KillerEST
05.01.2010 23:47:11
| No ma ei saa aru. Täpselt samad asjad töötavad ...
kaabakas
06.01.2010 04:53:24
Keerame raskusastet juurde:
su -c "yum remove pulseaudio padevchooser pavumeter paprefs pavucontrol" (kopi väljund meile ka)
reboot
95 |
KillerEST
08.01.2010 00:21:56
"Loaded plugins: refresh-packagekit
Setting up Remove Process
No Match for argument: padevchooser
adobe-linux-i386 | 951 B 00:00
rpmfusion-free-updates | 3.8 kB 00:00
rpmfusion-nonfree-updates | 3.8 kB 00:00
updates/metalink | 20 kB 00:00
updates | 4.4 kB 00:00
updates/primary_db | 4.9 MB 00:09
Package(s) padevchooser available, but not installed.
No Match for argument: pavumeter
Package(s) pavumeter available, but not installed.
No Match for argument: paprefs
Package(s) paprefs available, but not installed.
No Match for argument: pavucontrol
Package(s) pavucontrol available, but not installed.
Resolving Dependencies
--> Running transaction check
---> Package pulseaudio.i586 0:0.9.15-17.fc11 set to be erased
--> Processing Dependency: libprotocol-native.so for package: pulseaudio-module-x11-0.9.15-17.fc11.i586
--> Processing Dependency: libpulsecore-0.9.15.so for package: pulseaudio-module-bluetooth-0.9.15-17.fc11.i586
--> Processing Dependency: libpulsecore-0.9.15.so for package: pulseaudio-module-gconf-0.9.15-17.fc11.i586
--> Processing Dependency: libpulsecore-0.9.15.so for package: pulseaudio-module-x11-0.9.15-17.fc11.i586
--> Processing Dependency: pulseaudio for package: alsa-plugins-pulseaudio-1.0.21-2.fc11.i586
--> Processing Dependency: pulseaudio = 0.9.15-17.fc11 for package: pulseaudio-module-bluetooth-0.9.15-17.fc11.i586
--> Processing Dependency: pulseaudio = 0.9.15-17.fc11 for package: pulseaudio-module-gconf-0.9.15-17.fc11.i586
--> Processing Dependency: pulseaudio = 0.9.15-17.fc11 for package: pulseaudio-module-x11-0.9.15-17.fc11.i586
---> Package alsa-plugins-pulseaudio.i586 0:1.0.21-2.fc11 set to be erased
---> Package pulseaudio-module-bluetooth.i586 0:0.9.15-17.fc11 set to be erased
--> Processing Dependency: pulseaudio-module-bluetooth for package: gnome-bluetooth-2.27.8-3.fc11.i586
---> Package pulseaudio-module-gconf.i586 0:0.9.15-17.fc11 set to be erased
---> Package pulseaudio-module-x11.i586 0:0.9.15-17.fc11 set to be erased
---> Package gnome-bluetooth.i586 0:2.27.8-3.fc11 set to be erased
--> Processing Dependency: dbus-bluez-pin-helper for package: bluez-4.42-9.fc11.i586
--> Processing Dependency: gnome-bluetooth = 2.27.8-3.fc11 for package: gnome-bluetooth-libs-2.27.8-3.fc11.i586
---> Package bluez.i586 0:4.42-9.fc11 set to be erased
---> Package gnome-bluetooth-libs.i586 0:2.27.8-3.fc11 set to be erased
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Removing:
pulseaudio i586 0.9.15-17.fc11 installed 1.7 M
