omgwtf
04.11.2009 22:49:53
Guru3D ülevaates see päris positiivne lõik jäi silma :
| With our budget 80 EUR motherboard and armed with an OCZ Vendetta cooler we took the processor towards a whopping 4000 MHz instantly. All we did was cram 1.55 volts into the processor and upped the multiplier to 20 and we were good to go. After this range better cooling is required though |
AMD mehed siis saavad ka nüüd lõpuks 24/7 õhuga 4GHz masinad omale?
Või oli mingi valitud jubin neil
Igatahes huviga jälgin kuni mõni AHV väheke margitaks selle prosega õhuga
137 |
1dumbpcuser
04.11.2009 23:01:55
| omgwtf kirjutas: |
Igatahes huviga jälgin kuni mõni AHV väheke margitaks selle prosega õhuga  |
| Aare.pri.ee eng-est sõnaraamat kirjutas: |
| towards - suunas, poole |
_________________ M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat |
97 |
Metsjeesus
04.11.2009 23:08:01
Ehk siis esimese hooga pandi 4ghz takka, seega ilmselt läheks rohkemgi.
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
94 |
AJ
04.11.2009 23:15:14
AMD Phenom II X4 965 Black Edition C3 Review
http://www.bit-tech.net/hardware/cpus/2009/11/04/amd-phenom-ii-x4-965-be-c3-review/1
| The CPU does overclock better, you'll be glad to hear, although not much more on the current 965 Black Edition. We managed to squeeze out a solid 4GHz at 1.5V by increasing the multiplier, which we used in the next few pages benchmarking. Unfortunately, 4.1GHz just wasn't quite stable enough and an increase in voltage greatly increased temperature causing overheating on our Noctua heatsink. We also tried other heatsinks and additional fans, but to no avail. |
| Kommentaarid: 37 loe/lisa |
36 |
aap14
04.11.2009 23:25:28
Ootan 95W Phenom II 965BE-d. Väiksem voolutarve defis = väiksem temp. defis = loodetavasti parem kellatavus paremate tempide tõttu suuremal taktil
_________________ Slow is smooth and smooth is fast |
| Kommentaarid: 41 loe/lisa |
38 |
WäntWõll
make.believe
300 |
Go Kane!
| Kommentaarid: 1842 loe/lisa |
1345 |
WäntWõll
make.believe
04.11.2009 23:42:58
5minta keerutasin sain 750 krediiti casinosse ja draakoni embleemid,naaber on kaks päeva lapanud ja saanud 2x ATI märgid.
Draakon = terve süsteem
ATI logod = GPU ainult (krediiti 310)
Võta kinni, aga lõplik värk toimub loosimise alusel.
Kuid kes ei mängi see ei võida,lihtne kas pole
300 |
aap14
05.11.2009 00:43:49
Kolm korda saanud väikeste intervallidega 790GX emaplaati seal.
Ei tea kas on üldse mõtet edasi mängida kui ühe asja juba 'võitnud' oled?
38 |
05.11.2009 00:57:24
| omgwtf kirjutas: |
Väike pettumus oli, et õhuga piiri ei otsitud.Oleks tahnud teada palju nad max kätte oleks saanud jahutuse piires .Muidugi 4Ghz=Instant WIN
| Kommentaarid: 92 loe/lisa |
05.11.2009 10:19:52
| X4 kohta tõesti päris kõva tulemus, aga C3 rev ka...
201 |
kristjan*
06.11.2009 18:55:16
Mis temperatuuri & voldiga võiks üks 720BE 24/7 joosta?
| Kommentaarid: 60 loe/lisa |
58 |
One
06.11.2009 18:57:22
| kristjan* kirjutas: |
Mis temperatuuri & voldiga võiks üks 720BE 24/7 joosta?  |
alla 60c võiks load jääda aga proovi kõigepealt kas asi quadiks läheb
728 |
xheix1712
06.11.2009 20:40:30
Tundus et athlon ii x2 245 ei taha niisama üle 3.4 eriti minna. Oskate aidata, et palju ma volte tõstaksin, et väike boost saada... vaja 24/7 jooksma jätta
Emaplaadiks: ASrock a770de
175 |
One
06.11.2009 20:41:27
vcore 1.45v ja proovi siis
728 |
xheix1712
06.11.2009 21:03:19
Biosis näitab Cpu Volt 0.6v ja max volt oli 1.3xx V midagi.
Aga ASRocki OC utilitiga vist siiski saab tõsta 1.35-lt ülesse... katsetan
175 |
kristjan*
58 |
heff
95 |
kristjan*
07.11.2009 02:48:10
| Protsessor pole toetatud. Äkki on probleem W7'es?
