sõnum ![Teata moderaatorile Teata moderaatorile](./images/icon_move_w.gif) |
fedja
![fedja fedja](https://foorum.hinnavaatlus.ee/images/avatars/upload/c5f1eb6997a9819aa90b52d369df3cbb.png)
28.03.2006 12:57:49
Barton-M 2,5GHz, 1GB RAM ja MX440 jookseb väga kiirelt, aasta tagasi sama masinaga oli jube tatine.
Kommentaarid: 125 loe/lisa |
![](./images/komment/img_10_1.gif) ![](./images/komment/img_10_0.gif) ![](./images/komment/img_10_2.gif) |
116 |
![](templates/HinnaVaatlus/imagesHV/spacer.gif) |
AMD
![AMD AMD](https://foorum.hinnavaatlus.ee/images/avatars/upload/48af4341f745163f945fa838eeabb062.jpg)
28.03.2006 12:59:36
1.6GHz Palomino, 256MB ram, ja mingi gf2 jookseb kah ilusti.
_________________ From now on, the forum is owned by AMD.That means that you are NO LONGER allowed to talk about, or even mention *ntel. |
Kommentaarid: 335 loe/lisa |
145 :: |
12 |
Riivo
![Riivo Riivo](https://foorum.hinnavaatlus.ee/images/avatars/upload/271a9df235ce61737bb9b9a3f3cdcd32.jpg)
28.03.2006 16:03:50
minu arvates on sellega windows vista linuxilt "pähe saanud"
Kommentaarid: 233 loe/lisa |
221 |
soss
06.04.2006 19:04:30
üritan asja suse 10.0-i peal käima saada. How to-dest selgub, et vaja compiz nimeline utiliit peale panna... seda paigaldades saan järgmise teate: libcrypto.so.0.9.8 is needed by compiz-0.0.6-7
libdbus-1.so.2 is needed by compiz-0.0.6-7
libdbus-glib-1.so.2 is needed by compiz-0.0.6-7
libssl.so.0.9.8 is needed by compiz-0.0.6-7
libcrypto.so.0.9.8 is needed by compiz-cvs_060403-2
libdbus-1.so.2 is needed by compiz-cvs_060403-2
libdbus-glib-1.so.2 is needed by compiz-cvs_060403-2
libssl.so.0.9.8 is needed by compiz-cvs_060403-2
probleemi vast poleks kui leiaks nee vajalikud failid kuskilt üles. Aga, mida ei leia seda ei leia.
Ho Ho
![Ho Ho Ho Ho](https://foorum.hinnavaatlus.ee/images/avatars/upload/b739e74adfab65d624c7068cb369c1b1.jpeg)
06.04.2006 19:09:58
Kas compiz'i suse pakihalduris ei ole olemas? Kui on siis sealt kaudu installides peaks see koos kõigi sõltuvustega installeeritama.
Kommentaarid: 106 loe/lisa |
86 |
ylts
![ylts ylts](https://foorum.hinnavaatlus.ee/images/avatars/upload/a429119f8e5d2924d73f58c7c573d8e0.jpg)
Kommentaarid: 24 loe/lisa |
24 |
2ndalpha
![2ndalpha 2ndalpha](https://foorum.hinnavaatlus.ee/images/avatars/upload/1dab5ce92d6aab103884f41f9f0b6967.jpg)
08.04.2006 15:48:23
Mis videokaarte te kasutate? Ma pole oma Radeon X800XL 3D-kiirendust ikka veel tööle saanud (kunagi xorg R6 peal töötas).
Kommentaarid: 23 loe/lisa |
22 |
Ho Ho
08.04.2006 16:12:46
2ndalpha, mis distro?
Muidu R350+ videokaartidega on Linuxis vähe rohkem probleeme kui vanematega, su XL käib samuti nende alla.
Tõenäoliselt parim allikas ATI ja Linuxi paaritamise kohta:
http://odin.prohosting.com/wedge01/gentoo-radeon-faq.html
See baseerub küll Gentool kuid seaded on üldjuhul distrode vahel enam-vähem samad.
86 |
Mart352
![Mart352 Mart352](https://foorum.hinnavaatlus.ee/images/avatars/upload/224a2fac0f013714c9017d51a26bc353.gif)
10.04.2006 11:59:11
On keegi Kororaa XGl live cd ver 0.2 ka proovinud?
See plaat seadis kohe resoks 1400x1050 (kuigi esimese versiooniga sain ka oma soovitud resolutsiooni tööle). Miinuseks jälle, et üle võrgu ma audio ja media faile tööle ei saanud, Totem player jooksis kokku "has quit unexpectedly" amaroK pani lihtsalt end kinni ja avanes Kmail, et ma error report vmt saadaks. Desktopil oli veel media kaust kus sees üks *.avi video ja *.ogg, mis avanesid VLC playeriga ning mitte mingit probleemi polnud. Aga kui võrgus jagatud faile üritasin mängida siis jooksis ka VLC kokku
Proovisin ka login screenil seadeid muuta (hammasratta moodi ikoon) valisin XDM chooser vmt (0.1ver-is sain selle abiga reso muudetud) Selle peale aga jooksis X üldse kokku ja mina teda enam tööle ei saanud/osanud panna.
