Dude .
27.02.2010 11:36:40
[PSP] Monster Hunter Freedom Unite |
- Koduleht: Siin
- Arendaja: Capcom
- Väljaandja: Capcom
- Stiil: Action role-playing game
- Väljalaske kuupäev: June 26, 2009
- Kirjeldus:
tsitaat: |
Monster Hunter Freedom Unite has more missions, equipment, and monsters than Monster Hunter Freedom 2. A new feature is a Felyne fighter to help you on your quests. You can also get Rarity 9 and 10 armor and weapons. In addition, the player can now hold up to 99 of each item type in his/her item box, store up to 20 equipment sets, and get ten equipment pages instead of six. A new type of quest, the "Epic Hunting Quest", will be introduced, which will enable the hunter to take on, one by one, up to 4 different monsters in one quest, as shown in the released demo. Weapons can now have up to purple sharpness which is higher than white sharpness. You can now accept HR 7-9 quests in the gathering hall and new elder quests outside the gathering hall from a Felyne beside the village elder. |
Multiplayer: Jah
Uudised ja eelvaade: IGN
Ülevaade: Gametrailers
Screenshotid: IGN
Videod: Gametrailers
Kommentaarid: 15 loe/lisa |
15 |
beastbeats
Kommentaarid: 364 loe/lisa |
280 |
iDemon
27.02.2010 12:57:41
Ainuke tõsiselt võetav portable mäng imho. Endal on 300+ tundi tiksunud, siiani kõik solo teinud.
/ Kui kellelgi on raskusi või soovib sõpradega mängida siis läbi PS3 Ad-Hoc Party saab seda online'is mängida. Siiani populaarseim mäng seal (nii JP kui US/EU versioonil).
Kommentaarid: 122 loe/lisa |
104 |
beastbeats
27.02.2010 13:08:07
tsitaat: |
Kui leiaks veel 2 inimest võiks millalgi kokku saada ja co-op'i proovida
M: Uus/pakendis Fjern Fjork Titanium Forked Spoon - 10€ |
280 |
EvilKatarn
diivanilill
27.02.2010 13:11:16
Multit saab ainult läbi PS3'e? Vastasel juhul võtaks küll osa...
Kommentaarid: 109 loe/lisa |
80 |
beastbeats
09.03.2010 16:25:09
EvilKatarn, saab ka läbi PSP's adhoc'i, millele ka eelmises postituses "vihjasin"...
EDIT:
Kas kellelgi on õnnestunud rohkem kui üks Kirin Thunder Tail saada - ise 7 korda quest'i ära teinud, kuid sain ühe ainult esimesel korral
280 |
JOKKER666
14.03.2010 11:31:33
Selline asi, et kui võitlen nt mingi vee elukaga(daymo hermitaur) ja mul on armoril vee def. Kas see kaitse on ainult vee eluka vee rünnakute vastu, või ka tavaliste melee rünnakute vastu ka.
Ühtlasi tore oleks kui keegi ütleks mida kardab see Tigrex. Madistasin temaga kuni aja lõpuni ja terve selle ajaga sain saba otsast ja hakkas lonkama, aga täielikult maha nottimiseks ei jätku aega. Arvatavasti mul relv tema vastu kehva, sellepärast huvitabki, mida ta kardab.
Kommentaarid: 47 loe/lisa |
42 |
iDemon
14.03.2010 14:24:15
Monster Hunteri küsimustele leiab vastused MH Wikist.
Igatahes Thunderi vastu on tal nõrkus. Kõige lihtsam oleks Devil Sliceriga teda ettevaatlikult taguda, või siis mõne Great Swordiga millel on kõrge raw ATK teha charge-hitte vastu molu.
Mainin ära ka, et kui wywern lonkab on sul võimalus ta kinni püüda trapi ja tranq pommidega. Nii ei saa sa teda küll carvida, kuid see eest on rewarde rohkem ja kõvasti suurem võimalus leida midagi haruldast.
Armori kohta .. ei oska kindlalt öelda, aga kui ma ei eksi siis on see resistance tüübi vastu. Nii et kui sul on armor mis tõstab water-resistance'i siis veetüüpi koletiste rünnakud teevad mingil määral vähem kahju.
104 |
JOKKER666
17.03.2010 00:11:50
Kuidas selle kinnipüüdmisega on. Proovisin Daymot kinni püüda. Kui tal hakkas suu vahutama, viskasin maha shock trapi(korra proovisin ka pitfall trapi). Siis loopisin mingite stun pommidega, aga ei msikit. Proovisin mitu korda.
42 |
iDemon
17.03.2010 00:27:13
Kui tal hakkab suu vahutama, siis on ta vaid närvis. Krabidel on suu ees väga pisikesed lillad mullid kui HP on otsakorral. Mainin ära et krabisid saab vaid shock trapiga (+tranq pommid ofc) kinni püüda. Rajangi saab vaid siis püüda kui tal on vähe HP'd ja ta on närvis. Nargacurgaga sama lugu.
