sõnum |
Herr Kurm
10.10.2007 23:21:35
Kuradi hea ema
_________________ -logod, firmaidentiteet, küljendamine, flash-
-portfolio- |
Kommentaarid: 25 loe/lisa |
19 |
WäntWõll
make.believe
10.10.2007 23:29:47
XR, Näri ise pori ja kui see pole Subaru juppidele ehitatud custom käru siis ole ise enda emaks
tsitaat: |
Prodrive shows off new sports car
Prodrive is a company more usually associated with Subaru World Rally cars, but it's put all of its talents on show in a two-seat sports car.
The P2 sports car uses a Subaru Impreza STi's engine and four-wheel drive system, along with some Prodrive technology.
Prodrive, which is based in Banbury, Oxfordshire, has added its own tweaks to the turbo to avoid the delay in response often found in turbocharged cars.
There's also Prodive's Active Torque Dynamics to split the engine's power most effectively between the front and rear axles.
Thanks to the P2's light weight, it has a power-to-weight ratio of 350bhp per tonne.
The light weight and power sees the P2 go from rest to 62mph in less than four seconds and top 175mph.
Prodrive has modified a Subaru R1 supermini's chassis to accept the STi mechanicals, while the styling has been penned by Brit Peter Stevens.
Inside, the P2 uses the dash and seats from the Impreza.
There are no plans to build the P2 at the moment, but Prodrive says that if a manufacturer was interested in producing the P2, it would have a price tag of around £40,000. |
http://www.topgear.com/content/news/stories/433/
Kommentaarid: 373 loe/lisa |
299 |
Ardo
10.10.2007 23:40:14
C6 on ilus.
Kommentaarid: 271 loe/lisa |
224 |
XR
10.10.2007 23:41:18
dreamx kirjutas: |
tsitaat: |
http://www.topgear.com/content/news/stories/433/ |
See on ikkagi täiesti teine asi kui Prodrive Subaru. Paljudki ehitavad teiste tootjate juppidele.
Pagani Zonda on siis kah tavaline Mersu või?
Gumpert Apollo on Audi A8?
Bentley Continental GT on Volkswagen?
Kommentaarid: 49 loe/lisa |
42 |
WäntWõll
make.believe
10.10.2007 23:46:02
Ardo kirjutas: |
C6 on ilus. |
Lõpuni vaadates siis ka päris hea hobuste võiduajamisel
Mis kräppi sa XR ajad,see on see sama masin mille kirjeldus üleval on
Kui muidu asjale pihta ei saa siis googelda
Mäkki tuunitud mersu on ka mäkk vä
Nimeks on küll MäcMersu
299 |
Ardo
11.10.2007 00:03:02
Ei, need tüübid ei ole normaalsed.
224 |
XR
11.10.2007 00:06:26
dreamx kirjutas: |
Ardo kirjutas: |
C6 on ilus. |
Nimeks on küll MäcMersu |
Saad aru, kui auto on niivõrd palju ümberehitatud, siis võib tootja enda nime vabalt peale panna ja siis see ongi selle tootja auto!!
Pagani Zondal on ka Mersu mootor ja paar muud Mersu juppi. Samamoodi nagu teised minu nimetatud autod,
aga need on lihtsalt niivõrd palju ümber ehitatud, et nad ei ole enam algse tootja autod!!!
Kui sa võtad aluseks Subaru mootori ja vbl mõned veermiku osad, siis see ei tee autost veel Subarut!
Ma ei viitsi täpsemalt küll rääkida.
Aga igatahes see jalkaüritus on neil küll alati fun. Keegi võiks midagi sarnast Eestis firmadele korraldada.
Pakun, et tahtjaid oleks kindlasti palju.
42 |
Cacib
11.10.2007 00:33:22
Ja sellist autojalgpalli mängiks rõõmuga (ainult mitte enda autoga)
Selle TVR-ga oleks pidanud ikka kõik 3 sõitma, siis oleks selge pildi saanud kes kõvemkihutaja/parem õppija on (kuigi ega seda just raske arvata pole)
_________________ ...
viimati muutis Cacib 11.10.2007 00:45:57, muudetud 1 kord |
Kommentaarid: 8 loe/lisa |
B6
11.10.2007 00:35:12
teiste vara lammutaks muidugi nõrkemiseni 8)
Kommentaarid: 182 loe/lisa |
155 |
Aix
11.10.2007 01:21:15
oopelitega sellist üritust teha oleks suht vaffa
Kommentaarid: 397 loe/lisa |
332 |
Ardo
11.10.2007 08:48:57
aix17, osta mu 3 opelit ära. 8)
Keegi SR'i foorumis pidas sellise asja korraldamise plaani, kuid ma ei tea, mis sellest saanud.
