1dumbpcuser
17.01.2010 09:53:07
Kellelegi on PAE veel uudiseks?
| Physical Address Extension @ Wikipedia kirjutas: |
| x86 processor hardware architecture is augmented with additional address lines used to select the additional memory, so physical address size is increased from 32 bits to 36 bits. This, theoretically, increases maximum physical memory size from 4 GiB to 64 GiB. The 32-bit size of the virtual address is not changed, so regular application software continues to use instructions with 32-bit addresses and (in a flat memory model) is limited to 4 gigabytes of virtual address space. The operating system uses page tables to map this 4 GiB address space into the 64 GiB of physical memory. The mapping is typically applied differently for each process. In this way, the extra memory is useful even though no single regular application can access it all simultaneously. |
Ilma PAE toeta proseta ei tee sa puuksugi, kuigi jah:
| PAE is provided by Intel Pentium Pro (and above) CPUs - including all later Pentium-series processors except the 400 MHz bus versions of the Pentium M, as well as by other processors such as the AMD Athlon and later AMD processor models with similar or more advanced versions of the same architecture. |
XYZ
17.01.2010 11:10:53
| 1dumbpcuser kirjutas: |
veel olulisem on see, et soovitud rakendus oleks kompileeritud PAE toega. ilma selleta pole kogu sellest jurast ikkagi vähimatki tolku.
XeStAiSy
Aeg Maha 2a
17.01.2010 14:20:09
| tomorrow kirjutas: |
Lisaks kuuldavasti pidi PAE mõningast ebastabiilsust põhjustama  |
Ma lähiajal proovin selle asja ära. Patchi tuleb kasutada koos PAEga mis see app lisab. Sisuliselt praegu istun EFI otsas 2.5 mb ram 4GBdist. X64 os küll näeb seda, kuid kõike ei kasuta. Homme lükkan peale x86 ja muljetab võib-olla isegi täna.
_________________ Punktkeevitus patareidele/akudele. Akutrelli/laptopi/e-bike. PM
viimati muutis XeStAiSy 17.01.2010 15:55:02, muudetud 1 kord |
17.01.2010 15:39:12
/OT alati soovitan kontrollida, kas sõna "istun" on korrektselt kirjutatud...
1dumbpcuser
XeStAiSy
Aeg Maha 2a
17.01.2010 18:00:33
| bladerunner kirjutas: |
/OT alati soovitan kontrollida, kas sõna "istun" on korrektselt kirjutatud...  |
| ot: |
Tavaliselt ma ei loe enda teksti lihsalt ja lasen kahe käega, mind see mis tuleb ei huvita. Leiti kah asi. Ega ma pole ka mingi masinakirjutaja. |
Jääb ära minu test esialgu, mul HDD GPT formaadis, see X86 setup hakkas vastu mölisema. GPT partion stiil ei meeldinud. Formatit teha nagu ka ei tahaks. Ometigi disk 3 oli NTFS
18.01.2010 00:22:33
Keda häirib tohutu logide hulk mida Windows tekitab, siis siitpoolt õpetus teha fail mis topeltkõpsuga puhastab kõik logid .Code tagide vahel olev tekst salvestage tekstifaili ja faililaiend muutke .txt-->.cmd
wevtutil.exe cl Analytic
wevtutil.exe cl Application
wevtutil.exe cl DirectShowFilterGraph
wevtutil.exe cl DirectShowPluginControl
wevtutil.exe cl EndpointMapper
wevtutil.exe cl ForwardedEvents
wevtutil.exe cl HardwareEvents
wevtutil.exe cl Internet Explorer
wevtutil.exe cl Key Management Service
wevtutil.exe cl MF_MediaFoundationDeviceProxy
wevtutil.exe cl "Media Center"
wevtutil.exe cl MediaFoundationDeviceProxy
wevtutil.exe cl MediaFoundationPerformance
wevtutil.exe cl MediaFoundationPipeline
wevtutil.exe cl MediaFoundationPlatform
wevtutil.exe cl Microsoft-IE/Diagnostic
wevtutil.exe cl Microsoft-IEFRAME/Diagnostic
wevtutil.exe cl Microsoft-PerfTrack-IEFRAME/Diagnostic
wevtutil.exe cl Microsoft-PerfTrack-MSHTML/Diagnostic
wevtutil.exe cl Microsoft-Windows-ADSI/Debug
wevtutil.exe cl Microsoft-Windows-API-Tracing/Operational
wevtutil.exe cl Microsoft-Windows-ATAPort/General
wevtutil.exe cl Microsoft-Windows-ATAPort/SATA-LPM
wevtutil.exe cl Microsoft-Windows-ActionQueue/Analytic
wevtutil.exe cl Microsoft-Windows-AltTab/Diagnostic
wevtutil.exe cl Microsoft-Windows-AppID/Operational
wevtutil.exe cl Microsoft-Windows-AppLocker/EXE and DLL
wevtutil.exe cl Microsoft-Windows-AppLocker/MSI and Script
wevtutil.exe cl Microsoft-Windows-Application-Experience/Problem-Steps-Recorder
wevtutil.exe cl Microsoft-Windows-Application-Experience/Program-Compatibility-Assistant
wevtutil.exe cl Microsoft-Windows-Application-Experience/Program-Compatibility-Troubleshooter
wevtutil.exe cl Microsoft-Windows-Application-Experience/Program-Inventory
wevtutil.exe cl Microsoft-Windows-Application-Experience/Program-Inventory/Debug
wevtutil.exe cl Microsoft-Windows-Application-Experience/Program-Telemetry
wevtutil.exe cl Microsoft-Windows-Audio/CaptureMonitor
wevtutil.exe cl Microsoft-Windows-Audio/Operational
wevtutil.exe cl Microsoft-Windows-Audio/Performance
wevtutil.exe cl Microsoft-Windows-Audit/Analytic
wevtutil.exe cl "Microsoft-Windows-Authentication User Interface/Operational"
wevtutil.exe cl Microsoft-Windows-AxInstallService/Log
wevtutil.exe cl Microsoft-Windows-Backup
wevtutil.exe cl Microsoft-Windows-Biometrics/Operational
wevtutil.exe cl Microsoft-Windows-BitLocker-DrivePreparationTool/Admin
wevtutil.exe cl Microsoft-Windows-BitLocker-DrivePreparationTool/Operational
wevtutil.exe cl Microsoft-Windows-Bits-Client/Analytic
wevtutil.exe cl Microsoft-Windows-Bits-Client/Operational
wevtutil.exe cl Microsoft-Windows-Bluetooth-MTPEnum/Operational
wevtutil.exe cl Microsoft-Windows-BranchCache/Operational
wevtutil.exe cl Microsoft-Windows-BranchCacheClientEventProvider/Diagnostic
