uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia GeForce ForceWare Driverid märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 108, 109, 110, 111, 112, 113  järgmine
ccplazza
ccplazza
sõnum 16.01.2019 14:43:40 vasta tsitaadiga
londiste kirjutas:
https://forums.geforce.com/default/topic/1082681/geforce-drivers/is-it-possible-to-quot-port-quot-dithering-from-nvidia-x-server-to-geforce-driver-/post/5934577/#5934577
Proovisin ka seda. Panin 10 bit temporali key registrysse ja Lagomi gradient testis on tulemus palju parem. Rohkem pole hetkel testinud.
Kommentaarid: 57 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 53
Anna tooli
sõnum 10.03.2019 14:55:12 vasta tsitaadiga
NVIDIA Is Officially Ending Driver Support for 3D Vision
https://nvidia.custhelp.com/app/answers/detail/a_id/4781
Kommentaarid: 352 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 294
sõnum 22.03.2019 03:22:44 vasta tsitaadiga
NVIDIA Releases GeForce 419.67 Creator Ready Drivers
https://www.techpowerup.com/253926/nvidia-releases-geforce-419-67-creator-ready-drivers#comments
Nvidia has released the 419.67 CRD Creater Ready Drivers. This driver is for GeForce 1050 series and higher graphics cards under Windows 7 and 10. The CRD drivers are a new class of driver, alongside WHQL and Beta releases, that specifically improve performance and stability in creative applications such as Adobe Photoshop CC, Adobe Premiere Pro CC and Cinema 4D. Select Creator Ready Driver from the bottom drop-down box on the driver download page if you want to obtain these drivers.
Kommentaarid: 89 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 79
sõnum 11.04.2019 16:06:42 vasta tsitaadiga
dxr draiverid:
https://www.techpowerup.com/254528/nvidia-extends-directx-raytracing-dxr-support-to-many-geforce-gtx-gpus
- londiste
Kommentaarid: 237 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 212
Gap
Gap
sõnum 22.04.2019 12:51:44 vasta tsitaadiga
on keegi installinud ka omale,kellel on näiteks eelmise seeria kaart(pascal) need viimased 425.31 WHQL Raytracing toega driverid ? kuidas nad muidu käituvad ? on stabiilsed, mingeid jamasi ei esine ?
Kommentaarid: 20 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 16
busta
sõnum 23.04.2019 18:09:25 vasta tsitaadiga
Gap, Toimivad küll.
sõnum 01.05.2019 03:06:38 vasta tsitaadiga
https://www.techpowerup.com/255034/nvidia-releases-geforce-430-53-hotfix-driver-fixing-high-cpu-utilization-caused-by-telemetry
Driver number 430.53 addresses reported issues of high CPU utilization (due to NVDisplay.Container.exe) on NVIDIA's previous 430.39 WHQL driver
https://www.techpowerup.com/forums/threads/nvcleanstall-clean-installer-for-nvidia-drivers-alpha.249085/
Aeg maha 1p
sõnum 02.05.2019 12:11:23 vasta tsitaadiga
Shadowplay ilma GFE'ta ei toimi, ehk Telemeetria jne. tuleb juba ka kaasa?
Kommentaarid: 194 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 180
sõnum 02.05.2019 12:52:48 vasta tsitaadiga
rmc, Neist on ehk abi:
https://github.com/NateShoffner/Disable-Nvidia-Telemetry
https://github.com/Moyster/BaiGfe
angel
angel
sõnum 17.06.2019 00:12:04 vasta tsitaadiga
Küsimus: kas nvidia on oma telemeetria viimastes driverites ära jätnud kui geforce experience'i peale ei pane? Vanasti sai autoruns jms softiga neid keys'id maha võetud, nüüd enam ei leiagi vasta softiga võtmeid icon_rolleyes.gif
sõnum 17.06.2019 02:33:41 vasta tsitaadiga
angel, Ei. Telemeetria on vaikimisi enabled sõltumata sellest mis komponendid sa peale lased. Installer ei lase isegi valida, et kas telemeertia on off või on.
