486
17.10.2011 18:19:59
Ja naljakas t6esti kui rauakolakas ühe bikiniis zombi vastu pooleks läheb
_________________ zero |
| Kommentaarid: 46 loe/lisa |
39 |
Ertai
21.10.2011 20:21:53
Täna mängides avastasin mitu meeldivat muudatust, pärast sessiooni otsisin siis changelogi ka üles.
Endale meeldis see, et lootimine toimib nüüd valguskiirusel ja pole nii clunky, palju uusi mode leidsin 1 tunni jooksul, Gordon Freemanile oli ka üks pühendatud
Medkiti valib paremini
Crate'ides nüüd normaalsed relvad, mitte et level 3 kast ja mingi hädine jama seal
jne
Dead Island PC patch 1.3 has been released on Steam.
The headline alterations are a raised level-cap to 60, new weapon blueprints, better rewards from weapon crates and improvements made to enhance subsequent campaign playthroughs.
Gameplay improvements
Level cap raised to 60
New blueprints for weapon mods added
Infected damage reduced
Infected no longer interrupt player attacks
A series of improvements to subsequent playthroughs implemented: quest XP rewards adjusted, XP rewards for challenges adjusted, XP awarded for all quests completed in co-op
Purna's ammo carrying capacity increased by 50%
Character state from a save game can now be loaded when using the Start from Chapter option
New balancing option added: enemy levels can now be adjusted independently for each co-op player
Players respawn with more health
Lock pick skill level required to open a lock is now clearly indicated
Improved rewards in weapon crates
All weapon crates now contain rewards
Fixes and interface improvements
Fix: players are no longer left without a weapon after dropping the equipped item and healing with a medkit.
Fix: equipped items no longer swap mysteriously after drinking an energy drink
Tweak: healing with medkits from inventory works better, makes smarter choices of medkits
Fix: loot from dead enemies is now always identical for all co-op players
Fix: Purna no longer finishes her Fury with fists equipped
Fix: map tracking after death
Fix: zone info in the quarantine zone (City of Moresby)
Tweak: respawn point selection is now smarter
General
Improved stability and network performance in co-op
V-sync option added
Quest and reward fixes implemented
| Kommentaarid: 51 loe/lisa |
47 |
KrisVr
04.11.2011 02:49:31
| Techland registeeris kaubamärgi "Dead World", võimalik järg Dead Island'ile!
| Kommentaarid: 30 loe/lisa |
LKits
| Kommentaarid: 13 loe/lisa |
murdoch
07.11.2011 10:47:32
sai ka nüüd lõpuks mäng läbi tehtud. Aega läks pea 22 tundi. level jäi lõpuks 31. põhiliselt keskendusin main questidele.
tegelaseks oli see hiina naine.
Häiris väheke see, et zombid ründasid vahel läbi seinte ja uste. Lisaks oli palju sellised "odavaid" surmasid.
karstin, et häirib autoga sõitmine ja relvade kiire purunemine, kuid kartused olid asjata
kas kõikidel tegelastel on see Fury skill või ainult hiinakal? mina seda igatahes õigesti kasutada ei osanud.
on keegi teist korda ka mängu läbi teinud? kas tasub ette võtta, näiteks sama tegelaskujuga või siis mõne muu tegelasega, kas kogemus on piisavalt palju erinev või ei?
| Kommentaarid: 4 loe/lisa |
LKits
486
14.11.2011 05:17:58
Selles mängus mingit armor värki on üldse? Mida kõrgema leveli saavutan seda rohkem damagid saan suvakatelt. Parem üldse ei tahaks enam levelid saada. Kaob mõtte kui kõik on veelgi tugevamad kui enne.
39 |
LKits
murdoch
14.11.2011 10:18:59
ma siin ükspäev võtsin mängu teistkordseks läbimiseks ette. Lootsin, et saan nüüd paremate skillide ja relvadega vähemalt mängu alguses kenasti domineerida aga võta näpust, zombide levelid on samad mis endal. seega paar laksu sisse ja oled jälle maoli vereloigus.
see teeb kogu selle arengu suht mõttetuks kui vahekorrad on kogu aeg samad. vahet ju pole kas oled 1 levelil ja zombid on levelil 1 või siis 30 vs 30.
Ramones
01.01.2012 21:43:09
Kaevan vana teema välja
Hetkel Steamis soodukas: 4-paki puhul tuleks näkku 18,74€. Kahte inimest oleks juurde vaja.
| Kommentaarid: 76 loe/lisa |
75 |
madness
angel
03.01.2012 20:31:39
http://www.game.co.uk/en/dead-island-112269?pageSize=20&searchTerm=dead%20island
ja veel odavam + 3£ posti
peaks tulema kusagil 25.2€ kui just mööda ei arvutanud.
enamasti sedasorti mängus mingi aeg steamis 5€ juures... vähemalt enamik lõpetab sedasi. ehk järgmise "sale" ajal.
... kuigi steam'i 4 pakki vastu ju sa hinnaga ei saa...
157 |
xpander
03.01.2012 21:04:56
mitte et kedagi eriti kotiks, aga töötab päris normaalselt all ka see mäng
recorder teeb vahepeal kahtlaseid freeze mida mängides ei täheldanud.. kuid vahepeal on frameratiga ka nati probleeme kui uusi textuure või miskit laeb.
aga täitsa mängitav.
_________________ Linux Gaming Videos: Xpander69 |
| Kommentaarid: 18 loe/lisa |
16 |
Dominus
06.01.2012 07:14:43
Keegi mingit fixi videokaardi ülekuumenemisele teab?
Vaatan, et foorumites paljudel sama jama, nii ATI kui NVidia omanikel. Nt. teised uued mängud jooksevad enamvähem aga Dead Island ~70-80C+ ja ~2500-3000RPM.
Suht võimatu on midagi üle ventide müra kuulda
76 |
ertr2
06.01.2012 19:09:37
| Dominus kirjutas: |
Suht võimatu on midagi üle ventide müra kuulda  |
võta clocki vähemaks
| Kommentaarid: 67 loe/lisa |
65 |
One
06.01.2012 22:21:18
70-80c küll mingi temperatuur pole
728 |
486
06.01.2012 22:28:56
Mul ka vent undab. Ilmselt liiga kõva mäng.
39 |
trip
07.01.2012 18:21:41
mu kast on aga haudvaikne, kaardil vent 1400rpm/60C
303 |
KrisVr
26.01.2012 20:23:49
trip
26.01.2012 23:10:32
1 veebruaril siis väljas
303 |
d43m0n
21.03.2012 12:03:04
hea vaheldus
_________________ -= 1-2 =- |
| Kommentaarid: 12 loe/lisa |
DigeBeni
163 |
Volum
24.06.2012 21:45:36
kellelgi on see mäng alles 64 bitisel süsteemil? Oleks vaja syswow64 (windowsi kaustas) kaustast faili nimega libeay32.dll.
_________________ Tellin originaal A-varuosasi saksast. 15-70% soodsamalt kui esindustes!
Teostan diagonstikat tehasetasemel: BMW, VAG (Audi, VW, Seat, Skoda ja kaubikud), Volvo (sõiduautod), Scania - Tartus, Põlvas ja lisatasu eest Võrus. |
16 |
trip
303 |
Volum
26.06.2012 01:18:12
Tänud, nüüd teine probleem, 12 tundi sai pelatud, korra sai mäng kinni pandud, nüüd tahtsin uuesti, ja läks kõik save game kaduma
16 |
