praegune kellaaeg 24.04.2026 18:18:31
Dinkz
27.07.2013 14:29:27
Mul sellega ei toimind.
| Kommentaarid: 26 loe/lisa |
26 |
Mõmmik123
29.07.2013 22:19:48
| Dinkz kirjutas: |
Mul sellega ei toimind.  |
Mul kül toimis . Ju tegid miskit valesti.
| Kommentaarid: 7 loe/lisa |
KuriVaiM1
08.01.2014 11:01:45
Alternatiivne võimalus: protsessor sättida ainult 1 tuuma peale
Most of the computers nowadays have multi-core CPUs. However Scarface, was designed to run only on one core CPUs. You’ll need to configure your operation system to use only one core of your core CPU.
Click the start menu button on the bottom left and type in the Search Programs And Files Field “msconfig”. select Configuration. Go to the Boot tab and click the Advanced Options button. Tick the Number of Processors option and select 1 from the drop-down menu underneath. Click
OK, then OK again and you have configured your PC to use only 1 core of your CPU.
IMPORTANT: Don’t forget to revert back to the default settings after you are done playing Scarface. |
"Mõtle kriitiliselt" |
66 |