wevtutil.exe cl Microsoft-Windows-BranchCacheEventProvider/Diagnostic
wevtutil.exe cl Microsoft-Windows-BranchCacheSMB/Analytic
wevtutil.exe cl Microsoft-Windows-BranchCacheSMB/Operational
wevtutil.exe cl Microsoft-Windows-CAPI2/Operational
wevtutil.exe cl Microsoft-Windows-CDROM/Operational
wevtutil.exe cl Microsoft-Windows-COM/Analytic
wevtutil.exe cl Microsoft-Windows-COMRuntime/Tracing
wevtutil.exe cl Microsoft-Windows-Calculator/Debug
wevtutil.exe cl Microsoft-Windows-Calculator/Diagnostic
wevtutil.exe cl Microsoft-Windows-CertPoleEng/Operational
wevtutil.exe cl Microsoft-Windows-CertificateServicesClient-CredentialRoaming/Operational
wevtutil.exe cl Microsoft-Windows-ClearTypeTextTuner/Diagnostic
wevtutil.exe cl Microsoft-Windows-CmiSetup/Analytic
wevtutil.exe cl Microsoft-Windows-CodeIntegrity/Operational
wevtutil.exe cl Microsoft-Windows-CodeIntegrity/Verbose
wevtutil.exe cl Microsoft-Windows-ComDlg32/Analytic
wevtutil.exe cl Microsoft-Windows-ComDlg32/Debug
wevtutil.exe cl Microsoft-Windows-CorruptedFileRecovery-Client/Operational
wevtutil.exe cl Microsoft-Windows-CorruptedFileRecovery-Server/Operational
wevtutil.exe cl Microsoft-Windows-CredUI/Diagnostic
wevtutil.exe cl Microsoft-Windows-Crypto-RNG/Analytic
wevtutil.exe cl Microsoft-Windows-DCLocator/Debug
wevtutil.exe cl Microsoft-Windows-DNS-Client/Operational
wevtutil.exe cl Microsoft-Windows-DUI/Diagnostic
wevtutil.exe cl Microsoft-Windows-DUSER/Diagnostic
wevtutil.exe cl Microsoft-Windows-DXP/Analytic
wevtutil.exe cl Microsoft-Windows-DateTimeControlPanel/Analytic
wevtutil.exe cl Microsoft-Windows-DateTimeControlPanel/Debug
wevtutil.exe cl Microsoft-Windows-DateTimeControlPanel/Operational
wevtutil.exe cl Microsoft-Windows-Deplorch/Analytic
wevtutil.exe cl Microsoft-Windows-DeviceSync/Analytic
wevtutil.exe cl Microsoft-Windows-DeviceSync/Operational
wevtutil.exe cl Microsoft-Windows-DeviceUx/Informational
wevtutil.exe cl Microsoft-Windows-DeviceUx/Performance
wevtutil.exe cl Microsoft-Windows-Dhcp-Client/Admin
wevtutil.exe cl Microsoft-Windows-Dhcp-Client/Operational
wevtutil.exe cl Microsoft-Windows-DhcpNap/Admin
wevtutil.exe cl Microsoft-Windows-DhcpNap/Operational
wevtutil.exe cl Microsoft-Windows-Dhcpv6-Client/Admin
wevtutil.exe cl Microsoft-Windows-Dhcpv6-Client/Operational
wevtutil.exe cl Microsoft-Windows-DiagCpl/Debug
wevtutil.exe cl Microsoft-Windows-Diagnosis-DPS/Analytic
wevtutil.exe cl Microsoft-Windows-Diagnosis-DPS/Debug
wevtutil.exe cl Microsoft-Windows-Diagnosis-DPS/Operational
wevtutil.exe cl Microsoft-Windows-Diagnosis-MSDE/Debug
wevtutil.exe cl Microsoft-Windows-Diagnosis-PCW/Analytic
wevtutil.exe cl Microsoft-Windows-Diagnosis-PCW/Debug
wevtutil.exe cl Microsoft-Windows-Diagnosis-PCW/Operational
wevtutil.exe cl Microsoft-Windows-Diagnosis-PLA/Debug
wevtutil.exe cl Microsoft-Windows-Diagnosis-PLA/Operational
wevtutil.exe cl Microsoft-Windows-Diagnosis-Perfhost/Analytic
wevtutil.exe cl Microsoft-Windows-Diagnosis-Scheduled/Operational
wevtutil.exe cl Microsoft-Windows-Diagnosis-Scripted/Admin
wevtutil.exe cl Microsoft-Windows-Diagnosis-Scripted/Analytic
wevtutil.exe cl Microsoft-Windows-Diagnosis-Scripted/Debug
wevtutil.exe cl Microsoft-Windows-Diagnosis-Scripted/Operational
wevtutil.exe cl Microsoft-Windows-Diagnosis-ScriptedDiagnosticsProvider/Debug
wevtutil.exe cl Microsoft-Windows-Diagnosis-ScriptedDiagnosticsProvider/Operational
wevtutil.exe cl Microsoft-Windows-Diagnosis-TaskManager/Debug
wevtutil.exe cl Microsoft-Windows-Diagnosis-WDC/Analytic
wevtutil.exe cl Microsoft-Windows-Diagnosis-WDI/Debug
wevtutil.exe cl Microsoft-Windows-Diagnostics-Networking/Debug
wevtutil.exe cl Microsoft-Windows-Diagnostics-Networking/Operational
wevtutil.exe cl Microsoft-Windows-Diagnostics-PerfTrack-Counters/Diagnostic
wevtutil.exe cl Microsoft-Windows-Diagnostics-PerfTrack/Diagnostic
wevtutil.exe cl Microsoft-Windows-Diagnostics-Performance/Diagnostic
wevtutil.exe cl Microsoft-Windows-Diagnostics-Performance/Diagnostic/Loopback
wevtutil.exe cl Microsoft-Windows-Diagnostics-Performance/Operational
wevtutil.exe cl Microsoft-Windows-DirectShow-KernelSupport/Performance
wevtutil.exe cl Microsoft-Windows-DirectSound/Debug
wevtutil.exe cl Microsoft-Windows-DirectWrite-FontCache/Tracing
wevtutil.exe cl Microsoft-Windows-Disk/Operational
wevtutil.exe cl Microsoft-Windows-DiskDiagnostic/Operational
wevtutil.exe cl Microsoft-Windows-DiskDiagnosticDataCollector/Operational
wevtutil.exe cl Microsoft-Windows-DiskDiagnosticResolver/Operational
wevtutil.exe cl Microsoft-Windows-DisplayColorCalibration/Debug
wevtutil.exe cl Microsoft-Windows-DisplayColorCalibration/Operational
wevtutil.exe cl Microsoft-Windows-DisplaySwitch/Diagnostic
wevtutil.exe cl Microsoft-Windows-Documents/Performance
wevtutil.exe cl Microsoft-Windows-DriverFrameworks-UserMode/Operational
wevtutil.exe cl Microsoft-Windows-DxgKrnl/Diagnostic
wevtutil.exe cl Microsoft-Windows-DxgKrnl/Performance
wevtutil.exe cl Microsoft-Windows-DxpTaskRingtone/Analytic
wevtutil.exe cl Microsoft-Windows-DxpTaskSyncProvider/Analytic
wevtutil.exe cl Microsoft-Windows-EFS/Debug
wevtutil.exe cl Microsoft-Windows-EapHost/Analytic
wevtutil.exe cl Microsoft-Windows-EapHost/Debug
wevtutil.exe cl Microsoft-Windows-EapHost/Operational
wevtutil.exe cl Microsoft-Windows-EaseOfAccess/Diagnostic
wevtutil.exe cl Microsoft-Windows-EventCollector/Debug
wevtutil.exe cl Microsoft-Windows-EventCollector/Operational
