praegune kellaaeg 25.04.2024 22:07:16
sõnum |
Aeg maha 1p
Kommentaarid: 194 loe/lisa |
180 |
A.S.
15.08.2019 13:13:37
Seal ongi ju kõik eraldi, järelikult saad ka eraldi alla laadida.
http://jv.err.ee/gb/,,M/,H/,2016-023873-0001_0002_XHD_INDIAS-DAUGHTER_ETV3_1.mp4.urlset/master.m3u8
#EXTM3U
#EXT-X-MEDIA:TYPE=AUDIO,GROUP-ID="audio0",LANGUAGE="ru",NAME="русский",AUTOSELECT=YES,DEFAULT=YES,CHANNELS="2",URI="http://snotty.err.ee/gb/2016-023873-0001_0002_XHD_INDIAS-DAUGHTER_ETV3_1.mp4/index-a1.m3u8"
#EXT-X-MEDIA:TYPE=AUDIO,GROUP-ID="audio0",LANGUAGE="et",NAME=" Eesti",AUTOSELECT=NO,DEFAULT=NO,CHANNELS="2",URI="http://snotty.err.ee/gb/2016-023873-0001_0002_XHD_INDIAS-DAUGHTER_ETV3_1.mp4/index- a2.m3u8"
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1084525,RESOLUTION=704x396,FRAME-RATE=25.000,CODECS="avc1.4d401e,mp4a.40.2",AUDIO="audio0"
http://snotty.err.ee/gb/2016-023873-0001_0002_XHD_INDIAS-DAUGHTER_ETV3_1.mp4/index-v1-a1.m3u8
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=525222,RESOLUTION=320x180,FRAME-RATE=25.000,CODECS="avc1.42c00d,mp4a.40.2",AUDIO="audio0"
http://snotty.err.ee/gb/M/2016-023873-0001_0002_XHD_INDIAS-DAUGHTER_ETV3_1.mp4/index-v1-a1.m3u8
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1561212,RESOLUTION=1280x720,FRAME-RATE=25.000,CODECS="avc1.64001f,mp4a.40.2",AUDIO="audio0"
http://snotty.err.ee/gb/H/2016-023873-0001_0002_XHD_INDIAS-DAUGHTER_ETV3_1.mp4/index-v1-a1.m3u8
#EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=173028,RESOLUTION=704x396,CODECS="avc1.4d401e",URI="http://snotty.err.ee/gb/2016-023873-0001_0002_XHD_INDIAS-DAUGHTER_ETV3_1.mp4/iframes-v1-a1.m3u8"
#EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=50701,RESOLUTION=320x180,CODECS="avc1.42c00d",URI="http://snotty.err.ee/gb/M/2016-023873-0001_0002_XHD_INDIAS-DAUGHTER_ETV3_1.mp4/iframes-v1-a1.m3u8"
#EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=223690,RESOLUTION=1280x720,CODECS="avc1.64001f",URI="http://snotty.err.ee/gb/H/2016-023873-0001_0002_XHD_INDIAS-DAUGHTER_ETV3_1.mp4/iframes-v1-a1.m3u8"
Ja kuna a1 on vene audio, a2 aga originaal, siis oleks vist umbes nii...
http://snotty.err.ee/gb/H/2016-023873-0001_0002_XHD_INDIAS-DAUGHTER_ETV3_1.mp4/index-v1-a2.m3u8
Ja subtiitrid oleksid http://etvpluss.err.ee/subtitles/file/40048/40048_ET.vtt
Või mida sa küsisid?
Kommentaarid: 33 loe/lisa |
33 |
Aeg maha 1p
180 |
Maxxxim
Kommentaarid: 93 loe/lisa |
90 |
A.S.
18.01.2020 11:35:29
Võtad ette suvalise video, vaatad lehe algteksti (Page Source => Ctrl+U), otsid m3u8 või mp4 linki, mõtled veidi, laed alla...
33 |
Maxxxim
90 |
A.S.
33 |
Maxxxim
18.01.2020 12:25:09
Tänud!
90 |
Aeg maha 1p
180 |
A.S.
18.01.2020 20:30:42
Lihtsalt tuli alla.
Samamoodi vaatad lehe algteksti (Page Source => Ctrl+U), otsid m3u8, leiad
hls":"\/\/jv.err.ee\/drm\/,,M\/,H\/,2019-025846-0001_0001_XHD_DIVIDE--CONQUER-THE-STORY-OF-ROG_ETV2.mp4.urlset\/master.m3u8
Eemaldad ülearuse jura, saad
https://jv.err.ee/drm/,,M/,H/,2019-025846-0001_0001_XHD_DIVIDE--CONQUER-THE-STORY-OF-ROG_ETV2.mp4.urlset/master.m3u8
Vaatad master.m3u8 faili sisse.
