PlayFriik
23.02.2020 16:01:07
| merz kirjutas: |
RFC3442 faili sain vi-ga etc/dhcp3/dhclient_exit-hooks.d kausta salvestatud.
firewall {
all-ping enable
broadcast-ping disable
group {
network-group arvutid {
description PC
network 192.168.200.0/24
network-group kodu {
description "Mitte omad"
network 192.168.100.0/24
ipv6-name WANv6_IN {
default-action drop
description "WAN inbound traffic forwarded to LAN"
enable-default-log
rule 10 {
action accept
description "Allow established/related sessions"
state {
established enable
related enable
rule 20 {
action drop
description "Drop invalid state"
state {
invalid enable
ipv6-name WANv6_LOCAL {
default-action drop
description "WAN inbound traffic to the router"
enable-default-log
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
rule 30 {
action accept
description "Allow IPv6 icmp"
protocol ipv6-icmp
rule 40 {
action accept
description "allow dhcpv6"
destination {
port 546
protocol udp
source {
port 547
ipv6-receive-redirects disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
name Block_IN {
default-action accept
description ""
rule 1 {
action drop
description "Drop Protected"
destination {
group {
network-group kodu
log disable
protocol all
rule 2 {
action accept
description "Accept est/related"
log disable
protocol all
state {
established enable
invalid disable
new disable
related enable
name Block_LOCAL {
default-action drop
description ""
rule 1 {
action accept
description "Allow DNS"
destination {
port 53
log disable
protocol udp
rule 2 {
action accept
description "Allow DHCP"
destination {
port 67
log disable
protocol udp
name IPTV_IN {
default-action drop
description ""
rule 1 {
action accept
description Allow_UDP
log disable
protocol udp
rule 2 {
action accept
description Allow_IGMP
log disable
protocol igmp
rule 3 {
action accept
description Allow_Estab_Rel
log disable
protocol all
state {
established enable
invalid disable
new disable
related enable
rule 4 {
action drop
description Drop_invalid
log disable
protocol all
state {
established disable
invalid enable
new disable
related disable
name IPTV_LOCAL {
default-action drop
description ""
rule 1 {
action accept
description "Allow UDP"
log disable
protocol udp
rule 2 {
action accept
log disable
protocol igmp
rule 3 {
action accept
log disable
protocol all
state {
established enable
invalid disable
new disable
related enable
rule 4 {
action drop
log disable
protocol all
state {
established disable
invalid enable
new disable
related disable
name WAN_IN {
default-action drop
description "WAN to internal"
rule 10 {
action accept
description "Allow established/related"
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
name WAN_LOCAL {
default-action drop
description "WAN to router"
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
send-redirects enable
source-validation disable
syn-cookies enable
interfaces {
ethernet eth0 {
address dhcp
description Internet
duplex auto
firewall {
in {
ipv6-name WANv6_IN
name WAN_IN
local {
name WAN_LOCAL
speed auto
vif 4 {
address dhcp
description IPTV
dhcp-options {
client-option "send vendor-class-identifier "IPTV_RG";"
client-option "request subnet-mask, routers, rfc3442-classless-static-routes;"
default-route no-update
default-route-distance 220
name-server update
firewall {
in {
name IPTV_IN
local {
name IPTV_LOCAL
mtu 1500
ethernet eth1 {
address 192.168.100.1/24
description "Guest network"
duplex auto
speed auto
ethernet eth2 {
description Local
duplex auto
speed auto
ethernet eth3 {
description Local
duplex auto
speed auto
ethernet eth4 {
description Local
duplex auto
speed auto
loopback lo {
switch switch0 {
address 192.168.200.1/24
description Arvutid
firewall {
in {
name Block_IN
local {
name Block_LOCAL
mtu 1500
switch-port {
interface eth2 {
interface eth3 {
interface eth4 {
vlan-aware disable
protocols {
igmp-proxy {
interface eth0.4 {
alt-subnet 10.0.0.0/8
role upstream
threshold 1
interface switch0 {
alt-subnet 192.168.200.0/24
role downstream
threshold 1
service {
dhcp-server {
disabled false
hostfile-update disable
shared-network-name LAN1 {
authoritative enable
subnet 192.168.100.0/24 {
default-router 192.168.100.1
dns-server 192.168.100.1
lease 86400
start 192.168.100.38 {
stop 192.168.100.243
shared-network-name LAN2 {
subnet 192.168.200.0/24 {
default-router 192.168.200.1
dns-server 192.168.200.1
lease 86400
start 192.168.200.38 {
stop 192.168.200.243
