sõnum |
Elric
25.10.2007 16:40:06
Ärge ainult trügima hakake...
Kommentaarid: 2 loe/lisa |
earthbeat
25.10.2007 16:42:52
aga hinnast ei ole ikka veel haisugi... kas jääb samaks või on esimesele sajale special price?
Taavi_R
Kommentaarid: 181 loe/lisa |
161 |
earthbeat
26.10.2007 13:12:52
ma mõtlesin, et pigem on esimesed sada kallimad
veiho
Kommentaarid: 1 loe/lisa |
earthbeat
31.10.2007 11:14:47
winsupersite on kõige objektiivsem koht jah... se on umbes sama kui appleinsider või macworld hakkaks vistat arvustama
ma olen vahetevahel seal vaadanud... deem vennike ei tea mitte sittagi OSist
matasano on üsna asjalik.
fedja
Kommentaarid: 125 loe/lisa |
116 |
earthbeat
31.10.2007 17:57:11
Leopardi installiprobleemidest polegi sõnakestki? .
tsitaat: |
A number of users who have bought Mac OS X Leopard have been experiencing stalled upgrade installations, Apple's forums reveal. Upon nominally completing the installation process, some Macs have rebooted only to become stuck at a blue screen, requiring users to manually shut them down. Apple is said to already be aware of the issue, but the exact causes are at present unknown; some have suggested problems with attached peripherals, DivX Application Support or Tiger's RAID technology, but these factors are not constant. |
tsitaat: |
Apple has now acknowledged issues with Leopard installation that can result in an everlasting blue screen after the install has taken place. |
http://www.macnn.com/articles/07/10/29/leopard.install.freezes/
http://www.news.com/8301-13579_3-9806005-37.html
EDIT:Tundub,et Leopardi Firewall on ka paras sõelapõhi :
http://www.macnn.com/articles/07/10/30/leopard.firewall.flaw/ :
tsitaat: |
Security experts have analyzed Apple's Mac OS X 10.5 Leopard firewall, and have declared the feature unreliable |
tsitaat: |
The results mean Mac users can't rely on the firewall included with Mac OS X Leopard, according to the experts, because even if users choose to block all incoming connections potential attackers can continue to communicate with system services like the time server |
Kommentaarid: 89 loe/lisa |
79 |
veiho
31.10.2007 20:27:04
Lappasin seda ülevaadet, midagi asjalikku selles küll ei leidnud. Ümmargune jutt.
Millised nendest http://www.winsupersite.com/reviews/macosx_leopard.asp võetud järgnevatest väidetest sinu meelest väärad on?
tsitaat: |
While the Apple hype machine and its fanatical followers would have you believe that Mac OS X 10.5 "Leopard" is a major upgrade to the company's venerable operating system, nothing could be further from the truth. Instead, Leopard is yet another evolutionary upgrade in a long line of evolutionary OS X upgrades, all of which date back to the original OS X release in 2001. |
tsitaat: |
Apple advertises that Leopard includes over 300 new features, but even a casual examination of the new feature list reveals that the vast majority of those "features" are hardly anything to write home about. For example, the DVD player application has been updated for this release, and one might charitably describe that as a "new feature," in the sense that any improvement is, at least pedantically, new. But Apple doesn't break things down that way. No, the updated DVD player in Leopard is responsible for fully 10 of the operating system's new features. Among these "new" features are a time slider, auto zoom, and the ability to display the DVD player application on top of other windows. (Yes, seriously.) If Microsoft used this loose definition of the word new, it might have advertised Vista as having 11,000 new features. Heck, maybe it should. |
tsitaat: |
Oddly enough, even the few major new features in Leopard will look familiar to users of other operating systems. There's Time Machine, a bizarre take on the Previous Versions feature in Windows. And there's Spaces, a pleasant graphical front-end to the workspaces functionality that's been available in UNIX and Linux since, well, forever. What's old is new again. |
