uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD Vega seeria arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 76, 77, 78 ... 101, 102, 103  järgmine
sõnum 08.09.2018 20:36:58 vasta tsitaadiga
https://wccftech.com/amd-radeon-vega-20-gpu-xgmi-pcie-4-interconnect-linux-patch/
xGMI siis AMD vaste Nvidia NV-LINK ühendusele.
Hoopis huvitavam on artiklis välja toodud info selle kohta miks me PCI-E 4.0 niipeal veel mainstream platedel ei pruugi näha. Nimelt signal decay:
PCIe Gen 1.0, the signal retained strength up to 20 inches in mainstream FR4 boards. With PCIe 4.0, the signal would decay after only 3-5 inches, hence requiring the need of extender cables and signal amplifying chips.
Ja need võimendajad lisavad plate hinnale hetkel sadu dollareid. Kuskil Enterprise/HPC osas pole see kriitiline aga mainstream plate ise juba maksab nii palju.
Kommentaarid: 89 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 79
sõnum 10.09.2018 12:43:39 vasta tsitaadiga
https://www.flickr.com/photos/130561288@N04/44267520871/
- londiste
Kommentaarid: 238 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 213
anubis
anubis
sõnum 10.09.2018 12:50:54 vasta tsitaadiga
https://www.techpowerup.com/gpudb/3268/radeon-pro-vega-20
The Radeon Pro Vega 20 is a professional graphics card by AMD, launched in August 2018. Built on the 7 nm process, and based on the Vega 20 graphics processor, in its Vega 20 XT variant, the card supports DirectX 12.0. The Vega 20 graphics processor is a large chip with a die area of 325 mm². It features 4096 shading units, 256 texture mapping units and 64 ROPs. AMD has placed 16,384 MB HBM2 memory on the card, which are connected using a 4096-bit memory interface. The GPU is operating at a frequency of 1200 MHz, which can be boosted up to 1500 MHz, memory is running at 1200 MHz.
Being a dual-slot card, the AMD Radeon Pro Vega 20 draws power from 1x 6-pin + 1x 8-pin power connectors, with power draw rated at 230 W maximum. This device has no display connectivity, as it is not designed to have monitors connected to it. Radeon Pro Vega 20 is connected to the rest of the system using a PCI-Express 3.0 x16 interface. The card measures 267 mm in length, and features a dual-slot cooling solution.
Kommentaarid: 317 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 271
sõnum 10.09.2018 13:06:25 vasta tsitaadiga
paper launch, need peaks tulema kuskil aasta lõpus (ja mitte consumerile).
- londiste
anubis
anubis
sõnum 10.09.2018 14:11:44 vasta tsitaadiga
https://www.techpowerup.com/gpudb/3233/radeon-instinct-vega
Vega20 suurem versioon, 32GB HBM2'ga, on lisaks korralikult FP64 jõudlust juurde saanud. 1:16 -> 1:2, ehk et ~0,8TFlops -> 8,3TFlops.
Aeg maha 1p
sõnum 10.09.2018 14:25:26 vasta tsitaadiga
'tea, mis võimekusega tavasurelikele kaart tuleb... tahaks GPU ära uuendada ja ei taha "mandatory sign-in" control paneli ja muu jobu poliitika tõttu roheliste poolele minna icon_biggrin.gif
Kommentaarid: 195 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 181
anubis
anubis
sõnum 10.09.2018 14:31:02 vasta tsitaadiga
Ei usu, et seda tavakasutusse lastakse, pole väga kohta turul temajaoks. Samas 510mm2 -> 325mm2 annab hinnastuse osas korralikult mänguruumi juurde.
Taktsageduses paistab ilusti 2Ghz tegevat Instinct, seega lisanduv paarkümmend protsenti jõudlust juurde võimaldaks Vega56/64 derivaadid üsna võrdseks Nvidia kaartidega mitte-RT rakendustes, eeldatavasti..
sõnum 10.09.2018 14:36:08 vasta tsitaadiga
anubis, tpus on see kõik eelinfo, seal on üleval isegi vastav silt märkusega.
- londiste
anubis
anubis
sõnum 10.09.2018 14:49:15 vasta tsitaadiga
Release Date: Aug 1st, 2018
Generation: AMD Radeon Pro Vega
Production Status: Active
On Pro Vega 20 kohta kirjutatud, kuid jah, pole nagu kuulnud ametlikku launchi.
Aeg maha 1p
sõnum 10.09.2018 16:17:16 vasta tsitaadiga
Noh, mulle piisaks kui tuleks kõvasti odavam V64 perfiga kaart välja. 4K peale kolimiseni veel aega on icon_razz.gif
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 23.09.2018 20:47:42 vasta tsitaadiga
jälgiks ka vega 20 arenguid.
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid!
Kommentaarid: 112 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 85
Kremka
Kremka
sõnum 06.10.2018 11:18:38 vasta tsitaadiga
Kolisin ka Vega64 peale. Alguses rämedalt pettund, kuum ja lärmakas.
Lammutasin Asus 3x92mm fän maha koos raamiga ja panin 2x120mm AC PWM fans. Idles 600rpm, full loadis 1300. Temp langesid meeletult ja perf tõusis. Nt 3DMark scoor 23k pealt 25k peale.
Murelaps on aga selline, WattMan ei loadi bootides minu custom profiili. Iga boot on balanced. Äkki mingi kala seoses sellega, et fän profiil on tehtud läbi MSI Afterburneri, kuna Wattman selle kohapealt imeb minusilmis.