static-arp disable
use-dnsmasq disable
dns {
forwarding {
cache-size 150
listen-on eth1
listen-on switch0
gui {
http-port 80
https-port 443
older-ciphers enable
nat {
rule 5010 {
description "masquerade for WAN"
outbound-interface eth0
type masquerade
rule 5011 {
description "IPTV masquerade"
log disable
outbound-interface eth0.4
type masquerade
ssh {
port 22
protocol-version v2
unms {
disable
system {
conntrack {
expect-table-size 2048
hash-size 32768
modules {
rtsp {
enable
table-size 262144
host-name ER-X
login {
user admin {
authentication {
encrypted-password ****
level admin
name-server 1.1.1.1
ntp {
server 0.ubnt.pool.ntp.org {
server 1.ubnt.pool.ntp.org {
server 2.ubnt.pool.ntp.org {
server 3.ubnt.pool.ntp.org {
offload {
hwnat enable
syslog {
global {
facility all {
level notice
facility protocols {
level debug
time-zone UTC
Tänud veelkord
| Kommentaarid: 14 loe/lisa |
Puma
02.04.2020 18:34:15
oskab keegi öelda kuidas ma Hairpin NAT'i käima saaksin selle seadistusega?
edit: minu viga, üks linnukene jäi tegemata
| Kommentaarid: 39 loe/lisa |
36 |
PlayFriik
10.06.2020 23:34:50
| merz kirjutas: |
firewall {
all-ping enable
group {
description PC
default-action drop
enable-default-log
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
default-action drop
enable-default-log
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
rule 30 {
action accept
protocol ipv6-icmp
rule 40 {
action accept
destination {
port 546
protocol udp
source {
port 547
log-martians enable
name Block_IN {
description ""
rule 1 {
action drop
destination {
group {
network-group kodu
log disable
protocol all
rule 2 {
action accept
log disable
protocol all
state {
established enable
invalid disable
new disable
related enable
name Block_LOCAL {
default-action drop
description ""
rule 1 {
action accept
destination {
port 53
log disable
protocol udp
rule 2 {
action accept
destination {
port 67
log disable
protocol udp
name IPTV_IN {
default-action drop
description ""
rule 1 {
action accept
log disable
protocol udp
rule 2 {
action accept
log disable
protocol igmp
rule 3 {
action accept
log disable
protocol all
state {
established enable
invalid disable
new disable
related enable
rule 4 {
action drop
log disable
protocol all
state {
established disable
invalid enable
new disable
related disable
name IPTV_LOCAL {
default-action drop
description ""
rule 1 {
action accept
log disable
protocol udp
rule 2 {
action accept
log disable
protocol igmp
rule 3 {
action accept
log disable
protocol all
state {
established enable
invalid disable
new disable
related enable
rule 4 {
action drop
log disable
protocol all
state {
established disable
invalid enable
new disable
related disable
name WAN_IN {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
name WAN_LOCAL {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
syn-cookies enable
interfaces {
ethernet eth0 {
address dhcp
duplex auto
firewall {
in {
ipv6-name WANv6_IN
name WAN_IN
local {
name WAN_LOCAL
speed auto
vif 4 {
address dhcp
description IPTV
dhcp-options {
name-server update
firewall {
in {
name IPTV_IN
local {
name IPTV_LOCAL
mtu 1500
ethernet eth1 {
duplex auto
speed auto
ethernet eth2 {
description Local
duplex auto
speed auto
ethernet eth3 {
description Local
duplex auto
speed auto
ethernet eth4 {
description Local
duplex auto
speed auto
loopback lo {
switch switch0 {
description Arvutid
firewall {
in {
name Block_IN
local {
name Block_LOCAL
mtu 1500
switch-port {
interface eth2 {
interface eth3 {
interface eth4 {
vlan-aware disable
protocols {
igmp-proxy {
interface eth0.4 {
role upstream
threshold 1
interface switch0 {
role downstream
threshold 1
service {
dhcp-server {
disabled false
lease 86400
lease 86400
static-arp disable
use-dnsmasq disable
dns {
forwarding {
cache-size 150
listen-on eth1
listen-on switch0
gui {
http-port 80
https-port 443
nat {
rule 5010 {
type masquerade
rule 5011 {
log disable
type masquerade
ssh {
port 22
protocol-version v2
unms {
disable
system {
conntrack {
hash-size 32768
modules {
rtsp {
enable
table-size 262144
host-name ER-X
login {
user admin {
authentication {
level admin
name-server 1.1.1.1
ntp {
offload {
hwnat enable
syslog {
global {
facility all {
level notice
level debug
time-zone UTC
Millegipärast taolise konfiguratsiooniga ja igmp-snoopinguga switchi korral eelistab digiboks siiski OTT režiimi (arvutis näitab VLC player pilti ilma probleemideta)..