Püüda saab kolle ainult siis kui nende HP on piisavalt madalal tasemel, ning nad peavad lonkama/haavatuna liikuma ja tihti üritavad siis üritavad ära põgeneda et magada (mis vaikselt taastab neil elusid).
Järgnevaid kolle ei saa püüda : Akantor, Ucanlumbas, Yamatsukai, Queen Vespoid, Shakalaka King, Lao Shan Lung, Fatalis, Kirin, Fatalis (kõik värvid), Chameleos, Teostra, Lunastra, Kushala Daora, Shen Gaoren, Ukanlos. Ehk siis kõik special case teemad.
104 |
beastbeats
17.03.2010 15:32:11
tsitaat: |
JOKKER666, nüüd läheb Tigrex puhkama/magama - lähed ja paned talle shock trap'i + loobid teda tranq pommidega...
280 |
JOKKER666
19.03.2010 16:20:39
Sain uue relva(eager cleaver) ja Tigrex oli üsna kiiresti kööga. Juppide saamiseks sai teine kohe veel maha notitud. Muidu väga lahe mäng, iga elukas on uus väljakutse. Arvatavasti kõige raskem mäng ka mida üldse mänginud.
42 |
iDemon
19.03.2010 18:13:19
Eks ta üsna raske ole, kuid kui asja käppa saad siis on lausa lust neid nottida.
Ma väga ootan juba teie kommentaare kui G-ranked queste hakkate tegema, neid G☆☆ ja G☆☆☆ omi.
104 |
486
20.03.2010 14:39:42
Sai kunagi isegi proovitud seda aga levelid on liiga tunneldisainiga, et ja jätsin. Kolmas osa on loodetavasti etem.
_________________ zero |
Kommentaarid: 46 loe/lisa |
39 |
beastbeats
20.03.2010 15:21:26
486, "tunneldisainiga"
280 |
EvilKatarn
diivanilill
20.03.2010 15:23:39
Noh. Päris esimene treeninglevel oli suht tunnel jah
80 |
JOKKER666
20.03.2010 18:40:28
Kuskilt lugesin, et elder dragonitel läheb, kui neid maha ei noti, damage edasi järgmisesse võitlusesse. Et kas ongi nii, et kui esimest korda kushala daora põgenes peale mingit damaget ära, siis teist korda samas questis on ta niipalju nõrgem?
42 |
iDemon
20.03.2010 18:48:14
Just nii. Tavaliselt kui Elder põgeneb, siis on ta järgmine kord teisel kaardil üldse.
See kehtib vaid järgnevatele Elder dragonitele : Kushala Daora / Chameleos / Lunastra / Teostra.
DLC-questides Elder dragonitele see reegel ei kehti.
Hint : kui mingi Elder dragoni aura käib närvidele, näiteks Lunastra fire-aura või Chameleose nähtamatus siis tuleb lihtsalt neil sarv(ed) puruks lüüa pea küljes. Või poison-staatus peale panna.
104 |
PriitMeos
05.05.2010 21:30:57
Appi ma ei suuda g rank urgant questi ära teha (monoblos and white monoblos) kas keegi saaks aidata ma olen juba 5 korda prooving ma tüdind juba!!!!!!!
beastbeats
05.05.2010 21:45:24
PriitMeos, viie korraga juba tüdinud
Vale mängu oled siis valinud - saaksin veel aru, et 50 korda...
280 |
iDemon
104 |
PriitMeos
12.06.2010 16:07:12
Yeeee tapsin solos Akantori ära ja Fatalise ka (üksinda) kasutasin: Ceanataur S set igal armoril def 79 ja skillid olid:sharpening skill inc, attack up (medium) ja sharpness +1.Relv oli Ls :Smolder Dragonsword
NekoRobin
22.10.2010 20:43:34
lol /v/ lol
_________________ M: Heavenly Sword, Eternal Sonata (PS3), Legaia 2: Dual saga, Blazblue Continuum Shift (Limited Edition, PS3), Golden Sun: The Lost Age, Final Fantasy X-2
viimati muutis NekoRobin 23.10.2010 13:23:22, muudetud 1 kord |
Kommentaarid: 16 loe/lisa |
Anna tooli
22.10.2010 20:48:16
NekoRobin, hotlinkimine keelatud/pilt kustutatud
Kommentaarid: 362 loe/lisa |
298 |
NekoRobin
23.10.2010 13:22:55
panen kõike..., fix'd
_________________ M: Heavenly Sword, Eternal Sonata (PS3), Legaia 2: Dual saga, Blazblue Continuum Shift (Limited Edition, PS3), Golden Sun: The Lost Age, Final Fantasy X-2 |
