praegune kellaaeg 23.05.2024 07:33:00
sõnum |
18.04.2022 20:27:03
DELL VOSTRO 3300, 3400, 3500, 3700 bios i taaste (BIOS recovery) |
flashisin ühe 3300 i telliseks. (bricked one vostro 3300)
töötav juhend on siin: working solution here:
https://lazyadmin.nl/it/bios-recovery-dell-vostro-3500-3700-after-update-failed/
delli foorumis on selline: https://www.dell.com/community/Laptops-General-Read-Only/Vostro-3300-BIOS-Update-Failed-Recovery-Procedure-Needed/td-p/51031081. Download the Dell BIOS update .exe file to a USB flash drive.
2. Run the .exe file with /writehdrfile parameter
3. Run the .exe file with /writeromfile parameter
4. Copy the .hdr file to winery50.hdr <- not COPY but RENAME! failid fom ja hdr tuleb nimetada ümber vastavalt. näiteks 3300_a07.rom -> winery30.rom, 3300_a07.hdr -> winery30.hdr
5. Remove the battery and AC power from the dead computer
6. Insert the flash drive into the dead computer's USB port
7. Hold down the End key and then connect the AC power
8. Dead computer reads USB flash and asks if update should be done
9. Allow the update to finish and then reboot.
10. Computer is now working normally.
enda oma flashisin selliseks tagasi, nagu oli. rohkem katsetama ei hakka. aga sain tööle.
_________________ Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER! https://www.yaga.ee/mox-fulder
https://www.facebook.com/marketplace/profile/100087345405856/ värskeim loetelu. 25.05 ilmselt Tallinnas |
Kommentaarid: 1104 loe/lisa |
704 |
lisa lemmikuks |
