Lord Ami
26.09.2008 19:04:42
| jnt kirjutas: |
Igastahes mul nod32 midagi ei leidnud ja sas'iga lasin ka masina üle ja polnd midagi... äkki see avast teeb seal lehel false positive'i?  |
Ei tee:
Hello.
This file is already detected and it's not false.
Please quote all when answering. Do not forget to include you registration data.
Regards, Ostroverkhov Vladimir
Virus Analyst, Kaspersky Lab.
| Kommentaarid: 57 loe/lisa |
52 |
| Kommentaarid: 1152 loe/lisa |
724 |
jnt
26.09.2008 19:13:29
Ega väga ei usu, et kolmes masinas suisa ühtmoodi katki on ja et ka SAS ei leia midagi, kuid mine sa tea... vb proovingi Avasti järgi.
106 |
isiklik
26.09.2008 19:25:48
| tahanteada kirjutas: |
isiklik: Kell a 18:15 tegin Avasti kodulehel päringu uue parooli saamiseks:
Paar minutit hijlem tegin oma GMaili postkasti lahti ja nüüd võid ise lugeda mis mail postkastis oli:
register@register.avast.com to me show details 6:18 PM (0 minutes ago)
Nii, et pole mõtet vaielda ega heietada, et Avast saadab parooli kuni 24 tunni jooksul
8) |
Tahad vaielda? No vaidleme!
Loe tähelepanelikult PAKSUKS tehtud sõnumit. Kõik selle teksti koppisin üks-ühele avasti kodulehelt.
Registration of avast! 4 Home Edition
Your registration was sent to ALWIL Software. If the entered e-mail address was correct, you should receive an e-mail with the activation key within 24 hours...
The activation key expiration is not limited, but the program updates will only be available for the next 14 months. After this period, it is necessary to re-register.
IMPORTANT NOTICE: The free registration of avast! 4 Home Edition is performed by a robot which sends the message containing the license key to the email address you entered in the registration form. The mail is sent from: register@register.avast.com and the mailbox specified for reply is: support@avast.com; please make sure these addresses will not be stopped by your anti-spam software.
If you have any technical problem, mail to support@avast.com
If you don't have avast! Home Edition installed yet, please visit download page
If you like avast!, please be so kind and give a notice to users of CNet, ZDNet and/or other popular sites by using the links in the left-hand side column...
724 |
isiklik
26.09.2008 19:36:40
| laurx kirjutas: |
| isiklik, tulevad need registrationid hetkega. korduvalt kasutajatele reganud ja kasutanud installimiseks ka enne saadud keysid. ainuke piirang mis nende keydega on, et hapuks läheb key aasta pärast alates välja andmisest. ole hea ja vaata oma späm/ junk üle. |
Mulle tuli kah praegu hetkega, aga vaidlus sai alguse kaugel tagapool, kus ma kirjutasin, et kahele kliendile üleeile ja eile installisin avastit. Ja siis ma näitasin klientidele kuidas saab registreerida. Proovisime registreerida nende e-mailidele, aga isegi 10 minuti pärast ei olnud veel võtit tulnud ja siis ma ei saanud aru milles on pull ja proovisin veel registreeruda ja siis lõpuks lugesin seda teksti, kus kirjutati, et võtme saab 24 tunni jooksul.
Andke andeks, mina ei ole seda 24 tunni värki välja omast peast mõtelnud! Nii on see seal kirjas ja siia kirjutasin ka sellest mida ma lugesin.
Kas nüüd lõpuks on arusaadav?
Ma võin ju roheliseks ka värvida, kui keegi veel aru ei saa.
724 |
isiklik
26.09.2008 19:42:27
Mul on pulgal peale key veel väga palju asju.
724 |
26.09.2008 20:05:58
isiklik: Ära siis kasuta mailiaadresse, millede mailiserverid "molutavad ja mõtlevad, et kas on tegu spämmiga või mitte". Seega pole mõtet Avasti peale turtsuda, kui Su oma ISP mailiserver "nägusid teeb".
See, et Avastil on kiri "kuni 24 tundi", tean ma oma a 4 või 5 aastat juba. Ehk siis niikaua, kuni olen Avastit kasutanud. Ja selle aja jooksul olen Avastilt uut koodi küsinud sadades kordades. Ja mitte kordagi pole kulunud aega koodi saamiseks üle mõne minuti.
211 |
isiklik
26.09.2008 20:39:50
See, et Avastil on kiri "kuni 24 tundi", tean ma oma a 4 või 5 aastat juba. Ehk siis niikaua, kuni olen Avastit kasutanud. Ja selle aja jooksul olen Avastilt uut koodi küsinud sadades kordades. Ja mitte kordagi pole kulunud aega koodi saamiseks üle mõne minuti. |
Ma ei mäleta, et oleks avasti peale turtsunud, keegi süüdistas mind valetamises (võibolla olid see sina), et avast saadab võtme kohe. Kui ma kliendile seda ütlen, siis ma võin satuda täbarasse olukorda, kuna KOHE võtit ju ei tulnud. Kui ma ütlen kliendile 24 tunni jooksul saab võtme, nii nagu kirjas on, ma ei pea ju jääma sinna ööpäevaks ootele. Võibolla tuleb võti mitme tunni pärast, tõesti see oleneb paljudest asjaoludest.
