Xbox support chat on super
Aidati mul vana Gears of War 3 Xbox 360 kood XSX peal redeemida, vottis alla 10 minuti. _________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
cdkeys (olen ise viimasel ajal rohkem sealt ostnud), kinguin jne.
Mängud iseenesest on viimastel aastatel päris normaalsete hindadega isegi Xboxi enda poes (muidugi mitte kõige "ässamad" uued AAA mängud), sest iga nädal on teatud asjad sooduses ja päris tihti tehakse suuremaid alesid sinna otsa lisaks (XBL Gold/GP Ultimate omanikel veel omakorda iganädalased soodustused). _________________ /digitaalselt allkirjastatud/
võta game pass ultimate omale 100+ mängu kohe mängida...
kui teed seda gold prepaid ja ulimate sinna otsa hoiad väga korralikult kokku raha...
Aasta- ja kuumaksud mulle ei meeldi, uritan hoiduda toodetest ja teenustest, kus vahegi saab.
Mul ei ole palju mange vaja. Need, mis hetkel huvi pakkusid, ostsin juba ara. Uhekordne valjaminek.
Gears of War 3 - 3.18 eur
Gears of War 4 - 4.49 eur
Gears 5 - 12.37 eur
Forza Motorsport 7 - 25.53 eur
Forza Horizon 5 - 46.85 eur
Farming Simulator 22 - 15.73 eur
Kinguin tundub okei koht jah
CDKeys kaudu uritasin 4-5 korda osta nii PayPal kui ka oste pangakaardiga, ei toimi:
We regret that we are unable to process your order. We are not able to tell you specifically why the order failed, but it could be due to one or more of the following reasons:
• We are unable to confirm your payment
• The code you are purchasing is region-restricted
• A technical error occurred while completing the transaction
As your order was not processed or it may appear as ‘pending’ or ‘rejected’– the authorised amount held from your account will be released. You might receive a notification from your bank that an amount has been deducted from your account. However, please note that the amount is only an ‘authorisation hold’ and will be automatically credited back to your account. Depending on your card issuer, said amount will be available to you shortly or may take a couple of days. Please don’t contact our support desk as this process is automatic as the transaction was not successful.
Should you wish to try purchasing from CDKeys again we recommend using a different card or payment method. Apologies for any inconvenience caused.
viimati muutis SKG 12.11.2022 13:09:41, muudetud 2 korda
Täname Teid kirja eest.
Antud mäng on vaid Xbox One konsoolile, uurisime tarnijalt üle.
Xbox mängud cross-gen ei ole?
Töötas One peal ja töötab ka Series X/S peal (ostsin One X peale ja nüüd olen Series X peal). Minu teada peaks kõik Xbox One mängud Series X/S konsooliga töötama. Võibolla ajas tarnija midagi segi. Näiteks arvas, et küsitakse plaadi versiooni kohta, mis Series S-iga ei tööta, sest konsoolil puudub plaadilugeja.
edit:
Sry, sul ilma optiliseta. _________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
SKG, Alternatiiviks paned One mängud USB SSD peale. Ali adapterile lisa spets WD SSD. Äkki midagi on muutunud aastaga aga hind sai sama olema kui poest 220€ 1TB Seagate osta.
Mhmh, sai nüüd loetud ka veidi, osad mängud toimivad USB SSD pealt ka. Loodetavasti vaja ei lähe, aga suhteliselt kiiresti saab täis see sisemine 1TB, või noh, õigemini 800GB, kui sinna vingemaid mänge panna. 5-6 tükki ja ongi läinud
Samas rohkemat samaaegselt mängida ei jõua nagunii. _________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
Gears 5 - 12.37 eur
Dirt Rally 2.0 Xboxi peal on väga fun, isegi puldiga _________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
1. kasuta official mälu suurust ja osta kest aliexpressist (https://www.aliexpress.com/item/1005004070043634.html)
2. kasuta pikemat mälu suurust. osta kest aliexpressist ja lase kellelgi 3d printida kest (https://www.aliexpress.com/item/1005004486330391.html)
media remote osas see on kogu Xbox One familil üks ja seesama. _________________ next.Insiders - koht mängijatele ja tehnikahuvilistele toredaks ajaveetmiseks.
Lecktor - 3D printerid ja lisatarvikud, Voron, Prusa jne
Vaatasin neid Hiina korpuseid jah, aga hinnavõit pole kuigi suur kui üldse.
Ametlik 1TB Seagate Expansion Card on 220 eur.
Ootame Musta Reede hinnad ära
Hetkel mu mitu vanemat mängu ja kuna nad on oluliselt väiksemad, siis pole hullu, 800GB sisse mahub ära, aga kui tulevikus tahta rohkem uuemaid installida, siis tuleb ilmselt ruumipuudus.
Mis see parima graafikaga mäng on hetkel, mis näitaks, milleks konsool tehniliselt võimeline on, Forza Horizon 5? _________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
SKG, tehnoloogilisest perspektiivist ainult Metro Exodus Enhanced on ray tracinguga kuid paljud teised mängud näevad ka ilusad välja.
Link _________________ next.Insiders - koht mängijatele ja tehnikahuvilistele toredaks ajaveetmiseks.
FH ei näinud isiklikult midagi ilusat, graafika oli ok...
Xboxi peal Spider man on? CP77 kui mäng ise tõmbab. Pole uuendustega PC peal proovinud, aga hulga nauditavam oli motikaga kõrbes ringi rallida kui FH5;)
Konsoolil oli vist mõni eksklusiiv ka? God Of War võrreldakse DLSS/FSR on/Off palju...