wevtutil.exe cl Microsoft-Windows-EventLog-WMIProvider/Debug
wevtutil.exe cl Microsoft-Windows-EventLog/Analytic
wevtutil.exe cl Microsoft-Windows-EventLog/Debug
wevtutil.exe cl Microsoft-Windows-FMS/Analytic
wevtutil.exe cl Microsoft-Windows-FMS/Debug
wevtutil.exe cl Microsoft-Windows-FMS/Operational
wevtutil.exe cl Microsoft-Windows-FailoverClustering-Client/Diagnostic
wevtutil.exe cl Microsoft-Windows-Fault-Tolerant-Heap/Operational
wevtutil.exe cl Microsoft-Windows-Feedback-Service-TriggerProvider
wevtutil.exe cl Microsoft-Windows-FileInfoMinifilter/Operational
wevtutil.exe cl Microsoft-Windows-Firewall-CPL/Diagnostic
wevtutil.exe cl "Microsoft-Windows-Folder Redirection/Operational"
wevtutil.exe cl Microsoft-Windows-Forwarding/Debug
wevtutil.exe cl Microsoft-Windows-Forwarding/Operational
wevtutil.exe cl Microsoft-Windows-GettingStarted/Diagnostic
wevtutil.exe cl Microsoft-Windows-GroupPolicy/Operational
wevtutil.exe cl Microsoft-Windows-HAL/Debug
wevtutil.exe cl Microsoft-Windows-HealthCenter/Debug
wevtutil.exe cl Microsoft-Windows-HealthCenter/Performance
wevtutil.exe cl Microsoft-Windows-HealthCenterCPL/Performance
wevtutil.exe cl Microsoft-Windows-Help/Operational
wevtutil.exe cl "Microsoft-Windows-HomeGroup Control Panel Performance/Diagnostic"
wevtutil.exe cl "Microsoft-Windows-HomeGroup Control Panel/Operational"
wevtutil.exe cl "Microsoft-Windows-HomeGroup Listener Service/Operational"
wevtutil.exe cl "Microsoft-Windows-HomeGroup Provider Service Performance/Diagnostic"
wevtutil.exe cl "Microsoft-Windows-HomeGroup Provider Service/Operational"
wevtutil.exe cl Microsoft-Windows-HomeGroup-ListenerService
wevtutil.exe cl Microsoft-Windows-HotStart/Diagnostic
wevtutil.exe cl Microsoft-Windows-HttpService/Trace
wevtutil.exe cl Microsoft-Windows-IKE/Operational
wevtutil.exe cl Microsoft-Windows-IKEDBG/Debug
wevtutil.exe cl Microsoft-Windows-IPBusEnum/Tracing
wevtutil.exe cl Microsoft-Windows-IPSEC-SRV/Diagnostic
wevtutil.exe cl Microsoft-Windows-International-RegionalOptionsControlPanel/Operational
wevtutil.exe cl Microsoft-Windows-International/Operational
wevtutil.exe cl Microsoft-Windows-Iphlpsvc/Debug
wevtutil.exe cl Microsoft-Windows-Iphlpsvc/Operational
wevtutil.exe cl Microsoft-Windows-Iphlpsvc/Trace
wevtutil.exe cl Microsoft-Windows-Kernel-Acpi/Diagnostic
wevtutil.exe cl Microsoft-Windows-Kernel-Boot/Analytic
wevtutil.exe cl Microsoft-Windows-Kernel-BootDiagnostics/Diagnostic
wevtutil.exe cl Microsoft-Windows-Kernel-Disk/Analytic
wevtutil.exe cl Microsoft-Windows-Kernel-EventTracing/Admin
wevtutil.exe cl Microsoft-Windows-Kernel-EventTracing/Analytic
wevtutil.exe cl Microsoft-Windows-Kernel-File/Analytic
wevtutil.exe cl Microsoft-Windows-Kernel-Memory/Analytic
wevtutil.exe cl Microsoft-Windows-Kernel-Network/Analytic
wevtutil.exe cl Microsoft-Windows-Kernel-PnP/Diagnostic
wevtutil.exe cl Microsoft-Windows-Kernel-Power/Diagnostic
wevtutil.exe cl Microsoft-Windows-Kernel-Power/Thermal-Diagnostic
wevtutil.exe cl Microsoft-Windows-Kernel-Power/Thermal-Operational
wevtutil.exe cl Microsoft-Windows-Kernel-Prefetch/Diagnostic
wevtutil.exe cl Microsoft-Windows-Kernel-Process/Analytic
wevtutil.exe cl Microsoft-Windows-Kernel-Processor-Power/Diagnostic
wevtutil.exe cl Microsoft-Windows-Kernel-Registry/Analytic
wevtutil.exe cl Microsoft-Windows-Kernel-StoreMgr/Analytic
wevtutil.exe cl Microsoft-Windows-Kernel-StoreMgr/Operational
wevtutil.exe cl Microsoft-Windows-Kernel-WDI/Analytic
wevtutil.exe cl Microsoft-Windows-Kernel-WDI/Debug
wevtutil.exe cl Microsoft-Windows-Kernel-WDI/Operational
wevtutil.exe cl Microsoft-Windows-Kernel-WHEA/Errors
wevtutil.exe cl Microsoft-Windows-Kernel-WHEA/Operational
wevtutil.exe cl Microsoft-Windows-Known Folders API Service
wevtutil.exe cl Microsoft-Windows-Known Folders/ Operational
wevtutil.exe cl Microsoft-Windows-L2NA/Diagnostic
wevtutil.exe cl Microsoft-Windows-LDAP-Client/Debug
wevtutil.exe cl Microsoft-Windows-LUA-ConsentUI/Diagnostic
wevtutil.exe cl Microsoft-Windows-LanguagePackSetup/Analytic
wevtutil.exe cl Microsoft-Windows-LanguagePackSetup/Debug
wevtutil.exe cl Microsoft-Windows-LanguagePackSetup/Operational
wevtutil.exe cl Microsoft-Windows-MCT/Operational
wevtutil.exe cl Microsoft-Windows-MPS-CLNT/Diagnostic
wevtutil.exe cl Microsoft-Windows-MPS-DRV/Diagnostic
wevtutil.exe cl Microsoft-Windows-MPS-SRV/Diagnostic
wevtutil.exe cl Microsoft-Windows-MSPaint/Admin
wevtutil.exe cl Microsoft-Windows-MSPaint/Debug
wevtutil.exe cl Microsoft-Windows-MSPaint/Diagnostic
wevtutil.exe cl Microsoft-Windows-MUI/Admin
wevtutil.exe cl Microsoft-Windows-MUI/Analytic
wevtutil.exe cl Microsoft-Windows-MUI/Debug
wevtutil.exe cl Microsoft-Windows-MUI/Operational
wevtutil.exe cl Microsoft-Windows-MediaFoundation-MFReadWrite/SinkWriter
wevtutil.exe cl Microsoft-Windows-MediaFoundation-MFReadWrite/SourceReader
wevtutil.exe cl Microsoft-Windows-MediaFoundation-MFReadWrite/Transform
wevtutil.exe cl Microsoft-Windows-MediaFoundation-PlayAPI/Analytic
wevtutil.exe cl Microsoft-Windows-MemoryDiagnostics-Results/Debug
wevtutil.exe cl Microsoft-Windows-MobilityCenter/Performance
wevtutil.exe cl Microsoft-Windows-NCSI/Analytic
wevtutil.exe cl Microsoft-Windows-NCSI/Operational
wevtutil.exe cl Microsoft-Windows-NDF-HelperClassDiscovery/Debug
wevtutil.exe cl Microsoft-Windows-NDIS-PacketCapture/Diagnostic
wevtutil.exe cl Microsoft-Windows-NDIS/Diagnostic
wevtutil.exe cl Microsoft-Windows-NDIS/Operational
