sõnum ![Teata moderaatorile Teata moderaatorile](./images/icon_move_w.gif) |
rex
![rex rex](https://foorum.hinnavaatlus.ee/images/avatars/upload/rex.gif)
15.04.2008 18:55:11
Eks ta sinna kilo kanti jääb.
Kommentaarid: 247 loe/lisa |
![](./images/komment/img_10_1.gif) ![](./images/komment/img_10_0.gif) ![](./images/komment/img_10_2.gif) |
226 |
![](templates/HinnaVaatlus/imagesHV/spacer.gif) |
eldorado
![](images/avatars/gallery/BaldursGate/baldursgate_sharteel.gif)
16.04.2008 09:16:02
hea lappar endal seeria 701, olen rahul - aku pidavus hea, vorgukaart on sees, wifi sees. kui soov on - voimalik win xp instaleerida. Kui otsime vea vorgus vaga lahe, parem kui 13-14" laptopiga jooksma ringi D
Kommentaarid: 148 loe/lisa |
9 :: |
106 |
![SKG SKG](https://foorum.hinnavaatlus.ee/images/avatars/upload/db1ec2c4826213c2ec506b8bfbbd5419.gif)
17.04.2008 11:02:29
kaal jääb ikka alla 1kg
tsitaat: |
Specifications
Display: 8.9" Display, 1024 x 600 resolution
Color: Pearl White, Black
CPU: Intel® Mobile CPU
Processor: Intel Mobile Chipset
Memory: DDR II 1GB
Display Card: Intel UMA
Storage: 12GB (4GB built-in + 8GB flash) SSD (Microsoft Windows OS Version); 20GB (4GB built-in +16GB flash) SSD (Linux OS Version)
Audio: HD audio / built-in speakers
Wireless: Built-in 802.11b/g
Camera: 1.3M Pixel webcam
Storage Cards: SD / MMC (SDHC)
Input / Output: 3xUSB / VGA-out (D-Sub, 15pin) / earphone jack / mic / RJ45 10/100 Mbps
Power: Output: 12V, 36W; Input: 100-240V AC, 50/60Hz universal
Tracking Control: Utilizes FingerGlide
Operating System: Windows XP Home / Linux
Dimensions: 22.5cm(W) x 17.0cm(D) x 2cm~3.38cm(H)
Weight: 0.99 kg |
veel infot: http://www.asus.com/news_show.aspx?id=10911
_________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..." |
Kommentaarid: 373 loe/lisa |
313 |
davidco
Kommentaarid: 92 loe/lisa |
87 |
HighEnd
![HighEnd HighEnd](https://foorum.hinnavaatlus.ee/images/avatars/upload/3398f80a78ae83d6791f4895190d983d.jpg)
17.04.2008 16:42:33
Endal niikuinii läpaka ost ees. Täna nägin seda vana versiooni ee-pc-st. See on ikka päris pisike ja aku pidavat ka korralikult pidama. Tüüp kelle oma see oli ütls et San Andreas pidavat ka korralikult liikuma. Kui hind nii soodne tleb naq oodatakse siis arvatavasti ostan selle ära. Vanal versioonil on miinuseks natuke liiga väike ekraan minuarust. Muidu valin kumba osta kas mingit tillukest läpparit või mõnd delli quadro videoga. Sessuhtes et tegelen vahetevahel 3D-ga ja perf oleks suht vajalik.
_________________ ANIMIST |
Kommentaarid: 11 loe/lisa |
10 |
Le Inc
![Le Inc Le Inc](https://foorum.hinnavaatlus.ee/images/avatars/upload/c6b38c662de17281da1bfd88ece631be.jpg)
19.04.2008 21:30:28
Kas neil ka miskine kõvaketta liitmise võimalus ka on? See 2,5 ei ole ju nii suur et läpatsisse ära ei mahuks!?
Kommentaarid: 56 loe/lisa |
54 |
HighEnd
10 |
davidco
19.04.2008 21:56:04
Le Inc kirjutas: |
Kas neil ka miskine kõvaketta liitmise võimalus ka on? See 2,5 ei ole ju nii suur et läpatsisse ära ei mahuks!? |
milleks seda vaja on? sellise väikse pilli puhul pole küll hunnikus ketast vaja, ma ei suuda isegi 60gb ketast kunagi täis saada, max 30gb olen ära kasutand.
_________________ ..... |
87 |
HighEnd
10 |
Le Inc
21.04.2008 08:59:32
Lihtsalt 12 GB HDD tundub tsipa pisuke olevat .. kui Vista taoline monstrum pääle panna jääb muu kasuliku kraami jaoks väga vähe ruumi.
Kahjuks ei näinud ma ühtegi video-out otsikut? (vga ei lähe arvesse) .. ning kas see cellu-M suudab ka HD kino lahti kodeerida? Väga lahe oleks asja kasutada ka videomaikna lastes pilti TV.
54 |
sander85
![sander85 sander85](https://foorum.hinnavaatlus.ee/images/avatars/upload/65a57b568ccd70bfb64c06e27880c0fa.jpg)
21.04.2008 09:03:22
Le Inc kirjutas: |
Kahjuks ei näinud ma ühtegi video-out otsikut? (vga ei lähe arvesse) .. ning kas see cellu-M suudab ka HD kino lahti kodeerida? Väga lahe oleks asja kasutada ka videomaikna lastes pilti TV. |
hmm, ei maksa ikka üle ka pingutada, vaevalt, et see masin on mõeldud sellisteks operatsioonideks.. vista peale? unista edasi see kurnab ka võimekamaid masinaid.. mis ta selle väikse masinaga veel teeb?
