A time-lapse of Planet Earth, created from images produced by the geostationary Electro-L Weather Satellite. The images were obtained beginning on May 14th, and end on May 20th. The images are the largest whole disk images of our planet, each image is 121 megapixels, and the resolution is 1 kilometer per pixel. They are taken every half hour, and have been interpolated (smoothed) to create this video. The images are taken in four different wavelengths of light, three visible, and one infrared. The infrared light is reflected by forests and vegetation, which appear orange in these images.
Kusjuures kui hakata mõtlema, kas ainult põhja-lõuna suuna tõttu kuvatakse Maad niipidi nagu seda tavaliselt kuvatakse?
Ja kui kunagi magnetpoolused vahetuvad, kas hakatakse teistpidi vaatama? _________________ HV valuutakalkulaator
Kaarte Läänes hakati kujutama valdavalt põhja-lõuna suunaliselt alles siis kompass Euroopasse jõudis (~13saj). Enne seda olid mitmed kaardid kujutatud nii, et hoopis "ida" oli üleval.
The orientation of a map is the relationship between the directions on the map and the corresponding compass directions in reality. The word "orient" is derived from Latin oriens, meaning east. In the Middle Ages many maps, including the T and O maps, were drawn with east at the top (meaning that the direction "up" on the map corresponds to East on the compass). The most common cartographic convention is that north is at the top of a map.
_________________ Ehitusprojektid ja konstruktiivsed lahendused HV kasutajatele soodsamalt
Mitte ainult "tagurpidi", vaid seal ei ole ju peale India ookeani kohal hõljuvate pilvede suurt midagi üldse nähagi. Kõik huvitavad alad on ainult kitsa ribana külje pealt näha.
Ainsad normaalselt jälgitavad alad on India, Araabia poolsaar ja Ida-Aafrika ja ida pool natuke Indoneesia saarestikku. Kohad, kus erinevused aastaaegade vahel on väga väikesed parasvöötmega võrreldes. Orientatsiooni järgi arvaks, et video panid kokku austraallased, aga asukoha järgi, et hindud
Kas see satelliit vist hõljubki seal India ookeani kohal, et lihtsalt polegi tal midagi muud näha sealt. Põhjapoolsemate alade paremaks jälgimiseks peaks pilti arvutis töötlema ja "sirgeks triikima", välja venitama pooluse suunas ja ida-lääne suunas samuti. _________________ Tee inimesele lõke ja tal on soe üheks päevaks, pista ta põlema ja tal on soe elu lõpuni. (Terry Pratchett)
Algses postituses oli mainitud, et tegemist on geostatsionaarsega, seega ripub ühe koha peal maa suhtes, jah. Kiire guugel andis ühe Elektro asukohaks India ookeani, teise asukohta ei leidnud kiiresti, rohkem ei viitsinud otsida ka. _________________ Foxic is just a simple fox
Enne kui sa küsid oma küsimuse - küsi seda vannipardilt! Rangelt soovitatav enne programmeerimise alafoorumisse uue teema tegemist.
Arvata oli jah. Nojah, vaatasin et on meteoroloogiline satelliit. Ilmselt jälgibki peamiselt India ookeanil ja selle ümbruses toimuvat ilma peamiselt. Maismaa jälgimiseks on tunduvalt paremaid vaatepunkte ju. _________________ Tee inimesele lõke ja tal on soe üheks päevaks, pista ta põlema ja tal on soe elu lõpuni. (Terry Pratchett)
A little more than two weeks have passed since the apparent loss of the highly classified Zuma mission. Since then, SpaceX has publicly and privately stated that its Falcon 9 rocket performed nominally throughout the flight—with both its first and second stages firing as anticipated.
Now, the US Air Force seems to be backing the rocket company up. "Based on the data available, our team did not identify any information that would change SpaceX's Falcon 9 certification status," Lieutenant General John Thompson, commander of the Space and Missile Systems Center, told Bloomberg News. This qualified conclusion came after a preliminary review of data from the Zuma launch. That's according to Thompson, who said the Air Force will continue to review data from all launches.
Elon Musk
@elonmusk
This rocket was meant to test very high retrothrust landing in water so it didn’t hurt the droneship, but amazingly it has survived. We will try to tow it back to shore.
edit: Midagi lendab kosmosesse või õhku, huvitav saab igatahes olema.
Juba edasi lükatud vist 1,2h võrra _________________ This message was sent from space using stargate
Ma ei tea muid linke, kui keegi just ümber suunanud pole, siis http://www.spacex.com/webcast suunab ka youtube lehele
E:
9 min. Ja go _________________ This message was sent from space using stargate
Tesla kosmoses, don't panic kirjaga _________________ This message was sent from space using stargate
Kolmas vast sai otsa kõva pauguga. kukkusid kokutama ja jälgige meid twitteris.
Aga üldiselt Musk ütles, hea kui kosmosessegi saaks, esimest korda selline comboga
Lisamootorite maandumine oli imeline
Ja keskmine kadus kahjuks _________________ This message was sent from space using stargate
jeesus188, kindel, et core kadus? vb ainult kommunikatsioonid maas?
No ülekanne lõppes ka ennatlikult, lõpetati tähendab. Seal ümber on kindlasti ka laevad vms olemas. Arvan, et ikkagi kadus.
Samas loodame parimat _________________ This message was sent from space using stargate
Ülekandes juba tundus kahtlaselt horisontaalne, üks mootor suitsemas, ta peaks ikka suht otse alla tulema (parem ülemine)
Ja kus pidurduslabad on? Kahel teisel kenasti lahtised
