praegune kellaaeg 23.05.2024 09:27:08
sõnum |
mannie
03.03.2023 10:33:09
Arduino kompileerimise häda |
Hommik!
Olen hüpanud endale natuke tundmatusse maailma ja hätta jäänud. Kas keegi oskaks kommenteerida järgnevat veateadet?
Arduino: 1.8.19 (Linux), Plaat: "Arduino Pro or Pro Mini, ATmega328P (3.3V, 8 MHz)"
arduino-builder -dump-prefs -logger=machine -hardware /usr/share/arduino/hardware -tools /usr/share/arduino/hardware/tools/avr -built-in-libraries /usr/share/arduino/libraries -libraries /home/kaspar/Arduino/libraries -fqbn=arduino:avr:pro:cpu=8MHzatmega328 -ide-version=10819 -build-path /tmp/arduino_build_649257 -warnings=none -build-cache /tmp/arduino_cache_390417 -prefs=build.warn_data_percentage=75 -verbose /home/kaspar/ownCloud/Documents (2)/mereelektroonika/NMEA 0183 Wind Instrument/peet-bros-wind-master/wind/wind.ino
arduino-builder -compile -logger=machine -hardware /usr/share/arduino/hardware -tools /usr/share/arduino/hardware/tools/avr -built-in-libraries /usr/share/arduino/libraries -libraries /home/kaspar/Arduino/libraries -fqbn=arduino:avr:pro:cpu=8MHzatmega328 -ide-version=10819 -build-path /tmp/arduino_build_649257 -warnings=none -build-cache /tmp/arduino_cache_390417 -prefs=build.warn_data_percentage=75 -verbose /home/kaspar/ownCloud/Documents (2)/mereelektroonika/NMEA 0183 Wind Instrument/peet-bros-wind-master/wind/wind.ino
Using board 'pro' from platform in folder: /usr/share/arduino/hardware/arduino/avr
Using core 'arduino' from platform in folder: /usr/share/arduino/hardware/arduino/avr
Detecting libraries used...
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/eightanaloginputs" "/tmp/arduino_build_649257/sketch/wind.ino.cpp" -o "/dev/null"
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/eightanaloginputs" "-I/usr/share/arduino/hardware/arduino/avr/libraries/Wire/src" "/tmp/arduino_build_649257/sketch/wind.ino.cpp" -o "/dev/null"
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/eightanaloginputs" "-I/usr/share/arduino/hardware/arduino/avr/libraries/Wire/src" "-I/usr/share/arduino/libraries/PString" "/tmp/arduino_build_649257/sketch/wind.ino.cpp" -o "/dev/null"
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/eightanaloginputs" "-I/usr/share/arduino/hardware/arduino/avr/libraries/Wire/src" "-I/usr/share/arduino/libraries/PString" "/usr/share/arduino/hardware/arduino/avr/libraries/Wire/src/Wire.cpp" -o "/dev/null"
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/eightanaloginputs" "-I/usr/share/arduino/hardware/arduino/avr/libraries/Wire/src" "-I/usr/share/arduino/libraries/PString" "/usr/share/arduino/hardware/arduino/avr/libraries/Wire/src/utility/twi.c" -o "/dev/null"
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/eightanaloginputs" "-I/usr/share/arduino/hardware/arduino/avr/libraries/Wire/src" "-I/usr/share/arduino/libraries/PString" "/usr/share/arduino/libraries/PString/PString.cpp" -o "/dev/null"
Generating function prototypes...
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/eightanaloginputs" "-I/usr/share/arduino/hardware/arduino/avr/libraries/Wire/src" "-I/usr/share/arduino/libraries/PString" "/tmp/arduino_build_649257/sketch/wind.ino.cpp" -o "/tmp/arduino_build_649257/preproc/ctags_target_for_gcc_minus_e.cpp"
"/usr/bin/arduino-ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/tmp/arduino_build_649257/preproc/ctags_target_for_gcc_minus_e.cpp"
Visandi kompileerimine ...