wevtutil.exe cl Microsoft-Windows-NTLM/Operational
wevtutil.exe cl Microsoft-Windows-NWiFi/Diagnostic
wevtutil.exe cl Microsoft-Windows-Narrator/Diagnostic
wevtutil.exe cl Microsoft-Windows-NetShell/Performance
wevtutil.exe cl Microsoft-Windows-Network-and-Sharing-Center/Diagnostic
wevtutil.exe cl Microsoft-Windows-NetworkAccessProtection/Operational
wevtutil.exe cl Microsoft-Windows-NetworkAccessProtection/WHC
wevtutil.exe cl Microsoft-Windows-NetworkLocationWizard/Operational
wevtutil.exe cl Microsoft-Windows-NetworkProfile/Diagnostic
wevtutil.exe cl Microsoft-Windows-NetworkProfile/Operational
wevtutil.exe cl Microsoft-Windows-Networking-Correlation/Diagnostic
wevtutil.exe cl Microsoft-Windows-NlaSvc/Diagnostic
wevtutil.exe cl Microsoft-Windows-NlaSvc/Operational
wevtutil.exe cl Microsoft-Windows-OLEACC/Debug
wevtutil.exe cl Microsoft-Windows-OLEACC/Diagnostic
wevtutil.exe cl Microsoft-Windows-OOBE-Machine/Diagnostic
wevtutil.exe cl Microsoft-Windows-OfflineFiles/Analytic
wevtutil.exe cl Microsoft-Windows-OfflineFiles/Debug
wevtutil.exe cl Microsoft-Windows-OfflineFiles/Operational
wevtutil.exe cl Microsoft-Windows-OfflineFiles/SyncLog
wevtutil.exe cl Microsoft-Windows-OneX/Diagnostic
wevtutil.exe cl Microsoft-Windows-OobeLdr/Analytic
wevtutil.exe cl Microsoft-Windows-PCI/Diagnostic
wevtutil.exe cl Microsoft-Windows-ParentalControls/Operational
wevtutil.exe cl Microsoft-Windows-PeerToPeerDrtEventProvider/Diagnostic
wevtutil.exe cl Microsoft-Windows-PeopleNearMe/Operational
wevtutil.exe cl Microsoft-Windows-PortableDeviceStatusProvider/Analytic
wevtutil.exe cl Microsoft-Windows-PortableDeviceSyncProvider/Analytic
wevtutil.exe cl Microsoft-Windows-PowerCfg/Diagnostic
wevtutil.exe cl Microsoft-Windows-PowerCpl/Diagnostic
wevtutil.exe cl Microsoft-Windows-PowerEfficiencyDiagnostics/Diagnostic
wevtutil.exe cl Microsoft-Windows-PowerShell/Analytic
wevtutil.exe cl Microsoft-Windows-PowerShell/Operational
wevtutil.exe cl Microsoft-Windows-PrimaryNetworkIcon/Performance
wevtutil.exe cl Microsoft-Windows-PrintService/Admin
wevtutil.exe cl Microsoft-Windows-PrintService/Debug
wevtutil.exe cl Microsoft-Windows-PrintService/Operational
wevtutil.exe cl Microsoft-Windows-Program-Compatibility-Assistant/Debug
wevtutil.exe cl Microsoft-Windows-QoS-Pacer/Diagnostic
wevtutil.exe cl Microsoft-Windows-QoS-qWAVE/Debug
wevtutil.exe cl Microsoft-Windows-RPC/Debug
wevtutil.exe cl Microsoft-Windows-RPC/EEInfo
wevtutil.exe cl Microsoft-Windows-ReadyBoost/Analytic
wevtutil.exe cl Microsoft-Windows-ReadyBoost/Operational
wevtutil.exe cl Microsoft-Windows-ReadyBoostDriver/Analytic
wevtutil.exe cl Microsoft-Windows-ReadyBoostDriver/Operational
wevtutil.exe cl Microsoft-Windows-Recovery/Operational
wevtutil.exe cl Microsoft-Windows-ReliabilityAnalysisComponent/Operational
wevtutil.exe cl Microsoft-Windows-RemoteApp and Desktop Connections/Admin
wevtutil.exe cl Microsoft-Windows-RemoteAssistance/Admin
wevtutil.exe cl Microsoft-Windows-RemoteAssistance/Operational
wevtutil.exe cl Microsoft-Windows-RemoteAssistance/Tracing
wevtutil.exe cl Microsoft-Windows-Remotefs-UTProvider/Diagnostic
wevtutil.exe cl Microsoft-Windows-Resource-Exhaustion-Detector/Operational
wevtutil.exe cl Microsoft-Windows-Resource-Exhaustion-Resolver/Operational
wevtutil.exe cl Microsoft-Windows-Resource-Leak-Diagnostic/Operational
wevtutil.exe cl Microsoft-Windows-ResourcePublication/Tracing
wevtutil.exe cl Microsoft-Windows-RestartManager/Operational
wevtutil.exe cl Microsoft-Windows-Search-Core/Diagnostic
wevtutil.exe cl Microsoft-Windows-Search-ProtocolHandlers/Diagnostic
wevtutil.exe cl Microsoft-Windows-Security-Audit-Configuration-Client/Diagnostic
wevtutil.exe cl Microsoft-Windows-Security-Audit-Configuration-Client/Operational
wevtutil.exe cl Microsoft-Windows-Security-IdentityListener/Operational
wevtutil.exe cl Microsoft-Windows-Security-SPP/Perf
wevtutil.exe cl Microsoft-Windows-Sens/Debug
wevtutil.exe cl Microsoft-Windows-ServiceReportingApi/Debug
wevtutil.exe cl Microsoft-Windows-Services-Svchost/Diagnostic
wevtutil.exe cl Microsoft-Windows-Services/Diagnostic
wevtutil.exe cl Microsoft-Windows-Setup/Analytic
wevtutil.exe cl Microsoft-Windows-SetupCl/Analytic
wevtutil.exe cl Microsoft-Windows-SetupQueue/Analytic
wevtutil.exe cl Microsoft-Windows-SetupUGC/Analytic
wevtutil.exe cl Microsoft-Windows-ShareMedia-ControlPanel/Diagnostic
wevtutil.exe cl Microsoft-Windows-Shell-AuthUI-BootAnim/Diagnostic
wevtutil.exe cl Microsoft-Windows-Shell-AuthUI-Common/Diagnostic
wevtutil.exe cl Microsoft-Windows-Shell-AuthUI-CredUI/Diagnostic
wevtutil.exe cl Microsoft-Windows-Shell-AuthUI-Logon/Diagnostic
wevtutil.exe cl Microsoft-Windows-Shell-AuthUI-PasswordProvider/Diagnostic
wevtutil.exe cl Microsoft-Windows-Shell-AuthUI-Shutdown/Diagnostic
wevtutil.exe cl Microsoft-Windows-Shell-Core/Diagnostic
wevtutil.exe cl Microsoft-Windows-Shell-DefaultPrograms/Diagnostic
wevtutil.exe cl Microsoft-Windows-Shell-Shwebsvc
wevtutil.exe cl Microsoft-Windows-Shell-ZipFolder/Diagnostic
wevtutil.exe cl Microsoft-Windows-Shsvcs/Diagnostic
wevtutil.exe cl Microsoft-Windows-Sidebar/Diagnostic
wevtutil.exe cl Microsoft-Windows-Speech-UserExperience/Diagnostic
wevtutil.exe cl Microsoft-Windows-StickyNotes/Admin
wevtutil.exe cl Microsoft-Windows-StickyNotes/Debug
wevtutil.exe cl Microsoft-Windows-StickyNotes/Diagnostic
wevtutil.exe cl Microsoft-Windows-StorDiag/Operational
