praegune kellaaeg 10.04.2026 20:48:38
david
28.09.2002 14:42:00
Mul HITACHI plõgiseb kogu aeg lapparis - 20GB. Ja juba mitu kuud. Igatahes, ootan väheke, enne kui garantiisse viin
Teip
28.09.2002 21:11:00
Read this:
Symptom
The hard disk drive in your IBM ThinkPad system may periodically emit a soft clicking sound. This sound may be more noticeable on hard disk drives manufactured by Hitachi
Affected configurations
Any IBM ThinkPad system.
Solution
None. This is not a problem. The hard disk drive is working as designed. See the Additional information section below for more details.
A new firmware update has been released for Hitachi DK23CA hard disk drives to reduce the sound level of this clicking. Please note that this firmware will only reduce the sound and will not completely nullify it.
Please check the file download section in this site to see if your hard drive is applicable for this firmware update.
This clicking sound is caused by the hard disk drive unloading and loading its heads. The head is designed to be periodically unloaded for various reliability reasons. When the hard drive is accessed (either by action from the user or by the operating system), the head will be reloaded. This unloading and loading causes this clicking sound. This is a normal sound and the hard disk drive is working as designed.
Document id: MIGR-42320
Last modified: 2002-05-23
Copyright © 2002 IBM Corporation
| Kommentaarid: 201 loe/lisa |
184 |
david
28.09.2002 22:34:00
Yeah.. põnev, aga mul on HP
Ja kuidas seletada seda, et vahepeal oli kaks kohta - viljandi korter, kus jäi plõksumine järgi.. Siis Tartu - esimene nädal plõksis ja jäi järgi... Kuid pärast op-süsteemi taasinstallimist plõksib jälle mõlemas kohas... Müstika.
pinTero
29.09.2002 17:03:00
Hmm, huvitav jutt tõesti! Aegu tagasi lugesin sama asja ka kusagilt, et pidada täiesti normaalne olema. Ainult, et miks siis osad klõbisevad ja teised mitte?
Samas jah, jutt ei käi ka konkreetselt mitte 60GXP kohta, aga ikkagi...
[ Seda sõnumit muutis: pinTero on 29.09.2002 17:03 ]
| Kommentaarid: 150 loe/lisa |
132 |
zeppelin
04.05.2003 14:12:23
| Peale paarinädalast kasutamist on ka minu Maxtor veidralt klõpsuma hakanud. SMART info näitab 'seek error rate' ja 'seek time performance' väärtuste pidevat muutumist. Kas peaks backupi tegema ja garantiisse saatma?
117 |