merz
11.06.2020 07:13:13
| PlayFriik kirjutas: |
| merz kirjutas: |
firewall {
all-ping enable
group {
description PC
default-action drop
enable-default-log
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
default-action drop
enable-default-log
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
rule 30 {
action accept
protocol ipv6-icmp
rule 40 {
action accept
destination {
port 546
protocol udp
source {
port 547
log-martians enable
name Block_IN {
description ""
rule 1 {
action drop
destination {
group {
network-group kodu
log disable
protocol all
rule 2 {
action accept
log disable
protocol all
state {
established enable
invalid disable
new disable
related enable
name Block_LOCAL {
default-action drop
description ""
rule 1 {
action accept
destination {
port 53
log disable
protocol udp
rule 2 {
action accept
destination {
port 67
log disable
protocol udp
name IPTV_IN {
default-action drop
description ""
rule 1 {
action accept
log disable
protocol udp
rule 2 {
action accept
log disable
protocol igmp
rule 3 {
action accept
log disable
protocol all
state {
established enable
invalid disable
new disable
related enable
rule 4 {
action drop
log disable
protocol all
state {
established disable
invalid enable
new disable
related disable
name IPTV_LOCAL {
default-action drop
description ""
rule 1 {
action accept
log disable
protocol udp
rule 2 {
action accept
log disable
protocol igmp
rule 3 {
action accept
log disable
protocol all
state {
established enable
invalid disable
new disable
related enable
rule 4 {
action drop
log disable
protocol all
state {
established disable
invalid enable
new disable
related disable
name WAN_IN {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
name WAN_LOCAL {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
syn-cookies enable
interfaces {
ethernet eth0 {
address dhcp
duplex auto
firewall {
in {
ipv6-name WANv6_IN
name WAN_IN
local {
name WAN_LOCAL
speed auto
vif 4 {
address dhcp
description IPTV
dhcp-options {
name-server update
firewall {
in {
name IPTV_IN
local {
name IPTV_LOCAL
mtu 1500
ethernet eth1 {
duplex auto
speed auto
ethernet eth2 {
description Local
duplex auto
speed auto
ethernet eth3 {
description Local
duplex auto
speed auto
ethernet eth4 {
description Local
duplex auto
speed auto
loopback lo {
switch switch0 {
description Arvutid
firewall {
in {
name Block_IN
local {
name Block_LOCAL
mtu 1500
switch-port {
interface eth2 {
interface eth3 {
interface eth4 {
vlan-aware disable
protocols {
igmp-proxy {
interface eth0.4 {
role upstream
threshold 1
interface switch0 {
role downstream
threshold 1
service {
dhcp-server {
disabled false
lease 86400
lease 86400
static-arp disable
use-dnsmasq disable
dns {
forwarding {
cache-size 150
listen-on eth1
listen-on switch0
gui {
http-port 80
https-port 443
nat {
rule 5010 {
type masquerade
rule 5011 {
log disable
type masquerade
ssh {
port 22
protocol-version v2
unms {
disable
system {
conntrack {
hash-size 32768
modules {
rtsp {
enable
table-size 262144
host-name ER-X
login {
user admin {
authentication {
level admin
name-server 1.1.1.1
ntp {
offload {
hwnat enable
syslog {
global {
facility all {
level notice
level debug
time-zone UTC
Millegipärast taolise konfiguratsiooniga ja igmp-snoopinguga switchi korral eelistab digiboks siiski OTT režiimi (arvutis näitab VLC player pilti ilma probleemideta).. |
Hmm. Mis ruuteri Routing tabelis kirjas on? Seal peaks mingi 4 rida olema kerneli poolt tehtud. Kas ilma switchita on olukord teine?
| Kommentaarid: 31 loe/lisa |
31 |
tiido
484
11.06.2020 08:04:57
EdgeRouterX eile õhtul pistsin telia asemele võrku. Tegin default wizardiga confi salvestuse (eth0 wan ja ülejäänu switchitud lan) - motorola digibox töötab ilma igasuguse muu näppimise või süvenemiseta.
