
_________________ M: MSI B660M MORTAR
O: AM5 ITX emaplaat |
97 |
taksikaks
Auron
22.05.2025 16:09:03
| 1dumbpcuser kirjutas: |
| Tech Experts Say The Elder Scrolls IV: Oblivion Remastered's Camera Breaks the Longer You Play and Eventually Crashes When Loading a Save, Call for Emergency Patch |
See probleem oli ka kunagi ammu orikas olemas. Mida kauem olid mänginud ja ma ei pea silmas seda kuipalju antud käimalaskmie hetkel vaid üldse seda pipramaks mäng muutus, loadingu ajad pikemad, laodides crashid kuni corrupt seivideni välja. Morrowindis oli sama asi.
Kindlasti - see kui nö. mainstriimiks on muutunud mängimine võrreldes 20 aasta tagusega on ikka paras vahe. Ja ofkoors tuleb rääkida ka sellest, et saadavus on rohkematel platvormidel ehk sa ei pea ostma PC'd vaid saad ka mängida kui on XBOX/PS.
133 |
11.06.2025 22:26:53
1.1 siis väljas:
Thanks for all your excitement and feedback since the launch of The Elder Scrolls IV: Oblivion Remastered! We are actively working on two separate updates to be launched in the coming weeks, both of which will come to our Steam Beta first, before being released to all other platforms. The first update will be focused on quests, major bugs and blockers, and quality of life fixes. This update will enter the Steam Beta on June 5th, and will be available on all platforms on June 11th. Our second update will focus on performance, and we will share more details when we are able.
Update 1.1
GENERAL
Enabled ToggleHudVisibility and ShowHud console commands
UI
Fix for missing text when installing the Deluxe Upgrade
Fix 'Skip' button not showing correctly during intro
Fix for Redguard Origin stats being reversed
Fix for not automatically showing Local Map when inside interior spaces
Fix for being unable to name Enchanted items when using a controller
Fix punctuation issues in Chinese translation
Localized string fixes
Fix for interacting with Daedric Shrines not displaying subtitles
CRASHES
Fix crash when loading after fast travel to Vilverin
Fix crash when exploring Crayfish Cave
Fix crash when fighting Stunted Scamps
Fix crash when paying the fine after stealing in Castle Bravil
Fix for crash when loading Quicksaves
Fix crash when loading after fast travel to Mortal Camp
Fix for crash when loading a save in Quill-Weave's house
Fix crash when rapidly switching between Quality and Performance modes
Fix crash when storing items in a chest in Frostcrag Spire
Fix crash when creating multiple potions at once using stolen ingredients
Fix various CPU crashes
GAMEPLAY
Fix player animation issues when mounting horses
Fix High Chancellor Ocato arms not animating
Fix Shambles' animations getting stuck when attacking
Fix for Staff of Sheogorath not freezing enemies
Fix for Cap'n Dugal not spawning
Fix for Light spells not showing VFX
Fix for offset Map Markers when running on a secondary monitor
Fix for Local Map being blank when opening
Fix Peryite Shrine's voiceover being cut off
Fix for First Person camera being set above the player's head
Fix for Chameleon VFX being stuck on player
Fix for player's skin textures not matching when infected with a disease
SYSTEM
Fix player settings being reset when updating Settings
Fix XCloud mirroring settings from PC to XBOX
Fix for infinite loading issues
Fix for freezing when pressing Alt+Tab
Fix autosaving creating a new group of saves
Fix for old save files being renamed when the character is renamed at the Sewer exit
Fix for small Display Resolution sizes not showing correctly in Windowed Mode
QUESTS
The Battle for Kvatch - Fix Savlian becoming stuck after Castle Courtyard fight
A Knife in the Dark - Fix for Vincente Valtieri losing his hair
Finding the Thieves Guild - Fix for NPCs not appearing
The Sunken One - Fix for a Diary page being hidden under a bowl
The Elven Maiden - Fix for crash when Hieronymus Lex attempts to take Llathasa's Bust out of the cupboard in Myvryna Arano's house |
| Kommentaarid: 92 loe/lisa |
sukelduja
15.06.2025 20:44:10
| Juba neljas Elder Scrolli mäng, mis kipub lihtsalt pooleli jääma. Tuleb mingi parem mäng peale ja pärast ei suuda enam uuesti üles võtta.
| Kommentaarid: 25 loe/lisa |
25 |
aap14
05.07.2025 23:47:10
| sukelduja kirjutas: |
| Juba neljas Elder Scrolli mäng, mis kipub lihtsalt pooleli jääma. Tuleb mingi parem mäng peale ja pärast ei suuda enam uuesti üles võtta. |
Täpselt sama siin
Mingi maagia seal on aga midagi selles ringijooksmises on selline, mis nõuab rohkem aega kui see seda väärt on
_________________ Slow is smooth and smooth is fast |
| Kommentaarid: 41 loe/lisa |
38 |
Auron
07.07.2025 07:28:59
| aap14 kirjutas: |
Täpselt sama siin
Mingi maagia seal on aga midagi selles ringijooksmises on selline, mis nõuab rohkem aega kui see seda väärt on |
Asi on vägalihtne - olete vanaks raiped jäänd On igast muud tegemised, käimised ja kohustused, pere jne. ja ei ole enam sedasi, et tuled töölt, haarad võileiva ja toksad arvutis 3'ni öösel, nädalavahetusel sama aint selle vahega, et alustad kohe hommikul
Ja siis ongi, et hakkad pelama aga kuskil kuklas tuksleb mõte, et kurat äkki oleks saand ajaga midagi kasulikumat teha ja siis alateadvus hakkab otsima vigu mängujuures, et oleks põhjus pooleli jätta.
133 |