Ainuke lahendus ongi kolmanda osapoole utiliitide kasutamine. Registrivõtmete mahalaskmine pole hea mõte, sest esiteks need muutuvad ja teiiseks on oht midagi vajalikku maha lasta.
Parem kasuta mõned postid ülevalpool väljatoodud utiliite.
angel
angel
sõnum 17.06.2019 23:24:42 vasta tsitaadiga
Ee seda ma just küsisingi, et autoruns ja disable nVidia telemetri ei leia miskit. Vanasti võtsin autoruns'iga võtmed maha ja nvidia telemetry disable tööriistaga vaatasin veel üle. Nüüd aga ei leia mitte muhvigi nende abil. icon_rolleyes.gif
sõnum 18.06.2019 07:48:38 vasta tsitaadiga
angel, Kaks võimalust: kas Nvidia on muutnud teenuste/registrivõtmete nimesid ja seetõttu ei leia need tööriistad enam midagi või siis paigaldasid juba moditud draiverid kust telemeetria välja korjatud. Või kui pole clean install, siis vb oled juba varem eemaldanud?
angel
angel
sõnum 21.06.2019 22:09:25 vasta tsitaadiga
Tomorrow kirjutas:
enne igat driveri installi lasen süsteemi DDU 'ga üle ehk siis täiesti puhas purk. Ja alati tõmban driverid nvidia enda kodukalt, igasugu mode'itud juraga ei hakka isegi jändama kui selline asi peaks olemas olema. Ise kasutasin autoruns vanakooli tarkvara ja otsisin nii telemetry kui nVidia key'sid ja miskit ei leia. Võimalik, et nüüdsest pannakse telemeetria ainult neile peale kes geforce experience'i kasutavad? Seda telemeetria jura on selle tarvis vaja minuteada. Ilma selleta see vähemalt ei tööta (geforce experience).
-edit-
Keegi veel sellise asja vastu on huvi tundnud ja märganud miskit muutust uuemate driveritega telemeetria osas?
Gap
Gap
sõnum 12.07.2019 12:06:05 vasta tsitaadiga
https://www.guru3d.com/files-details/nvidia-frameview-download.html
FrameView is NVIDIA's own benchmark software for graphic cards based on PresentMon and can measure frame rates, power consumption and frame times. The company offers the release as public beta of the software.
sõnum 26.07.2019 15:06:09 vasta tsitaadiga
https://www.techpowerup.com/257708/nvidia-rushes-out-geforce-hotfix-431-68-driver-to-address-broken-mouse-pointer
nägin ka seda probleemi korra peale draiverite installi. huvitaval kombel kadus see küll peale esimest restarti ära.
enda kogemusest - asja muutis mängust välja minek aga mitte suvalisest vaid windows store/äpp mängust. forza street minu puhul. töötas ka niipidi, et kursor lükati mõneks ajaks tööle tagasi. lisaks oli mingi seos multimonitoriga, ühel monitoril oli asi okei aga monitoride vahel liikudes kippusid katki minema.
- londiste
angel
angel
sõnum 26.07.2019 16:59:51 vasta tsitaadiga
See hiire jama tuleb tagasi pidevalt, ainuke viis lahendada on kas restart või siis korraks reso ära muuta ja tagasi panna. Esineb vist ainult RTX kaartidega thumbs_down.gif
Mõtlesin juba, et kaart pekkis aga meenus, et eelmise driveri versiooniga alates tekkis selline viga.
sõnum 20.08.2019 15:13:21 vasta tsitaadiga
elagu konkurents
https://www.techpowerup.com/258440/nvidia-prepares-geforce-436-02-gamescom-special-graphics-drivers
ehk siis ultra-low latency mode, integer scaling ja sharpen filter on üsna selgelt vasted amd ja inteli sarnastele featuretele.