0.2 tundub seega veid ebastabiilsem, loodetavasti tuleb kolmas parem
Proovin vb õhtuks Kororaa üldse HDD-le installida, vaatab, mis siis saab
_________________ Imperfection is perfect |
Kommentaarid: 54 loe/lisa |
51 |
Spott
![Spott Spott](https://foorum.hinnavaatlus.ee/images/avatars/upload/2e786b1770f6af3babecf621311ab61b.jpg)
Kommentaarid: 162 loe/lisa |
6 :: |
134 |
DigeBeni
![DigeBeni DigeBeni](https://foorum.hinnavaatlus.ee/images/avatars/upload/3750a181e91daf8cb0c11c2555e6c25f.gif)
10.04.2006 12:47:32
... sarnased probleemid, mida Mart352 kirjeldas samas, mis puutub Spott'i kogemustesse, siis Live-CD'na on asi küll üsna kiire st. võrreldes teiste samasugustega, kõvaketta installiga ei saa loomulikult võrrelda, juba CD poole pöördumine võtab oma aja, rääkimata sealt lugemisest ...
![](https://www.db.pri.ee/failid/allkiri.gif) |
Kommentaarid: 193 loe/lisa |
160 |
Mart352
10.04.2006 13:39:49
DigeBeni kirjutas: |
... sarnased probleemid, mida Mart352 kirjeldas samas, mis puutub Spott'i kogemustesse, siis Live-CD'na on asi küll üsna kiire st. võrreldes teiste samasugustega, kõvaketta installiga ei saa loomulikult võrrelda, juba CD poole pöördumine võtab oma aja, rääkimata sealt lugemisest ... |
Ise olen Knoppix-i, Ubuntu ja siis Kororaa Live CD-si kasutanud ja vahest tunduvad isegi kiiremad kui HDD-l installitud. Ubuntu vahest harva aeglasem kuid selle eest temal kõik alati korras. Knoppix-iga olen pidanud alati ise reso määrama bootimise alguses.
Seda vaadates, tuli meelde, et mul ka terminal tööle ei läinud.
51 |
DigeBeni
10.04.2006 22:24:00
... kui mälu piisavalt, siis võib tõepoolest mõneti kiirem tunduda, kuid vähese mälu korral, pole kiirusest haisugi ...
... terminal minul töötas ...
160 |
2ndalpha
10.04.2006 23:02:17
Ho Ho kirjutas: |
See baseerub küll Gentool kuid seaded on üldjuhul distrode vahel enam-vähem samad. |
Mul on gentoo. Olen igasugu Xorg-i seadistusi proovinud, lihtsalt kui DRM on lubatud, siis jääb pilt mustaks:(
Mõningatel seadistustel on enne näha ka paari värvilist ristkülikut. Videokaardil on kaks DVI väljundit ja monitor on ühendatud DVI->VGA adapteriga esimesse väljundisse. Olen proovinud kas videokaart saadab signaali hoopis teisse väljundisse, kahjuks ta seda ei tee.
22 |
obundra
![obundra obundra](https://foorum.hinnavaatlus.ee/images/avatars/upload/3afec8fb5a8301d4ef757a71073d909a.gif)
11.04.2006 00:46:38
Kas xorgi logis pole mingeid vihjeid ja kas kernel on Ho Ho, antud lingil olevate seadetega kompileeritud?Vaata ka biosis "AGP Aperture Size" suurust.Kui alla 64MB on, siis peaks xorg seda logisse kurtma.Samas 256MB korral seda logisse ei öeldud kuid must pilt oli sellegipoolest, 64MB peale sättimine aitas.
_________________ Hold the heathen hammer high! |
Kommentaarid: 27 loe/lisa |
25 |
2ndalpha
11.04.2006 01:23:45
obundra kirjutas: |
Kas xorgi logis pole mingeid vihjeid ja kas kernel on Ho Ho, antud lingil olevate seadetega kompileeritud?Vaata ka biosis "AGP Aperture Size" suurust.Kui alla 64MB on, siis peaks xorg seda logisse kurtma.Samas 256MB korral seda logisse ei öeldud kuid must pilt oli sellegipoolest, 64MB peale sättimine aitas. |
Tegemist on PCIe kaardiga. Kerneliks on 2.6.16-gentoo-r7 (amd64)
22 |
ikruusa
11.04.2006 01:50:20
Ma proovisin Kororaa XGL LiveCD 0.2 ja esimest korda ajas ikka irvitama. Mul Geforce 6200 ja need efektid olid tõesti edevad. Võtad aknal ülevalt sinisest servast kinni ja teed hiirega kiireid liigutusi - nalja kui palju. Siis ctrl+alt+shift ja hiire vasak klahv alla ja liigutad - jälle tore. See, kuidas kõik vetruvad ja võbelevat asjad paika jäävad, on ikka tõeline boioioingngggg efekt Kui keegi edevat nalja tahab natuke saada, siis tasub kõrvetamist küll.