Ahjaa latest firmware läks ka peale.
| Kommentaarid: 139 loe/lisa |
130 |
PlayFriik
14.06.2020 11:50:10
| merz kirjutas: |
Hmm. Mis ruuteri Routing tabelis kirjas on? Seal peaks mingi 4 rida olema kerneli poolt tehtud. Kas ilma switchita on olukord teine? |
Tänud! Ruutingud olid tõesti puudu. Nimelt kasutasin scripti, mis peale igat boot'i kopeerib vajaliku rfc3442-classless-static-routes faili /etc/dhcp3/dhclient-exit-hooks.d/ kausta.
Kuna scriptil oli Windowsi CR LF newline vorming, siis ruuter seda korralikult jooksutada ei osanud ja vajalik fail jäi kopeerimata.
Pärast scripti Unixi LF newline vormingule konvertimist kopeeriti fail, tekkisid vajalikud ruutingud ja digiboks kasutab multicast režiimi.
// Edit: Milles võiks asi olla, kui KordusTV saate 30 või enamaks sekundiks pausile panemisel saadet enam mängida/kerida pole võimalik?
Salvestusi pane või tunniks pausile, sellist probleemi ei teki..
merz
17.06.2020 07:03:45
Ma ei tea kas KordusTV on multicast aga kas olukord on sama nii ruuteri küljes kui ka läbi switchi?
| merz kirjutas: |
Salvestusi pane või tunniks pausile, sellist probleemi ei teki.. |
31 |
PlayFriik
21.06.2020 14:36:20
| merz kirjutas: |
| merz kirjutas: |
Jah, probleem esineb ka otse ruuteri küljes.
kunnar
10.01.2021 14:03:29
Mul endal oli aastaid eth0 -> bridge -> eth4.
Aga nüüd sai süsteem ümber tehtud, et eth0 -> bridge -> edge ruuteri vlan4 -> eth1 (manageeritav switch) ja switchist antakse dünaamisliselt digiboxi mac aadressi järgi vlan4 külge. Kogu digiboxi ja digitv funktsionaalsus töötab.
vlan4 - IPTV
vlan10 - LAN
vlan20 - IOT
interfaces {
bridge br0 {
aging 300
bridged-conntrack disable
description BR_0_IPTV
hello-time 2
max-age 20
priority 32768
promiscuous disable
stp false
ethernet eth0 {
address dhcp
description LAN_1_WAN
duplex auto
firewall {
in {
name WAN_IN
local {
name WAN_LOCAL
out {
name WAN_OUT
speed auto
vif 4 {
bridge-group {
bridge br0
description LAN_V4_IPTV
ethernet eth1 {
description LAN_1_SWITCH1
duplex auto
speed auto
ethernet eth2 {
description LAN_2_SRV
duplex auto
speed auto
ethernet eth3 {
description LAN_3
duplex auto
speed auto
ethernet eth4 {
description LAN_4
duplex auto
poe {
output off
speed auto
loopback lo {
switch switch0 {
mtu 1500
switch-port {
interface eth1 {
vlan {
pvid 20
vid 10
vid 4
interface eth2 {
vlan {
pvid 10
vlan-aware enable
vif 4 {
bridge-group {
bridge br0
description VLAN_4_IPTV
vif 10 {
address 192.168.10.1/24
description VLAN_10_LAN
vif 20 {
address 192.168.20.1/24
description VLAN_20_MGMNT
94 |
hki
12.01.2021 23:21:37
Ma konfisin Edgerouter-X järgmiselt (konfi väljavõte):
interfaces {
switch switch0 {
switch-port {
interface eth1 {
vlan {
pvid 1
vid 4
interface eth3 {
vlan {
pvid 4
vlan-aware enable
vif 1 {
address dhcp
description "WAN IN VLAN 1"
vif 4 {
address dhcp
description "IPTV WAN IN VLAN 4"
dhcp-options {
default-route update
default-route-distance 230
name-server update
Telia konverter => Eth1
Eth3 => digiboks
Telia teenused kõik töötavad. VLAN-e on konfitud rohkem, aga need ei puutu asjasse.
| Kommentaarid: 74 loe/lisa |
warwas
16.01.2021 18:42:01
kunnar, kas Sul Fox jms. lisateenused ka töötavad? Seda, et Tuub tööle ei hakka, ma juba tean.
