mine lehele eelmine  1, 2, 3 ... 162, 163, 164 ... 579, 580, 581  järgmine
jt234
jt234
sõnum 21.11.2017 16:49:04 vasta tsitaadiga
Eks Grand Macho RT jahutaks ka passiivis ära kui kastis mingigi õhuliikumine on. Mõte on varsti katsetada.
Dima oli siin
Kommentaarid: 129 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 121
Dijital
Dijital
sõnum 21.11.2017 16:51:52 vasta tsitaadiga
rmc, passiivis on raskem mingit trendikat RGB-d külge pookida ju icon_biggrin.gif
Mobrog tasustatud küsitluste paneeli affiliate link: KUTSE
Kommentaarid: 40 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 31
sõnum 21.11.2017 16:53:43 vasta tsitaadiga
rmc kirjutas:
Aga review'st https://www.guru3d.com/articles-pages/thermalright-hr-02-cpu-cooler-review,1.html "Thermalright actually introduces this product as a passive CPU Cooler."
"You can use the HR-02 in many ways, if you want to, you could go passive with it. Even then the cooling performance remains nice and even with a hint of an overclock (3.3 GHz / 1.3v on the 2.67 GHz Core i5 750 processor) the cooler managed to keep the processor at very acceptable temperatures, all measured with a full load of Prime95 CPU stress testing, let's not forget that."
"Even with a slight overclock at 3.3 GHz on the Core i5 750 processor with 1.3v on the CPU we still get acceptable temperatures. Roughly 61 Degrees C when we stress all the processor cores. That in fact is impressive. Though possible, I wouldn't go higher on the overclock though."
Ja vaata kui vana prose see ;D
https://www.hardocp.com/article/2010/08/26/thermalright_hr02_passive_processor_heatsink_review/3
i7 920'ga ka @ 3,6GHz
- londiste
Kommentaarid: 238 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 213
Viilutaja
Viilutaja
sõnum 21.11.2017 17:07:01 vasta tsitaadiga
No näed siis, isegi vanade jahutitega jahutatakse ilusti Ryzeni 8C masinaid icon_razz.gif - passiivis!
Kommentaarid: 222 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 192
Aeg maha 1p
sõnum 21.11.2017 17:18:07 vasta tsitaadiga
Noh, eks ta ole, et kokkuvõtteks on 1700 võimalik passiivis jahutada küll. Kui casefanid kasti õhuvoolu korras hoiavad. Keegi võiks proovida ilma selleta ;D
Eks see, kuidas kõige mõistlikum on, on katsetamise asi... huvitav nt., kas mõistlikum üks vent sisse või välja puhuma või üks vent radika külge.. ise arvaks, et radika külge vast pigem. Samas kui kõik fanid on ühtlaselt madala voldi peal, siis pole nagu vahet.
Kommentaarid: 195 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 181
One
sõnum 21.11.2017 17:39:56 vasta tsitaadiga
Ei tea, kui mul veel 760K(100w) oli ja jahutiks Akasa Nero 3 + Enermax Cluster @ min rpm siis jooksis see kooslus
lõdvalt ka 5GHz(max load 65c) peal, seda overvoldi ja 0 casefaniga.
Ei usu, et 65w prose mingi vähegi normaalsema jahutiga enamvähem passiivis ei jookseks.
Kommentaarid: 1007 loe/lisa Kasutajad arvavad:  :: 3 :: 1 :: 727
sõnum 21.11.2017 17:55:20 vasta tsitaadiga
Winterwind, enam-vähem passiiv ja passiiv on väga erinevad asjad.
- londiste
Vael
sõnum 21.11.2017 18:19:45 vasta tsitaadiga
Mõttekam ei oleks prosa küljes jooksutada madalatel pööretel ventilaatorit, selmet korpuse küljes? Korpuse küljes "kostub" lärm kohe välja, CPU jahuti küljes sumbub mingil määral juba korpusesse. Passiiv ei ole ta kummalgi juhul nagunii...
One
sõnum 21.11.2017 18:23:07 vasta tsitaadiga
https://www.youtube.com/watch?v=ArJjI0F32rU
Auron
Auron
sõnum 21.11.2017 18:46:35 vasta tsitaadiga
Selle passiivse jahutamisega on ilmselgelt teatud nüansid. Esiteks on passiivne prose jahutamine BS kui korpusevendid uhavad minna. Teiseks on passiivne jahutamine BS kui kui kaart istub idles ja prosele antakse korra koormust - teatavasti vähegi asisemad kaardidi on oluliselt suurema soojuseraldusega kui prosed ehk siis pigem on huvitav mida teeb kastis passiivis jahutiga prose peale poolt tundi nõudliku kaasaegse mängu mängimist asise kaardiga. See, et netis käies prose kannatab passiivis ära jahutada pole mingi müstika.
