sõnum ![Teata moderaatorile Teata moderaatorile](./images/icon_move_w.gif) |
madness
![madness madness](https://foorum.hinnavaatlus.ee/images/avatars/upload/793d2c8119ea35466c485b1887b61b7d.jpg)
13.01.2014 16:06:53
Jah, varem mul Guilini koobastes FPS kukkus kolinal, aga enam mitte.
Kommentaarid: 13 loe/lisa |
![](./images/komment/img_10_1.gif) ![](./images/komment/img_10_0.gif) ![](./images/komment/img_10_2.gif) |
![](templates/HinnaVaatlus/imagesHV/spacer.gif) |
The_Boss
![The_Boss The_Boss](https://foorum.hinnavaatlus.ee/images/avatars/upload/9ba0de872d575995ac543d17e99d77e6.jpg)
13.01.2014 16:38:55
Njaa, pärast seda uuendust nüüd 10 minuti jooksul nägin rohkem kui 5 korda seda, et sain vastasele pihta, aga temaga midagi ei juhtunud.
Kommentaarid: 347 loe/lisa |
276 |
Genert
Kommentaarid: 1 loe/lisa |
renekas
![renekas renekas](https://foorum.hinnavaatlus.ee/images/avatars/upload/a7314956b466b8bc5a7568686ff14d33.jpg)
13.01.2014 16:43:50
Ma sain alguses üldse mitu korda igast seinast seina erroreid, paar korda originile restarti siis hakkas alles uuendama.
Kommentaarid: 22 loe/lisa |
21 |
The_Boss
13.01.2014 16:48:56
The_Boss kirjutas: |
Avot kirjutas: |
UUS patch täna:
Jan 13 PC Game Update Notes
-Various fixes for improving general stability
-Fixed a memory leak issue occurring after level shutdowns, which could result in a out-of-memory crash in longer play sessions
-Additional fix for the "sound loop" deadlock when running High/Ultra graphics settings
-Added a warning for using Legacy AMD drivers that were out of date
-Fixed a player feedback timing issue where blood was appearing before other damage indicators, and before damage was actually done
-Fixed a bug where players’ rank icons on the scoreboard would not be updated
-Fix for Asian users unable to start Battlefield 3 and Battlefield 4 on Windows 8.1
-Normalized repair rates across all vehicles.
-Fixed problem with killer health in kill card not being correctly updated (showing 100% health even though the soldier was hurt)
-Fix for friendly marker not always showing when needed to, resulting in players shooting team members
-Fixed a bug where a Main Battle Tank Coaxial HMG ammo box was occasionally blocking the driver’s camera
-Increased damage by 25% for the Stealth Jet 20mm cannons.
-Stealth Jets now have more similar handling attributes to each other. F35 & J-20 are slightly more agile, Su-50 is less agile.
-Attack Jets now have more similar handling attributes to each other, and all 3 are now slightly less agile than earlier
-Fixed camera glitch when switching weapons while moving in crouch
-Fixed an occasional bug where players could experience intermittent engine sound dropouts when driving wheeled IFVs
-Fix for player spawning under the map when deploying on Lancang Dam
-Fixed flickering in map and minimap on Rogue Transmission and Operation Locker |
Väga oodatud fixid
Imelikul kombel memory leak probleem on olnud mul ainult ühel päeval.
Piisavalt tiimikaaslasi lasknud ![icon_biggrin.gif](images/smiles/icon_biggrin.gif) |
Njaa, vara hõiskasin. Friendly marker jama on ikka alles.
276 |
Dave20
13.01.2014 17:43:42
Ma ise ei rutta seda uuendust veel peale laskma, vaatan mida räägitakse
Kommentaarid: 26 loe/lisa |
25 |
The_Boss
13.01.2014 17:48:05
Dave20, kas sul on üldse valikut? Mul hakkas automaatselt patchima igatahes.
276 |
pohmakas,
käed värisevad
![pohmakas, pohmakas,](https://foorum.hinnavaatlus.ee/images/avatars/upload/bce120a5ed2cdbfccfaa15e0635a549b.jpg)
13.01.2014 17:53:18
Ega patchid pole "vabatahtlikud". Kui tuleb, siis peab peale laskma.
Dave20 kirjutas: |
Ma ise ei rutta seda uuendust veel peale laskma, vaatan mida räägitakse ![icon_biggrin.gif](images/smiles/icon_biggrin.gif) |
Kommentaarid: 159 loe/lisa |
132 |
Dave20
13.01.2014 17:55:32
oli jah kohustuslik
25 |
Karl P.