Proovin vast kõik seaded teha läbi MSI, aga HBM V ei saa sealt muuta icon_sad.gif
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 63
sõnum 06.10.2018 12:07:01 vasta tsitaadiga
Kremka, AMD CPU oc vidinaga on sama asi. Seal on see featuur, polegi mõeldud, et oc peale jääb, selleks on muud riistad. Äkki on GPUga sama asi.
Kommentaarid: 177 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 143
Viilutaja
Viilutaja
sõnum 06.10.2018 13:02:47 vasta tsitaadiga
Kremka kirjutas:
Proovi OverdriveN tooliga peale jätta.
Kui seal masin läheb kontrollitud reboot siis laeb viimase profiili ülesse mis sul oli.
Ise sain oma Vega64 FireStrike GPU skoori 23000 pealt 27000 peale.
Ja seda ainult parema õhkjahutusega ja undervoldiga.
https://www.3dmark.com/compare/fs/16190036/fs/16546496
Kommentaarid: 222 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 192
sõnum 06.10.2018 15:47:47 vasta tsitaadiga
Kremka, AMD kaartidega on jah tihtipeale nii, et default on voldid väga suureks pandud, et ka kehvemad isendid ikka väljakuulutatud kellad ära teeks. Paistab, et AMD eriti per-binningut ei tee vist. Seetõttu ongi, et kui undervoltida ja custom kellad/fan curve panna saab ise palju parema tulemuse. Ise sama teema läbi teinud minevikus mitme AMD kaardiga. Ma ei ütle, et see tingimata halb oleks. Minusugustele näppijatele sobib küll. Samas vahel tahaks midagi mis lihtsalt töötab optimaalsemalt out of box max perf lähedal normaalse müraga ja selles osas on Nvidia parem.
Aeg maha 1p
sõnum 06.10.2018 16:19:50 vasta tsitaadiga
Muarust võiks nad out-of-the-box vb. sama suunda jätkata, ent lisaks võiks AMD Settingsi all olla lihtne viis seda ümber "programmeerida" AMD enda toolidega ja seda püsivalt, et paned korra peale ja siis lased selle peal. Tagasimineku võimalusega, juhuks kui ebastabiilne, vms. Või siis nt. isegi nii, et kui critical video erroritega crashib, siis tõmbab defaulti. Igatahes võiks AMD jätkata seda suunda, et lisaprogramme pole vaja ja kõik on tehtav AMD Settingsis.
Viilutaja
Viilutaja
sõnum 06.10.2018 19:55:59 vasta tsitaadiga
rmc kirjutas:
jah, sellega olen nõus.
Ning miks ma just reference kaardi muretsesin, et sellele korralik jahutus ise panna:
a) reference kaartidel on kogu VRM ülesehitus ja disain robustsem ja kindlam kui custob PCB'l (erinevatest ülevaadetest lugedes)
b) dual bios switch, ühele lasin peale teise biosi ning ilma mureta, et pärast pekkis.
Kremka
Kremka
sõnum 06.10.2018 21:38:53 vasta tsitaadiga
c) kõige odavam.
sõnum 07.10.2018 18:10:26 vasta tsitaadiga
Viilutaja kirjutas:
- londiste
Viilutaja
Viilutaja
sõnum 07.10.2018 21:48:10 vasta tsitaadiga
londiste kirjutas:
Viilutaja kirjutas:
See annab lihtsalt vaba ruumi boostida gpu klokki.
Ning ega ta ju seda ei kasuta ära kui jahutust pole piisavalt. See limiit on lihtsalt nüüd eest ära, kui mul oleks väga jaheda vee peal siis ta võibolla tõmbaks selle +50% ära.
sõnum 07.10.2018 22:11:14 vasta tsitaadiga
jahutus piirab vegat vähe, power limit on see suurem kurja juur.
- londiste
Kremka
Kremka
sõnum 11.10.2018 17:51:08 vasta tsitaadiga
Kremka kirjutas:
Lõpuks leidsin lahenduse. Kasutan ASUS enda GPU Tweak 2 proge, mis on mõeldud Vegale. Töötab ilusti koos WattManiga ja Custom fän profile ka olemas thumbs_up.gif
Viilutaja
Viilutaja
sõnum 16.10.2018 12:58:05 vasta tsitaadiga
Link
sõnum 16.10.2018 13:26:16 vasta tsitaadiga
muide, enamik saite saab vähe teistmoodi tulemused. kaartide omavahelist kohta arvestades üsna sinna tavalisse codi kanti. terve cod seeria jookseb amd raual paremini ja on jooksnud läbi aegade.
- londiste
Viilutaja
Viilutaja
sõnum 16.10.2018 13:55:18 vasta tsitaadiga
londiste kirjutas:
Kuid ligi 800 eurone ahjusoe Nvidia kaart on sama hea/kehv kui tunduvalt odavam AMD kaart icon_razz.gif Ma ütleks, et korralik tulemus AMD'lt!
Ning ma pakun, et see tulemus saadi tavalise reference jahutusega Vegaga. Cuistom jahutuse ja undervolt Vegaga oleks tõenäoliselt paremgi tulemus.
Ning see näitab seda, et kui hea kaart tegelikult Vega on, kui vähegi uuemad API'd kasutusel ja optimiseeritud.
Forza Horison 4, Call of Duty: BO 4. Ning ma pakun, et neid hakkab järjest juurde tulema.
Ning teades tulevikku, uutel PS5'l ja XBoxidel on kasutusel AMD gpud' millele hakatakse optimeerima nagunii. Siis tulevik on helge ja kordub see, et AMD = "good wine".
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD Vega seeria arutelu mine lehele eelmine  1, 2, 3 ... 76, 77, 78 ... 101, 102, 103  järgmine
