Mitu tolli on sinu peamine igapäevases kasutuses olev monitor? |
10-15" |
1% |
[ 3 ] |
15-20" |
2% |
[ 6 ] |
20-25" |
17% |
[ 44 ] |
25-30" |
42% |
[ 108 ] |
30-35" |
26% |
[ 67 ] |
35" või suurem |
11% |
[ 29 ] |
hääli kokku : 257 |
sõnum |
von Wu
22.11.2019 13:33:51
londiste kirjutas: |
mingi sharpness setting monitoril? |
Endal kogemus, et keegi oli monitoril "Gaming" režiimi sisse lülitanud. Tegi tekstid rõvedalt karvaseks ja varjud taga.
_________________ Haruldane Mazda oksjonil: link |
Kommentaarid: 867 loe/lisa |
654 |
29.11.2019 16:59:16
NVIDIA to Open G-Sync Monitors to VRR Support, Enabling AMD Graphics Cards Support
https://www.techpowerup.com/261494/nvidia-to-open-g-sync-monitors-to-vrr-support-enabling-amd-graphics-cards-support?
tsitaat: |
confirmed by NVIDIA, the company will enable VRR support for next releases of monitors equipped with the company's G-Sync module. This will essentially enable AMD graphics cards to work with NVIDIA-branded G-Sync monitors. |
tsitaat: |
This move will only work for future monitor releases, mind you - a firmware update which will be distributed amongst monitor makers will enable the next releases of G-Sync to support VESA's VRR standard. This will not, apparently, be happening with already-released G-Sync modules, whether carrying NVIDIA's first take on the technology, nor the v2 G-Sync modules. It's not a perfect solution, and current adapters of G-Sync are still locked-in to NVIDIA graphics cards for VRR support on their monitors. |
Seega kahjuks ainult uutele G-Sync mooduliga mudelitele. Ehk siis väga väike hulk potentsiaalseid tooteid. Tootjad vaevalt, et lähevad tagasi ja hakkavad vanematele mudelitele püsivara uuendust tegema, kuigi tehniliselt oleks see võimalik.
EDIT:
Veidi huvitavat statistikat kah:
https://levvvel.com/gaming-monitor-study/
TL;DR:
65% Freesync, 17% G-Sync, 5,8% Freesync 2 ja 3,3% G-Sync Ultimate.
91,3% omab VRR tuge
27" @ 45% ja 24" @ 32%
1080p @ 53% ja 1440p @ 35%
45% VA, 40% TN ja 14% IPS
74% 144Hz, 7% 240Hz
Kommentaarid: 89 loe/lisa |
79 |
karts3
Kommentaarid: 58 loe/lisa |
57 |
pots4t4j4
02.12.2019 17:50:00
1k eest tahaks küll
Kommentaarid: 488 loe/lisa |
396 |
heretic666
02.12.2019 17:54:26
Nkn maksab see mingi 2 ja pool kilo
Kommentaarid: 70 loe/lisa |
68 |
pots4t4j4
02.12.2019 18:16:27
vaevalt, lg oma on 2k, sama tootega aasta aega hiljem turule tulla kallima hinnaga natuke nonsens pole? Kui Lg omalegi paneelide tootmisega hakkama ei saa siis kustkohast see acer neid võtab?
396 |
karts3
02.12.2019 19:46:53
Ootan juba pikemat aega 38GL950G-B monitori , sama paneeliga mis Aceril, kuid LG lükkab järjest välja tuleku aega edasi. Paistab et mul jääbki monitor ostmata.
57 |
pots4t4j4
02.12.2019 20:11:50
See juba aasta aega "väljas" lihtsalt saadavus kehva?
396 |
heretic666
02.12.2019 20:12:58
pots4t4j4 kirjutas: |
vaevalt, lg oma on 2k, sama tootega aasta aega hiljem turule tulla kallima hinnaga natuke nonsens pole? Kui Lg omalegi paneelide tootmisega hakkama ei saa siis kustkohast see acer neid võtab? |
Uurisin ja on jah väidetavalt 2K eur LG isend, samas ma ei saa aru miks sa eeldad kohe odavamat hinda? Aceri disain ju "ägedam".
68 |
denis28
Kommentaarid: 65 loe/lisa |
63 |
22.12.2019 17:33:34
LG.Display Latest Panel Development Plans – Dec 2019
https://www.tftcentral.co.uk/blog/lg-display-latest-panel-development-plans-dec-2019/
AU Optronics Latest Panel Development Plans – Dec 2019
https://www.tftcentral.co.uk/blog/au-optronics-latest-panel-development-plans-dec-2019/
LG'l päris huvitavad paneelid arenduses. Kahjuks kaugel. Enne 2021 ilmselt lettidel neid ei näe.
tsitaat: |
Overall focus areas for LG.Display are:
Improved design with new thinner profiles and “real borderless” design
Use of Mini LED backlights for improved local dimming and HDR performance
Extending colour spaces for more vivid and lifelike colours
Faster IPS gaming panels
More low blue light filter developments |
tsitaat: |
One looks like it will be the 27″ UltraHD (3840 x 2160 res) panel with 144Hz refresh rate that we’ve talked about before. This will have a 4-side borderless design and offers a 98% DCI-P3 colour gamut and HDR600 support. That is penciled in at this stage for Q3 2020 production.
