praegune kellaaeg 06.04.2026 12:56:28
ikruusa
08.09.2010 18:01:01
| Njaa, esimene reaktsioon oli pilti vaadates "jummel, sellega saab peaaegu seksida". Kuidagi tobedalt suur paistab seal käes. Sellega nö. telefonikõnet teha oleks vist sama kui lauatelefoni täies hiilguses kõrvaääres hoida. Aga eks jah on bluetooth HF olemas, häälvalimine kah ja siis pole nagu hullu. Ütled nime ja helistadki. Kas mitte Android v2.2 polnud see versioon, kust häälkäskluste tugi tekkis? Kas Androide peab õpetama või nad nt. lihtsalt toetavad eestikeelseid käsklusi nagu Nokia? Minu Nokia käest küsid, et "Mis kell on?" ja see räägib viisakas eesti keeles vastu (ilma, et peaks õpetama v. sisselugema).
| Kommentaarid: 11 loe/lisa |
sagem
08.09.2010 22:01:38
| See mängib ka kindlasti downconverditud madalama bitikiirusega full HD-d resoga 1920x1080 ja lahjema koodekisiga mida on lihtsam prosel lahti pakkida.
arm2004
09.09.2010 11:13:58
sellega ei saagi niiviisi rääkida nagu tavalise telefoniga, s.t. kõrvaääres.
| GSMArena kirjutas: |
Telephony
This is certainly one of the most interesting features of the Galaxy Tab. Not because every user will be using the tablet for calls non-stop, but because it's interesting to see how Samsung implemented it.
And we are pleased to say that the South Korean company did a great job with it. You can talk on the phone using the built in microphone and loudspeaker, you can plug in a pair of headphones and use only the microphone or you can attach a handsfree and use its built-in mic instead. The even better news is there will also be a handsfree supplied in the retail package.
Bluetooth handsfree units are also compatible with the Samsung Galaxy Tab. And with the front-facing 1.3 MP videocall camera the capabilities of the device are basically as good as they get. Okay, you cannot hold the device next to your ear and talk in it but that's all you are missing and it would look ridiculous anyway. |
_________________ nooope! |
97 |
