Braien
01.01.2013 16:55:59
omgwtf, No kui power on count on sisse lülitamiste arv, siis võrdle enda power on count ja power on hours teistega, saad vastuse.
90 |
Chaza!
01.01.2013 17:33:51
Kas linuxis ka seda kuidagi vaadata saab?
Smartctl andis sellise väljundi:
sudo smartctl -a /dev/sda
smartctl 5.41 2011-06-09 r3365 [i686-linux-3.2.0-35-generic-pae] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Intel 320 Series SSDs
Device Model: INTEL SSDSA2CW120G3
Serial Number: CVPR147302G1120LGN
LU WWN Device Id: 5 001517 bb275d39f
Firmware Version: 4PC10362
User Capacity: 120 034 123 776 bytes [120 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Tue Jan 1 16:32:47 2013 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 1) seconds.
capabilities: (0x75) SMART execute Offline immediate.
No Auto Offline data collection support.
Abort Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
Conveyance self-test routine
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 5
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
3 Spin_Up_Time 0x0020 100 100 000 Old_age Offline - 0
4 Start_Stop_Count 0x0030 100 100 000 Old_age Offline - 0
5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 4806
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1001
170 Reserve_Block_Count 0x0033 100 100 010 Pre-fail Always - 0
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
183 Runtime_Bad_Block 0x0030 100 100 000 Old_age Offline - 2
184 End-to-End_Error 0x0032 100 100 090 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
192 Unsafe_Shutdown_Count 0x0032 100 100 000 Old_age Always - 81
199 UDMA_CRC_Error_Count 0x0030 100 100 000 Old_age Offline - 0
225 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 125798
226 Workld_Media_Wear_Indic 0x0032 100 100 000 Old_age Always - 65535
227 Workld_Host_Reads_Perc 0x0032 100 100 000 Old_age Always - 65535
228 Workload_Minutes 0x0032 100 100 000 Old_age Always - 65535
232 Available_Reservd_Space 0x0033 100 100 010 Pre-fail Always - 0
233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 0
241 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 125798
242 Host_Reads_32MiB 0x0032 100 100 000 Old_age Always - 108442
SMART Error Log Version: 1
ATA Error Count: 1
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 1 occurred at disk power-on lifetime: 727 hours (30 days + 7 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 c3 40 83 93 d2 00 Error: UNC at LBA = 0x00d29383 = 13800323
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
20 00 40 83 93 d2 00 00 00:00:06.643 READ SECTOR(S)
18 00 30 08 47 64 00 00 00:00:06.643 RECALIBRATE [RET-4]
ef 90 00 83 93 d2 00 00 00:00:06.643 SET FEATURES [Reserved for Serial ATA]
ef 02 00 83 93 d2 00 00 00:00:06.643 SET FEATURES [Enable write cache]
20 00 40 83 93 d2 00 00 00:00:06.612 READ SECTOR(S)
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
Note: selective self-test log revision number (0) not 1 implies that no selective self-test has ever been run
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay. |
_________________ Linux - Future
1984 was not supposed to be instruction manual |
| Kommentaarid: 59 loe/lisa |
53 |
ThedEviL
01.01.2013 18:39:17
| omgwtf kirjutas: |
Mis kõik lülitavad ööseks omal välja kaste,või millest nii väiksed power on hoursid
Eputisest amatöör
[/spoiler]
97 |
omgwtf
137 |
pinTero
01.01.2013 19:03:49
Töötundidega on hulga etem ju uhkeldada:
Model Family: Intel X25-E SSDs
Device Model: SSDSA2SH032G1GN INTEL
Serial Number: CVEM010000TF032HGN
Firmware Version: 045C8860
User Capacity: 32,000,000,000 bytes
3 Spin_Up_Time 0x0000 100 000 000 Old_age Offline - 0
4 Start_Stop_Count 0x0000 100 000 000 Old_age Offline - 0
5 Reallocated_Sector_Ct 0x0002 100 100 000 Old_age Always - 0
9 Power_On_Hours 0x0002 100 100 000 Old_age Always - 20962
12 Power_Cycle_Count 0x0002 100 100 000 Old_age Always - 35
192 Unsafe_Shutdown_Count 0x0002 100 100 000 Old_age Always - 26
232 Available_Reservd_Space 0x0003 100 100 010 Pre-fail Always - 0
233 Media_Wearout_Indicator 0x0002 099 099 000 Old_age Always - 0
225 Host_Writes_32MiB 0x0000 200 200 000 Old_age Offline - 45241
226 Intel_Internal 0x0002 255 000 000 Old_age Always - 0
227 Intel_Internal 0x0002 000 000 000 Old_age Always - 0
228 Intel_Internal 0x0002 000 000 000 Old_age Always - 0
Aga serveriketas on vist cheatimine ja ma ei kvalifitseeru?
| Kommentaarid: 150 loe/lisa |
132 |
ThedEviL
01.01.2013 19:08:27
| pinTero kirjutas: |
Aga serveriketas on vist cheatimine ja ma ei kvalifitseeru?  |
A mul on ikkagi rohkem kui sul
Aga mis moodi on serveril write'e ainult 1.3TB jagu?
Lihtsalt süsteemikas, kus ühtegi andmebaasi peal pole?
97 |
pinTero
01.01.2013 19:29:13
| ThedEviL kirjutas: |
Lihtsalt süsteemikas, kus ühtegi andmebaasi peal pole? |
Raamatupidamise baas istub seal tegelikult uhkes üksinduses, aga ma kahtlustan, et seal on pigem lugemist rohkem, kui kirjutamist (kahju, et lugemisest smarti märget ei jää).
132 |
01.01.2013 19:59:38
| ThedEviL, tahad sa selgitada, kuidas sul Power On Hours on 2 aastat ja 5 kuud samas kui Force 3 tuli turule alles 1 aasta ja 4 kuud tagasi?
| Kommentaarid: 85 loe/lisa |
ThedEviL
01.01.2013 21:55:05
| mikk36 kirjutas: |
| ThedEviL, tahad sa selgitada, kuidas sul Power On Hours on 2 aastat ja 5 kuud samas kui Force 3 tuli turule alles 1 aasta ja 4 kuud tagasi? |
See on küll hea märge
Soetatud on ta 23.09.2011
Seega üle 11k ei tohiks seal kuidagi olla....
Mida krdit tähendab tal 12bfc4000052f6 mis on 5277398115308278?
kui võtta 4 viimast numbrit, siis saaks
21238,00
Huvitav kas Corsairil on RTC vigane?
SSD life arvab asjast sama.
Edit: Teema tõstatatud corsa foorumis.
97 |
omgwtf
02.01.2013 11:33:48
SSDLife järgi on mul 65% health samas ennustatav eluiga veel 8a8k18p
137 |
woox2k
04.01.2013 16:39:29
Mul isegi näitab power on tunde täitsa normaalselt... PS. hea number täna
Ei ole rahaboss, et 24/7 seda elukat töös hoida, selleks on säästumasin kuurinurgas
_________________ Mess with the best, die like the rest! |
| Kommentaarid: 20 loe/lisa |
18 |
lolloom
09.10.2013 02:41:01
Süsteemiketas alates 2013 juulist.
Total host writes: ~1TB
_________________ One does not simply overclock Sandy Bridge with SetFSB |
| Kommentaarid: 244 loe/lisa |
209 |
Braien
09.10.2013 06:57:41
Mul ka suvest saadik süsteemiketas.
90 |
heretic666
10.10.2013 11:13:31
OS ja mängud:
| Kommentaarid: 73 loe/lisa |
