Provides support to control usage of Indirect Branch Prediction Barrier (IBPB) within some AMD processors (CPUs) for mitigating CVE-2017-5715, Spectre Variant 2 when switching from user context to kernel context (See AMD Architecture Guidelines around Indirect Branch Control and AMD Security Updates for more details). Follow instructions outlined in KB4073119 for Windows Client (IT Pro) guidance to enable usage of IBPB within some AMD processors (CPUs) for mitigating Spectre Variant 2 when switching from user context to kernel context.
Ma ei rõhu absoluutsele tõele aga kui kedagi huvitab siis X470 on poes müügis alates 19.04. Kohati on juba poes olemas aga müüa ei lubata ja tänasest 12.04 müügis uued AMD prosed.
Teen laost tellimust aga olen pisut arusaamatuses. Osad Ryzen 5 2400G on erineva artikkelnumeriga ja hinnaga. Mind ajab segadusse, et erinevate distribuutorite hinnakirjades on osad Radeon Vega seeria nimetusega, teistel selline tähis puudub. Mis neil vahet on?. :
Ise tellisin seda odavamat Ryzen 5 2400G ja need seal minu tulevased müügihinnad mida näete (see on tõmmis müüja laost)
Mis neist dollarihindadest ikka vaadata. Vaatame parem € hindu ikka. Prose hinnad peaks suht paigal olema aga emaplaadi hindu (eriti ASUS-e omi) ärge hetkel 100% tõepähe võtke:
Jep see on kahjuks suht BS test. wccftechil oli muidugi kõlav pealkiri pandud: AMD Ryzen 7 2700X / X470 Review Out, Beats i7 8700K in Gaming & Multi-Threaded Benchmarks
Tulemused on kah absurdsed. Kord on nt 6700K kiirem kui 8700K. Kord on kõige kiirem hoopis R5 1400
Lisaks testitud enamus 4K peal mis on 99% GPU limited ja ei näita tuhkagi prosede võrdluses.
*There is a disclaimer on the retail-boxed part here. Our samples look completely retail, aside from two things: the serial number on the box is #1234567891234, which is clearly filled in, but also our CPUs say ‘2017’ on them. This is interesting as it would mean that AMD has had retail-ready silicon since 2017. Either that or the heatspreader printing/etching did not tick over its counter.
edit: hüpoteetiliselt, AMD plaanib hetkeseisuga väidetavalt selle aasta sees tulla turule 48c/96t Epyc isenditega, mis otsekui vihjaks sellele, et neil on 12c/24t (6+6 CCX) kivi juba olemas. See võiks ka ideeliselt olla põhjus, miks midagi pole kuulda 2800 ja 2800x isenditest. Sest juhul kui Intel tuleb välja 8c/16t + Z390 komboga siis võimaldaks see AMD'l väikse vaevaga kogu oma AM4 seeria lipulaevaga 12c/24t peale upgradeda.
6/12 + Navi=Vega=Polaris=14nm Fiji APU oleks hea ost.
alartt kirjutas:
Huvitalt panin arvutisse 3 pulka 3x8gb siis. Ikka näitab dual channel. Netist uurides sain aru et siis pidi single olema.
Üldiselt on siis esimene 16 dual ja pulk 3 16-24 on üksi. Samas biose bugi ei saa välistada.