- londiste
sõnum 21.08.2019 02:49:21 vasta tsitaadiga
Pole paha. Mõned agad siiski on. Max prerendered frames=1 juba annab enamus eeliseid. See uus Ultra säte on küll veidi parem aga iseasi kas enamus seda 10ms vahet märkab. Integer scaling on kahjuks Turing only featuur. Sharpen vajab Geforce Experience installi.
Pealegi kui Nvidial on nüüd oma sharpen filter mis point on siis üldse DLSS enam kasutada? Kas nad mitte iseendaga siin ei võistle?
EDIT:
https://www.nvidia.com/en-us/geforce/forums/game-ready-drivers/13/310429/geforce-game-ready-driver-43602-update/
NVIDIA has found a bug in our recent 436.02 driver posting, causing it to install GeForce Experience even if the user selects not to install it.
XeStAiSy
sõnum 09.10.2019 11:23:25 vasta tsitaadiga
Mida mina olen 1070 kaarti pikemat kasutanud siis parimad diverid on windowsis endas olen kasutanud sellist trikki paigaldanud nõks vanema 10ne teinud kõik uuendused jas siis upgrade viimasele numbile ja unustanud igasugsed driveri uuendused. Tulemuseks sujuv voolav probleemivaba xp. Need uuemad driverid juba pidurdavad ja tulemuseks ikkagi meh iga uue driveriga vanema rauaga.
Renq
Renq
sõnum 20.11.2019 13:21:57 vasta tsitaadiga
Mul on selline mure, et alates eelmise kuu mingist driverist alates ei taha G-sync peale jääda. Valin, et nii full screenis kui windowed mode'is a siis lähen näiteks PUBGI ja vaatan, et G-sync on täitsa väljas või kui arvuti panen käima, siis on linnuke full screeni taga ainult. Monitoriks LG 34GK950F-B. Märkasin seda sellepärast, et järsku hakkasid mingi stuttering mängus pihta ja mingil hetkel kadus monitoril pilt lihtsalt ära või ei saanud ekraan signaali. Need viimased juhud on üksikud. Samas kui mängust välja minna, siis viskab korra ekraani pimedaks.
sõnum 20.11.2019 13:50:47 vasta tsitaadiga
Renq, Kindel, et monitor ise surema ei hakka? Tasub kontrollida monitori toiteadapterit (juhul kui on eraldi karbike).
Draiverite osas võib olla ka kasu DDU programmiga Nvidia asjade mahalaskmisest ja siis puhta (clean install) valikuga uuesti pealelaskmisest.
Renq
Renq
sõnum 20.11.2019 14:19:43 vasta tsitaadiga
Tomorrow kirjutas:
Monitor ma usun võiks nagu korras olla. Lükkasin DDU käima, kuidagi kaua võtab aega. 6 minutit on juba "Executing SetupApi remove Audio controller" juures. Olen seda varasemalt kasutanud ja ainult eelmine kord oli ka selline jama. Siis aitas hard reset. Või keeras mobo biosi uuendus midagi pekki. Ma ei oska midagi arvata enam.
edit: 14 minti sama koha peal
NATAS999
sõnum 30.12.2019 22:51:53 vasta tsitaadiga
kas sealt driveri installeri paketist midagi muud peale display.driver ja physx on vaja veel lahti pakkida? mul viskas see nvidinahhui paskperience sita ventikasse oma konto majandamisega ja otsustasin ddu'ga kogu pasa maha lasta ja ainult hädavajaliku installida.
e: ise küsin, ise vastan. peale farceware ikalduse täielikku eemaldamist ilmus installerisse maagiliselt valik driveri installiks ja driver koos paskperience installiks. mul enne ei õnnestund selle sittperience eest linnukest ära saada.
Aeg maha 1p
sõnum 30.12.2019 23:27:37 vasta tsitaadiga
Kas Windows 10 peal enam desktop programmina control panelit polegi, ainuke variant Windows Store-i äpp tirida lasta?
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia GeForce ForceWare Driverid mine lehele eelmine  1, 2, 3 ... 108, 109, 110, 111, 112, 113  järgmine