tsitaat: |
All you really need to know about Spaces is that it's a typically elegant Apple take on a long-time UNIX feature called workspaces, which allows you to configure two or more virtual desktops, or workspaces, each of which can contain its own application windows. |
tsitaat: |
Worse is the updated Dock, which now sports a gratuitous and pointless "3D" shelf effect. Theres no real 3D involved, of course, but there is a hokey looking border, modeled after a highway median strip, separating the two sections of the Dock. As ever, the Dock is a usability nightmare, with overlapping functionality (it contains shortcuts for both running and certain non-running applications as well a separate location for folder shortcuts), but Apple seems to at least tacitly acknowledge this fact: Its added a useful if limited new feature called Stacks to the Dock to close the gap with the superior and more logical Windows Start Menu. |
tsitaat: |
Spotlight now supports Boolean operators like AND, OR, and NOT, which should be familiar to database gurus and Google fans. As with Vista's Start Menu search feature, you can now use Spotlight to quickly find and launch applications. (This was possible in previous versions, but wasn't as seamless.) And for all you DOS-minded folks out there, you can actually use Spotlight to search for file names now. What a country. |
tsitaat: |
Apple's lackluster Safari Web browser is updated to version 3 in Leopard and it features some improvements that will be familiar to user of Firefox. First, there's an enhanced find that works a lot like the Find functionality in Mozilla Firefox, with a subtle Find box near the toolbar instead of an obtrusive dialog box as in previous Safari versions. |
tsitaat: |
Safari 3 also supports drag and drop tab reordering, another feature lifted from Firefox. |
tsitaat: |
Safari 3 now supports creating a single bookmark from an entire range of tabs. Yes, you guessed it: Just like Firefox. |
Muidugi on selles artiklis liiga palju mõttetut Vistaga võrdlemist, kuid Windowsi saidi kohta ootuspärane.
earthbeat
31.10.2007 20:53:01
Spotlight vs. Vista search on nüüd küll mõttetu teema 8)
Ma tormasin kaa seda kohe kasutama kui vistat esimest korda nägin... deem kus asi imes täiesti kasutu asi.
Ja se jutt, et Tiigri Spotlight ei tööta on veidi idiootne (või tuleb teadmatusest)... ma olen 2 aastat juba spotlighti app launcherina kasutanud töötab kiirelt ja veatult. Vastupidiselt Vista searchiga Loepoldi spotlight on muidugi veel tõhusam... ja üllatavalt väle ka sittematel masinatel.
Dock on ka minu meelest liiga microsoftilik... rohkem applet oleks vaja
fedja
31.10.2007 23:05:41
Windowsifänni arvamus Apple'i uuest operatsioonisüsteemist peaks midagi väärt olema ?
Artikkel käsitleb ainult autori arvamusi ja eelistusi, 3D dokk on nõme ja Spaces pole uus idee, Firefoxi ideesid on pännatud jne., so what ?
Kui ei meeldi, ära kasuta, Vista plagiaate ja miinuseid võib samahästi üles lugeda, tulemust sel ei ole.
116 |
veiho
01.11.2007 01:31:47
Küsimus on ilmselt selles, et kui Apple fanboyd pidevalt ei kilkaks, et Apple on oma toodete funktsionaalsusega esirinnas ja teised ainult kopeerivad, siis ei tekiks ka vastupidise tõestamise vajadust. Tõepoolest, suure operatsioonisüsteemide revolutsioonina on esitletud teistes süsteemides triviaalseid asju.
fedja
01.11.2007 02:22:47
veiho kirjutas: |
Küsimus on ilmselt selles, et kui Apple fanboyd pidevalt ei kilkaks, et Apple on oma toodete funktsionaalsusega esirinnas ja teised ainult kopeerivad, siis ei tekiks ka vastupidise tõestamise vajadust. Tõepoolest, suure operatsioonisüsteemide revolutsioonina on esitletud teistes süsteemides triviaalseid asju. |
Kõik kopeerivad, kuid Apple teeb seda hästi, siin foorumis on sellest juba küllalt arutelu olnud, kasuta otsingut.