58 |
heff
07.11.2009 02:56:11
| Ei. See on see bug, mis mitmel tekib, et tuumade avamisega enam tempe ei näe.
95 |
Aeg maha 1p
07.11.2009 02:59:54
Mis x4 810 prosest arvata?
| Kommentaarid: 94 loe/lisa |
81 |
One
07.11.2009 10:05:45
kristjan*, mul jäid enda settingud peale jah.. pole paha ju selle raha eest lahtiste kordajatega quadi saada või mis?
krt oleks ikka pidanud tolle endale jätma
carlking, suht normaalne prose on aga tiba võiks klokkida kah
728 |
kristjan*
07.11.2009 13:17:45
Hetkel tundub niimoodi päris stabiilne olevat. Kas peaks volti alla tõmbama? (Temperatuurid on normis muidu.)
Ja kas see on normaalne, et volt läheb loadis natukene ülesse?
58 |
heff
07.11.2009 16:28:01
| kristjan*, olenevalt platest on normaalne küll. Enamasti loadi all langeb veidi, aga osadel ka tõuseb.
95 |
Kemmukas
07.11.2009 18:02:08
| Üritasin ka täna oma Phenom II x3 720BE-l 4. tuuma lahti saada, aga kui jõudsin windowsisse(windows 7 64bit rc), muutus pilt must-valgeks. Kas mul on siis selline prose , millel ei ole võimalik 4. tuuma korralikult avada? Plateks Gigabyte 770T - UDP3. Seadete osas muutsin ACC auto ja see Firmare oma Hybridiks.
| Kommentaarid: 13 loe/lisa |
One
07.11.2009 18:38:12
bios update ikka tehtud?
Mul on küll täna hea päev, sain enda uue X2 550 kätte ja tuumad tulid lahti,
lisaks veel HD5770 ja muu nänn
728 |
Kemmukas
07.11.2009 19:21:01
| Winterwind kirjutas: |
| bios update ikka tehtud? |
Ei ole, kas probleem võib siis olla selles?
One
07.11.2009 19:28:25
loomulikult
728 |
Kemmukas
07.11.2009 20:46:07
Aga kuidas seda tehakse? Mingi download link on tootja lehel, F4 kõige uuem versioon seal.
One
07.11.2009 20:55:00
| lase mobo cd-lt või netist @bios peale ja sellega on asi ikka väga lihtne
728 |
Go Kane!
1345 |
One
07.11.2009 21:40:37
SB peab mobol 710 või 750 olema ja minu kahest X2 550-st ühel tulid tuumad lahti
728 |
Go Kane!
07.11.2009 21:43:25
SB peab mobol 710 või 750 olema ja minu kahest X2 550-st ühel tulid tuumad lahti  |
Aga jõudluse vahe on ka 2 kordne?
Mingeid teste X2-na vs X4-na oled lasknud. Palju tavakasutamises sellest reaalselt kasu on?
_________________ Vajad midagi Würthist , küsi julgelt 😉 https://eshop.wuerth.ee/et/EE/EUR/
taavi.jahu@wuerth.ee +37258309618 |
1345 |
WäntWõll
make.believe
07.11.2009 21:45:21
ei,oleneb mida teed.
Mängudes 1-2% winrar ca 30%
CAD;CS ja muu soga vist jääb kah sinna 50% juurde.
300 |
Aeg maha 1p
08.11.2009 09:44:07
carlking, suht normaalne prose on aga tiba võiks klokkida kah |
Kui suurt vahet ma märkan videot renderdades, kui tõsta 2.6GHz pealt 3.0 GHz peale?
81 |
1dumbpcuser
97 |
One
08.11.2009 11:02:22
| carlking kirjutas: |
| Kui suurt vahet ma märkan videot renderdades, kui tõsta 2.6GHz pealt 3.0 GHz peale? |
Aga proovi?
Mu X2 550 jookseb quadina 3.8GHz peal 1.4v-ga küll.
St kõik 3dmargid ja mängud on stabiilsed aga prime/occt talle ei meeldi,
paneb alati paari esimese sekiga lihtsalt pange
Stepping on asjal CACYC AC 0923EPMW
viimati muutis Winterwind 08.11.2009 11:06:16, muudetud 1 kord |
728 |
Go Kane!