![Karl P. Karl P.](https://foorum.hinnavaatlus.ee/images/avatars/upload/f337e8ab98b4088b07d2996639d4d245.jpg)
13.01.2014 18:06:08
Zavodis peabki tolm lihtsalt õhus seisma?
Kommentaarid: 28 loe/lisa |
24 |
renekas
13.01.2014 18:16:20
Jep, koos laserkiirte ja medkittidega
21 |
kankka
13.01.2014 18:34:34
Friendly marker...5 minutit võid ühte vennikest Spottida ja sinist junni ei ilmu - lased maha ja tuleb välja, et ikka enda oma
![](https://foorum.hinnavaatlus.ee/images/200x40_HV.gif) |
Kommentaarid: 6 loe/lisa |
pohmakas,
käed värisevad
13.01.2014 19:00:19
Sai ka üle pika aja nüüd mängitud. Zavodi levolution: korsten jäi minu pildis püsti, keskkond lagunes ja nähtamatud rusud olid
132 |
proz213
![proz213 proz213](https://foorum.hinnavaatlus.ee/images/avatars/upload/0f4ee5b13efc30d6c3651e8739162ae1.png)
13.01.2014 19:05:39
Mul ka, 50/50 elioni pakett, maks kiirus 4-5 MB/S, originis tõmbab 8-10 MB/S. Kahtlane värk
_________________ "either we are alone in the Universe or we are not. Both are equally terrifying.” ― Arthur C. Clarke |
Kommentaarid: 7 loe/lisa |
lauri23
![lauri23 lauri23](https://foorum.hinnavaatlus.ee/images/avatars/upload/3ff37e0a60b1b89b599ae9546b7fba01.jpg)
Kommentaarid: 27 loe/lisa |
ownagetime
![ownagetime ownagetime](https://foorum.hinnavaatlus.ee/images/avatars/upload/b81d3869ad8e433d5e5bd2f7ccc81488.jpg)
13.01.2014 19:23:57
Suur see uus patch on?
Kommentaarid: 14 loe/lisa |
10 |
S.I.L.L.U
![](images/avatars/gallery/Female/00128.gif)
13.01.2014 19:26:51
260MB
Kommentaarid: 90 loe/lisa |
84 |
äss
![äss äss](https://foorum.hinnavaatlus.ee/images/avatars/upload/c83b269ed8960084d499ba7cdbd3da2a.jpg)
13.01.2014 19:34:38
Vahest crashib ikka peale seadete muutmist.
Kommentaarid: 29 loe/lisa |
23 |
The_Boss
13.01.2014 19:42:21
see 260MB tõmbas nii märkamatult kiiresti ära, nagu olekski neti kiirus 2x kiirem
276 |
ownagetime
13.01.2014 19:54:28
Originis mul tõmbab ka kiiremini kui mujal
10 |
est4ever
![est4ever est4ever](https://foorum.hinnavaatlus.ee/images/avatars/upload/575100d54a58f7fbb8d9660037226333.jpg)
13.01.2014 19:57:54
mul ka mingi imelik värk, elioni 12mbit nett, aga originis sikutas praegu 2.05mbaiti/s
Kommentaarid: 86 loe/lisa |
81 |
proz213
13.01.2014 20:27:11
lauri23 kirjutas: |
Sama ühendus ja sama kiirus. Ei tea mis moodi siis elion seda kiirust piirab. Torrentite kiirust oskab küll piirata. |
Spetside käes küsides sain sellise vastuse
tsitaat: |
It is not possible for them to bypass speed limit set by your ISP, they probably have agreement with your ISP company to offer higher speeds only for their services or the ISP is serving you cached data from their own servers to reduce network traffic and give you better download speed - although I find this highly unlikely.
This is assuming that the download speed is 2 times faster than one in contract with your ISP if the download speed you get on origin is same as your ISP promised you then the issue is with other services (or your ISP) limiting bandwidth and origin just working as expected. |
madness
13.01.2014 20:53:18
Minu arust see Origini client selgelt valetab kiiruse kohta
The_Boss
13.01.2014 20:56:21
Stopper kätte, mõõda ära
276 |
kankka
13.01.2014 21:08:15
Origini allalaadimine on ainuke asi mis EA ikka päris korraliku teinud on Eriti glitche pole.