116 |
skoop
03.11.2007 00:47:47
ise kasutan tiigrit aga proovisin leopardit kah. paraku läksin tiigri juurde tagasi.
põhjus lihtne - nagu see winsupersite'i mees kirjutas, pole mingit põhjust ligi 2000 krooni leopardi eest välja käia. tiiger töötab vähemalt sama kenasti. ja dock on tõepoolest ebafunktsionaalsemaks läinud, samuti menubar. Finder pole ka just eriti vingemaks läinud - cover flow, mis itunes'is on igati vinge, tundub failide vaatamiseks küll paraku suht mõttetu ja pigem ressurssi raiskav. time machine ... ei oskagi midagi arvata, eriti ise ei kasutaks (töödokumentidest teen nagunii varukoopiaid, meilid on netis).
kõige suurem probleem on minu jaoks see, et kuna kõik asjad muudkui graafilisemaks ja änksamaks muutuvad, siis jääb kasulikku ekraanipinda üha vähemaks... varsti tuleb väikese ekraaniga MacBookidele teha eraldi minimalistlik versioon OSXist, sest igasugu tilulilu võtab liiga palju ruumi. Lauaarvutiga, millede ekraanide suurus pidevalt kasvab, seda muret muidugi pole. Tundubki, et Leopard oleks ideaalne näiteks uue iMaci peal.
Üldiselt, et kes saab uue arvutiga Leopardi, siis see võib õnnelik olla. Ja kelle vanas arvutis jookseb Tiiger, see võib ka õnnelik olla.
Kusjuures winsupersite'i mehel on ses osas hea point, et noh 300 "new features" on paras nali jah. Time Machine pole mitte ise uus feature, vaid lausa 11 uut featuret, samamoodi DVD mängija 10 jnejen
Aga muidu võib tõesti kinnitada, et tegu on igati toreda OSiga ... aga Tiigrilt üle minnes +2000eek on ikka paras nöörimine.
Kommentaarid: 113 loe/lisa |
100 |
Alari A.
03.11.2007 11:12:02
krt.ennast ka huvitaks mis seal 300 uuendust oleks
mõne noole kuju muutmine ilmselt ka sinna sisse loetud
viimati muutis Alari A. 03.11.2007 11:56:11, muudetud 1 kord |
Kommentaarid: 649 loe/lisa |
533 |
03.11.2007 11:51:56
digweed kirjutas: |
mõne noole kuju muutmine ilmselt ka sinna sise loetud |
Njah...selle loogika järgi oleks Vistal võrreldes XP-ga 11000 uuendust .Nad peaks ikka tõelisi uuendusi lugema
79 |
Vermon
03.11.2007 13:32:17
Kõige paremad uuendused minu meelest on wifi nimekirjas näitamine millised võrgud on lahti ja kui iCal dokki panna siis näitab õiget kuupäeva ikooni peal Terminali tabid ka muidugi.
Kommentaarid: 14 loe/lisa |
12 |
Alari A.
03.11.2007 15:06:28
tore leo juures see, et mul paneb aku ~30 min kauem ehk 4h
533 |
v2hja
03.11.2007 17:01:31
Vermon kirjutas: |
Kõige paremad uuendused minu meelest on wifi nimekirjas näitamine millised võrgud on lahti ja kui iCal dokki panna siis näitab õiget kuupäeva ikooni peal Terminali tabid ka muidugi. |
tiigril on see ical überfunktsioon täitsa olemas
kui ical jookseb siis ikoon näitab õiget kuupäeva ..
_________________ www.ninjatune.net
RIP Monkey Radio |
Kommentaarid: 74 loe/lisa |
60 |
Elric
03.11.2007 20:30:38
Jah, kui jookseb.
Vermon
04.11.2007 02:43:51
Täpselt, kui seisab siis näitab 17. Juuli kuna tiiger tuli välja see päev
12 |
fedja
04.11.2007 17:23:14
Vermon kirjutas: |
Täpselt, kui seisab siis näitab 17. Juuli kuna tiiger tuli välja see päev |
Paraku mitte, Tiiger tuli välja 29.04.2005, see kuupäev on aga iCal-i esmaesitlusest, 17.07.2002.
116 |
Vermon
04.11.2007 19:00:07
A nii hoopis. Ma googlist otsisin ja ei viitsinud päris lõpuni lugeda, järeldasin, et tiiger
12 |
skoop
100 |
