uus teema   vasta Ärifoorumid »  Varia ja muu tehnika (sh helitehnika) ost/müük/vahetus »  » M: Romoss RM300 80000mAh 256Wh akujaam :: Asukoht: Harjumaa märgi kõik teemad loetuks
-HeiS-
sõnum 06.11.2025 15:49:50 » M: Romoss RM300 80000mAh 256Wh akujaam :: Asukoht: Harjumaa vasta tsitaadiga
Uus, kinnises pakendis akujaam Romoss RM300 80000mAh 256Wh
Vahendan garantiid ~2 aastat
AH: 170€ / OK: 190€
Power Nominal: 300W Peak: 600W
Information displayed by the LCD screen Battery charge status level, R-MAX constant power mode, ECO mode, remaining charging time, current input power, AC/DC inputs status, high temperature warning, current temperature, fan operation status, remaining usage time, current output power, USB output status, AC/DC output status, low voltage warning
LED lighting 1 × 2W
Inputs 1 × AC input (220-240V~50/60Hz 3.2A MAX, 300W MAX).
Socket for charging from the wall 2 × DC input
Solar charging port (XT60)/car charging port (XT60) 12-30V 8A, max. 100W; Type-C (PD3.0): 5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/3A, max. 60W
Outputs 1 × AC Outlet: 220-240V~50/60Hz 1.36A, total power 300W; 3 × DC Outputs: USB-A (QC3.0): 5V/3.4A, 9V/2A, 12V/1.5A, max. 18W, 36W total; USB-C (PD3.0): 5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/3A, max. 60W; 1 × Cigarette lighter socket: 12V 10A, max. 120W; 1 × Wireless charging station 15W
Total output 360W
Buttons LED light button, AC output button, reset button, main power button, ECO button, DC output button
Temperature range Charge: 0-40°C / 32-104°F Discharge: -10-40°C / 14-104°F
Safety standards UL, FCC, CE, RoHS, UN38.3, SGS, MSDS, CCC
Battery life 80%+ capacity after 3000 cycles
Service life 10 years
Dimensions 253 × 164 × 168 mm
Weight 3.95 kg
Kommentaarid: 78 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 73
archieb0ld
archieb0ld
sõnum 13.11.2025 17:53:17 vasta tsitaadiga
150.- äkki? 220V pesa on EU, ma saan aru?
-HeiS-
sõnum 13.11.2025 19:17:02 vasta tsitaadiga
archieb0ld kirjutas:
AH eest võiks kohe tehingut teha
AC pesa on EU oma jah
archieb0ld
archieb0ld
sõnum 14.11.2025 00:07:39 vasta tsitaadiga
kus asub muidu?
-HeiS-
sõnum 14.11.2025 08:24:14 vasta tsitaadiga
kus asub muidu?
Tallinn, Lasnamäe võimalik üle anda