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/eightanaloginputs" "-I/usr/share/arduino/hardware/arduino/avr/libraries/Wire/src" "-I/usr/share/arduino/libraries/PString" "/tmp/arduino_build_649257/sketch/wind.ino.cpp" -o "/tmp/arduino_build_649257/sketch/wind.ino.cpp.o"
In file included from /home/kaspar/ownCloud/Documents (2)/mereelektroonika/NMEA 0183 Wind Instrument/peet-bros-wind-master/wind/wind.ino:32:0:
/usr/share/arduino/libraries/PString/PString.h:34:16: error: conflicting return type specified for ‘virtual void PString::write(uint8_t)’
virtual void write(uint8_t);
In file included from /usr/share/arduino/hardware/arduino/avr/cores/arduino/Stream.h:26:0,
from /usr/share/arduino/hardware/arduino/avr/cores/arduino/HardwareSerial.h:29,
from /usr/share/arduino/hardware/arduino/avr/cores/arduino/Arduino.h:233,
from /tmp/arduino_build_649257/sketch/wind.ino.cpp:1:
/usr/share/arduino/hardware/arduino/avr/cores/arduino/Print.h:51:20: error: overriding ‘virtual size_t Print::write(uint8_t)’
virtual size_t write(uint8_t) = 0;
Kasutatakse Wire teegi versiooni 1.0 kaustast: /usr/share/arduino/hardware/arduino/avr/libraries/Wire
Kasutatakse PString teeki kaustast: /usr/share/arduino/libraries/PString (legacy)
exit status 1
Viga „Arduino Pro or Pro Mini“ plaadile kompileerimisel.
Kood on kättesaadav siit: https://github.com/guywithaview/peet-bros-wind/blob/master/wind.ino
Mulle endale jääb mulje, et viga pole mitte koodis vaid PString teegis, aga selle sealt otsimine käib üle minu teadmiste ja oskuste.
PString.h - Lightweight printable string class
Copyright (c) 2009 Mikal Hart. All right reserved.
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#ifndef PString_h
#define PString_h
#include "Print.h"
#include <stdarg.h>
#include <stddef.h>
#include <stdio.h>
#include <string.h>
class PString : public Print
private:
char *_buf, *_cur;
size_t _size;
public:
// Basic constructor requires a preallocated buffer
PString(char *buf, size_t size) : _buf(buf), _size(size)
{ begin(); }
// templated constructors allow inline renderings of this type: PString(buf, size, myfloat[, modifier]);
template<class T> PString(char *buf, size_t size, T arg) : _buf(buf), _size(size)
{ begin(); print(arg); }
template<class T> PString(char *buf, size_t size, T arg, int modifier) : _buf(buf), _size(size)
{ begin(); print(arg, modifier); }
// returns the length of the current string, not counting the 0 terminator
inline const size_t length()
{ return _cur - _buf; }
// returns the capacity of the string
inline const size_t capacity()
{ return _size; }
// gives access to the internal string
inline operator const char *()
{ return _buf; }
// compare to another string
bool operator==(const char *str)
{ return _size > 0 && !strcmp(_buf, str); }
// call this to re-use an existing string
void begin();
// This function allows assignment to an arbitrary scalar value like str = myfloat;
template<class T> inline PString &operator =(T arg)
{ begin(); print(arg); return *this; }
// Concatenation str += myfloat;
template<class T> inline PString &operator +=(T arg)
{ print(arg); return *this; }
// Safe access to sprintf-like formatting, e.g. str.format("Hi, my name is %s and I'm %d years old", name, age);
int format(char *str, ...);
Kommentaarid: 4 loe/lisa |
napoleon
Unknown virus
04.03.2023 14:29:56
Ilmselt peaks sul see osa seal olema
private:
char *_buf, *_cur;
size_t _size;
public:
hoopis:
private:
char *_buf, *_cur;
size_t _size;
virtual size_t write(uint8_t);
public:
aga ütlen ausalt, et arduinost otseselt suurt midagi ei tea, lihtsalt veateadet ja koodi vaadates tundub nii.
Kommentaarid: 76 loe/lisa |
59 |
aseesimees
04.03.2023 17:43:30
Võta uuem PString teek kasutusele, seal on viga parandatud. http://arduiniana.org/libraries/pstring/
#if defined(ARDUINO) && ARDUINO >= 100
#else
#endif
Kommentaarid: 12 loe/lisa |
mannie
07.03.2023 21:01:34
aseesimees kirjutas: |
#else
#endif |
Toimis! Tänud!
lisa lemmikuks |