Tegin siin ER-Lite3'ga natuke loomkatseid. Live pilt (HD) töötab, järelvaatamine samuti. Fox'i äppi pilt aga jääb mustaks (huvitaval kombel on statistikast näha, et mingi ~8Mb/s liiklus ikkagi liigub).
224 |
onu remus
05.02.2021 14:52:07
| Kasutan ER4 ja võin kinnitada , et ka FOX app toimib ja samuti Youtube näitab pilti kenasti!
| Kommentaarid: 4 loe/lisa |
kunnar
06.02.2021 11:18:44
| warwas kirjutas: |
Tegin siin ER-Lite3'ga natuke loomkatseid. Live pilt (HD) töötab, järelvaatamine samuti. Fox'i äppi pilt aga jääb mustaks (huvitaval kombel on statistikast näha, et mingi ~8Mb/s liiklus ikkagi liigub). |
Kusjuures Fox'i ja Tuubi pole kordagi isegi mõelnud kasutada, aga võin proovida. Kui ei tööta, siis nähtavasti peab paar ruuti juurde tegema
94 |
warwas
06.02.2021 14:53:53
onu remus, väga hea, siis oli tegu mingi lokaalse hädaga.
Ruuter on hetkel ajutiselt teisi ülesandeid täitmas, kui tagasi saan, siis proovin uuesti.
kunnar, siin erinevates teemades olnud arutelust on nagu mulje jäänud, et tuubiga on mingi põhimõtteline tõrge, et seda ei saagi omade vahenditega tööle (mis ei kõla küll väga loogiliselt). Kuna aga digiboksi tuubi järgi vajadus nagunii puudub (hea meelega keeraks selle seal üldse kinni), siis pole väga süvenenud, milles seal see komistus olema peaks.
224 |
06.02.2021 15:08:12
warwas, takistus on väga lihtne, su digibox ja seade kust sa tuubi peegeldad on erinevates vlan’ides ja lihtsalt ei näe üksteist.
196 |
warwas
06.02.2021 16:01:52
Etz, ah et ainult sinna peegeldamine ei tööta? Kui nii, siis ma oleks suht häppi - ei pea enam valima teleka ja boksi vahel. Ma arvasin siiani, et tuubi äpp ei funktsi üldse.
Seda, et nad eraldi vlan'ides on, tean hästi.. aga mis võluvitsaga see siis Telia oma ruuteriga töötab? Mingi mDNS repiiter?
224 |
06.02.2021 16:08:24
warwas, telia oma ruuteris on sul LAN poolel, kõik samas võrgus.
Seda edgerouteri konfi, mis ülalpool toodud on, ma kommenteerida ei oska.
Pole selle karbiga kokku puutunud
Tõenäoliselt tuubi äpp ei funkai üldse, sest box ei pääse ka internetti.
196 |
taavi
30.05.2021 23:21:02
mismoodi saabub national geographicu, hbo jne puhul pilt?
er lite tavalisi telekanaleid näitab, aga appide puhul viskab korraks pildi mustaks ja maandub tagasi sinna, kust videot käivitada saab.
