09.04.2008 18:47:26
[X360] Fable II |
Fable II
Fable 2 is the true sequel to the wildly successful original that sold more than 3 million copies, offering even more choices and building on the core gameplay theme of Fable, where a player's every decision continually defines whom they become. Fable 2 is an action role-playing game (RPG) that truly allows players to live the life they choose in an unimaginably open world environment.
Set 500 years after the original, Fable 2 will provide gamers with an epic story and innovative real-time gameplay, including a massive amount of freedom and choice to explore a vast collection of dungeons, catacombs and caves in the world of Albion. |
Multiplayer: jah
Uudised ja eelvaated: Gamespot
Ülevaade: Gamespot
Screenshotid: Lionhead Studios
Videod: Gametrailers
Videopäevikud: part 1, part 2, part 3, part 4, part 5, part 6
_________________ MÜÜA: Xbox 360 E 250GB (UUS)
viimati muutis SKG 07.08.2008 18:58:58, muudetud 7 korda |
313 |
313 |
jaanus147
| Kommentaarid: 10 loe/lisa |
10 |
Peltz
13.05.2008 22:52:24
Täiesti sisutu Gamespoti artikkel.
Vihjab et release on kuskil enne jõule.
_________________ "Do you know what the 'Chain of Command' is? It's the chain i'm going to beat You with untill You understand who is in command!"
"And you have the right to say, No!" |
| Kommentaarid: 23 loe/lisa |
22 |
jaanus147
10 |
313 |
jaanus147
10 |
313 |
jaanus147
10 |
20.06.2008 08:34:02
hehe
IGN: Can I do the old trick of killing a character and then buying the vacant house on the cheap?
Carter: Most definitely if you're that way inclined. On the other hand, if you're feeling less bloodthirsty, you can become friends with the owner first, so he'll give you a discount on the house price without resorting to premeditated murder. See what a nice game we're making? Try to contain your bloodlust! |
_________________ MÜÜA: Xbox 360 E 250GB (UUS) |
313 |
aivo80
20.06.2008 09:08:24
| Paistab olevat mäng mille pärast tasuks jõuludeks siis xbox endal muretseda, seda enam et PS3. peal ei ole hack'n'slash rpg'd vist oodata nii pea.
| Kommentaarid: 31 loe/lisa |
29 |
jaanus147
10 |
xtriz
24.06.2008 22:50:51
Esimese Fable tegin 100% kurjana läbi. Sarved olid pähe kasvand ja kärbsed lendasid ümber
Fable 2 üritan "light sidega" läbi teha. Jään ootama
| Kommentaarid: 9 loe/lisa |
9 |
jaanus147
10 |
deusexum
14.07.2008 21:33:32
E3: http://www.gametrailers.com/player/36200.html
Pettumus oli see, et nii rõhuasetus oli stoorile ja sellele mailma loomisele. Simsi tunde jättis ja kuna sims on mu arvates igav, siis ei teagi mida oodata.
| Kommentaarid: 7 loe/lisa |
xtriz
15.07.2008 01:02:13
| deusexum kirjutas: |
Pettumus oli see, et nii rõhuasetus oli stoorile ja sellele mailma loomisele. Simsi tunde jättis ja kuna sims on mu arvates igav, siis ei teagi mida oodata. |
Mis mõttes? Esimest osa oled üldse mänginud? See on samasugune (saad abielluda jne. aga see pole üldse vajalik ja ei pea seda tegema).
9 |
jaanus147
10 |
313 |
Peltz
26.07.2008 22:18:59
Huumor gametrailersi veebilt:
| i might rent it... but i won't buy it unless i can take a big fat nasty shite and be able to put it in a bag and set it on my neighbors doorstep and set it on fire. i mean, that would definitely make it a AAA title, no? |
22 |
wicked
| Kommentaarid: 68 loe/lisa |
63 |
qodopob
25.08.2008 08:19:56
| wicked kirjutas: |
| Kas mõni EU pood ka Pub Games koodi pakub koos CE-ga? (nagu nt. GameSpot teiselpool lompi) |
game.co.uk-st tuli täna meil, et siin on sinu pre-orderi kood
| Kommentaarid: 30 loe/lisa |
Splash
25.08.2008 11:39:01
Wicked, see peaks olema ikka Gamestop, mitte gamespot.
Ma sain oma Pub gamesid kätte juba ammu, kuigi pole veel eeltellinud
Qodopob, sa seda trikki ikka tead kuidas raha kiiresti tuleb ?
qodopob
25.08.2008 12:19:56
| Splash kirjutas: |
| Qodopob, sa seda trikki ikka tead kuidas raha kiiresti tuleb ? |
Ei. Ma alles täna sain selle kätte, ning töö tõttu ei jõua seda ka täna proovida.
Splash
25.08.2008 16:24:00
Igatahes ma seletan ära siis. Üldiselt LB on siis max bet mängudes, aga Fortune's Toweris on selline lahe asi, et kui paned minimum beti, siis deal, ja pärast "väravakaardi" ( gate card ) ilmumist vajutad kähku max bet nuppu siis sinu rahast läheb maha minimum bet, aga võita saad max betiga arvestatud summasid.
Ise olen kõik Fortune's Toweri ja Spinnerboxi mängud avanud. Keystone's veel kõike raskem mäng avada ning siis turniirid läbi teha. Nendest veel kah 2 Keystone'i oma ja Spinnerboxi viimane.
qodopob
26.08.2008 22:55:19
Jõudsin enne tööle tagasi minemist nadi seda proovida (~3h). **** käes. See Keystone on jah kõige rohkem aega nõudvaim nendest. Spinnerites ainult 2 veel avamata, ning isegi 5000-ga plussis (no dept no more ). Peale seda kui 4* täis sain, siis proovisin veelkord turniire (alguses tehtud 2 olid täis failure / kohad 18 ja 19), ning võitsin Spinnerite esimese taseme esimese üritamisega . Kas sellega on nii, et mida suurem su score, seda paremad on sinu jaks tõenäosused või on lihtsalt avatavates mängudes lihtsam võita?
Vaatab, kuidas edasi läheb. Kui tulevik on sama helde, siis pole seda bug/cheat-i vaja kasutada. Pärast on Fable II ise liiga igav - "You have no money, you have problems. You have money, you have no problems."
PS. Kõik asjad olemas, kõik achievement-id ka olemas (va. see mille jaoks Fable-t vaja) Aga enamuses on asi ikka täielik õnne peale toetav mäng - kord tuleb see mida vaja, teine kord aga ei tule kordagi...