The other planned option with this Oxide design is a 27″ module with 2560 x 1440 resolution and a 240Hz refresh rate. This too has a 98% DCI-P3 gamut and HDR600 support, but is penciled in for Q4 2020 production. |
Ehk siis mõlemad tootjad liiguvad FALD pealt edasi Mini-LED peale mis on vahesamm enne Micro-LED kasutuselevõtmist järgmisel kümnendil. Kahjuks OLED pole desktop monitorides eriti realiseerunud, seega lootus on, et Micro-LED seda suudab.
Ühtlasi 240Hz IPS variandid 1440p peal ja 4K IPS 144Hz koos DP 1.4 ja DSC-ga+Mini-LED ehk 1000+ tsooni ja puudub vajadus chroma subsampling teha, et 144Hz edastada üle DP 1.4 (tänu Display Stream Compression featuurile).
Siiski kui hetkel panna kirja mis võiks olla realistlik ja mida ise tahaks ütleme 5 aasta pärast näha hiljemalt:
27-32" 1440p @ 240Hz-480Hz või 35-37" 4K @ 144Hz-240Hz
IPS, Mini-LED, HDR 1000-1400
HDMI 2.1, DP 2.0
GSync & Freesync ühilduv
ULMB & Sync tugi samaaegselt
79 |
22.12.2019 17:42:20
4k 144hz mini-led mõitsliku hinnaga tahaks, 2k pole mõistlik
Kommentaarid: 71 loe/lisa |
22.12.2019 17:50:05
jeesus188, Esimesed 4K 144Hz FALD variandid on kukkunud 2k pealt 1,6k peale ja Aceri ilma FALD-ta analoog on 1,1k kandis.
79 |
22.12.2019 18:06:29
No ühel on fan probleem, kogu aeg töötab ja teisel oli mingi muu kamm
pots4t4j4
22.12.2019 18:36:53
Millega te seda 4k 144hz asja jooksutada tahate ? Tavaline rtx 2080 ei saa isegi 3440x1440 resul hakkama 120hz paneeliga, 2080ti teid ka ei pääasta 4k ja 144hz juures kahjuks.
396 |
22.12.2019 20:22:54
pots4t4j4, ei osta aastaks molli ju. Tuimalt pakun, et uus monitor jääb 5+ aastaks lauale
Küll lõpuks ka videod järgi jõuavad
pots4t4j4
22.12.2019 20:31:40
Ja kui ükskord jõuavad siis on ammu 4k 144hz monitorid 500€ tk ja paremad ka veel
396 |
22.12.2019 21:00:52
Paar aastat möödas ja pole kusagile jõudnud selles segmendis
Vael
23.12.2019 08:07:11
Lülita monitor 30Hz peale kui Vstnc vaja jookautada. Sama häda jätkub, siis tootjad ei panustagi enam 60Hz+ moniroridele "bc ur PC wii blow up if 144Hd=|=FPS".
Jah kõrgem FPS on alati parem, aga midagi ei juhtu kui 144HZ monitor silub <144FPS, vastypidi, alla 60FPS tyleb 120Hz+ monitori kasutegur veel paremini välja.
Sama hea väide nagu, "u cant see more than 60FPS". Silm ei rwgistreeri jah väiksemaid vahesid, aga monitor ei väljasta sul 60FPS ühtlast pilti- alustades ülalt alla skaneerimise ja lõpetades 0.1% low-ga.
Ma ei taha paari aasta pärast tagasi kolida 60Hz peale sest osa rahvast arvab, et nagunii GPU-d järgi ei tyle, siis pole 144Hz monitoril ka mõtet.
EDIT: https://www.blurbusters.com/gsync/gsync101-input-lag-tests-and-settings/, 2a vana artikkel tegelikult juba olemas, siin küll VSYNC ka mängus, aga point jääb ikka samaks:
60FPS@144HZ 2x parem kui 300FPS@60Hz. Ja kui ülejäänud artiklit vaadata, siis pigem 144FPS@144Hz on kehvem kui 10FPS alla monitor HZ.
Võrdluseks 142FPS@144Hz
Kommentaarid: 17 loe/lisa |
16 |
SirAskAlot
04.01.2020 16:47:52
Millega te seda 4k 144hz asja jooksutada tahate ? Tavaline rtx 2080 ei saa isegi 3440x1440 resul hakkama 120hz paneeliga, 2080ti teid ka ei pääasta 4k ja 144hz juures kahjuks. |
Äkki ta tahab 1080p ja 144hz peal vahel mõnda shooterit mängida ? Sa ei hakka ju selleks eraldi monitori ostma
Gap
Kommentaarid: 20 loe/lisa |
16 |
Renq
Kommentaarid: 4 loe/lisa |
kuccu
05.01.2020 00:12:06
See samsa G9 võib juba päris viisakas alternatiiv olla kolmikutele auto simudes kui VRi ei kannata. R1000 raadiusega piisavalt lähedale nina saad peaks päris hea olema juba.
Kommentaarid: 5 loe/lisa |
79 |
06.01.2020 10:49:58
Tomorrow, njah, esimese hinnalipik hakkab arvatavasti number kolmega
