praegune kellaaeg 01.06.2024 22:37:15
sõnum |
Amdfan
27.12.2021 14:14:25
Toshiba SATA ketta RMA |
Kas kellelgi on äkki kokkupuudet Toshiba SATA ketta RMA´ga? SN järgi näitab ilusti, et 5a garantii, mis on kehtiv, aga nagu "end-user" vaatest RMA´d algatada ei saagi.
Vaata kasutaja äripakkumisi |
M: Intel 11400F kombo, i5 10 gen prosed, i5-12400, 16TB SATA ketas, 5 bay USB kettaboks |
2 | 79 |
M: Erinevad MiniPC, SFF ja tower masinad, Intel ja AMD, garantiiga ja ilma vol2 |
6 | 1614 |
M: Erinevad MiniPC, SFF ja tower masinad, Intel ja AMD, garantiiga ja ilma |
16 | 2468 |
Kommentaarid: 303 loe/lisa |
281 |
01.01.2022 15:04:16
Ei saa jah. Ainult edasimüüja kaudu kui see viitsib.
_________________ Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER! https://www.yaga.ee/mox-fulder
https://www.facebook.com/marketplace/profile/100087345405856/ värskeim loetelu. |
Kommentaarid: 1104 loe/lisa |
704 |
arny
Kommentaarid: 10 loe/lisa |
9 |
Amdfan
03.01.2022 12:39:08
Sain vana aasta sees neilt vastuses, ehk SATA ketastega on tuuga, otse neile RMA´sse ketast saata ei saagi, ainult läbi müüja. Edasipidi tasub ainult WD või Seagate osta.
For the mentioned hard drive models, we do offer a 5 year warranty processing for direct Toshiba OEM customers.
If such a hard drive has not been purchased directly through a Toshiba contact, the intermediary seller is responsible for handling the warranty as well as available warranty times.
The latter will then returns the affected product via their own process.
For this reason, we can only recommend to contact your dealer and ask regarding available warranty services.
2 | 79 |
6 | 1614 |
16 | 2468 |
281 |
03.01.2022 13:25:12
On põhjus veel miks mitte osta toshiba ketast. Tehaseutikat pole.
704 |
lisa lemmikuks |