Reso oli ainult vähe karm by default - keeras mulle 1600x1200 ette. Aga ma keerasin menüüst 1200x1024 peale tagasi ja väga bueno.
Kommentaarid: 11 loe/lisa |
Death
![Death Death](https://foorum.hinnavaatlus.ee/images/avatars/upload/6097f89e3092d4ccd249c9d479785c1f.jpg)
12.04.2006 11:59:54
infox: selleks et Xgli käima ajada tuleb konsoolilt ( saab sinna näiteks alt+Ctl+F1) anda käsk goxgl mis seal ka kenasti kirjas on AGA mis minul näiteks liiga lyhikest aega ees oli, et märgata oleksin jõudnud... Muidu asi ise oli VÄGA bro! Natuke häiris see 3Dle omane vilkumine kui väga kiiresti aknaid vedada aga muidu jummalast supper. Proovitud siis profiili teise masina peal.
_________________ "To be or not to be?" is a question of when, not if. |
Kommentaarid: 39 loe/lisa |
36 |
ikruusa
14.04.2006 01:01:02
Death kirjutas: |
infox: selleks et Xgli käima ajada tuleb konsoolilt ( saab sinna näiteks alt+Ctl+F1) anda käsk goxgl mis seal ka kenasti kirjas on AGA mis minul näiteks liiga lyhikest aega ees oli, et märgata oleksin jõudnud... Muidu asi ise oli VÄGA bro! Natuke häiris see 3Dle omane vilkumine kui väga kiiresti aknaid vedada aga muidu jummalast supper. Proovitud siis profiili teise masina peal. |
Sel pidi mingi põhjus olema, et miks sellise kirja ette viskas ja miks tuli see käsk anda. Mul töötas kohe ja ka see "3Dle omane vilkumine" jäi minul täheldamata. Graafikakaartide põlvkondade erinevus?
DigeBeni
14.04.2006 09:40:12
... endal linuxipurgis samuti fx5200 ja ei mingit vilkumist, ning xgl töötas ilma lisaabita koheselt. Kas kellelgi õnnestub CD pealt ka KDE keskkonda siseneda ? Sessiooni muutsin ära aga ikka sisenes Gnome keskkonda. Samas, kui kõvakettale isntallisin, siis toimis ka KDE ...
160 |
Death
14.04.2006 13:46:33
hmm ei oska öelda... Samas ei anna pead, et mul vana versiooni iso pole. Nimi oki küll õige aga... Kui keegi viitsiks selle iso mõnda kodumaisesse ftpse lykkata oleks väga tore.
36 |
2ndalpha
15.04.2006 00:51:34
Tere!
Paigaldasin masinale uusimad ati driverid ning eelkirjeldatud probleem on ikka alles.
Võib-olla keegi targem viskaks logile pilgu peale.
http://clockwise.ee/2ndalpha/Xorg.0.log
BTW: ilma 3D-kiirenduseta lähevad draiverid ilusasti käima.
22 |
Death
15.04.2006 10:26:28
2ndalpha, logis on mingi möll teise kaarti ymber mida nagu olemas pole... Aga otseselt vigu ka ei näidata... X läheb sul käima või yldse iei lähe? Xorg.conf faili võiks ka ette näidata.
Edit on kororaa: tirisin uue iso aga midagi sellest ei muutunud küll. goxgl et 3D k2ima panna ja kui akent raputada tekib kohati aknajoonistamisse aste.
36 |
ikruusa
15.04.2006 11:56:35
Death, kas sul siis enne selle käsu andmist raua kiirendust üldse pole (glxinfo)? Abiks oleks peale goxgl käsku glxinfo, xdpyinfo väljundit võrrelda kellegagi, kellel ona sama kaart, aga asjad ei vilgu. Kui seal vahet pole, siis võib vilkumise raua kaela vist ajada.
Death
15.04.2006 12:57:12
ikruusa, kaart tunnakse kenasti ära ja kõik paistab minema plaanipäraselt, kui muidugi see välja arvata, et miskipärast splashi pilte minu jaoks lihtsalt ei leita(mul on 2 CDromi, kahtlustan seda), samas kui teises arvutis see ok kuid ka seal Xgli käima ei panda. Proovin veel yhes radeoni kaardiga masinas, eks siis näeb.
Edit: profiiili viimane masin, Kõik on ok ja isegi XGL pannakse kohe käima kuid kompiz e tööta lihtsalt ja ekraan on täis mustvalgeid vahelduvaid triipe, ning selle kõige peal kursor. Tegu EI ole resolutsiooni kalaga.
36 |