wevtutil.exe cl Microsoft-Windows-StorPort/Operational
wevtutil.exe cl Microsoft-Windows-Subsys-Csr/Operational
wevtutil.exe cl Microsoft-Windows-Subsys-SMSS/Operational
wevtutil.exe cl Microsoft-Windows-Superfetch/Main
wevtutil.exe cl Microsoft-Windows-Superfetch/StoreLog
wevtutil.exe cl Microsoft-Windows-Sysprep/Analytic
wevtutil.exe cl Microsoft-Windows-SystemHealthAgent/Diagnostic
wevtutil.exe cl Microsoft-Windows-TCPIP/Diagnostic
wevtutil.exe cl Microsoft-Windows-TSF-msctf/Debug
wevtutil.exe cl Microsoft-Windows-TSF-msctf/Diagnostic
wevtutil.exe cl Microsoft-Windows-TSF-msutb/Debug
wevtutil.exe cl Microsoft-Windows-TSF-msutb/Diagnostic
wevtutil.exe cl Microsoft-Windows-TZUtil/Operational
wevtutil.exe cl Microsoft-Windows-TaskScheduler/Debug
wevtutil.exe cl Microsoft-Windows-TaskScheduler/Diagnostic
wevtutil.exe cl Microsoft-Windows-TaskScheduler/Operational
wevtutil.exe cl Microsoft-Windows-TaskbarCPL/Diagnostic
wevtutil.exe cl Microsoft-Windows-TerminalServices-LocalSessionManager/Admin
wevtutil.exe cl Microsoft-Windows-TerminalServices-LocalSessionManager/Analytic
wevtutil.exe cl Microsoft-Windows-TerminalServices-LocalSessionManager/Debug
wevtutil.exe cl Microsoft-Windows-TerminalServices-LocalSessionManager/Operational
wevtutil.exe cl Microsoft-Windows-TerminalServices-MediaRedirection/Analytic
wevtutil.exe cl Microsoft-Windows-TerminalServices-PnPDevices/Admin
wevtutil.exe cl Microsoft-Windows-TerminalServices-PnPDevices/Analytic
wevtutil.exe cl Microsoft-Windows-TerminalServices-PnPDevices/Debug
wevtutil.exe cl Microsoft-Windows-TerminalServices-PnPDevices/Operational
wevtutil.exe cl Microsoft-Windows-TerminalServices-RDPClient/Analytic
wevtutil.exe cl Microsoft-Windows-TerminalServices-RDPClient/Debug
wevtutil.exe cl Microsoft-Windows-TerminalServices-RDPClient/Operational
wevtutil.exe cl Microsoft-Windows-TerminalServices-RdpSoundDriver/Capture
wevtutil.exe cl Microsoft-Windows-TerminalServices-RdpSoundDriver/Playback
wevtutil.exe cl Microsoft-Windows-TerminalServices-RemoteConnectionManager/Admin
wevtutil.exe cl Microsoft-Windows-TerminalServices-RemoteConnectionManager/Analytic
wevtutil.exe cl Microsoft-Windows-TerminalServices-RemoteConnectionManager/Debug
wevtutil.exe cl Microsoft-Windows-TerminalServices-RemoteConnectionManager/Operational
wevtutil.exe cl Microsoft-Windows-ThemeCPL/Diagnostic
wevtutil.exe cl Microsoft-Windows-ThemeUI/Diagnostic
wevtutil.exe cl Microsoft-Windows-TunnelDriver
wevtutil.exe cl Microsoft-Windows-UAC-FileVirtualization/Operational
wevtutil.exe cl Microsoft-Windows-UAC/Operational
wevtutil.exe cl Microsoft-Windows-UIAnimation/Diagnostic
wevtutil.exe cl Microsoft-Windows-UIAutomationCore/Debug
wevtutil.exe cl Microsoft-Windows-UIAutomationCore/Diagnostic
wevtutil.exe cl Microsoft-Windows-UIAutomationCore/Perf
wevtutil.exe cl Microsoft-Windows-UIRibbon/Diagnostic
wevtutil.exe cl Microsoft-Windows-USB-USBHUB/Diagnostic
wevtutil.exe cl Microsoft-Windows-USB-USBPORT/Diagnostic
wevtutil.exe cl "Microsoft-Windows-User Control Panel Performance/Diagnostic"
wevtutil.exe cl "Microsoft-Windows-User Profile Service/Diagnostic"
wevtutil.exe cl "Microsoft-Windows-User Profile Service/Operational"
wevtutil.exe cl Microsoft-Windows-User-Loader/Analytic
wevtutil.exe cl Microsoft-Windows-UserModePowerService/Diagnostic
wevtutil.exe cl Microsoft-Windows-UserPnp/DeviceMetadata/Debug
wevtutil.exe cl Microsoft-Windows-UserPnp/DeviceNotifications
wevtutil.exe cl Microsoft-Windows-UserPnp/Performance
wevtutil.exe cl Microsoft-Windows-UserPnp/SchedulerOperations
wevtutil.exe cl Microsoft-Windows-UxTheme/Diagnostic
wevtutil.exe cl Microsoft-Windows-VAN/Diagnostic
wevtutil.exe cl Microsoft-Windows-VDRVROOT/Operational
wevtutil.exe cl Microsoft-Windows-VHDMP/Operational
wevtutil.exe cl Microsoft-Windows-VWiFi/Diagnostic
wevtutil.exe cl "Microsoft-Windows-Virtual PC/Admin"
wevtutil.exe cl Microsoft-Windows-VolumeControl/Performance
wevtutil.exe cl Microsoft-Windows-VolumeSnapshot-Driver/Operational
wevtutil.exe cl Microsoft-Windows-WABSyncProvider/Analytic
wevtutil.exe cl Microsoft-Windows-WCN-Config-Registrar/Diagnostic
wevtutil.exe cl Microsoft-Windows-WER-Diag/Operational
wevtutil.exe cl Microsoft-Windows-WFP/Analytic
wevtutil.exe cl Microsoft-Windows-WFP/Operational
wevtutil.exe cl Microsoft-Windows-WLAN-AutoConfig/Operational
wevtutil.exe cl Microsoft-Windows-WLAN-Autoconfig/Diagnostic
wevtutil.exe cl Microsoft-Windows-WLANConnectionFlow/Diagnostic
wevtutil.exe cl Microsoft-Windows-WMI-Activity/Trace
wevtutil.exe cl Microsoft-Windows-WMPDMCCore/Diagnostic
wevtutil.exe cl Microsoft-Windows-WMPDMCUI/Diagnostic
wevtutil.exe cl Microsoft-Windows-WMPNSS-PublicAPI/Diagnostic
wevtutil.exe cl Microsoft-Windows-WMPNSS-Service/Diagnostic
wevtutil.exe cl Microsoft-Windows-WMPNSSUI/Diagnostic
wevtutil.exe cl Microsoft-Windows-WPD-ClassInstaller/Analytic
wevtutil.exe cl Microsoft-Windows-WPD-ClassInstaller/Operational
wevtutil.exe cl Microsoft-Windows-WPD-CompositeClassDriver/Analytic
wevtutil.exe cl Microsoft-Windows-WPD-CompositeClassDriver/Operational
wevtutil.exe cl Microsoft-Windows-WPD-MTPClassDriver/Operational
wevtutil.exe cl Microsoft-Windows-WSC-SRV/Diagnostic
wevtutil.exe cl Microsoft-Windows-WUSA/Debug
wevtutil.exe cl Microsoft-Windows-WWAN-MM-Events/Diagnostic
wevtutil.exe cl Microsoft-Windows-WWAN-NDISUIO-EVENTS/Diagnostic
wevtutil.exe cl Microsoft-Windows-WWAN-SVC-Events/Diagnostic
