#PS4 is targeted to be the “central device in the living room.”
"Core gamers are our primary audience.” #PS4 build around them, salable to the outsiders.
5 Core Principles of the #PS4: Simple, Immediate, Social, Integrated, Personalized.
#PS4 CPU: 64-bit x86 arch, low power consumption, low heat, 8 cores, 8 HW threads, 2MiB L2 cache per 4 core group, 32kib l1 I/D-cache
PlayStation Shader Language, very similar to HLSL, allows featured BEYOND Direct X 11 and OpenGL 4.0
"GPU – Tessellation – adding geometric detail to smooth edges or create more organic shapes”
#PS4 RAM – 8GB 256 bit GDDR5 (GDDR5 is very high end graphics memory only found on PC graphics cards)
#PS4 will have a “very large hard drive in every console.”
PS4 Dev Environment – Windows 7-bit, tools are fully integrated into Visual Studio 2010 and 2012
“Debug your PS4 code as you would your PC code”
#PS4 Controller: Start/Select buttons are now “Options.” New System button is “Share.”
Speaker, headset hack and “extension port” on the #PS4 controller.
Controller buttons are going back to digital over analog because no one used it on PS3
Controller L2/R2 - Curved design to get rid of the accidental @netflix fast forwarding.
Controller: 1920x900 resolution on the analog touchpad.
Controller colors are the Player Numbers: 1-Blue, 2-Red, 3-Green, 4-Pink (Like the buttons)
PS4 will charge controllers when it's off. Unlike the PS3.
#PS4 controller light bar can be used for muzzle flashes, health bars, etc.
“The #PS4 Eye will enhance the PS4 user experience.” High sensitivity dual color cameras – 1280x800, 12 bits/pixel, 60Hz
Dedicated port for the #PS4 camera, exclusive SCE Connector. Means it won't use a USB port on the console, but won't plug into your PC
#PS4 Cam suggested uses: walkthrough vids, taunting in killcam, login, speech recognition, etc.
Possible #PS4 Camera Magic – Sees the controller, you guys move, splitscreen moves to be on the right side.
2004: XMB, 2011: LiveArea, 2013: New #PS4 one based on the five principles from earlier.
PS4 UI is meant to give you at a glance info without loading the game. See what new DLC is out and whatnot. What friends are saying
Have to enable people seeing your real name on the #PS4. Auto-enabled if you import from another social network. (Can be turned off)
#PS4 RAISES THE PSN FRIEND LIMIT.
All the #PS4 streaming and sharing: that's on the hardware. Devs don't have to do anything special to their game _________________ Sinikiir: Blu-ray temaatiline foorum
MGS kasutas _________________ sometimes i hug myself for no reason.
Kind of hale on see, et kuu aega varem näidatakse mingit kandilist udukogu ja selle tulemusena saavutatakse fanbase'is mingi kollektiivne erektsioon.
Who cares milline see välja näeb... _________________ Võib öelda, et ma olen liigselt enesekeskne, aga mind see ei häiri
Tulge kõik HV rahvaga jalkat mängima!|
On inimesi, keda huvitab seadme disain, mis neil järgmised viis aastat kodus ruumi võtab.
selgemast selgem,et ps 4 tuleb kasutamissõbralikum kui uus iks kast,nüüd jääb uus kast ostmata tänu sellistele jamadele mis mikisoft teeb,ps 4 on kindel ost,on olemas siiani kõik konsoolid,aga uus x-box jääb raudselt vahele ei hakka ostma mänge karbis selleks et kohe peale installimist ära visata,idiootsus kuubis ikka ja mingid ideootseid asju mis näidati seiaalid ja tv milleks microsoft.....WHY _________________
Vici, what if Sony mängude mudel on samasugune nagu Xboxi oma ainult nad pole seda välja öelnud? _________________ next.Insiders - koht mängijatele ja tehnikahuvilistele toredaks ajaveetmiseks.
Sony on juba öelnud seda, et kõik mängud tulevad DD + karbi teema. Anyway see box oma kellade ja viledega ei paku mingit huvi. Konsooli ostan mängimiseks ja hea, kui BD filme ka mängib. Muu suva.
Sa pole pressikat kuulanud w ?
Selgelt öeldud selle kohta, pole huupi mõtet pakkuma hakata, kui asjaga kursis pole. _________________ Inflatsioon on maksustamine ilma seadusandluseta
londiste, ma arvan, et jätkub sama ps4 puhul mis ps3 ja 360nel oli, ehk siis ainuke asi mida "kaotad" on DLC. _________________ Inflatsioon on maksustamine ilma seadusandluseta
No Eestis pannakse alati natuke juurde hinnale. Kuid peaks tulema odavam kui PS3 alguses.
PC arhitektuur
Ei ole Backwards compatible
Blueray ei maksa enam nii palju.
Kõlakate järgi odavam kui PS3e $499 ja Sony väitel konkurentsivõimeline. Nii et loodetavasti $399, meil €399. _________________ Sinikiir: Blu-ray temaatiline foorum
Eesti jah 1 imelik koht.
Aga annab ju soomest ja mujalt ka tuua...
Küsimus ongi, et mis see hind siis umbes olla võib.
Tulevad vist suht samal ajal xboxiga. _________________ Aita suve, söö lund!
