Müüa Gigabyte RTX 3080 GAMING OC 10G (Rev 1.0), kasutatud ainult mängimiseks ning kaevandatud pole. Lisaks pole ka LLM'ideks kasutanud.
Omaltpoolt annan käimaminemise garantii kuna üleeile veel töötas enne kui uue kaardi peale kolisin.
Postiga saadan vaid ettemaksu alusel. Karp on kahjuks kolimise käigus kaduma läinud, saan saata teise kaardi karbiga.
Kuidas temperatuuridega on? Termopastat vahetatud?
Termopastat pole vahetanud.
Viimane hwmonitor raport kuupäevast 06.06.26 (EFT'd pelasin samal ajal):
Hardware monitor NVIDIA NVAPI
Voltage 0 0.94 Volts [0x3AF] (GPU)
Current 1 25.91 Amps (GPU)
Current 6 13.86 Amps (Core Power Supply)
Current 7 7.24 Amps (Frame Buffer Power Supply)
Current 9 4.08 Amps (SRAM Power Supply)
Current 10 4.45 Amps (PCIe +12V)
Current 11 10.20 Amps (8-PIN #0)
Current 13 11.26 Amps (8-PIN #1)
Power 01 308.76 W (GPU)
Power 06 162.58 W (Core Power Supply)
Power 07 89.24 W (Frame Buffer Power Supply)
Power 09 47.92 W (SRAM Power Supply)
Power 10 52.93 W (PCIe +12V)
Power 11 121.54 W (8-PIN #0)
Power 13 134.29 W (8-PIN #1)
Temperature 1 69 degC (GPU)
Temperature 3 94 degC (Memory)
Temperature 2 80 degC (Hot Spot)
Fan 0 1987 RPM [0x7C3] (FAN #0)
Fan 1 2117 RPM [0x845] (FAN #1)
Clock Speed 0 1830.00 MHz [0x726] (Graphics)
Clock Speed 1 9502.00 MHz [0x251D] (Memory)
Clock Speed 2 n.a. (Processor)
Hardware monitor NVIDIA NVML
Power 01 309.36 W (GPU)
Power 40 314.50 W (Power Limit)
Clock Speed 1 9501.00 MHz [0x251D] (Memory)