08.11.2009 11:06:14
paneb alati paari esimese sekiga lihtsalt pange |
Tohib küsida mis skoor 06margis sul selle 5770 videoga tuli
1345 |
One
08.11.2009 11:07:04
| -cocain- kirjutas: |
Tohib küsida mis skoor 06margis sul selle 5770 videoga tuli  |
default kastiga 15.5k, prose @ 3.8GHz ja video 950/1400 sai 17.8k
728 |
Stalker
08.11.2009 13:06:17
| Kas kellellgi homme suvalist uuemat AMD prose on laenata? Samas võiksin ise emaplaadiga ka läbi kuskilt astuda. Nimelt ehitan HTPC-d ja see ei taha pilti ette võtta - ei onboard videoga ega ka PCIe kaardiga. Kõik muu on läbi proovitud ja kahtlustan mingit lambi prose compatibility probleemi (kuigi paberite järgi toetab antud AM3 mobo AM2 prosesid), mis ei lase masinal POSTida või siis on plaat kutu ja poodi muret kurtma vaja sammud seada.
| Kommentaarid: 28 loe/lisa |
26 |
1dumbpcuser
97 |
UrmoZ
08.11.2009 15:51:16
| Mu X2 550 jookseb quadina 3.8GHz peal 1.4v-ga küll. |
krdi hästi läheb siis minu oma oli def. voldi peal stabiilne ainult kuni 3,3GHz-ni.
volti ei tõstnud, jahuti ei saa eriti hakkama.
anyway, kuna 4-tuuma peal erilist perfi tõusu ei näinud, lükkasin 2 tuuma kinni tagasi.
Stalker, vaata asi uuesti üle... AM3 mobo ei toeta AM2/+ prosesid mingil juhul
_________________ Amazon - will not buy!
12VHPWR or 12V2x6 GPU power connector - will not touch.
Müügiteemale PS pakkumisi ei aktsepteeri! |
| Kommentaarid: 226 loe/lisa |
206 |
heretic666
08.11.2009 16:02:57
Tšekka üle seda asja, AM2+ mobo toetab AM3 prosesid, kuid AM3 mobo AM2(+) prosesid ei söö.
| Kommentaarid: 73 loe/lisa |
kristjan*
08.11.2009 18:10:12
Prime95'e small FFTs test töötab ilusti, large FFTs ja blend crashib. Mälud saavad 1,95V (peaks olema piisav) ja CPU NB saab +0,15V (ei teagi mis seal alguses on, ei näita seda). Ei tea kui kõrgele ma seda CPU NB volti tõsta võin? Ilmselt on probleem selles? Või tõmban lihtsalt NB multiplieri väiksemaks?
58 |
One
08.11.2009 18:40:01
| anna prosele lihtsalt tiba rohkem volti. nb-le küll lisa vaja pole
728 |
kristjan*
08.11.2009 18:46:55
| Kas protsessori ebastabiilsus ei peaks mitte "small FFTs" testiga välja tulema? (Pidasin muidu silmas just CPU NB'd. Teisisõnu siis IMCd.)
58 |
One
08.11.2009 19:24:31
ei pruugi see small ffts midagi näidata.
proovisin tiba NB-d kellata, st kõik voldid on biosist defis
ja asi niisama katsetus
e: winrar tiba paremate mälutimmidega:
728 |
UrmoZ
08.11.2009 19:47:40
kui Prime95 "Blend" on stabiilne, siis korras.
kristjan*, võid HT Link ja NB sageduse veidi alla tõmmata, mõlemad 2GHz ringi.
Ülekellamisel võivad veidi probleeme tekitada ja niikuinii midagi märgatavat nendest juurde ei tule.
Winterwind, HT Link @ 2GHz tekitab klokkimisel probleeme?
206 |
One
08.11.2009 19:50:03
| UrmoZ kirjutas: |
| Winterwind, HT Link @ 2GHz tekitab klokkimisel probleeme? |
ei, mul oli too biosist "auto", ei tea miks ta selle ise madalamaks lasi
| UrmoZ kirjutas: |
Ülekellamisel võivad veidi probleeme tekitada ja niikuinii midagi märgatavat nendest juurde ei tule. |
NB annab ikka päris korralikult juurde..
st proovi ennem asi stabiilseks saada ja alles siis kloki nb-d ning otsi uuesti stabiilsed settingud.
24/7 jaoks võiks nb ikka 2600MHz küll olla Phenom 2-l
728 |
Evil
Hull
08.11.2009 20:15:20
Kokkuvõttes on see tuumadega jebimine ikka mõttetu. bullshitÕiged amd quadid ei maksa mitte sittagi, kelluvad vähemalt sama hästi ja ei ole prime/OCCT-ga mingeid probleeme.
202 |