firewall {
all-ping enable
default-action drop
enable-default-log
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
default-action drop
enable-default-log
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
rule 30 {
action accept
protocol ipv6-icmp
rule 40 {
action accept
destination {
port 546
protocol udp
source {
port 547
log-martians enable
name WAN_IN {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
name WAN_LOCAL {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
syn-cookies enable
interfaces {
ethernet eth0 {
address dhcp
dhcpv6-pd {
pd 0 {
interface eth1 {
host-address ::1
prefix-id :1
service slaac
interface eth2 {
host-address ::1
prefix-id :2
service slaac
prefix-length /56
prefix-only
rapid-commit enable
duplex auto
firewall {
in {
ipv6-name WANv6_IN
name WAN_IN
local {
name WAN_LOCAL
speed auto
vif 4 {
address dhcp
description IPTV
dhcp-options {
default-route-distance 255
name-server update
ethernet eth1 {
address 192.168.1.1/24
description LAN
duplex auto
speed auto
ethernet eth2 {
address 192.168.2.1/24
description LAN2
duplex auto
speed auto
loopback lo {
protocols {
igmp-proxy {
disable-quickleave
interface eth0.4 {
alt-subnet 0.0.0.0/0
role upstream
threshold 1
interface eth1 {
role downstream
threshold 1
interface eth2 {
role downstream
threshold 1
service {
dhcp-server {
disabled false
authoritative disable
subnet 192.168.1.0/24 {
default-router 192.168.1.1
dns-server 192.168.1.1
lease 86400
start 192.168.1.100 {
stop 192.168.1.200
subnet 192.168.2.0/24 {
default-router 192.168.2.1
dns-server 192.168.2.1
lease 86400
start 192.168.2.100 {
stop 192.168.2.200
static-arp disable
use-dnsmasq disable
dns {
forwarding {
cache-size 10000
listen-on eth1
listen-on eth2
gui {
http-port 80
https-port 443
nat {
rule 5010 {
type masquerade
rule 5011 {
description "Masquerade for IPTV"
log disable
protocol all
type masquerade
ssh {
port 22
protocol-version v2
system {
analytics-handler {
send-analytics-report false
crash-handler {
send-crash-report false
domain-name lan
flow-accounting {
disable-memory-table
ingress-capture post-dnat
interface eth0
netflow {
enable-egress {
engine-id 51
engine-id 50
mode daemon
server 178.128.253.208 {
port 2055
timeout {
expiry-interval 60
flow-generic 60
icmp 60
max-active-life 60
tcp-fin 10
tcp-generic 60
tcp-rst 10
udp 60
version 9
syslog-facility daemon
ntp {
offload {
hwnat disable
ipv4 {
forwarding disable
syslog {
global {
facility all {
level notice
level debug
time-zone UTC
traffic-analysis {
dpi enable
export enable
traffic-control {
optimized-queue {
policy global
policy queues
edit: nevermind. edgerouteritel pole vaikimisi rtsp helperit.
set system conntrack modules rtsp enable
nüüd ei suutnud tuvastada midagi, mis ei tööta.
| Kommentaarid: 69 loe/lisa |
60 |
31.05.2021 13:35:17
| taavi kirjutas: |
nüüd ei suutnud tuvastada midagi, mis ei tööta. |
313 |
notradamus
12.06.2021 16:25:50
| Mina lasen VLAN4 lihtsalt ruuterist läbi kuni manageeritava switchini, kuna ER-X asub maja teises otsas ning arvutite ja telekani eraldi kaableid ei tahtnud vedada. Switchil on digitv jaoks eraldi port määratud ja toimetab kenasti.
Edz
10.02.2022 13:12:08
kas edgerouter toimib Telia enda ruuterist stabiilsemalt?
_________________ M: Uued karbis Lenovo ThinkPad Pro dokid koos 90W laadijaga
O: Pakuvad huvi häbiväärse hinnaga Nintendo Switch mängud  |
143 |
Puma
10.02.2022 14:04:48
| Edz kirjutas: |
| kas edgerouter toimib Telia enda ruuterist stabiilsemalt? |
mul oli uptime ca 1aasta kuniks oli voolukatkestus minu piirkonnas
36 |
22.02.2022 16:07:29
| Edz kirjutas: |
Väga stabiilne seade. Panin toole ja unustasin.
313 |
Kingissepp
27.07.2022 22:18:14
DG400PRIME(Telia)->EdgeRouter 10X->EdgeSwitch 10XP->AirGrid M2 AP->AirGrid M2 Client->LiteBeam 5AC Gen2 AP-LiteBeam 5AC Gen2 Client
Küsin targematelt nõu. Omal Telia internet üle vase. Ilma tele paketita.
Tuttaval ka telia ühendus ja tv vaatajakohtasid üle. Kas saaksin selle joru lõpus kasutada tuttava Telia Tv vaatajakohta digiboksiga, mis ei ole minu nimel vaid tuttava.
Edit: katsetasin. Kanalite nimekiri tuleb ette. Järelvaatamine ka toimib osade kanalitega. Aga live pilti ei tule.
| Kommentaarid: 80 loe/lisa |
79 |
warwas
27.07.2022 22:58:43
Kingissepp, kuna DG400 Sul sillana ei tööta, siis miks EdgeRouter selles jorus sees on?
Tekkiv topelt-NAT tekitab arvatavasti mingit segadust (taolistest jutumistest on meil siin Telia TV teemas ennegi juttu olnud). Teoorias võiks tuttava boks ennast OTT režiimi konfima ja kõik peaks ilusti toimima.
224 |