Removing for dependencies:
alsa-plugins-pulseaudio i586 1.0.21-2.fc11 installed 86 k
bluez i586 4.42-9.fc11 installed 1.0 M
gnome-bluetooth i586 2.27.8-3.fc11 installed 1.3 M
gnome-bluetooth-libs i586 2.27.8-3.fc11 installed 95 k
pulseaudio-module-bluetooth i586 0.9.15-17.fc11 installed 183 k
pulseaudio-module-gconf i586 0.9.15-17.fc11 installed 18 k
pulseaudio-module-x11 i586 0.9.15-17.fc11 installed 40 k
Transaction Summary
Remove 8 Package(s)
Reinstall 0 Package(s)
Downgrade 0 Package(s)
Is this ok [y/N]: y
Downloading Packages:
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
Erasing : bluez-4.42-9.fc11.i586 1/8
Erasing : gnome-bluetooth-libs-2.27.8-3.fc11.i586 2/8
Erasing : pulseaudio-module-x11-0.9.15-17.fc11.i586 3/8
Erasing : pulseaudio-module-bluetooth-0.9.15-17.fc11.i586 4/8
Erasing : pulseaudio-0.9.15-17.fc11.i586 5/8
Erasing : alsa-plugins-pulseaudio-1.0.21-2.fc11.i586 6/8
Erasing : pulseaudio-module-gconf-0.9.15-17.fc11.i586 7/8
Erasing : gnome-bluetooth-2.27.8-3.fc11.i586 8/8
Removed:
Dependency Removed:
Complete!"
// Päris pikk sai, ei märganudki. Läksin kohe rebooti tegema...
Igastahes "ps ax | grep pulse" pärast rebooti:
" 2212 pts/0 S+ 0:00 grep pulse"
Proovisin Settlersit käivitada ja tuli selline:
"waitpid(): No child processes
err:wave:PULSE_ContextStateCallback Context failure: Internal error
err:wave:PULSE_WaveInit Failed to connect to server
wine: Unhandled page fault on read access to 0x0000002a at address 0x2001dfa3 (thread 0009), starting debugger...
wine: Unhandled page fault on read access to 0x0000002a at address 0x68279fa3 (thread 0150), starting debugger...
err:seh:start_debugger Couldn't start debugger ("winedbg --auto 335 64") (87)
Read the Wine Developers Guide on how to set up winedbg or another debugger"
// Otsisin ringi ja leidsin sellise asja: http://forum.winehq.org/viewtopic.php?t=1457
Et kas tasuks sealt midagi vaadata ja proovida?
kaabakas
08.01.2010 03:09:35
Seal käib jutt pulseaudio disablemisest, mis on sul juba tehtud. Vaata winecfg audio tabi, kas seal pulse lubatud pole? Keela kõik peale alsa.
95 |
KillerEST
08.01.2010 15:00:30
| Kui ma maha võtsin, siis ei olnud midagi, isegi mitte Alsat. praegu on mul ka seal ainult PulseAudio, Alsat ei ole.
Riivo
08.01.2010 20:53:14
| Praegu ei lähe mäng käima, sest wine otsib pulseaudio serverit, aga seda pole. Ehk on lahendus alsa paigaldada ja wine sellele ka suunata.
221 |
KillerEST
10.01.2010 18:18:36
Võtsin siis Wine alt PulseAudio linnukese ära ja panin Alsale linnukese.
Tuli selline error alguses:
wine: Unhandled page fault on read access to 0x0000002a at address 0x6848ffa3 (thread 014e), starting debugger...
wine: Unhandled page fault on read access to 0x0000002a at address 0x75664fa3 (thread 0150), starting debugger...
