sõnum |
Maa Mees
24.04.2024 11:02:20
10» M: Uued 5x Raspberry pi5, 2xRaspberry Pico W + ekraanid, 7.9" (400x1920) touch :: Asukoht: Tallinn/Smartpost/DPD/Omniva |
Pakkuda selliseid asju:
1. Raspberry Pi 5 Uued
Broadcom BCM2712 2.4GHz quad-core 64-bit Arm Cortex-A76 CPU, with cryptography extensions, 512KB per-core L2 caches and a 2MB shared L3 cache
VideoCore VII GPU, supporting OpenGL ES 3.1, Vulkan 1.2
Dual 4Kp60 HDMI® display output with HDR support
4Kp60 HEVC decoder
LPDDR4X-4267 SDRAM (4GB/8GB)
Dual-band 802.11ac Wi-Fi®
Bluetooth 5.0 / Bluetooth Low Energy (BLE)
microSD card slot, with support for high-speed SDR104 mode
2 × USB 3.0 ports, supporting simultaneous 5Gbps operation
2 × USB 2.0 ports
Gigabit Ethernet, with PoE+ support (requires separate PoE+ HAT)
2 × 4-lane MIPI camera/display transceivers
PCIe 2.0 x1 interface for fast peripherals (requires separate M.2 HAT or other adapter)
5V/5A DC power via USB-C, with Power Delivery support
Raspberry Pi standard 40-pin header
Real-time clock (RTC), powered from external battery
Power button
Pakkuda 3x 8GB ja 2x 4GB
4GB= AH 65.-
8GB= AH 80.-
Kõigil kaasas 5A 5V laadija.
2. Raspberry pico W koos ekraaniga:
Pico LCD 0.96
Operating voltage: 3.3V/5V
Operating current: 40mA
Resolution: 80(H) RGB x 160(V) Pixels
Communication interface: 4-wire SPI
Display size: 21.70(H) x 10.80(V)mm
Display panel: IPS
Pixel size: 0.135(H) x 0.1356(V)mm
Driver: ST7735S
Dimensions: 52.00(H) x 25.00 (V)mm
Info: https://www.waveshare.com/wiki/Pico-LCD-0.96
AH: 15.-
3. Raspberry pico W koos ekraaniga:
Pico LCD 1.8
Supply Voltage 2.6V ~ 5.5V
Operating Current 40mA
Screen TFT
Controller ST7735S
Communication Interface 4-wire SPI
Resolution 128(H)RGB x 160(V) Pixels
Pixel Size 0.219(H)x 0.219(V)mm
Display Size 28.03(H)x 35.04(V)mm
Outline Dimensions 34.5(H)x 52.00(V) mm
Info: https://www.waveshare.com/wiki/Pico-LCD-1.8
AH:17.-
Pildid:
4.Waveshare 7.9inch Capacitive Touch Screen LCD, 400×1280, HDMI, IPS, Toughened Glass Cover:
Pakkuda kaks tk, üks lahtise pakendiga ja teine kinnine:
AH:65.- lahtisele
70.- kinnisele
Head pakkumsit
_________________ Some Will Seek Forgiveness, Other Escape... |
Kommentaarid: 433 loe/lisa |
347 |
HenryL
24.04.2024 16:18:32
1 Pi5 4Gb ah +post
Kommentaarid: 1 loe/lisa |
Maa Mees
24.04.2024 16:44:27
Jäi mainimata, et kaasa tulevad ka aktiiv jahutid.
Maa Mees
347 |
Ypi
24.04.2024 23:01:46
1x Pi5 8gb + kinnine display
Kommentaarid: 21 loe/lisa |
21 |
Maa Mees
28.04.2024 08:54:04
Maa Mees
347 |
i8080
28.04.2024 14:43:24
3. Raspberry pico W koos ekraaniga: Pico LCD 1.8
17.-
Kommentaarid: 165 loe/lisa |
148 |
lynx311
28.04.2024 16:33:52
tsitaat: |
1x Pi5 8gb AH. Käest kätte kesklinnas või smartpostiga |
sorry, hetkel loobun
Kommentaarid: 3 loe/lisa |
Maa Mees
28.04.2024 21:19:02
Maa Mees
347 |
lynx311
29.04.2024 12:06:14
Nii, vaatasin oma vajadustele teravama pilguga, lugesin juhendeid ning ikka meedia süsteemi jaoks vaja Pi5. Teistele ka infoks, et Pi5 on esimene Raspberry millega saab stabiilselt Youtube Fullscreen 1080p vaadata (ilma framedroppideta). Google ise ei paku arm64 Chromiumile teravamat pildi kui 1080p. Chrome arm64 hetkel isegi ei eksisteeri.
Seega pakun Pi5 8GB AH (80eur). Kui on olemas OK hind, siis paluks seda PSi
Tehing käest kätte kesklinnas või smartpostiga.
hydsekas
29.04.2024 12:23:49
1. Raspberry Pi 5 8gb AH +post või nädalavahetusel Tallinnas käest kätte
Kommentaarid: 35 loe/lisa |
33 |
Maa Mees
03.05.2024 19:08:55
Maa Mees
347 |
JDF
04.05.2024 10:13:40
Hei
Sooviks ka ühte Pi5 8gb AH
Edit: Kui 8gb on juba 3tk müüdud siis sobiks ka 4gb mudel.
Kommentaarid: 8 loe/lisa |
Maa Mees
04.05.2024 17:54:04
Alles :
1. 2x 4GB pi
3.Pico 0.96 lcd
Maa Mees
347 |
Sten003
08.05.2024 20:48:30
1. AH
Kommentaarid: 10 loe/lisa |
9 |
sektor1
08.05.2024 23:04:08
1. AH
_________________ AMD VS INTEL |
Kommentaarid: 29 loe/lisa |
lynx311
13.05.2024 14:47:32
Nii, kahjuks minu use-case'le ei osutunud Pi 5 kasulikuks ning ehitan endale mini ITX x86 masina.
Seega paneks müüki siin samas teemas ostetud Pi5 8Gb komplekti. Ostsin OK hinnaga 90euri ning annaks sama hinnaga edasi. Kirjutage PSi
Maa Mees
26.05.2024 13:32:17
Alles veel:
3.Pico 0.96 lcd
4.2xWaveshare 7.9inch Capacitive Touch Screen LCD, 400×1280, HDMI, IPS, Toughened Glass Cover
Maa Mees
347 |