wevtutil.exe cl Microsoft-Windows-WWAN-UI-Events/Diagnostic
wevtutil.exe cl Microsoft-Windows-WebIO-NDF/Diagnostic
wevtutil.exe cl Microsoft-Windows-WebIO/Diagnostic
wevtutil.exe cl Microsoft-Windows-WebServices/Tracing
wevtutil.exe cl Microsoft-Windows-Win32k/Concurrency
wevtutil.exe cl Microsoft-Windows-Win32k/Power
wevtutil.exe cl Microsoft-Windows-Win32k/Render
wevtutil.exe cl Microsoft-Windows-Win32k/Tracing
wevtutil.exe cl Microsoft-Windows-Win32k/UIPI
wevtutil.exe cl Microsoft-Windows-WinHTTP-NDF/Diagnostic
wevtutil.exe cl Microsoft-Windows-WinHttp/Diagnostic
wevtutil.exe cl Microsoft-Windows-WinINet/Analytic
wevtutil.exe cl Microsoft-Windows-WinRM/Analytic
wevtutil.exe cl Microsoft-Windows-WinRM/Debug
wevtutil.exe cl Microsoft-Windows-WinRM/Operational
wevtutil.exe cl Microsoft-Windows-Windeploy/Analytic
wevtutil.exe cl "Microsoft-Windows-Windows Defender/Operational"
wevtutil.exe cl "Microsoft-Windows-Windows Defender/WHC"
wevtutil.exe cl 'Microsoft-Windows-Windows Firewall With Advanced Security/ConnectionSecurity"
wevtutil.exe cl "Microsoft-Windows-Windows Firewall With Advanced Security/ConnectionSecurityVerbose"
wevtutil.exe cl 'Microsoft-Windows-Windows Firewall With Advanced Security/Firewall"
wevtutil.exe cl 'Microsoft-Windows-Windows Firewall With Advanced Security/FirewallVerbose"
wevtutil.exe cl Microsoft-Windows-WindowsBackup/ActionCenter
wevtutil.exe cl Microsoft-Windows-WindowsColorSystem/Debug
wevtutil.exe cl Microsoft-Windows-WindowsColorSystem/Operational
wevtutil.exe cl Microsoft-Windows-WindowsSystemAssessmentTool/Operational
wevtutil.exe cl Microsoft-Windows-WindowsSystemAssessmentTool/Tracing
wevtutil.exe cl Microsoft-Windows-WindowsUpdateClient/Operational
wevtutil.exe cl Microsoft-Windows-Wininit/Diagnostic
wevtutil.exe cl Microsoft-Windows-Winlogon/Diagnostic
wevtutil.exe cl Microsoft-Windows-Winlogon/Operational
wevtutil.exe cl Microsoft-Windows-Winsock-AFD/Operational
wevtutil.exe cl Microsoft-Windows-Winsock-WS2HELP/Operational
wevtutil.exe cl Microsoft-Windows-Winsrv/Analytic
wevtutil.exe cl Microsoft-Windows-Wired-AutoConfig/Diagnostic
wevtutil.exe cl Microsoft-Windows-Wired-AutoConfig/Operational
wevtutil.exe cl Microsoft-Windows-Wordpad/Admin
wevtutil.exe cl Microsoft-Windows-Wordpad/Debug
wevtutil.exe cl Microsoft-Windows-Wordpad/Diagnostic
wevtutil.exe cl Microsoft-Windows-mobsync/Diagnostic
wevtutil.exe cl Microsoft-Windows-ntshrui
wevtutil.exe cl Microsoft-Windows-osk/Diagnostic
wevtutil.exe cl Microsoft-Windows-stobject/Diagnostic
wevtutil.exe cl ODiag
wevtutil.exe cl OSession
wevtutil.exe cl Security
wevtutil.exe cl Setup
wevtutil.exe cl System
wevtutil.exe cl TabletPC_InputPanel_Channel
wevtutil.exe cl WINDOWS_MP4SDECD_CHANNEL
wevtutil.exe cl WMPSetup
wevtutil.exe cl WMPSyncEngine
wevtutil.exe cl "Windows PowerShell"
Nagu näha siis see hulk on ikka üüratu
Muidugi võite muuta enda vajadustele vastavaks, et puhastada näiteks ainult mõni kindel logi vms
Logide puhastamisest niipalju kasu, et kui mingi probleem pidevalt esineb, siis saab logid puhtaks lüüa ja kui järjekordne crash vms tuleb, siis puhtast logist leiab palju kiiremini ülesse vea
Lisaks käivitub Event Viewer tunduvalt kiiremini.
Tegelikult peab uurima kuidas enamus logidest üldse disable panna .Reaalselt on minul ainult eales vaja läinud Windows Application ja Windows System ehk siis kahte
EDIT:
Kahjuks miskipärast ei taha hästi aksepteerida disable käsku logidele seega paremuselt järgmine on piirata logi suurus minimaalse 1MB peale.Samas selles osas samuti mõned ei aksepteeri käsku
Igatahes siin on need mis aksepteerivad.Sisestage need konsooli:
wevtutil sl application /ms:1048576
wevtutil sl system /ms:1048576
wevtutil sl hardwareevents /ms:1048576
wevtutil sl security /ms:1048576
wevtutil sl Microsoft-Windows-GroupPolicy/Operational /ms:1048576
wevtutil sl Microsoft-Windows-ParentalControls/Operational /ms:1048576
wevtutil sl Microsoft-Windows-PowerShell/Operational /ms:1048576
wevtutil sl Microsoft-Windows-TaskScheduler/Operational /ms:1048576
wevtutil sl Microsoft-Windows-User Profile Service/Operational /ms:1048576
1048576 baiti=1024 kilobaiti=1MB
CoiL
31.01.2010 12:22:35
öelge kiiresti keegi kuidas run as administrator paremklikk-menüüsse saada KÕIKIDE failide jaoks? Kunagi nagu tegin seda kuidagi kuid hetkel ei leia miskipärast netist ka õpetust
13.02.2010 12:50:56
*Kuidas Safe Mode käivitamisel keelata Help.Nimelt iga kord Safe Mode minna viskab selle lollaka Help akna ette mille teksti ma juba peast tean .Ja siis iga kord pean manuaalselt sulgema selle .
Lihtsalt nimetasin HelpPane.exe faililaiendi ümber C:\Windows kaustas
Enne oli vaja paraku selle faili õigused endale võtta ja ja Take Ownership paremklikkmenüü häkk millegipärast ei toiminud selle faili puhul
CoiL
16.02.2010 13:27:38
e:
Kes ei kasuta Hibernation valikut see saab järgneva käsuga 1,5GB ruumi kohe juurde süsteemipartitsioonil .
*Ava Command Prompt(start menüü otsingusse cmd või WinKEY+R ja cmd.exe )
*Sisesta järgnev käsk:
*Süsteemipartitsioonilt kustutatakse koheselt hiberfil.sys (varjatud fail ~1,5GB)
*Tee restart
Sleep jms toimib nagu ennegi.Kui on vaja uuesti sisse lülitada Hibernation siis saab tagasi selle käsuga:
Kasulik kui vaja tsipa ruumi juurde saada või lihtsalt ebavajalikust vabaneda
Hibernate ei kasuta kunagi ja mul vabanes sellega 3,01GB OS kettalt
olafsand
16.02.2010 15:09:35
| 3 giga vabaneb jah.
