praegune kellaaeg 07.11.2026 17:50:34
Auron
24.06.2005 20:04:38
| TanElofJ kirjutas: |
| Ega ei kujuta ette, et arvutimänge ka loodaks mingi Celeroniga, mis slim korpuses. |
Justnimelt.
133 |
Ho Ho
24.06.2005 21:50:53
| Mitte SDK aka software development kit vaid lihtsalt developer kit mis peaks käituma üsna sarnaselt päris PS3'le. Siiani arendati oma mänge üsna tavaliste masinate peal kuid too peaks olema nüüd õige Celliga(madalamate kelladega) ning RSX'ga võrdväärse kaardiga(võibolla ka RSX ise)
87 |
külaline
25.06.2005 09:22:49
pildilt paistab küll väga PC-lik prose
Overall, the IBM/Sony/Toshiba Cell processor has a bright future ahead of it, and not just because millions will be sold in Playstation 3 consoles. With the correct compiling tools, Cell-inside PCs could potentially excel at the kind of applications we buy high-end PCs for today: Graphics, video, audio and games.
The only question that remains is will they in the face of Intel's upcoming Extended Memory-64 Technology and dual-core Pentium 4 processors? |
Aga mida tähendab correct compiling?Korrektsem kui seni,või lihtsalt spetsiaalselt Cellile mõeldud?
What will this Cell Based system look like? - Our Speculation
- MotherBoard supports up to 4 Cell Chips
- Each Cell Chip will have its own Rambus main memory. The memory will be on plug in strips much like DDR etc
- The Cell Chips on the motherboard will cooperate by means of FlexIO which is a multilane/serial technology.
- There will be two slots meant for video cards. Similar to AGP but designed for Rambus, not AGP compatable, 10x faster than AGP.
- All other I/O will be done by means of FlexIO similar to what is now possible with USB - except the system will boot from flexIO
- There will be no legacy hardware support - NO PCI, AGP, usb, serial, parallel, ps2 , ethernet - nothing
- The power supply will need to be about 500 watts.
- power management will allow cell chips and parts of cell chips to be powered down when not in use.
- There will be 16 FlexIO ports coming out the back. 2 in and 2 out for each Cell Chip.
- Cluster can be created by stacking Cell Boxes and connecting them with the FlexIO cables. |
Arvatavasti ka 10x kiirem kui agp tähendab ,et vist jutt käib 10x kiirem kui agp8x,Ja puudub PCI?Ehk isegi pci-e?
486
25.06.2005 10:45:20
Misasja neid ei olegi või?
_________________ zero |
| Kommentaarid: 46 loe/lisa |
39 |
Ho Ho
11.10.2005 14:29:14
| Aga mida tähendab correct compiling?Korrektsem kui seni,või lihtsalt spetsiaalselt Cellile mõeldud? |
Ma arvan et selle all on mõeldud koodi Cellile optimeerida suutvat kompilaatorit.
| Misasja neid ei olegi või? |
Ega macil pole ju samuti flopit ning keegi ei kurda. Cell ei ole PC ega mac. Jätke see endale meelde.
Kui nad tõepoolest peaks hakkama neid vananenud tehnoloogiaid toetama siis tähendaks see et üsna suur enamus neist masinaist oleks enam-vähem sama võimsusega mis praegused PC'dki. Kui aga kasutada spetsiaalselt Cellile disainitud rauda on võimsuse kasv PC->Cell kordades, seda eeltõttu andmekanalite kiiruse kasvu tõttu.
Samas ma usun et USB ning ethernet on siiski olemas, tõenäoliselt läbi mingi konverter-kiibi, umbes nagu praegu saab PC'le lisada lsiakaarte USB ja firewire portidega
http://www.cooltechzone.com/index.php?option=content&task=view&id=1660
Cell Microprocessor: An In-Depth Look at the Future
Hetkel loen, hiljem kommenteerin
[edit]
Mnjah, suurt midagi huvitavat ei olnud mida siin teemas poleks juba mainitud
Muidu kes tahab võib vaadata ~1h7min pikkust video presentatsiooni Celli kohta mis esitati selle aasta Game Developers Conference Europe'l:
CELL: A New Platform for Digital Entertainment
http://www.pqhp.com/cmp/gdctv/
[edit2]
http://theinquirer.net/?article=25229
Sony claims Playstation 3 Linux & Tiger capable
SONY HAS stuck an interesting sentence into the very last line of a release that tells us the wonderful technological heights that the console will be able to aspire to. The company said: "The integrated Cell processor will be able to support a variety of operating systems (such as Linux or Apple's Tiger)."
In the upcoming age of online-enabled consoles with plenty of ports and capabilities for extra peripherals - a keyboard, for example it doesnt take a genius to spot where Sony might be going with this line of thought.
So, are future consoles a PC replacement? Well, at least a Mac replacement at this stage.
The company does mention just before that little bombshell that "Sony is expected to offer optional hard drives for the PS3 with potential memory capacity of 80 or 120 GB", meaning that the HD space is there for computer replacements.
Interesting strategy. µ
Peale seda kui vaatasin videot Celli arhitektuuri ja progemise kohta usun et olen üks esimesi kes endale PS3'e hangib. Tõsi, mängima ma vist selle peal eriti palju ei hakka
[edit3]
IBM jagab Celli kohta veidike tehnilisi dokumente
Cell architecture from 20,000 feet
Cell Broadband Engine Architecture V1.0
Synergistic Processor Unit (SPU) Instruction Set Architecture V1.0
SPU Application Binary Interface Specification V1.3
SPU Assembly Language Specification V1.2
SPU C/C++ Language Extensions V2.0
http://www-128.ibm.com/developerworks/power/cell/
Enamus dokumente vajab tasuta registreerumist
[edit4]
Upitan taas teemat.