224 |
tomson
11.10.2007 11:05:41
Ardo kirjutas: |
C6 on ilus. |
Mis C6? Citroen?
Krt, siin sellised autopeded koos, et kurat teab, mis see C6 on. Mingi V20 10 liitrine 4 turboga bensumootor.
Kommentaarid: 33 loe/lisa |
28 |
Anti
11.10.2007 11:06:44
Google otsin "C6" ja saad kohe teada, mis on tsee kuus.
Kommentaarid: 313 loe/lisa |
240 |
Taavi_R
11.10.2007 11:20:29
Ma vaatasin ka eile aga hakkasime mõtlema, et jäin mingist osast ilma Pange ikka automark ka. Ma mõtlesin juba Corvette peale.
_________________ raamatupidamine | laadakalender |
Kommentaarid: 181 loe/lisa |
161 |
tomson
11.10.2007 11:25:13
velsa kirjutas: |
Google otsin "C6" ja saad kohe teada, mis on tsee kuus. |
Google otsing annab mingi 6 esimest linki "Citroen C6" siis on vahepeal mingi saast Corvette ja siis läheb "Citroen C6" edasi.
Kui mõeldakse Corvette C6'te siis minu arvamus on, et üks isikupäratu pasajunn. Iga teine sportauto näeb selline välja. Ainuke normaalne Corvette, mis üldse tehtud on C3, mis on tõsiselt stiilne. Ainuke asi, mis üldse paneb uuemate Corvette'de poole vaatama on see plära, mis sumpast tuleb ning mõte, et kas tõesti ei suudeta nii kallile autole normaalset väljalaset panna.
Aga kui jutt oli Citroen C6'st siis ega too ka oma disainiga ei hiilga.
28 |
Cacib
11.10.2007 13:33:19
tomson kirjutas: |
Aga kui jutt oli Citroen C6'st siis ega too ka oma disainiga ei hiilga. |
Aga Corvette on kah Top Gearist läbi käinud ja nende arvamus masinast oli minu mäletamist mööda vägagi
_________________ ... |
WäntWõll
make.believe
11.10.2007 13:38:12
Lihtsalt täpsustuseks siis Corvette ei ole C6 vaid CO6
299 |
Anti
11.10.2007 13:50:03
Ee, Corvette C6 on viimane corvette, mis praegu tootmises on.
240 |
WäntWõll
make.believe
11.10.2007 13:57:31
velsa, OK my bäd
JA ei olnud mitte CO6 vaid ZO6
299 |
namstoop
11.10.2007 14:37:14
Aga saade on lahe küll. Isegi minusugune mitteautopede vaatab, ja kodus isegi naine piilub vaiksel üle õla teleka suunas. Ma küll ei vaata seda saadet selleks, et suud mõne vinge auto suunas vesistada, vaid lihtsa hea huumoori ja lahedate testide/katsete pärast. ja noh kui tibake ka midagi tehnilist külge jääb, siis ega see mööda külgi maha ikka jookse. Sellest ilmselt tolle saate edu seisnebki, et ei minda liiga tehniliseks vaid võetakse asju vabalt, auto üle otsustatakse skaalas lahe või mittelahe, mitte hj järgi vms. Ütleme nii, et Rooli võim, või mis saade see kusagil eesti kanalil oligi kunagi, mu lemmiksaadet hulka just ei kuulunud. Top Gear aga hetkel üks vähestest, mida vaatan.
Kommentaarid: 72 loe/lisa |
63 |
WäntWõll
make.believe
11.10.2007 14:38:41
namstoop, Roolivõim on miskit muud aga see Eesti poolne versioon(Auto Bild Eesti promo) oli vististi "Sõidame"
299 |
11.10.2007 16:51:27
Rooli võim käib siiamaani TV3 peal ning see on liiklussaade, top gear aga autosaade
Kommentaarid: 85 loe/lisa |
XR
11.10.2007 18:00:45
dreamx kirjutas: |
velsa, OK my bäd
JA ei olnud mitte CO6 vaid ZO6 |
on olemas Corvette C6 ja Z06, mis on täiesti erinevad autod.
42 |
Anti
11.10.2007 18:22:28
Kas just täiesti, aga jah...
240 |
Mart352
Kommentaarid: 54 loe/lisa |
51 |