Q.
CoiL
miq1988
18.02.2010 19:06:07
Kuidas saab "size all columns to fit" nii, et see oleks alati peal.
pruuli555
02.03.2010 10:08:07
ma siis proovisin hibernate välja llülitada. ja sain vastuseks et you do not have a premission to disable or enable hibernate function. või kuda see sõnastus seal oli
to tomorrow.
milliste .code vahelt ma peans elle texti copi pastema:d
jakas on veel mingeid twake millega nt hiooldada arvuti kettakasutust.
puhastada siit ja sealt kust muidu ei saa vms
selle logid epuhastamise fail annab ka acsess denied
_________________ BatRat |
CoiL
02.03.2010 16:01:46
| pruuli555, järelikult ei ole sa adminni õigustega kasutajaga sisse logitud.
06.03.2010 02:44:03
Ehk olete märganud, et 64bit Win7 all Task Manager käima panna näitab ta ennast nimekirjas taskmgr.exe *32
Ehk siis 64bit süsteemis vaikimisi kasutab 32bit TM-i.Suht ajuvaba
Tehke töölauale uus shortcut ja copy pastege järgmine rida(kui teil on Win7 muul kettal asendage C:\ vastava tähega.Muu jääb samaks):
| C:\Windows\winsxs\amd64_microsoft-windows-taskmgr_31bf3856ad364e35_6.1.7600.16385_none_705720d4c2e4f76e\taskmgr.exe |
Pange sobiv nimi ja vajutage ok.Võite ka superbarile lohistada.Nüüd on kenasti taskmgr.exe ehk siis 64bit versioon
Dinkz
06.03.2010 02:56:49
Pange sobiv nimi ja vajutage ok.Võite ka superbarile lohistada.Nüüd on kenasti taskmgr.exe ehk siis 64bit versioon  |
Märt.
06.03.2010 22:18:50
Mina kasutan Process Explorerit, mis on 32-bit, käivitades tunneb ära, et on 64-bit süsteem ning ka programmikausta tekib "procexp64.exe" fail, mis sealt jälle proge sulgemisega kaob...
Vahur
06.03.2010 22:45:20
Ehk siis 64bit süsteemis vaikimisi kasutab 32bit TM-i.Suht ajuvaba  |
Minul ei näita, et oleks 32bitine, vaid kasutab vaikimisi 64bitist.
06.03.2010 23:18:14
| [VaHuR] kirjutas: |
Minul ei näita, et oleks 32bitine, vaid kasutab vaikimisi 64bitist. |
Sama siin
06.03.2010 23:36:33
+1. native 64bit.
tomorrow, sa oled oma süsteemi vast lihtsalt üle "tuuninud" et sul asad veidrailt käituvad.
07.03.2010 01:33:53
| [VaHuR] kirjutas: |
| Etz kirjutas: |
| [VaHuR] kirjutas: |
Sama siin  |
+1. native 64bit.
tomorrow, sa oled oma süsteemi vast lihtsalt üle "tuuninud" et sul asad veidrailt käituvad. |
Nüüd tehke parem hiireklikk Taskbaril ja valige Start Task Manager
Ikka veel native x64?
kes tahab paremat bootimiskiirust saada tehke desktopile järgmine shortcut:
| C:\Windows\System32\Defrag.exe -b %SystemDrive% /H /U |
Optimeerib boot faile süsteemis.
/H annab normaalse prioriteedi(vaikimisi on Low).Seega peaks tsipa kiiremini lõpetama
/U kuvab protsendiliselt progressi
Tegelikult on ka:
/W mis peaks andma täieliku defragmendi ja
/X mis peaks kokku tõstma vaba ruumi
Paraku 2 viimast selle shortcutiga mul ei toiminud
Küll on aga kindel see, et 64bit süsteemis ei kasutata vaikimisi 64bit Windows Media Playerit .Fix:
http://www.mydigitallife.info/2009/10/25/how-to-set-64-bit-windows-media-player-12-wmp12-as-default-player/
07.03.2010 01:57:44
Ikka veel native x64?  |
Ma sealt seda enamasti ainult avangi
Ja näitab et 64-bit native peaks olema...
siinus
07.03.2010 02:56:25
Microsoft Disk Defragmenter
Copyright (c) 2007 Microsoft Corp.
Invoking boot optimization on (C:)...
Analysis: 100% complete.
Some registry entries were missing from the boot optimization section of the registry. (0x89000017) |
_________________ suck less | no slop grenade
ceemic
24/7@kalal
07.03.2010 03:11:03
| /X peale tuleb jah "An invalid command line option was specified. (0x89000008)"; teised käsud toimivad.
07.03.2010 03:32:00
| djpvx kirjutas: |
Ei oska kommenteerida mis sul seal puudu võis olla.Proovi tavalist:
| C:\Windows\System32\Defrag.exe -b %SystemDrive% |
Run as Admin kah igaks juhuks
07.03.2010 10:31:53
| Etz kirjutas: |
Ja näitab et 64-bit native peaks olema...  |
I`ll look into that  |
64bit Home Premium Retail ENG
Äkki sul mingi teine versioon lihtsalt. Ehk ära postita vaimustunult kõike mida netist leiad kohe tõe pähe...
CoiL
07.03.2010 10:46:12
Mul jookseb ka native 64-bit
07.03.2010 15:30:26
Äkki sul mingi teine versioon lihtsalt. Ehk ära postita vaimustunult kõike mida netist leiad kohe tõe pähe...  |
Ok sain pihta milles asi oli.Teadmiseks - ei leidnud seda netist
Lisaks lahendus ühele probleemile.Nimelt kes on tõmmanud minu Shortcut kogumiku ja kasutanud custom shortcutte powrscheme tegemiseks siis esineb järgmine probleem:
Windows Experience Index(WEI) ei näe korrektset powerscheme GUID-d ja katkestab iga kord jõudluse hindamise.Ehk siis Control Panel\All Control Panel Items\Performance Information and Tools - Rate this Computer ei toimi .
Fix on üsna lihtne.Cmd aknasse 3 käsku selles järjekorras:
| powercfg -getactivescheme |
- see annab hetkel aktiivse powerscheme GUID koodi(copy saab CMD aknast nii, et Paremklikk-Mark-valite teksti-paremklikk)
| powercfg -duplicatescheme <YOUR GUID> 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c |
- dubleerib teie aktiivse powercheme uude powercheme mis on korrektse GUID-ga.Asendage <YOUR GUID> väärtusega mille saite esimese -getactivescheme käsuga.Esimene näide asendab custom GUID High Preformance GUID sättega.Siin on kaks ülejäänut:
| powercfg -duplicatescheme <YOUR GUID> 381b4222-f694-41f0-9685-ff5bb260df2e |
- Balanced
| powercfg -duplicatescheme <YOUR GUID> a1841308-3541-4fab-bc81-f71556f20b4a |
- Power Saver
| powercfg -delete <YOUR GUID> |
- Kustutab eelneva custom GUID-ga powercheme
Nüüd peaks WEI ilusti jooksma .Kes oleks võinud arvata, et WEI aksepteerib ainult 3 GUID-i
NB.Kui te pole seda paketti tõmmanud ja teatud shortcutte sealt kasutanud siis see ei puuduta teid ja ärge hakake suvaliselt kohe järgi tegema .Teil peaks juba olema korrektne GUID
pruuli555
09.03.2010 16:52:14
mul ei olegi teisi kasutajaid kuda saab mitte admini õigusi olla :d
09.03.2010 21:56:17
Kunagi küsisin kuidas saaks JumpListide backupi teha.Mõistagi mind naerdi välja.Kellel seda küll vaja oleks?
