General Bugfixes
- Fixed some enemy using wrong combination of pants and shoe meshes
- Fixed Sightcones not being cleared properly when leaving a level
- Fixed Sightcones displayed in wrong direction when moving in command mode
- Shader bug fixed that caused incorrectly colored objects
- Fixed bug where tank had impact on performance
- Fixed smoke grenade (blocking sight and its visual effect duration were slightly different)
- Fixed bug where recruitable PCs like Ira became not recruitable after leaving the map
- Fixed bug where AI coud become unalterted again after saving & loading
Modding
- Added additional Weapon and Ammo IDs
- Sight distances made more easy to modify
- Noise made more easy to modify
Achievements
- Fixed bug where "She's dead, Enrico" achievement would not unlock correctly
- Collect achievements are not anymore received when game has been modified
Visuals and Graphics Options added
- Launcher does not anymore check for vertex shader texture fetch, prohibiting older cards to start the game although they feature SM 3.0
- Added Distance based culling for small objects
- Added "Very High" terrain quality option in ingame menu
- Added View Distance as option in ingame menu (determines distance fog position)
Gameplay Fixes and Changes
- Civilians and potential militia recruits do not trigger mines anymore
- Children will try to maintain a minimum distance from player characters to ensure they do not clog doors or passages when following the player around the map
- Noise perception influenced by objects that cover the origin of the sound
- Enemy perception tweaked, enemies can now see and hear slightly better which will make it more likely that they use their weapon range to full extend (e.g. enemies with rifles will open fire from a greater distance)
- Enemy sight cones in 2D displays in addition to 3D Cone to make more clear what an enemy can see and to make lag of 3d cone calculation on slower machines more bearable
- Durability of clothing or items worn is only reduced when they actually prevented damage
- Armor is reduced only by 10% for each time it can fully prevent its protection value (e.g. if armor can potentially prevent 30 damage and only prevents 15 damage since it is hit in an already existing weak spot its durability is only reduced by 5%)
- Stamina is not reduced anymore when the whole map belongs to the player (all enemies are killed)
- Bobby Ray‘s Inventory only restocks after 3 days
- Bobby Ray’s express delivery now takes 24 hours, standard delivery takes 48 hours
- Laserpointer attachments reduce time to aim
- When a merc is hit while aiming the time to aim is reduced in relation to the damage received
- Targeting has several points of origin to become more flexible, further reduced chance of a small objects preventing a shot
- Picking improved, should be easier to select body zones when targeting
- Militia is always on the map even if the map still belongs to the enemy and can be recruited directly after liberating a map
- Reloading always reduces the smallest stack of ammo in the inventory to ensure that inventory space is cleared more quickly
- World Map: Travel speed is reduced when stamina is low
- World Map: Squads are forced to rest when stamina is close to 0 stamina to prevent squads reaching their target location with 0 stamina
- Explosives Skill also influences time for grenades to detonate after being thrown (e.g. a merc with higher explosive skill will “cook” grenades longer before throwing them so they explode more closely to their impact on the ground)
UI
- SHIFT+ RIGHT CLICK on target orders merc to repeat the attack until the target is dead
- Merc names are displayed on mouse over
- Time to shoot is displayed as a countdown on each merc when attacking to make it more transparent that a merc is actually trying to shoot and how long it will take the merc to fire his shot
- Closing the inventory when a merc has been selected who is currently selectable in game will not reset selection to previous merc
- Added „Loot All“ Button in loot UI
- Added “Select Whole Squad” Button to Squad name
- Minimap: Left Click jumps camera to cursor position
- Minimap: Right Click orders selected merc(s) to move to cursor position
- Worldmap: Added „Enter Map“ Button to Squad UI to allow “fast travel” via the world map to be more flexible (e.g. player can also enter a map outside a combat zone)
- Worldmap: Clicking enemy squad displays level of squad members to allow the player to make a more educated guess on wheter or not he should intercept the squad or leave the defense to militia
- Worldmap: Squad UI displays slowdown or resting via status icon
Sound
- Sound played after last enemy on map has been killed
Additional
- Added translations for new features
- Further improvements to targeting enemy body zones with the cursor
- Fixed bug where wounds would result in mercs not being able to recover stamina anymore
- Fixed some recruitable characters not displaying legs when their pants were removed
- Grenade launcher now launches grenades instead of shooting them in a direct path
- 40mm grenades added to be used by Grenade Launcher
- Color of line drawn to target now indicates ideal distance for shooting target (green = ideal)
- Changed melee base damage to prevent some melee focused mercs from one hitting enemies of level 3 and above
- Fixed bug where tanks could not be hit with rockets fired from rocket launcher
- Fixed unreachable enemy spawn position on map Overland11
- Open or closed state for all doors in Drassen Airport are saved now
- Fixed explosive spot in Alma prison on which wall was not correctly removed on both sided
noonius, ei ütleks et hull oli. väga mängitav mäng.
E: uus patch tulekul, changelog väga
steamis weekend deal 40% alet JABIA
As you may have seen the Jagged Alliance: Back in Action is now available at the Weekend Deal with 40% off (until Monday evening). With that said I'd like to pre-release the changelog for the upcoming patch which will (hopefully) be available by the end of this month. Testing has already started. And if everything works out fine it'll be released very soon Please note: It could be possible that the patch will be released in May, but right now everything is planned for April. Please also note: This is not the final changelog. Things still could change due to tests. Please also note: This time the changelog is not as long as the last time. The main focus was on the new features and I can confirm that they really, really took a lot of work. Nuff said. Here you go:
Added Features
• Added hard difficulty level as option on game start. Modifies enemy strength, income and starting funds.