#EXTM3U
#EXT-X-MEDIA:TYPE=AUDIO,GROUP-ID="audio0",LANGUAGE="et",NAME="Eesti",AUTOSELECT=YES,DEFAULT=YES,CHANNELS="2",URI="https://vespa.err.ee/drm/2019-025846-0001_0001_XHD_DIVIDE--CONQUER-THE-STORY-OF-ROG_ETV2.mp4/index-a1.m3u8"
#EXT-X-MEDIA:TYPE=AUDIO,GROUP-ID="audio0",LANGUAGE="nl",NAME="Nederlands",AUTOSELECT=NO,DEFAULT=NO,CHANNELS="1",URI="https://vespa.err.ee/drm/2019-025846-0001_0001_XHD_DIVIDE--CONQUER-THE-STORY-OF-ROG_ETV2.mp4/index-a2.m3u8"
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1075208,RESOLUTION=704x396,FRAME-RATE=25.000,CODECS="avc1.4d401e,mp4a.40.2",AUDIO="audio0"
https://vespa.err.ee/drm/2019-025846-0001_0001_XHD_DIVIDE--CONQUER-THE-STORY-OF-ROG_ETV2.mp4/index-v1-a1.m3u8
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=525471,RESOLUTION=320x180,FRAME-RATE=25.000,CODECS="avc1.42c00d,mp4a.40.2",AUDIO="audio0"
https://vespa.err.ee/drm/M/2019-025846-0001_0001_XHD_DIVIDE--CONQUER-THE-STORY-OF-ROG_ETV2.mp4/index-v1-a1.m3u8
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1522352,RESOLUTION=1280x720,FRAME-RATE=25.000,CODECS="avc1.64001f,mp4a.40.2",AUDIO="audio0"
https://vespa.err.ee/drm/H/2019-025846-0001_0001_XHD_DIVIDE--CONQUER-THE-STORY-OF-ROG_ETV2.mp4/index-v1-a1.m3u8
Järelikult video on
ja eraldi "eestikeelne" (mida iganes see siis ka ei tähenda) audio on
Need m3u8 failid saad vajadusel alla laadida, sees on nimekiri pisikestele ts failikestele.
Võid need ts failikesed vajadusel samuti kõik jupikaupa alla laadida ja suureks videoks kokku lappida.
Subtiitrite saamiseks otsid vtt, leiad https://etv2.err.ee/subtitles/file/45881/45881_ET.vtt
Mida sa selle juraga lõpuks peale hakkad, ei oska arvata. Näed ju isegi, et aadressireal ilutseb uhkelt sõna DRM.
Või on sul mõni lihtne DRM kaitse eemaldamise meetod teada?
33 |
Scott
18.01.2020 23:21:14
Kas DRMiga saated on ainult failitükkidena saadaval või saab siiski kohe ka tervikliku mp4 sealt kätte, nagu tavalistel saadetel?
Kas DRM kood on igale tükile erinev või sama nende tükkide kogumile?
A.S.
19.01.2020 10:09:29
Kas kunagi ei olnud võtmemoodi asjandus isegi mitte m3u8 faili sees kirjas, seega julgen oletada, et kood video käigus ei muutu.
Aga kas korraga kätte saab? Ei oska arvata. Krüpteerimata värk tuleb küll lihtsalt mp4 faili tellides alla, ERR poolses otsas lapitakse need jupikesed eelnevalt ilusasti tervikuks kokku, see aga ei tundu tulevat. Aga pole ju välistatud, et kuidagi ikka saab. Pole endal küll mingit viitsimist ega vajadust asja uurida. FFmpeg igatahes on küll nõus selle m3u8 ühes tükis maha mängima, salvestamisega pole viitsinud katsetama hakata.
33 |
Aeg maha 1p
19.01.2020 12:34:30
Mnjah, vb. siis ikkagi polnud DRM-iga asjade downloadimise varianti, variant oli neid vaid salvestada.
Aga selle konkreetse asja puhul tuli rikas kanada onu appi õnneks...
Tänud kaasamõtlemast!
180 |
Dijital
Kommentaarid: 40 loe/lisa |
31 |
Aeg maha 1p
180 |
A.S.
30.03.2020 18:49:46
https://mz-edge.stream.co.jp/ws/get_m3u8/v1/iPad/3792993.m3u8
#EXTM3U
#EXT-X-STREAM-INF:PROGRAM-ID=1, BANDWIDTH=1276928
https://nhkw-mzvod.akamaized.net/www60/mz-nhk10/_definst_/mp4:mm/flvmedia/5905/n/f/y/nfyixe51_g9lq6lxi_h264_1244K.mp4/chunklist.m3u8
#EXT-X-STREAM-INF:PROGRAM-ID=1, BANDWIDTH=680960
https://nhkw-mzvod.akamaized.net/www60/mz-nhk10/_definst_/mp4:mm/flvmedia/5905/n/f/y/nfyixe51_gw904f05_h264_664K.mp4/chunklist.m3u8
#EXT-X-STREAM-INF:PROGRAM-ID=1, BANDWIDTH=392192
https://nhkw-mzvod.akamaized.net/www60/mz-nhk10/_definst_/mp4:mm/flvmedia/5905/n/f/y/nfyixe51_injvjez3_h264_384K.mp4/chunklist.m3u8 |
https://mz-edge.stream.co.jp/media/5905/thumbs/q/t/b/qtb9kjcm/qtb9kjcm.vtt
33 |
Aeg maha 1p
02.05.2020 13:51:36
A.S., mhmh, sellised variandid leidsin - mõtlesin, et ehk ujub kuskilt .mp4 ka otse välja
Jupiteri on keegi kangutanud juba? .mp4 ei tundu sealt nii välja ujuvat?!
