SurfData
20.10.2014 15:16:33
Re: Android L tuleb - ja uued tahvlid-telefonid koos sellega |
| miki kirjutas: |
Oktoobris tuleb välja ka Google´i / Motorola ühistelefon Nexus 6.
vot seda jään ootama, saab oma 3,5 aastat vana lutsu ehk välja vahetatud Eks hind paneb asja paika ning mis jõudlust selle hinna eest saab.
| Kommentaarid: 84 loe/lisa |
74 |
krist2an
20.10.2014 18:36:35
| CnZ kirjutas: |
2K (Quad HD) on ainult resolutsioon. Paneel on ikkagi teise, kehvema, tehnoloogiaga. AMOLEDi eelis ongi mustad toonid (kuna piksel surnud sel momendil) ja sellest tulenevalt energiasääst. Kõiges muus (koos heledate värvidega) jääb ta IPS-tehnoloogiale alla. Üleküllastunud värvid on muidugi hea pseudoteadus reklaamimaks seda kui väga heade värvidega ekraani.  |
Ei ole nii:
| Based on our extensive Lab tests and measurements, the Galaxy S5 is the Best performing Smartphone display that we have ever tested. It has a long list of new records for best Smartphone display performance including: Highest Brightness, Lowest Reflectance, Highest Color Accuracy, Infinite Contrast Ratio, Highest Contrast Rating in Ambient Light, and smallest Brightness Variation with Viewing Angle. The Galaxy S5 has raised the bar for top display performance up by another notch – an impressive achievement for OLED technology! |
E: ja ka see
| We recently gave the Samsung Galaxy Note 4 our overall Best Smartphone Display award, and for the time being that continues for all of the reasons originally mentioned there. In particular, for implementing Color Management to provide multiple Color Gamuts, and then using the Color Management to provide the Highest Absolute Color Accuracy for Standard (sRGB/Rec.709) consumer content of any Smartphone or Tablet display that we have ever measured (in one of its four available screen modes, which many reviewers seem to overlook). |
viimati muutis krist2an 20.10.2014 18:38:57, muudetud 1 kord |
| Kommentaarid: 42 loe/lisa |
41 |
prtv
| Kommentaarid: 82 loe/lisa |
73 |
CnZ
20.10.2014 21:16:07
| krist2an kirjutas: |
Ei ole nii:
E: ja ka see
Oleksid võinud siiski alglingi ka panna. Googeldasain allika välja. Aga tegemist ühe konkreetse arvustuse ja testikogumiga.
Kuna endal holi mõni aeg tagasi kodus nii Nexus 5, iPhone 5S, 6 ja Galaxy S5, siis julgen öelda, et viimase puhul see tüüpiline Galaxy AMOLED ekraani värvide üleküllastatus - värvid ei ole accurate. Teed sama telefoniga pildi heas valguskeskkonnas olevast punasest tulbist. Galaxy ekraanil nagu nii erkpunane kui punane veel olla saab ebareaalselt. Sama pilt iPhone 6 või Apple Thunderbolt (H-IPS paneel) suure monitori peal hoopis naturaalsem. Muideks Samsung ise on vaikselt üle minemas PLS paneeli tehnoloogiale, jäätes AMOLEDi selja taha.
| Kommentaarid: 14 loe/lisa |
ThedEviL
21.10.2014 09:21:05
Ise ka ütlevad et google pole chrome'ile lihtsalt viitsinud teha 32bit codecit.
iPhone 6 nii paljudes testides selliseid häid tulemusi näitab ja seda 1 GB RAMi puhul, pidi ju sinu väite kohaselt 64bit raua ja tarkvara koostöö paremus välja tulema alles peale 4GB RAMi
See on küll väga hea võrdlus. Tuletan meelde, et alati kui Õun tuleb välja uue mudeliga, on vana mudel aeglasem kui uus. Vanale mudelile lihtsalt ei looda enam optimeeringuid, isegi kui riistvaraliselt pole ta mitte üksteps kehvem. Kui keegi ei viitsi teha enam tarkvara arendust eelmisele generatsioonile, ei tähenda et eelmine generatsioon riistvaraliselt kehvem on
Ära tule Windowsi masinaid ARM maailmaga võrdlema,
Keegi pole windowsiga midagi võrrelnud. Võrdleme ikka linuxiga. Droid on linux. See, et droidil kasutatakse RISC protsessoreid, ei anna automaatselt talle eristaatust.
