praegune kellaaeg 24.04.2026 06:30:37
airm
28.03.2008 23:12:38
sorry, fdisk -l /dev/sda
grub.confi faili sisu tahaks ka tegelt
| Kommentaarid: 56 loe/lisa |
50 |
j2nx
28.03.2008 23:19:41
| airm kirjutas: |
grub.confi faili sisu tahaks ka tegelt |
fdisk -l /dev/sda
Disk /dev/sda: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x90000000
Device Boot Start End Blocks Id System
/dev/sda1 1 1584 12723448+ 83 Linux
/dev/sda2 1585 1827 1951897+ 82 Linux swap / Solaris
/dev/sda3 * 1828 4377 20482843+ 7 HPFS/NTFS
grub.conf'i mul pole.
| Kommentaarid: 4 loe/lisa |
sf
28.03.2008 23:28:21
grub.conf on vägagi sama asi, mis menu.lst
_________________ pea kinni puu sees |
| Kommentaarid: 14 loe/lisa |
j2nx
28.03.2008 23:31:35
| sf kirjutas: |
| grub.conf on vägagi sama asi, mis menu.lst |
Vabandust
# menu.lst - See: grub(8), info grub, update-grub(8)
# grub-install(8), grub-floppy(8),
# grub-md5-crypt, /usr/share/doc/grub
# and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not use 'savedefault' or your
# array will desync and will not let you boot your system.
default 0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout 10
## hiddenmenu
# Hides the menu by default (press ESC to see the menu)
#hiddenmenu
# Pretty colours
#color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line) and entries protected by the
# command 'lock'
# e.g. password topsecret
# password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title Windows 95/98/NT/2000
# root (hd0,1)
# makeactive
# chainloader +1
# title Linux
# root (hd0,0)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
## kopt_2_6_8=root=/dev/hdc1 ro
## kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=UUID=97e8ddb8-dd16-40d9-b572-a306918fa414 ro
## Setup crashdump menu entries
## e.g. crashdump=1
# crashdump=0
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd0,1)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
## alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
## lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet splash
## should update-grub lock old automagic boot options
## e.g. lockold=false
## lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
## altoptions=(recovery) single
# altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
## howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
## memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## should update-grub add savedefault to the default options
# savedefault=false
## ## End Default Options ##
title Ubuntu 7.10, kernel 2.6.22-14-generic
root (hd0,0)
kernel /boot/vmlinuz-2.6.22-14-generic root=UUID=97e8ddb8-dd16-40d9-b572-a306918fa414 ro quiet splash
initrd /boot/initrd.img-2.6.22-14-generic
quiet
title Ubuntu 7.10, kernel 2.6.22-14-generic (recovery mode)
root (hd0,0)
kernel /boot/vmlinuz-2.6.22-14-generic root=UUID=97e8ddb8-dd16-40d9-b572-a306918fa414 ro single
title Ubuntu 7.10, memtest86+
root (hd0,0)
kernel /boot/memtest86+.bin
quiet
### END DEBIAN AUTOMAGIC KERNELS LIST
# This is a divider, added to separate the menu items below from the Debian
# ones.
title Other operating systems:
root
# This entry automatically added by the Debian installer for a non-linux OS
# on /dev/sda1
title Microsoft Windows XP Professional
root (hd0,2)
savedefault
makeactive
chainloader +1
hal.dll ülekirjutamine edu ei toonud, vist installin uuesti windowsi.
airm
28.03.2008 23:43:33
Ei ole windowsi segadus, seal peaks kõik hea olema.
Sa saad UID -jura vahetada /dev/sda[1,2]
nii fstab kui ka menu.1st failis ja siis proovida.
50 |
j2nx
29.03.2008 00:00:35
| airm kirjutas: |
nii fstab kui ka menu.1st failis ja siis proovida. |
Vabandust, mis on UID-jura?
fdisk ja menu.lst.
Paraku pole veel väga tuttav Linuxi käsustikuga
airm
29.03.2008 00:59:09
välja peaks nägema selline üks rida fstabis:
/dev/sda1 / ext3 defaults 0 0
kohe pead ka siis paralleelselt muutma menu.lst:
root (hd0,0)
kernel /boot/vmlinuz-2.6.22-14-generic root=/dev/sda1 ro quiet splash
Sarnasust näed?
Aga vist käib see meil üle jõu, kui siin igat muutujat tutvustame sulle
50 |
j2nx
29.03.2008 02:37:26
| airm kirjutas: |
root (hd0,0)
Sarnasust näed?
Aga vist käib see meil üle jõu, kui siin igat muutujat tutvustame sulle  |
Windowsit buutides ikka see sama error,
menu.lst lõpp on selline:
root (hd0,0)
quiet
root (hd0,0)
kernel /boot/vmlinuz-2.6.22-14-generic root=/dev/sda1 ro single
root (hd0,0)
quiet
# ones.
root
# on /dev/sda3
root (hd0,2)
savedefault
makeactive
chainloader +1
fstab:
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
# /dev/sda1
# /dev/sda2
/dev/sda2 / none swap sw 0 0
# /dev/sda3
/dev/sda3 / ntfs defaults 0 0
/dev/hda /media/cdrom0 udf,iso9660 user,noauto,exec 0 0 |
Eelnevas postis on õnneks vana originaal alles 8)
sf
29.03.2008 03:16:17
| airm kirjutas: |
| Ei ole windowsi segadus, seal peaks kõik hea olema. |
Ma jätkuvalt arvan, et ikkagi on segadus ja mitte hea. (kuigi ma windowsi buutimisest suurt ei tea)
Tundub, et ketta lõpus majandamise asemel on midagi muud tehtud. Sest on raske ette kujutada, et mingi windowsi partitsioneerimisvahend otsiks tundmatust failisüsteemist ühe konfifaili üles ja teeks sinna muudatusi (kahtlaselt õigesse kohta pealegi). Kettal on midagi liigutatud (võimalik, et eest midagi eemaldatud)
UUID jura ei puutu üldse asjasse. Kui grubi chainloader+1 ikkagi järje windowsile üle annab (ja annab, nagu näha), siis ei ole edasine üldse grubi konfiga ( ja veel vähem fstabiga) seotud.
Mul pole tõepoolest windowsi buutimisest vähimatki aimu, aga populaarne otsimootor annab vihjeid boot.ini parandamiseks bootcfg /rebuild käsuga (windowsis muidugi)
Kunagi olen dual-boot masinates grubile partitsioonide peitmise ja ümbermappimise korraldusi andnud, (millega ka windowsi püsti sai) aga ma oletan, et eelmises lõigus on parem meetod mainitud. Kuigi pole proovinud
j2nx
29.03.2008 13:09:29
Suur aitäh airm, marqs ja sf
Sain nüüd masinavärgi korda.
Leidsin netist otsides boot.ini parandamise õpetuse. Ning nüüd buudib end kenasti.
Oma aruga oleks alustanud jälle vist formatitega. Nüüd peaks Linuxi manuali leidma ja hakkama algusest peale omale asju selgeks tegema.
Suur aitäh, vastanutest oli palju abi. Hea kui leidub selliseid kannatlike tegelasi