_________________ Think of how stupid the average person is, and realize half of them are stupider than that.
-- G. Carlin |
Kommentaarid: 2 loe/lisa |
djkiller
![djkiller djkiller](https://foorum.hinnavaatlus.ee/images/avatars/upload/0c17024f29f8505346361a86e68b6ce0.jpg)
21.04.2008 09:25:16
maha põleb
Kommentaarid: 222 loe/lisa |
201 |
21.04.2008 09:31:10
Le Inc kirjutas: |
selleks pole see masin võimeline ega mõeldud
313 |
DVDRW
![DVDRW DVDRW](https://foorum.hinnavaatlus.ee/images/avatars/upload/fa43a4098d05e0c57c52c9d465b22b05.GIF)
21.04.2008 11:19:06
See meenutab aega kui K-arvutisalong tuli välja 1.20 kr hinnaga 10x15 foto, mis pani teised firmad kõik nutma 8)
nüüd on Asus esimene odava kerge läpakaga ja teised panevad kõik järgi.
Teistsugust 1Kg SSD läpakat alla mõnekümne tuhande kroonise hinnaga naljalt ei leia
Kindlasti on meil vaja nüüd seal jooksutama hakata uusimaid mänge, Autocad 2008 ja FullHD filme
Kommentaarid: 27 loe/lisa |
26 |
chesm6mmi
![chesm6mmi chesm6mmi](https://foorum.hinnavaatlus.ee/images/avatars/upload/a189d6ba1c06a5fba67338e090c997bd.jpg)
21.04.2008 11:31:35
ei see 12gb on täitsa tibenstobens ma usun. saab xp kenasti peale panna ilma mudimata ja officed asjad ka ja rohkem ple vajagi, kõik suuremad failid ja suuremad proged ja võimsust nõudvad asjad teed ju eniveis siis koduarvutipeal
Kommentaarid: 107 loe/lisa |
102 |
djkiller
21.04.2008 12:04:32
chesm6mmi kirjutas: |
ei see 12gb on täitsa tibenstobens ma usun. saab xp kenasti peale panna ilma mudimata ja officed asjad ka ja rohkem ple vajagi, kõik suuremad failid ja suuremad proged ja võimsust nõudvad asjad teed ju eniveis siis koduarvutipeal ![thumbs_up.gif](images/smiles/thumbs_up.gif) |
või kannad saasas usb HDD;)
201 |
Mytant
![Mytant Mytant](https://foorum.hinnavaatlus.ee/images/avatars/upload/4504a10c633f886522c674b257208640.jpg)
21.04.2008 12:56:12
on olemas selline asi nagu 16gb SDHC mälukaart (paned sisse ja on sul juba 28gb kokku)
ps. see 16gb maksab poes ca 800eeku
Kommentaarid: 349 loe/lisa |
304 |
marek
21.04.2008 17:29:02
tundub, et 20GB mälukaardiga ja linuxiga versioon maksab sama palju kui windowsi oma, nii et kellel litsentseeritud windows juba olemas või südametunnistuseta piraja võib osta linuxiga eee ja paigaldada windowsi ise.
http://www.computerworld.com/action/article.do?command=viewArticleBasic&articleId=9079078
tsitaat: |
"Also, [the] Linux version is our main Eee PC model with our unique interface, so the consumer not only can get the great and easy-to-use interface on the Linux version but extra storage space," Ho added. |
USA $549 teiseneb vist ligi 7000-ks krooniks Eestis(?).
viimati muutis marek 21.04.2008 17:31:13, muudetud 1 kord |
HighEnd
21.04.2008 17:31:26
marek, dollar on alla 10 eegi minuteada. Arvan et see hind jääb sinna 5.5k ja 6.5k vahele.
E: Eniveis miks 20gb windowsi ple. Ise ostan kindlalt 20 gb versiooni kuna endal kodus erinevaid Os-e valida.
10 |
![Tanel Tanel](https://foorum.hinnavaatlus.ee/files/tanel_avatar_141.png)
21.04.2008 17:34:33
tsitaat: |
Pmst jah, USA hindu võib arvestada umbes järgmise valemi järgi (kui ametlikult maale tuua)
549 x 10 (kurss) x 1,10 (maaletoojate, edasimüüjate kate) x 1,18 (käibemaks)
_________________ HV valuutakalkulaator |
Kommentaarid: 461 loe/lisa |
12 :: |
7 :: |
356 |
marek
21.04.2008 17:38:38
poed ei arvesta ju hinda ainult kursi järgi. vana eee maksis kah 5000 kuigi USAs oli vist $399.
edit: Tanel juba jõudis täpsemalt selgitada.
HighEnd
21.04.2008 18:44:29
palju nende lisaakude ja hiirte hinnad olla võivad?
10 |
Ezh
Kommentaarid: 7 loe/lisa |
ago123
![ago123 ago123](https://foorum.hinnavaatlus.ee/images/avatars/upload/b2dfde7673c668dd6f4d9dc28a62eb9c.jpg)
26.04.2008 21:27:32
Kasutaja |
Ostsin Asus EEE PC ühes esimeste seas Eestis. Ilusti on vastu pidanud. Sain suurema 1024x786 reso ka tööle. Mugav on seda kasutada ja igale poole kaasa võtta. Uut ilmselt enne ei osta kui praegune isend katki läheb.
Kommentaarid: 4 loe/lisa |
Ezh
27.04.2008 01:27:52
Kuidas said 1024*768? Virtual resoga?