Üleüldiselt on Windowsis kõik optimeeringud tehtud juba viimased paar aastat just 64bit süsteemile. Seega, pole nagu windowsi all töötava chrome'i võrdlemine väga pädev.
Jääb täiesti arusaamatuks miks rahvas selle 64bit prosega nüüd kohe mõistuse ära kaotanud on.
Kas tal on perspektiivi, JAH, tulevikus, kui mäluhulgad lähevad suuremaks.
Kas ta on PRAEGU parem kui 32bit, EI. Senikaua kui enamus tarkvara optimeeringuid on 32bit süsteemile ning enamus arendust on just 32bit süsteemil, ei ole 64bit peal mingit eelist. Kui selle 64bit propaganda nii suureks aetakse, et enam 32 bit arendust üldse ei tehta, siis peab olude sunnil minema üle 64bit süsteemile.
Öelda, et 64bit on vingem, võimsam, kiirem, energiasäästlikum lihtsalt sellepärast et ta on 64bit on räige hülgemöla
97 |
joulukas
21.10.2014 09:41:29
| Marie kirjutas: |
| ThedEviL kirjutas: |
... Võid ju ise proovida, otsi mõni x64 kõlbulik suvaline masin, millel 2gb mälu.
Tee benchmargid 64bit ubuntuga ning 32bit ubuntuga. Ja ära tule ütlema, et mobiilidel ning tahvlid on teistmoodi kuna nad on pisemad  |
Ära tule Windowsi masinaid ARM maailmaga võrdlema, vaata parem ja mõtle miks iPhone 6 nii paljudes testides selliseid häid tulemusi näitab ja seda 1 GB RAMi puhul, pidi ju sinu väite kohaselt 64bit raua ja tarkvara koostöö paremus välja tulema alles peale 4GB RAMi |
See A7/A8 head saavutused testides on pigem seotud ARMv8 kasutusele võtuga. Lisaks tundub, et cyclone on kenasti õnnestunud tuum, paistab, et mehed ei tegele vaid ümarate nurkade ja turunduse planeerimisega. 64 biti on küll kaas-faktor, aga seal on pigem küsimus appide ja OSi optimiseerimises, uues arhitektuuris ja kenas riistvaras, kui 64 biti ilmumises. Jama selle õunakese juures on see, et 1GB mälu lisamises on tulevik tume, kuna multi-tasking saab sellest mõjutatud, 64 biti sind siin kahjuks ei päästa.
_________________ HinnaVaatlus liituja nr. 285 |
| Kommentaarid: 16 loe/lisa |
14 |
tiitise
21.10.2014 11:43:56
| CnZ kirjutas: |
Mingil põhjusel on amoled display note 4-l kõige parema pildiga ja täpsema värviedastusega. Parem isegi kui iphone6 ekraan. Milles siis täpsemalt ta ipsile alla jääb?
Kuna nexus 6 amolediga siis tekkis endal ka soov lõpuks soetada aga kahjuks suurus on see mis natuke eemale tõukab.
Ootan huviga ülevaateid ja arvamusi.
| Kommentaarid: 6 loe/lisa |
krist2an
21.10.2014 14:19:45
| CnZ kirjutas: |
Kuna endal holi mõni aeg tagasi kodus nii Nexus 5, iPhone 5S, 6 ja Galaxy S5, siis julgen öelda, et viimase puhul see tüüpiline Galaxy AMOLED ekraani värvide üleküllastatus - värvid ei ole accurate. Teed sama telefoniga pildi heas valguskeskkonnas olevast punasest tulbist. Galaxy ekraanil nagu nii erkpunane kui punane veel olla saab ebareaalselt. Sama pilt iPhone 6 või Apple Thunderbolt (H-IPS paneel) suure monitori peal hoopis naturaalsem. Muideks Samsung ise on vaikselt üle minemas PLS paneeli tehnoloogiale, jäätes AMOLEDi selja taha. |
Loeme nüüd uuesti:
Kasutasid ikka õiget ekraaniseadistust?