• Added tactical mode as option on game start.
- Enemies have to be revealed via line of sight in tactical mode.
- Sound sources are marked in tactical view as well as on the minimap
• Added two new achievements for tactical mode and higher difficulty.
• Added option to level recruited militia via location UI on the world map.
• Added options to distribute militia via location UI on the world map (evenly across all locations, focused on single location)
• Added sector inventory, accessible via Character Detail Screen
- Always accessible in friendly sectors
- Automatically includes all containers that have been opened and all enemy drops that have been spotted by the player
- Accessible for militia recruitment and trading with NPCs
• Added item exchange via Drag & Drop in Character Details Screen. Illegible mercs are marked red. Within hostile sectors mercs need to be within 5m distance to be able to exchange items.
• Stamina is reduced when returning to the strategic map when squads travelled great distances in the tactical view
• Current ammo saved for each weapon, weapons are unloaded when being handed over to militia. Militia will hand weapons back unloaded to prevent players cheating ammo via the militia equip screen
• NPC Traders restock their inventory over time (rules can be modified via characters.txt)
• Targeting line indicates best range of weapon and chance to hit via color from green (good) to red (bad)
• Camera scrolling possible by moving the cursor to the border of the screen
• Polnish language added
Bug Fixes
• Fixed some exploits that allowed to duplicate items via item exchange
• Fixed bugs in squad selection via list on world map
• Fixed regeneration of HP on world map, HP lost due to wounds takes longer to regenerate
• Added missing text for Raider’s hiring dialogue
Balancing Changes and Tweaks
• Added grenade launcher ammo to containers in some locations in the world
• Added grenade launcher ammo to the stock of some local traders
• Slightly decreased accuracy of snipers when prone
• Tweaked enemy attributes to adjust aim time in combat
• Tweaked enemy perception to accommodate introduction of Line of Sight
• Enemies do not drop additional ammo but only the ammo they have left in their weapon
• Enemy area defenders swap random positions to make the game less predictable in tactical mode (interval can be modified via templatesAIdescription.txt)
• Reduced chance of friendly fire between enemies
• State of tanks is stored outside of levels
• Destroyed tanks only respawn if the location still belongs to the enemy after 24 hours
• Location of Limited Edition DaHonko Flakes is now randomized
Fine printed: With the release of the patch there might come along a hint at what happens after the patch. Maybe. I repeat: Maybe.
Attention Beware that if you have modified the game that it could happen that your game won't start with the new patch. Please delete all gamefiles first and make sure nothing is left. Otherwise we won't be able to give support.
Key Features
Tactical combat at its finest, using the enhanced “Plan ‘n’ Go” system of plotting your team’s moves strategically, then executing them in nail-biting real time
10 new mercenaries round out your team, offering a roster of more than 50 unique combatants with unique skills, weaknesses and quirky personalities
10 new maps, set in the unforgiving, frozen mountainous countryside will challenge your planning skills – rocky mountain terrain, narrow valleys and icy cliffs will provide new cover opportunities, chokepoints and offer optimum ambush points
15+ hours of gameplay across a brand new campaign with a broad variety of missions
New weapons, enemies and equipment – supplies are scarce, and your mercenaries will have to make the most of outdated weapons, limited supplies and equipment
Enjoy the Jagged Alliance series as never before with vastly improved graphics, enhanced AI behavior, a polished interface and numerous performance and gameplay updates
Mõnus mäng ikka. Ma tõmban arvutist maha ja siis paari kuu pärast läheb jälle peale.
Hea rahulikult pausile panna ja nokitseda. Lõpu osa läheb liiga sebimiseks ja bottidega võitlemiseks ära. Aga kuhugi Airportini on hea uusi lähenemiseid proovida.
Seekord võtsin eesmärgiks alale läheneda mõne teise nurga alt, teised tegelased kasutusel ja tundub tibake erineva kogemusena ka. Otsustasin ka kohe investeerida parematesse relvadesse, selmet juurde palgata merce. Hea investeering oli, kui relvad niidavad paremini, siis ei ole ka vastutuld nii palju...
Tüütuks läheb Meduna City juures jah. Aga keerulist pole midagi.
1-2 tüüpi peavad kiired olema, N Vintorez-ga, kes takistavad vaenlast vastu tulistamast.
Paar mg-d(minime mu lemmikud) kiireks maha niitmiseks.
Endale meeldib ka snaipritega lahingut alustada- m82-ga paari laksuga 1 maha võtta ning Raveni käes KH PSG1 one-shottib.
Kõige parem on kuulata lahingu käigus välja hõikeid, Fox(50 Marksmanship skilliga) kuulutab mahanottimisi kõige tihemini- m82 teeb üllatavalt head tööd ka kõige kehvemate näitajatega tegelaste käes.
Grummi lähedal Supply Depot ma viimasel ajal ei puutu enam- mingi 15x lvl5 aimbot vaenlast seal. Mõttetu enesepiinamine. Ma võtan viimasel ajal tihti käsile lihtsalt lõbu pärast, teen kuni lõunas oleva Airfieldini, edasi läheb liiga micromanagement-ks ära. 2-3x läbi teinud, ka raskema astme ja LOS-ga. Rohkem pole mõtet aega raisata modimata katkise lõpu peale.