Selle aasta alguses kui Cellist veel ei teatud kirjutas üks inimene selle kohta ühe artikli kuid ta naerdi välja sest tegi seal mitmeid üsna utoopilisi järeldusi.
Mõnda aega tagasi kirjutas sama isik uue artikli ning tundub et seekord ta enam nii suuresti ämbrisse ei astunud. Jutt on seekord täiesti normaalne ning enamus väidetele on ka valdavalt usaldusväärsed viited olemas.
Seal artiklis tunnistab ta ka viga eelmises artiklis ning ütleb selle kohta nii:
Contrary to some opinions the first version was not an attempt to hype the Cell processor.
The original version of this was written after I read a debate on the Cell in late 2004. The Cell was clearly not widely understood at the time and I felt I could provide an explanation.
I am a technology enthusiast and when I see some very advanced technology heading in our direction Im interested and Im excited. Some of this emotion evidently made it into the first version of the article.
Neither this or the previous version was requested or paid for by Sony, Toshiba, IBM or anyone else. |
87 |
heameel
külaline
09.11.2005 13:51:10
kaks kärbest ühe hoobiga |
Progejad peavad hakkama tõsiselt suhtuma multi-tegum (thread) ja paralleel programeerimisse. Seda tuleks ka koolist õpetajate käest lunida - vaja on mitte ainult võtmesõnu vaid arhitektuure ja mudeleid mille peal katsetada. See kõik pole õnneks uus nii et peaks olema õppejõududele hoomatav (SIMD, MIMD ja sõbrad). Kui varem kaldus eksootikasse siis nüüd on juba vajalik oskus.
Samas tulevad koos paralleel keeltega sisse ka riistvara kirjelduse keeled (VHDL, VERILOG), seda vajaduse ja arvutusliku mudeli sarnasuse kaudu.
Need kaks asja kokku annavadki vajaliku baasi tulevastele ITikeele filoloogidele.
Ho Ho
09.01.2006 19:03:47
Kui kedagi peaks huvitama siis IBM on GPL'i all välja lasknud Cell'i SDK
Koosneb see sellistest vidinatest:
The complete programming environment consists of the full stack of the IBM Full-System Simulator for the CBEA, the XL C compiler, and software samples and library code (from alphaWorks), and the GCC compiler, toolchain, operating system kernel, and library (from the Barcelona Supercomputer Center).
Mul endal lähemal ajal nii katsetamiseks vist piisavalt vaba aega ei teki kuid kui keegi siiski asja järgi proovib andke kogemustest teada.
[edit]
Lisan siis siia kah ühe teemasse käiva lõigu varasemast postist teises teemas:
https://foorum.hinnavaatlus.ee/viewtopic.php?p=1759193#1759193
The key goal of OpenRT and RPU have been to provide realtime performance
for ray tracing. To this respect we have optimized the software and now
achieve up to 10 fps at 1k x 1k resolution with a single off-the-shelf
processor. This scales well with multi-core and multi-chip setups. With
a simplified setup we already showed 30-50 fps full screen on the Cell
Processor at last Siggraph.
Loomulikult ka ei saa Cell kaugeltki lähedale spets riistvarale. Umbes sama töö teeks ära üksainus RPU millel on neli "toru" ja takt on kõigest kusagil 200MHz juures. Celli takt oli kusagil 2.8-3.2GHz kandis ning kasutati kõiki kaheksat kaasprotsessorit. Samas nii kaua kuni riistvaralisi kiirendusi ei ole peaks Cell olema next best thing.
87 |
Yorick
arvutisõber
04.03.2006 17:06:21
Mnjaa, neil tuleb vist hakata ka XBox360 -i PC -ks deklareerima, et mingi riik kuhu arvuteid ei tohtinud müüa, ostis mingi aeg hulgi PS2 -sid kokku
Aga PS2 käib juba kaua aega PC alla. Samas tänu sellele lähevad maksud ka väiksemaks...
_________________ ... |
| Kommentaarid: 55 loe/lisa |
53 |
Ho Ho
15.09.2006 17:40:21
Too pole ainus masin
http://www.mc.com/products/view/index.cfm?id=27&type=systems
http://www.mc.com/products/view/index.cfm?id=64&type=boards
[edit]
Kui kellelgi väga igav on võib ta aega veeta lugedes Celli progemsie käsiraamatut, aka Cell Broadband Engine Programming Handbook, otselink
Tõenäoliselt on too raamat sarnane Inteli arhitetkuuri käsiraamatutele.
[edit2]
Noh, kes soovib endale Celli põhist blade serverit hankida?
http://www-03.ibm.com/developerworks/blogs/page/powerarchitecture?entry=new_bladecenters_are_here_with
datasheet
Director of research computing at the University of Manchester, W.T. Hewitt, said, "Computing systems built from blades based on the Cell Broadband Engine can change the economics associated with supercomputing." He's one of the lucky few already using a QS20 which, BTW, contains two 3.2GHz processors, 40GB disk, 512KB of level 2 cache per processor, and dual gigabit Ethernet support -- all at a mere US$18,995.
Ehk siis tühise $19k eest saab kaks korda rohkem prosevõimsust kui PS3 seda ~40x odavamalt pakkuma hakkab
87 |