41 |
ninzor
21.10.2014 16:41:30
| Motorola kõrgema otsa nutitelefonid tulevad AMOLED ekraanidega, et Ambient display(Nexus 6)/Active Display(Moto X)/Moto Display(Moto X 2nd gen.) oleks võimaldatav mõistliku akukasutusega, mis on vägagi tervitatav lahendus, eriti seadmele, mille kättesaadavus peaks laialdasem olema kui Motorola enda brändi omade siin maal.
| Kommentaarid: 225 loe/lisa |
195 |
Mario.
21.10.2014 18:46:11
Valest otsast jahute.
L = RAW! FTW
Mida see minu kui fotograafi jaoks tähendab, on midagi ligilähedast kompromissitusetusele e mul on on-demand taskus võimekas aparaat, mis kiire workflow korral ajab sellist pilti välja, et oi oi.
Full manual controls + raw.
Kiire test öises keskkonnas (muidugi päevavalgus on teine tera, aga et anda aimdu, mis on raw ja mitte..) @ G2 @ Mi2raw:
Vasak RAW ISO 100 exposure pushed +5
Keskmine JPEG ISO 800
Parem JPEG ISO 100 lol ?
http://www.upload.ee/image/4319084/IMG_20141021_191706.jpg
6 :: |
217 |
CnZ
21.10.2014 19:19:11
http://www.phonearena.com/reviews/Screen-comparison-Galaxy-S5-vs-iPhone-5s-vs-One-M8-vs-Note-3-vs-Nexus-5-vs-G2_id3652
| When it comes to overall color balance and accuracy, the iPhone 5s and Nexus 5 have the best screens around, with the iPhone 5s having a slightly better balance between primary and secondary colors, and the Nexus 5 exhibiting a more accurate color temperature. All other handsets participating in this comparison are far behind these two in this department. |
| At the end of the day, we can conclude that while Samsung's Super AMOLED screens have come a long way since their debut, there's still much to ask for. If you simply love their extra-vivid and punchy nature - that's perfectly OK - no one can deny that they really look fancy and impressive. They also have the notable advantage of being able to display perfect black, which enables their attractive, contrasty look. On the other hand, though, the LCD tech's ability to replicate colors exactly as they are in reality is a whole other type of achievement, and one that should not be underestimated. |
21.10.2014 19:46:58
| Lahe. Tänapäeval vaieldakse tsitaatidega - minu copy/paste mingilt random lehelt on parem kui sinu oma!
146 |
CnZ
21.10.2014 20:11:42
Eks ta selline kerge väljapääsutee ole. Ja mis parata, kui oma ala spetsialistid hindavada - miks mitte!
Endal pole aparatuuri, piisavat kogemust ega viitsimist-tahtmist nende nittide jms parameetrite mõõtmiseks, küll aga on olnud käes kasutamiseks pea kõik high-end telefonid. Ja vaielda võib palju tahes on ka viimase, Galaxy S5, ekraani puhul kasutatud lolli värvide üleküllastamist. Mid-toonid on ka lisaks "pestud". Olenemata värviprofiilist.
21.10.2014 20:21:01
Keegi ütles kunagi Eesti audio newsgroup'is hästi: "Autosse high-end helisüsteemi ehitamine on lihtne - tuleb hankida kiire auto millega saab ruttu koju sõita. Koju, kus on siis suured kõlarid ja muu hea tehnika." Sõnastus oli teine aga mõte sama.