Lemmy
26.09.2008 20:53:14
Mis te kurat kaklete selle Avasti key üle. Tehke 1 parem. Kui on lubatud kuni 24h jooksul, siis hädaldama peaks hakkama, kui selle aja möödudes pole muffigi saabunud. Tavapraktikas muidugi on loetud minutite jooksul kohale jõudnud.
Vihjeks veel (eeldatavasti teada asi), et sama key'd saab paljudele produktidele sisestada. Ei pea igale versioonile eraldi tellima.
_________________ Vähem möla, pikem samm! |
| Kommentaarid: 41 loe/lisa |
38 |
meybo
26.09.2008 21:13:29
Kas see teema mitte juba mitu lehekülge tagasi sujuvalt AV-de võitlustandriks ei muutunud?
_________________ www.meybo.ee |
| Kommentaarid: 22 loe/lisa |
20 |
26.09.2008 21:19:46
| laurx kirjutas: |
| ilmselt on selles masinas mingi katkine nöötkolkmkendkaks.. way to go. |
"nöööd koldkükaks... pole katki"
Soovitav oleks vaid antiviiruseid OSTA või kasutada freewaret...
Mitte neid crackida...whatever, mis "kätte juhtub" failidega...mis lubavad teha "sust jumala taevas"...
196 |
isiklik
26.09.2008 21:22:54
| Lemmy kirjutas: |
Vihjeks veel (eeldatavasti teada asi), et sama key'd saab paljudele produktidele sisestada. Ei pea igale versioonile eraldi tellima. |
Seda ma tean jah. joon juba ka.
http://kolyan.net/index.php?newsid=7195
Vaadake lõpuni, täitsa armas viirus.
NATAS999
26.09.2008 21:40:44
Oojaa, on küll armas viirus, endalgi võiks selline olla
39 |
meybo
26.09.2008 23:07:19
Väide, et lehel www.tallmac.ee asub mingi viirus, on täielik pullikaka. Arvutit kaitseb Eset Smart Security (täiesti töötav, ei ole katkine), mis ei teinud piiksugi. Midagi kahtlast enda arvutis samuti toimumas ei näinud. Sai süsteem üle skännitud Avira Premium Security Suite'iga, mis samuti väidetavat viirust ei leidnud, küll aga tegi hunniku valehäireid mitmete tuntud programmide failide peale.
20 |
angel
26.09.2008 23:21:22
käisin seal nii IE kui FF 'iga. Nod32 uusim ja Avira ei näidanud mitte piixugi (enne oli nod32 peal nüüd avira)
157 |
NATAS999
26.09.2008 23:23:44
| Lord Ami kirjutas: |
| jnt kirjutas: |
Ei tee:
Hello.
Virus Analyst, Kaspersky Lab. |
et kaspersky vennad tegid nalja siis?
39 |
angel
26.09.2008 23:24:55
automaat vastus? ei tahaks uskuda et keegi masina taga istub terve ööd/päevad ja vaatab ükshaaval faile üle
157 |
Lord Ami
26.09.2008 23:30:27
| NATAS999 kirjutas: |
| jnt kirjutas: |
Ei tee:
Hello.
et kaspersky vennad tegid nalja siis? |
Ei teinud.
Tõesti, KLAB "viirusetuvastajad" kontrollivad neid faile üksipulgi läbi.Karantiinist saadad ja saad vastuse umbes paari tunniga.Vahepeal isegi paari minutiga
Angel, neid on seal mitmeid.Pole kindel, aga vähemalt 10 erinevat isikut.
Nt:
Hello,
setup_1_2_.exes - not-a-virus:FraudTool.Win32.AntiSpyWarePro.c
New potentially risk software was found in this file. It's detection will be included in the next update. Thank you for your help.
Sophos:
Good morning,
Thanks for your submission to Sophos Support.
The file downloaded from the website -setup_1_2_.exe- resulted in the creation of a new threat identity:
Troj/FakeVir-FZ
Detection for that file has been released to the databanks. For more information, you can go to the description below:
http://www.sophos.com/security/analyses/viruses-and-spyware/trojfakevirfz.html
Please do not hesitate to contact me if I can be of any further assistance.
Regards,
Karin Cowell
Sophos Technical Support
52 |
26.09.2008 23:40:21
Lord Ami: Ära liiga naiivne ja Kaspersky-t pimesi ülearu uskuv ka pole 8) Kaspersky-t saadab vähemalt iga aasta paar - kolm skandaali või skandaalikest, kus olematu, süütu pisipraht keeratakse suure lärmiga suure kella külge. Tekitades sellega - järjekordse paanika, mille käigus inimesed pimesi poodi Kaspersky Antiviirust ostma tormavad... Ja siis firmajuhid - koos marketingimeestega - hõõruvad käsi, löövad tooste kokku uue müügiedu puhul ja nuputavad, kuidas inimesi uuesti poodi meelitada
211 |
angel
26.09.2008 23:48:37
see ammu teada et firmas on kaks osakonda.. üks teeb viiruseid ja teine teeb vastumürki. Kui kumbki neist hätta jääb siis aidatakse üksteist. Äri on vaja ju ajada 8)
157 |
724 |
Lord Ami
26.09.2008 23:52:21
See oli siiski nagu näide ja ka väike tõestus.
Saatsin sama lehe ka ESETile.Vaatame kas ESETi produktid ka seda lehte viiruselevitajaks peavad
Aga tegelikult ka.Jätame selle teema rahule ja kolima AV vs AV omasse ?
52 |