err:seh:start_debugger Couldn't start debugger ("winedbg --auto 335 52") (4)
Pärast seda tuli selline:
"0x8968e00:1: Handle table last=37 count=64 process=0x8968cb0
000c: 0x8686928 04120089 File fd=0x8693360
0010: 0x86933d8 04120116 File fd=0x8693410
0014: 0x8693488 04120116 File fd=0x86934c0
0034: 0x89685c8 041f0003 Event manual=1 signaled=1 name=""
0090: 0x8686928 04120089 File fd=0x8693360
0094: 0x86933d8 04120116 File fd=0x8693410
0098: 0x8693488 04120116 File fd=0x86934c0
0x89685c8:1: Event manual=1 signaled=1 name=""
0x86934c0:1: Fd unix_fd=24 user=0x8693488 options=00000020
0x8693488:2: File fd=0x86934c0
0x8693410:1: Fd unix_fd=23 user=0x86933d8 options=00000020
0x86933d8:2: File fd=0x8693410
0x8693360:1: Fd unix_fd=22 user=0x8686928 options=00000020
0x8686928:2: File fd=0x8693360"
// Aa ja pärast PulseAudio maha võtmist oli sama asi.
Vaatasin seda kirja "Couldn't start debugger ("winedbg --auto [kaks vähemalt kahekohalist numberit. St. iga kord erinev.]")"
Kui kirjutan selle sama winedbg, näiteks: "winedbg --auto 355 64")", siis tuleb selline teade terminali: "Can't attach process 0163: error 87" ja aknas tuleb teade sellisena :"Internal errors - invalid parameters received".
Kuskilt lugesin veel, et nendele ".dll" failid kasutavad liiga vähe mälu vms ja seetõttu ei pruugi mäng või programm tööle minna.
Leidsin lingi: https://bugzilla.redhat.com/show_bug.cgi?id=550736
Ma käivitasin uuesti ja uurisin kõik korralikult läbi.
Alguses leidsin sellise asja:
"ALSA lib pcm_dmix.c:1010:(snd_pcm_dmix_open) unable to open slave
Kas nii ei ole võimalik, et võtan kõik driverid maha? Et kas siis võiks hakata tööle?
Natuke guugeldasin ja leidsin ühest foorumist sellise teema: http://bbs.archlinux.org/viewtopic.php?id=79700
Eks ma proovin seda "OSS"-i installida, ehk aitab (Muud võimalust ma hetkel ei leia).
No ei saa selle OSS-i pealepanemisega hakkama . Ei leia õiget pakki, mida tõmmata.
kaabakas
11.01.2010 05:47:45
Ikka üsna kole on see värk sul. Oled kindel et mälu korras on? Memtest tuleb kontrollima.
95 |
11.01.2010 09:08:29
| ot: |
kaabakas, kell 5.47 oled "juba foorumis" või "alles foorumis"?  |
kaabakas
11.01.2010 10:03:32
| ot: |
| Dogbert kirjutas: |
Seekord juba. Sessiajal kella ei tunta:) Kuigi üldiselt karjub minu iseloom millegi sellise järele http://xkcd.com/320/ |
95 |
KillerEST
16.01.2010 14:04:49
| kaabakas kirjutas: |
| Ikka üsna kole on see värk sul. Oled kindel et mälu korras on? Memtest tuleb kontrollima. |
Mälu peaks korras olema. Kui vaja siis võin ära teha selle testi.
// Sa mõtlesid vist RAM'i arvatavasti?
Kõvaketta kohapealt on nii, et sellel oli kilobaitides ainult vaba ruumi, hetkel tühjendan natuke.
Mõtted täiesti otsas... Ennem vist korda ei saa, kui ma Windowsi uuesti peale panen
kaabakas
16.01.2010 15:38:42
Tee memtest ära ja kui mälu korras on siis pane prooviks ubuntu.
95 |
KillerEST
16.01.2010 16:07:04
| Memtest justkui olemas, aga käivitada ei saa kuidagimoodi.
marqs
16.01.2010 16:48:05
| KillerEST kirjutas: |
| Memtest justkui olemas, aga käivitada ei saa kuidagimoodi. |
Kui memtest pakist paigaldatud, siis käima tuleb ta tõmmata alglaadimisel läbi grubi menüü - sinna on kõigi eelduste kohaselt üks-kaks valikut juurde tekkinud.