Aga kes viimasena naerab - naerab paremini
Seega tegin uurimistööd ja tulemused on siin:
JumpListe on kahte tüüpi tuleb välja:
Automatic - ehk siis Jumplisti vaikimisi alaosa
Custom - ehk siis kohaldatud ülaosa
Otse Exploreriga ei pääse ligi kaustale kus mõlemad sees on.Õigemini pääseb aga see on teise nimega ja isegi varjatud failide näitamist lubades paistab pealtnäha tühi.Ei usu?
Vaadake kas te leiate C:\Users\KASUTAJANIMI\AppData\Roaming\Microsoft\Windows kaustast Recent kausta?.Ei te ei leia .On ainult Recent Items ja seal pole seda mida vaja.
Trikk on minna otse:
WinKEY+R ja sisestage %APPDATA%\Microsoft\Windows\Recent\AutomaticDestinations
Aga miks mitte %APPDATA%\Microsoft\Windows\Recent\ küsite?.Sinna minna siis saate jälle tühja kausta kust pole kuhugi edasi minna.MS on kavalalt ära peitnud JumpListid
Trikk ongi WinKEY+R ja sisestage %APPDATA%\Microsoft\Windows\Recent\AutomaticDestinations .Seal kaustas olles vajutada Back nuppu avastate ennast Recent kaustas kus on ka CustomDestinations kaust.
Varundades need 2 kausta varundate ühtlasi ka oma kohaldatud JumpListid
OSA 2:
Nüüd kus JumpListid on varundatud tekib küsimus - faile oli neist kaustades vähem kui mul on Taskbaril ikoone?.Vastus on selline, et mitta igal ikoonil taskbaril pole oma JumpListi ja seega pole ka sama arv faile.Failid ise on vastavalt kas kujul xxxxxxxxxxxxxxxx.automaticDestinations-ms või xxxxxxxxxxxxxxxx.customDestinations-ms .Tegu tundub olevat raw failidega seega neid pole millegagi avada, et sisu vaadata.xxxx... on 16 kohaline alfanumeriaalne kombinatsioon mis ei ütle samuti midagi konkreetse faili kohta.Notepadiga saab neid avada ja mõned sõnad selle põhjal ära arvata aga see on ka maksimum.
OSA 3:
JumpListid on kasulikud aga neist poleks midagi kasu ilma konkreetsete otseteedega mille olete Taskbarile pannud.Aga kus need asuvad?
Vastus on, et need asuvad C:\Users\KASUTAJANIMI\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned kaustas.
User Pinned on varjatud kaust
Seal kaustas on veel omakorda 2 kausta:
StartMenu
TaskBar
Seega nagu nimedest näha hoiavad need vastavalt Start menüü ja Taskbari shortcutte.
Varundades need ja JumpListid saate Win7 uuesti installides taastada kogu taskbari konfiguratsiooni nagu see oli enne
Loodetavasti on abiks
Btw:
Keda huvitab, siis Start Menüü sätted(Kõrgus ja muud sätted v.a shortcutid) saab varundada registrist aadressilt:
| [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu] |
Exploreri sätted aadressilt:
| [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer] |
Neid on veel.Millalgi postitan täieliku nimekirja neist mida ma ise kasutan
10.03.2010 14:54:39
tomorrow, sa muidu sellise programmikesega kah kursis oled http://www.rt7lite.com/
Ise mõtlesin mingi hetk katsetada, kui veidike "vaba" ajalist ressurssi tekib
10.03.2010 16:35:22
| Etz kirjutas: |
Ise mõtlesin mingi hetk katsetada, kui veidike "vaba" ajalist ressurssi tekib  |
Esimest korda näen.Tundub üsna põhjalik.Kahjuks veel alla ei saa laadida.
Unattended pole enam vaja.Selle ehitasin teise programmiga juba nullist üles(x64,x86 ja VPC versioonid)
Loodetavasti Driverite osas toetab /ForceUnsigned flagi  |
Miks ei saa alla laadida?
Ma alles eile sikutasin selle sealt alla endale...proovida pole jõudnud ainult...
olafsand
10.03.2010 16:48:22
Download RT Se7en Lite - BETA (Build 1.03) now!
(It will be available soon)
ja aktiivset linki pole, mille kaudu saaks alla sikutada.
XeStAiSy
Aeg Maha 2a
10.03.2010 17:32:09
Ise tegin winni nii kiiremaks, installis lõin partid os läks 100GB NTFS ja swap läks 10GB FAT32 peale igatages arvuti muutus ohtralt kiiremaks kui seda ei tee siis varsti on suu winnil lohvi täis 1TB HDD puhul. Unustage defragid need paremaks ei tee midagi.
Võtsin selle katsetuse ette kuna loobusin korraks UEFI süsteemist bugide pärast. Nädal otsa juba mul winn selle katsetusega olnud. Ütleks, et väga hea ja tasub katsetada.
10.03.2010 18:18:20
Kellelgi on Win 1TB partitsioonil
Milleks?
| olafsand kirjutas: |
ja aktiivset linki pole, mille kaudu saaks alla sikutada. |
Viskasin ajutiselt siia ülesse: v1.02 Beta
XeStAiSy
Aeg Maha 2a
10.03.2010 18:24:49
| Etz kirjutas: |
Milleks?  |
Ma ei tea kui mul vana emaplaat oli siis pold mingit vahet kuidas tegid, vista oli kiire ka peale poolt aastat. Mulle tegelikult partidega jamamine ei meeldi, jura installida asju ja liiguta faile nagu tola.
CoiL
10.03.2010 22:09:51
| ot: |
Täitsa piix Uskumatu. |
XeStAiSy
Aeg Maha 2a
11.03.2010 07:24:35
Ma olen koguaeg AHCI kasutanud. Linnuke eject this drive ja hdd istub seal. Ja olen seda hotswapi proovinud funkab küll.
| ot: |
tomorrow AHCI mitte ACHI.
Ma ajan ka pidevalt sassi.
Kommentaare lugedes kui teed sellest seagate omast partid siis pidi peaegu sama effect olema.
friik1
11.03.2010 10:04:48
Seda suuruse piiramist on vahel kasutatud SASi massiivide puhul, kus access time oli ülitähtis. Keegi nimetas seda short stroking kunagi ja keegi benchmarkis kah.
Kui maksimaalse võimaliku seek time vähenemine välja jätta, on üsna mõttetu protseduur.
11.03.2010 10:18:39
Mul endal jooksevad Kettad AHCI modes...
Tegelt sama effekti saab ka ketta ümber partitsionnerimisega, nii et osa jätad unallocated, samamoodi OS seda ei näe...
12.03.2010 00:27:41
| Etz kirjutas: |
| Viskasin ajutiselt siia ülesse: v1.02 Beta |
Kahjuks ei tööta.Lihtsalt "Stopped Working" igal kävitamisel.Run as Admin ja Comp mode kah ei aita.Eks jääb 1.3 ootama.See on väidetavalt kõigest ~6MB ~190MB asemel :
Tundub mingi CLR veaga kokku kukkuvat.
.NET viga seega?.Installitud .NET Framework 4.0 RC siinpool  |
Treitakse uut jahh, sest M$ koputas sellidele , teatud installeris sisalduvate asjade eest, sõbralikult õlale
Mul igatahes käivitus Net 3.5 siis peal..
Eks ma nädalavahetusel uuri täpsemalt...