Nt. https://jupiter.err.ee/1038512/tuulepealne-maa
180 |
psydeblo
Kommentaarid: 147 loe/lisa |
134 |
A.S.
33 |
psydeblo
02.05.2020 14:32:13
kupisin esimese mp4 lingi, mis ette jäi.
Aga miks mitte kasutada https://www.downloadhelper.net/ ? Sellega jääb igasugune peavalu ära ju..
134 |
Aeg maha 1p
180 |
A.S.
02.05.2020 15:26:03
rmc kirjutas: |
Põhimõtteliselt samast logist saab .ts failide aadressist ka kätte... |
Nii see käib jah. Algul laed alla
https://jv.err.ee/etvsaated/,,M/,H/,2008-002451-0001_0003_D10_TUULEPEALNE-MAA_UHEKS-PAEVAKS-ISE_ETV1_1.mp4.urlset/master.m3u8
Seal sees on
#EXTM3U
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1107183,RESOLUTION=704x396,FRAME-RATE=25.000,CODECS="avc1.4d401e,mp4a.40.2"
https://vespa.err.ee/etvsaated/2008-002451-0001_0003_D10_TUULEPEALNE-MAA_UHEKS-PAEVAKS-ISE_ETV1_1.mp4/index-v1-a1.m3u8
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=491486,RESOLUTION=320x180,FRAME-RATE=25.000,CODECS="avc1.42c00d,mp4a.40.2"
https://vespa.err.ee/etvsaated/M/2008-002451-0001_0003_D10_TUULEPEALNE-MAA_UHEKS-PAEVAKS-ISE_ETV1_1.mp4/index-v1-a1.m3u8
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1590721,RESOLUTION=1280x720,FRAME-RATE=25.000,CODECS="avc1.64001f,mp4a.40.2"
https://vespa.err.ee/etvsaated/H/2008-002451-0001_0003_D10_TUULEPEALNE-MAA_UHEKS-PAEVAKS-ISE_ETV1_1.mp4/index-v1-a1.m3u8
#EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=122632,RESOLUTION=704x396,CODECS="avc1.4d401e",URI="https://vespa.err.ee/etvsaated/2008-002451-0001_0003_D10_TUULEPEALNE-MAA_UHEKS-PAEVAKS-ISE_ETV1_1.mp4/iframes-v1-a1.m3u8"
#EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=42962,RESOLUTION=320x180,CODECS="avc1.42c00d",URI="https://vespa.err.ee/etvsaated/M/2008-002451-0001_0003_D10_TUULEPEALNE-MAA_UHEKS-PAEVAKS-ISE_ETV1_1.mp4/iframes-v1-a1.m3u8"
#EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=143810,RESOLUTION=1280x720,CODECS="avc1.64001f",URI="https://vespa.err.ee/etvsaated/H/2008-002451-0001_0003_D10_TUULEPEALNE-MAA_UHEKS-PAEVAKS-ISE_ETV1_1.mp4/iframes-v1-a1.m3u8" |
Sealt m3u8 seest saad juba .ts failikeste aadressid. Saab ükshaaval alla laadida ja kokku lappida. Ja nii see käib igal pool, mitte vaid ERR kanalitel. Ja mõningatel juhtudel on audio eraldi .ts failikeste sees. Ja subtiitrid on mõnikord samuti eraldi, sageli .vtt faili sees.
Varem lappis server need .ts failikesed sinu eest kokku ja andis sulle .mp4 faili, see võimalus on tänapäevastel salvestustel millegipärast kuhugi ära kadunud. Ja jällegi, mitte vaid ERR kanalitel.
psydeblo kirjutas: |
Firefoxis f12... |
Ja kui mõnel brauseril (Opera vist oli näiteks selline) F12 ei toimi, siis Ctrl + Shift + I ikka vast toimib.
33 |
Aeg maha 1p
180 |
A.S.
03.05.2020 09:25:18
Tuleb-tuleb, varasemad salvestused (see konkreetne tundub olevat aastast 2008) endiselt tulevad mp4-na, uuematega võib probleeme esineda (vähemalt mingil ajal oli). Osad on lausa DRM kaitse all.
Ja .ts lingist .mp4 linki tuletada pole mõistlik, nii võid midagi maha magada. Parem võta kõige esimene .m3u8 fail (tavaline tekstifail, kasvõi näiteks notepad avab) ja vaata sealtkaudu edasi.
33 |
Aeg maha 1p
03.05.2020 11:50:50
DRM-i osas kursis, jah - tundub, et valitud materjaliga on neil selline diil, et vaid DRM-iga tohivad avaldada ja neid .mp4-na kätte ei saa.
On kogemust, et .ts faili kaudu saadav .mp4 link on puudulik vs. .m3u8-st saadav?
180 |
lisa lemmikuks |