_________________ 0xDEAD
0xBEEF |
| Kommentaarid: 28 loe/lisa |
kaabakas
95 |
KillerEST
16.01.2010 17:52:34
Oot, ma ei saa täpselt aru. Kuidas ma täpsemalt käima saan alglaadimisel?
Proovisin sealt tõmmata, aga seal on "iso" failid, millega ma midagi teha ei saa.
marqs
16.01.2010 18:22:41
Paned arvuti käima, ootad, kuni on ees menüü, kus esimeseks valikuks on Fedora. Otsid valikut, millel nimeks memtest, memtest86, Memory Test või muu sarnane. Seda eeldusel, et Fedora vaikimisi installis on memorytest juba paigaldatud või oled selle ise pakihaldurist peale klikkinud. Kui memtest tegelikult paigas ei ole (a'la oled kusagilt mingi memtest-nimelise asja alla sikutanud aga ei mõista sellega midagi peale hakata), tutvud pakihalldusega - http://docs.fedoraproject.org/user-guide/f11/en-US/html/chap-User_Guide-Managing_software.html#sect-User_Guide-Using_PackageKit-Installing_software - ning paigaldad paki, millel nimeks memtest86+. Kui peale seda alglaadimisel menüüs Memory Test (või sarnast) valikut ei ole, käivitad juurikana /usr/sbin/memtest-setup ja proovid uuesti.
Väidetavalt on see olemas ka Fedora plaadil - http://docs.fedoraproject.org/install-guide/f11/en-US/html/ch-beginninginstallation.html#sn-boot-menu
0xBEEF |
KillerEST
17.01.2010 11:17:35
Peaks olemas olema küll, aga ta ei näita ennast.
Kuidagi peaks saama ju sinna menüüsse käskudega selle tekitada? Ainult et ma ei tea kuidas.
Selline pakk on mul installitud: "Stand-alone memory tester for x86 and x86-64 computers. Memtest86+-2.11-9.fc11 (i586)"
Riivo
17.01.2010 13:36:37
Lisa /boot/grub/menu.lst faili
title Memtest86
root (hd0,0)
kernel /boot/memtest.bin |
221 |
KillerEST
17.01.2010 15:16:34
| Mis käsuga seda faili saab täpsemalt avada?
Riivo
17.01.2010 15:31:54
| Mis käsuga seda faili saab täpsemalt avada? |
| sudo gedit /boot/grub/menu.lst |
"gedit'i" võid asendada enda lemmik tekstiredaktoriga. Seal failis peaks juba ees näha olema praegused valikud.
221 |
KillerEST
17.01.2010 16:34:33
Ei leia faili üles, kuigi see on olemas.
Sellised failid on mul hoopis seal: "elf-memtest86+-2.11" ja "memtest86+-2.11".
Riivo
17.01.2010 17:23:48
| Ehk on Fedoras see menüü fail hoopis asukohaga /etc/grub.conf.
221 |
Andykas
17.01.2010 17:24:57
kirjuta siia kogu wine output, nt:
wine S4.exe > ~/Desktop/output.txt
| Kommentaarid: 25 loe/lisa |
22 |
KillerEST
17.01.2010 17:46:38
@riivo21
Valik oli olemas, aga faili ta ei leidnud, kuigi see oli olemas.
@Andykas
Testin hetkel Windowsi versioon 2000'ga (Ma olen kõik läbi proovinud muidu). Audiodriveriks Alsa:
Kui kirjutan "wine S4.exe > ~/Desktop/output.txt", siis ta tuleb ikkagi terminali ja txt fail on tühi, kui ma kirjutan: "wine S4.exe &> ~/Desktop/output.txt", siis tuleb.
Ei hakka tervet siia kopima, panen lingina :
S4.exe, (The Settlers IV Demo kaustas) Speedyshare (Siit ei pea tõmbama)
S4-main.exe (The Settlers IV Demo/Exe kaustas) Speedyshare (Siit ei pea tõmbama)