Ehk siis mobiiliekraanilt "loomulikkust" otsida tundub mu jaoks kergelt kummaline. Seda enam, et tegu on igaljuhul mitmekordselt digitöödeldud signaaliga. Kui tahad "loomulikkust" ja õigeid värve siis vaata peenras tulpi või mine botaanikaaeda. Mitte ära vahi mobla ekraani.
146 |
kussu
| Kommentaarid: 69 loe/lisa |
68 |
ihvike
| Kommentaarid: 12 loe/lisa |
12 |
dex
22.10.2014 13:32:13
| Mark0 kirjutas: |
Ehk siis mobiiliekraanilt "loomulikkust" otsida tundub mu jaoks kergelt kummaline. Seda enam, et tegu on igaljuhul mitmekordselt digitöödeldud signaaliga. Kui tahad "loomulikkust" ja õigeid värve siis vaata peenras tulpi või mine botaanikaaeda. Mitte ära vahi mobla ekraani. |
Milleks üldse kuhugi areneda? Siksiga sai ka sõita ja nokia 5110 üsna talutavalt rääkida.
_________________ Süümi, juumi, makkami ja kui tüüle nakkami... |
| Kommentaarid: 97 loe/lisa |
86 |
iir
22.10.2014 14:22:46
just.
| Kommentaarid: 90 loe/lisa |
22.10.2014 15:19:13
| Kas SAMOLED on sigull?
146 |
dex
22.10.2014 15:27:44
minu võrdluses on 5110 ühe värviline vedelkristallekraan sigull. SAMOLED on pigem nagu tesla
86 |
CnZ
22.10.2014 18:53:34
SAMOLED on pigem nagu Hyundai Genesis. Nagu oleks premium, aga ei ole ka.
Ennast tõestanud ja "rafineeritum" valik IPS. Autode maailmast päris S-klassi ei hakka paralleeliks tooma, küll aga lihtsalt IPS=saksa pill
bitCON
23.10.2014 11:38:04
| ot: |
http://www.phoronix.com/scan.php?page=article&item=ubuntu_1410_32v64&num=1 järgminekord tead oma suu kinni hoida kui ei tea millest räägid |
23.10.2014 15:53:42
| CnZ kirjutas: |
Ennast tõestanud ja "rafineeritum" valik IPS. Autode maailmast päris S-klassi ei hakka paralleeliks tooma, küll aga lihtsalt IPS=saksa pill  |
Ma võibolla ei saanud aru millest jutt on aga kõrvuti Samsung Galaxy S2 SAMOLED ekraan ja Nexus 5 IPS siis esimene on ikka ilusate kirgaste värvidega ja ei jää päikesevalguses vaadateski hätta, IPS tundub suht tuhm selle kõrval. Eraldi nüüd Nexust kasutades ei tunne samas aga OLEDist veel puudust
| Kommentaarid: 261 loe/lisa |
227 |
ihvike
23.10.2014 16:08:49
| OLED on vaieldamatult igas mõttes parem tehnoloogia kui IPS, seega küsimus on ainult implemetantsioonis. Selle teema üle saab argumenteeritult vaielda ainult nii, et IPS ekraan selles konkreetses telefonis on parem kui OLED ekraan konkreetses teises telefonis, kuna seal pole osatud OLEDi potentsiaali ära kasutada ja seetõttu on (sisesta mõni objektiivne kriteerium) kehvem kui IPS ekraanil.
12 |
23.10.2014 18:14:32
| indrekp kirjutas: |
| CnZ kirjutas: |
Ma võibolla ei saanud aru millest jutt on aga kõrvuti Samsung Galaxy S2 SAMOLED ekraan ja Nexus 5 IPS siis esimene on ikka ilusate kirgaste värvidega ja ei jää päikesevalguses vaadateski hätta, IPS tundub suht tuhm selle kõrval. Eraldi nüüd Nexust kasutades ei tunne samas aga OLEDist veel puudust  |
S2 ekraan on ju rõvedalt roheline-sinine võrreldes IPS'ga.
Pane kõrvuti kummalegi valge pilt ja saad aru.
| Kommentaarid: 85 loe/lisa |