Kommentaarid: 150 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 127
pots4t4j4
sõnum 21.11.2017 18:52:03 vasta tsitaadiga
500 rpm ventikat anyway ei kuule ja juba sellega saab rahus näiteks 7700k 5ghz, mõttetu üritus see jumala eest passiivis jooksutamine.
Kommentaarid: 488 loe/lisa Kasutajad arvavad:  :: 4 :: 3 :: 396
sõnum 21.11.2017 19:02:46 vasta tsitaadiga
Kui mõnel siin 100% pasiivis masin on, siis eeldan, et ka GPU on passiivis?
sõnum 21.11.2017 20:51:42 vasta tsitaadiga
Auron, salatoimik, see pole Ryzeni teema aga mu profiilis on detailid arvuti kohta (Haswell + Maxwell), kus ainsad ventilaatorid on GPU peal. Ca 1h mängimist tähendab, et CPU temperatuur on midagi 75C kandis, GPU jääb 70C kanti (1200p@60). Ei ole GPU ventilaatorite kiirust kunagi jälginud aga kastist on kuulda vaid vaikset sahinat mängimise ajal. Muul ajal on kast ilmselgelt hääletu.
Kommentaarid: 178 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 144
Insomnia
Insomnia
sõnum 22.11.2017 00:11:52 vasta tsitaadiga
Link
Kristocfc
Kristocfc
sõnum 22.11.2017 14:26:07 vasta tsitaadiga
huvitav kas tänasel päeval peaks ikka veel ryzenile rami ostes lähtuma MB QVL listist? või võib lajatada odavaima 3200 seti sisse näiteks?
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 51
Aeg maha 1p
sõnum 22.11.2017 15:31:49 vasta tsitaadiga
Kõige lollikindlam on guugeldada teiste kogemusi mobo, prose, rami koosluse suhtes..
-antero-
-antero-
sõnum 23.11.2017 11:08:32 vasta tsitaadiga
rmc kirjutas:
Minu Corsair 3200 2*8 kit ei jookse tänaseni 3200 peal (kuigi on kasutajaid kellel pole mingit probleemi sama kit'iga olnud), küll aga sain nad jooksma 2933 peal ja oluliselt parema timinguga kui default sätted.
Paar päeva tagasi tulid uued Bios'id välja ning ilmselt homme peale tööd katsetan uuesti 3200 käima saada icon_smile.gif
p1lv1k
sõnum 23.11.2017 14:09:40 vasta tsitaadiga
https://www.techpowerup.com/forums/threads/asus-bios-change-log-reveals-new-ryzen-processors-incoming.239061/
DeTHiCa.
DeTHiCa.
sõnum 23.11.2017 14:13:31 vasta tsitaadiga
-antero-, huvi pärast võiksid postitada enda thaiphoon burneri screenshoti.
http://www.softnology.biz/files.html
mul endal peaks olema samad mälud (lihtsalt musta värvi)
minu oma on selline:
clock frequency näitab valesti miskipärast
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 136
pots4t4j4
sõnum 23.11.2017 15:19:28 vasta tsitaadiga
p1lv1k kirjutas:
Uue ryzeni v6taks küll, vana pea 9 kuud juba olnud, igati ok va overclocks like shit.
-antero-
-antero-
sõnum 23.11.2017 15:21:30 vasta tsitaadiga
DeTHiCa., ikka saab. Koju jõuan, siis vaatan järgi. Aga ma ise kahtlustan et asi pigem mobos kuna need samad mälud mis mul praegu kasutusel, jooksid sinu masinas vist ilusti 3200 peal? Mul ei võta XMP'ga näiteks üle 2666 midagi vastu. 2933 on käsitsi pandud.
Viilutaja
Viilutaja
sõnum 23.11.2017 15:39:48 vasta tsitaadiga
DeTHiCa. kirjutas:
Minul on tavalised Corsair LPX 16 Gb kit. 3200Mhz ja XMP läks 1006 biosega ilusti peale ja tööle. Ennem oli ka ainult 2933Mhz käsitsi max.
DeTHiCa.
DeTHiCa.
sõnum 23.11.2017 15:49:19 vasta tsitaadiga
Viilutaja, sul profiilis pole mobo kirjas
Aeg maha 1p
sõnum 23.11.2017 15:56:25 vasta tsitaadiga
pots4t4j4 kirjutas:
p1lv1k kirjutas:
Uue Ryzeni võtaks küll, 2500k on natukene liiga kaua masinas olnud juba icon_biggrin.gif
Viilutaja
Viilutaja
sõnum 23.11.2017 18:08:19 vasta tsitaadiga
DeTHiCa. kirjutas:
Nüüd panin profiili ka, aga on Gigabyte B350M-Gaming3
uus teema   vasta Raud »  Protsessorid »  AMD Zen/Ryzen/Threadripper/Epyc arutelu mine lehele eelmine  1, 2, 3 ... 162, 163, 164 ... 579, 580, 581  järgmine
